Verification OTA w/ update.zip and diff-ota.zip
Step 1: Build r13.4.1
        make         /* Store images file for MFGTool use */
        make dist    /* Get ota_1.zip, and target_files_1.zip at out/dist, store them in a dedicated directory, for example .../release-1 */
Step 2: Modify any files in source code base;
Step 3: make dist    /* Get ota_2.zip, and target_files_2.zip at out/dist, store them in a dedicated directory, for example .../release-2 */
Step 4: MFGTool flash release-1 images;
Step 5: cp ota_2.zip to SD;
Step 6: start board, then execute following commands under serial terminal;
        cp /sdcard/ota_2.zip /cache/ota_2.zip
        mkdir /cache/recovery
        echo --update_package=/cache/ota_2.zip > /cache/recovery/command
        sync
        reboot recovery
        Then you can see the upgrade successful.
Step 7: MFGTool flash release-1 images;
Step 8: ./build/tools/releasetools/ota_from_target_files -i .../release-1/target_files_1.zip .../release-2/target_files_2.zip ./diff_from_1_to_2.zip Step 9: cp diff_from_1_to_2.zip to SD;
Step10: start board, then execute following commands under serial terminal;
        cp /sdcard/diff_from_1_to_2.zip /cache/diff.zip
        echo --update_package=/cache/diff.zip > /cache/recovery/command
        sync
        reboot recovery
Tags (2)
Comments
I am trying to update images over USB, as mentioned in above steps for imx6 sabersd (android 6.0.1). But not able to see "upgrade successful." message on the console and not able to see the changes after flashing done.
Below are the steps i am following,
1. $source build/envsetup.sh
2. $lunch sabresd_6dq-user
3. $make
4. Flash the generated images using mfgtool
5. Do changes one of the packages
6. $make dist
7. cp out/target/product/sabresd_6dq/sabresd_6dq-ota-20160331.zip /media/usb/ (copy from Host to USB device)
8. cp /mnt/media_rw/USB/sabresd_6dq-ota-20160331.zip /cache
9. $echo --update_package=/cache/sabresd_6dq-ota-20160331.zip > /cache/recovery/command
10. $reboot recovery
After step #10 system halting for some time with the below logs
init: Starting service 'recovery'...
EXT4-fs (mmcblk3p6): Ignoring removed nomblk_io_submit option
EXT4-fs (mmcblk3p6): mounted filesystem with ordered data mode. Opts: nomblk_io_submit
random: nonblocking pool is initialized
SysRq : Emergency Remount R/O
Emergency Remount complete
reboot: Restarting system with command ''
Please let me know if anything wrong in the above steps or is there any other way to flash in new versions of android.
Thanks in advance.
Babu A
%3CLINGO-SUB%20id%3D%22lingo-sub-1117672%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EVerification%20OTA%20w%2F%20update.zip%20and%20diff-ota.zip%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117672%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20class%3D%22MsoPlainText%22%3EStep%201%3A%20Build%20r13.4.1%3C%2FP%3E%3CP%20class%3D%22MsoPlainText%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Emake%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%2F*%20Store%20images%20file%20for%20MFGTool%20use%20*%2F%3C%2FP%3E%3CP%20class%3D%22MsoPlainText%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Emake%20dist%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%2F*%20Get%20ota_1.zip%2C%20and%20target_files_1.zip%20at%20out%2Fdist%2C%20store%20them%20in%20a%20dedicated%20directory%2C%20for%20example%20...%2Frelease-1%20*%2F%3C%2FP%3E%3CP%20class%3D%22MsoPlainText%22%3EStep%202%3A%20Modify%20any%20files%20in%20source%20code%20base%3B%3C%2FP%3E%3CP%20class%3D%22MsoPlainText%22%3EStep%203%3A%20make%20dist%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%2F*%20Get%20ota_2.zip%2C%20and%20target_files_2.zip%20at%20out%2Fdist%2C%20store%20them%20in%20a%20dedicated%20directory%2C%20for%20example%20...%2Frelease-2%20*%2F%3C%2FP%3E%3CP%20class%3D%22MsoPlainText%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoPlainText%22%3EStep%204%3A%20MFGTool%20flash%20release-1%20images%3B%3C%2FP%3E%3CP%20class%3D%22MsoPlainText%22%3EStep%205%3A%20cp%20ota_2.zip%20to%20SD%3B%3C%2FP%3E%3CP%20class%3D%22MsoPlainText%22%3EStep%206%3A%20start%20board%2C%20then%20execute%20following%20commands%20under%20serial%20terminal%3B%3C%2FP%3E%3CP%20class%3D%22MsoPlainText%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecp%20%2Fsdcard%2Fota_2.zip%20%2Fcache%2Fota_2.zip%3C%2FP%3E%3CP%20class%3D%22MsoPlainText%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Emkdir%20%2Fcache%2Frecovery%3C%2FP%3E%3CP%20class%3D%22MsoPlainText%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eecho%20--update_package%3D%2Fcache%2Fota_2.zip%20%26gt%3B%20%2Fcache%2Frecovery%2Fcommand%3C%2FP%3E%3CP%20class%3D%22MsoPlainText%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Esync%3C%2FP%3E%3CP%20class%3D%22MsoPlainText%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ereboot%20recovery%3C%2FP%3E%3CP%20class%3D%22MsoPlainText%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoPlainText%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3EThen%20you%20can%20see%20the%20upgrade%20successful.%3C%2FP%3E%3CP%20class%3D%22MsoPlainText%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoPlainText%22%3EStep%207%3A%20MFGTool%20flash%20release-1%20images%3B%3C%2FP%3E%3CP%20class%3D%22MsoPlainText%22%3EStep%208%3A%20.%2Fbuild%2Ftools%2Freleasetools%2Fota_from_target_files%20-i%20...%2Frelease-1%2Ftarget_files_1.zip%20...%2Frelease-2%2Ftarget_files_2.zip%20.%2Fdiff_from_1_to_2.zip%20Step%209%3A%20cp%20diff_from_1_to_2.zip%20to%20SD%3B%3C%2FP%3E%3CP%20class%3D%22MsoPlainText%22%3EStep10%3A%20start%20board%2C%20then%20execute%20following%20commands%20under%20serial%20terminal%3B%3C%2FP%3E%3CP%20class%3D%22MsoPlainText%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecp%20%2Fsdcard%2Fdiff_from_1_to_2.zip%20%2Fcache%2Fdiff.zip%3C%2FP%3E%3CP%20class%3D%22MsoPlainText%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Emkdir%20%2Fcache%2Frecovery%3C%2FP%3E%3CP%20class%3D%22MsoPlainText%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eecho%20--update_package%3D%2Fcache%2Fdiff.zip%20%26gt%3B%20%2Fcache%2Frecovery%2Fcommand%3C%2FP%3E%3CP%20class%3D%22MsoPlainText%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Esync%3C%2FP%3E%3CP%20class%3D%22MsoPlainText%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ereboot%20recovery%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117673%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Verification%20OTA%20w%2F%20update.zip%20and%20diff-ota.zip%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117673%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%20%3C%2FP%3E%3CP%3EI%20am%20trying%20to%20update%20images%20over%20USB%2C%20as%20mentioned%20in%20above%20steps%20for%20imx6%20sabersd%20(android%206.0.1).%20But%20not%20able%20to%20see%20%22upgrade%20successful.%22%20message%20on%20the%20console%20and%20not%20able%20to%20see%20the%20changes%20after%20flashing%20done.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBelow%20are%20the%20steps%20i%20am%20following%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CDIV%20data-canvas-width%3D%22234.00000000000009%22%20style%3D%22left%3A%2090.0018px%3B%20top%3A%20582.245px%3B%20font-size%3A%2015px%3B%20font-family%3A%20monospace%3B%20transform%3A%20scaleX(1)%3B%22%3E1.%20%24source%20build%2Fenvsetup.sh%3C%2FDIV%3E%3CDIV%20data-canvas-width%3D%22216.00000000000006%22%20style%3D%22left%3A%2090.0018px%3B%20top%3A%20598.145px%3B%20font-size%3A%2015px%3B%20font-family%3A%20monospace%3B%20transform%3A%20scaleX(1)%3B%22%3E2.%20%24lunch%20sabresd_6dq-user%3C%2FDIV%3E%3CDIV%20data-canvas-width%3D%22216.00000000000006%22%20style%3D%22left%3A%2090.0018px%3B%20top%3A%20598.145px%3B%20font-size%3A%2015px%3B%20font-family%3A%20monospace%3B%20transform%3A%20scaleX(1)%3B%22%3E3.%20%24make%3C%2FDIV%3E%3CDIV%20data-canvas-width%3D%22216.00000000000006%22%20style%3D%22left%3A%2090.0018px%3B%20top%3A%20598.145px%3B%20font-size%3A%2015px%3B%20font-family%3A%20monospace%3B%20transform%3A%20scaleX(1)%3B%22%3E4.%20Flash%20the%20generated%20images%20using%20mfgtool%3C%2FDIV%3E%3CDIV%20data-canvas-width%3D%22216.00000000000006%22%20style%3D%22left%3A%2090.0018px%3B%20top%3A%20598.145px%3B%20font-size%3A%2015px%3B%20font-family%3A%20monospace%3B%20transform%3A%20scaleX(1)%3B%22%3E%20%3C%2FDIV%3E%3CDIV%20data-canvas-width%3D%22216.00000000000006%22%20style%3D%22left%3A%2090.0018px%3B%20top%3A%20598.145px%3B%20font-size%3A%2015px%3B%20font-family%3A%20monospace%3B%20transform%3A%20scaleX(1)%3B%22%3E5.%20Do%20changes%20one%20of%20the%20packages%3C%2FDIV%3E%3CDIV%20data-canvas-width%3D%22216.00000000000006%22%20style%3D%22left%3A%2090.0018px%3B%20top%3A%20598.145px%3B%20font-size%3A%2015px%3B%20font-family%3A%20monospace%3B%20transform%3A%20scaleX(1)%3B%22%3E6.%20%24make%20dist%3C%2FDIV%3E%3CDIV%20data-canvas-width%3D%22216.00000000000006%22%20style%3D%22left%3A%2090.0018px%3B%20top%3A%20598.145px%3B%20font-size%3A%2015px%3B%20font-family%3A%20monospace%3B%20transform%3A%20scaleX(1)%3B%22%3E7.%20cp%20out%2Ftarget%2Fproduct%2Fsabresd_6dq%2Fsabresd_6dq-ota-20160331.zip%20%2Fmedia%2Fusb%2F%20(copy%20from%20Host%20to%20USB%20device)%3C%2FDIV%3E%3CDIV%20data-canvas-width%3D%22216.00000000000006%22%20style%3D%22left%3A%2090.0018px%3B%20top%3A%20598.145px%3B%20font-size%3A%2015px%3B%20font-family%3A%20monospace%3B%20transform%3A%20scaleX(1)%3B%22%3E8.%20cp%20%2Fmnt%2Fmedia_rw%2FUSB%2Fsabresd_6dq-ota-20160331.zip%20%2Fcache%3C%2FDIV%3E%3CDIV%20data-canvas-width%3D%22216.00000000000006%22%20style%3D%22left%3A%2090.0018px%3B%20top%3A%20598.145px%3B%20font-size%3A%2015px%3B%20font-family%3A%20monospace%3B%20transform%3A%20scaleX(1)%3B%22%3E9.%20%24echo%20--update_package%3D%2Fcache%2Fsabresd_6dq-ota-20160331.zip%20%26gt%3B%20%2Fcache%2Frecovery%2Fcommand%3C%2FDIV%3E%3CDIV%20data-canvas-width%3D%22216.00000000000006%22%20style%3D%22left%3A%2090.0018px%3B%20top%3A%20598.145px%3B%20font-size%3A%2015px%3B%20font-family%3A%20monospace%3B%20transform%3A%20scaleX(1)%3B%22%3E10.%20%24reboot%20recovery%3C%2FDIV%3E%3CDIV%20data-canvas-width%3D%22216.00000000000006%22%20style%3D%22left%3A%2090.0018px%3B%20top%3A%20598.145px%3B%20font-size%3A%2015px%3B%20font-family%3A%20monospace%3B%20transform%3A%20scaleX(1)%3B%22%3E%20%3C%2FDIV%3E%3CDIV%20data-canvas-width%3D%22216.00000000000006%22%20style%3D%22left%3A%2090.0018px%3B%20top%3A%20598.145px%3B%20font-size%3A%2015px%3B%20font-family%3A%20monospace%3B%20transform%3A%20scaleX(1)%3B%22%3EAfter%20step%20%2310%20system%20halting%20for%20some%20time%20with%20the%20below%20logs%3C%2FDIV%3E%3CDIV%20data-canvas-width%3D%22216.00000000000006%22%20style%3D%22left%3A%2090.0018px%3B%20top%3A%20598.145px%3B%20font-size%3A%2015px%3B%20font-family%3A%20monospace%3B%20transform%3A%20scaleX(1)%3B%22%3E%20%3C%2FDIV%3E%3CDIV%20data-canvas-width%3D%22216.00000000000006%22%20style%3D%22left%3A%2090.0018px%3B%20top%3A%20598.145px%3B%20font-size%3A%2015px%3B%20font-family%3A%20monospace%3B%20transform%3A%20scaleX(1)%3B%22%3Einit%3A%20Starting%20service%20'recovery'...%3CBR%20%2F%3EEXT4-fs%20(mmcblk3p6)%3A%20Ignoring%20removed%20nomblk_io_submit%20option%3CBR%20%2F%3EEXT4-fs%20(mmcblk3p6)%3A%20mounted%20filesystem%20with%20ordered%20data%20mode.%20Opts%3A%20nomblk_io_submit%3CBR%20%2F%3Erandom%3A%20nonblocking%20pool%20is%20initialized%3CBR%20%2F%3EEXT4-fs%20(mmcblk3p6)%3A%20Ignoring%20removed%20nomblk_io_submit%20option%3CBR%20%2F%3EEXT4-fs%20(mmcblk3p6)%3A%20mounted%20filesystem%20with%20ordered%20data%20mode.%20Opts%3A%20nomblk_io_submit%3CBR%20%2F%3ESysRq%20%3A%20Emergency%20Remount%20R%2FO%3CBR%20%2F%3EEmergency%20Remount%20complete%3CBR%20%2F%3Ereboot%3A%20Restarting%20system%20with%20command%20''%3C%2FDIV%3E%3CDIV%20data-canvas-width%3D%22216.00000000000006%22%20style%3D%22left%3A%2090.0018px%3B%20top%3A%20598.145px%3B%20font-size%3A%2015px%3B%20font-family%3A%20monospace%3B%20transform%3A%20scaleX(1)%3B%22%3E%20%3C%2FDIV%3E%3CDIV%20data-canvas-width%3D%22216.00000000000006%22%20style%3D%22left%3A%2090.0018px%3B%20top%3A%20598.145px%3B%20font-size%3A%2015px%3B%20font-family%3A%20monospace%3B%20transform%3A%20scaleX(1)%3B%22%3EPlease%20let%20me%20know%20if%20anything%20wrong%20in%20the%20above%20steps%20or%20is%20there%20any%20other%20way%20to%20flash%20in%20new%20versions%20of%20android.%3C%2FDIV%3E%3CDIV%20data-canvas-width%3D%22216.00000000000006%22%20style%3D%22left%3A%2090.0018px%3B%20top%3A%20598.145px%3B%20font-size%3A%2015px%3B%20font-family%3A%20monospace%3B%20transform%3A%20scaleX(1)%3B%22%3E%20%3C%2FDIV%3E%3CDIV%20data-canvas-width%3D%22216.00000000000006%22%20style%3D%22left%3A%2090.0018px%3B%20top%3A%20598.145px%3B%20font-size%3A%2015px%3B%20font-family%3A%20monospace%3B%20transform%3A%20scaleX(1)%3B%22%3EThanks%20in%20advance.%3C%2FDIV%3E%3CDIV%20data-canvas-width%3D%22216.00000000000006%22%20style%3D%22left%3A%2090.0018px%3B%20top%3A%20598.145px%3B%20font-size%3A%2015px%3B%20font-family%3A%20monospace%3B%20transform%3A%20scaleX(1)%3B%22%3EBabu%20A%3C%2FDIV%3E%3CDIV%20data-canvas-width%3D%22216.00000000000006%22%20style%3D%22left%3A%2090.0018px%3B%20top%3A%20598.145px%3B%20font-size%3A%2015px%3B%20font-family%3A%20monospace%3B%20transform%3A%20scaleX(1)%3B%22%3E%20%3C%2FDIV%3E%3CDIV%20data-canvas-width%3D%22216.00000000000006%22%20style%3D%22left%3A%2090.0018px%3B%20top%3A%20598.145px%3B%20font-size%3A%2015px%3B%20font-family%3A%20monospace%3B%20transform%3A%20scaleX(1)%3B%22%3E%20%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎07-21-2013 07:40 PM
Updated by:
