The purpose of the document is to help customer setup development environment of android BSP, The document includes the following contents:
1.Setup environment for compiling android BSP source code
2. Setup tftp and NFS environment for android development
3. Common Steps of Porting android to customized borad ( L3.0.35 kernel)
(1) ubuntu version is suitable for 12.04/14.04/15.04
(2) android BSP version is 4.2.2 / 4.3 / 4.4.2
If cusotmer is using android5.1.1 / android 6.0 or above, The way of porting kernel should be focused on adjusting device tree.
(3)Each andoid BSP has its own MFG tools version.
User should pay attention to this, don't use wrong version of MFG Tools.
NXP TIC team
Weidong Sun
