Question, i.MX6Q SSI time slot
Hi team,
My customer is facing the issue of unexpected behavior of i.MX6Q SSI.
The customer uses SSI as slave/Network mode. And they want to transfer 4 time-slot data.
As for the register setting, RFEN0, RFEN1 and RDMAE is set to 1.
And only first time slot data is transferred.
Do you have any ideas about the cause of this?
Miyamoto
This document was generated from the following discussion:
%3CLINGO-SUB%20id%3D%22lingo-sub-1123071%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EQuestion%2C%20i.MX6Q%20SSI%20time%20slot%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1123071%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20team%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMy%20customer%20is%20facing%20the%20issue%20of%20unexpected%20behavior%20of%20i.MX6Q%20SSI.%3C%2FP%3E%3CP%3EThe%20customer%20uses%20SSI%20as%20slave%2FNetwork%20mode.%20And%20they%20want%20to%20transfer%204%20time-slot%20data.%3C%2FP%3E%3CP%3EAs%20for%20the%20register%20setting%2C%20RFEN0%2C%20RFEN1%20and%20RDMAE%20is%20set%20to%201.%3C%2FP%3E%3CP%3EAnd%20only%20first%20time%20slot%20data%20is%20transferred.%3C%2FP%3E%3CP%3EDo%20you%20have%20any%20ideas%20about%20the%20cause%20of%20this%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks%2C%3C%2FP%3E%3CP%3EMiyamoto%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThis%20document%20was%20generated%20from%20the%20following%20discussion%3A%26nbsp%3B%3CA%20__default_attr%3D%22351364%22%20__jive_macro_name%3D%22thread%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎04-07-2015 03:49 AM
Updated by:
