Patch to enable ASRC_P2P support for SSI based on Kernel 3.0.35 for I.MX6DL/DQ SebreSD boards
i.MX6 4.0.0 BSP release doesn't support ASRC_P2P function. This patch provides the reference codes to enable ASRC_P2P function for SSI. It can convert input sample rate to 44.1K_16bit/44.1K_24bit and 48K_16bit/48K_24bit. You can modify the configurations in the Board file.
By the way, the SSI controler works at slave mode.
Known limitations for the patch:
-- The SDMA doesn't support SSI Dual FIFO when using ASRC_P2P function.
-- From the waveform, the converted 24bit data have some abnormal data(values between 0 and 1) , but can't hear any abnormal sound from headphone. One suggestion is given under https://community.freescale.com/docs/DOC-95340
添付
コメント
Lei Ge / Xiaoli Zhang
We have implemented P2P ASRC for recording using your attached patch.
ASRC is working perfectly but it stops working after 8 to 10 hours of Recording.
We are getting Overflow error in SDMA_MODE_P2P mode.
How to fix this issue?
Saurabh
%3CLINGO-SUB%20id%3D%22lingo-sub-1109319%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%203.0.35%20%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8F%20SSI%20%E3%81%AE%20ASRC_P2P%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81I.MX6DL%2FDQ%20SebreSD%E3%83%9C%E3%83%BC%E3%83%89%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1109319%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ei.MX6%204.0.0BSP%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%A7%E3%81%AF%E3%80%81ASRC_P2P%E6%A9%9F%E8%83%BD%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E3%80%81SSI%20%E3%81%AE%20ASRC_P2P%20%E6%A9%9F%E8%83%BD%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E5%8F%82%E7%85%A7%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%85%A5%E5%8A%9B%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%AC%E3%83%BC%E3%83%88%E3%82%9244.1K_16bit%2F44.1K_24bit%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8A%E3%82%88%E3%81%B348K_16bit%2F48K_24bit%E3%80%82%E3%83%9C%E3%83%BC%E3%83%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E6%A7%8B%E6%88%90%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%A1%E3%81%AA%E3%81%BF%E3%81%AB%E3%80%81SSI%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%81%AF%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E6%9B%B4%E6%96%B0%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%AE%E6%97%A2%E7%9F%A5%E3%81%AE%E5%88%B6%E9%99%90%20%3A%3C%2FP%3E%3CP%3E--%20SDMA%20%E3%81%AF%E3%80%81ASRC_P2P%20%E6%A9%9F%E8%83%BD%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81SSI%20%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%20FIFO%20%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E-%E6%B3%A2%E5%BD%A2%E3%81%8B%E3%82%89%E3%80%81%E5%A4%89%E6%8F%9B%E3%81%95%E3%82%8C%E3%81%9F24%E3%83%93%E3%83%83%E3%83%88%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AB%E3%81%AF%E7%95%B0%E5%B8%B8%E3%81%AA%E3%83%87%E3%83%BC%E3%82%BF(0%E3%80%9C1%E3%81%AE%E5%80%A4)%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%98%E3%83%83%E3%83%89%E3%83%95%E3%82%A9%E3%83%B3%E3%81%8B%E3%82%89%E7%95%B0%E5%B8%B8%E3%81%AA%E9%9F%B3%E3%81%AF%E8%81%9E%E3%81%93%E3%81%88%E3%81%BE%E3%81%9B%E3%82%93%E3%80%821%E3%81%A4%E3%81%AE%E6%8F%90%E6%A1%88%E3%81%AF%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-95340%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-95340%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1109319%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ei.MX6%204.0.0BSP%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%A7%E3%81%AF%E3%80%81ASRC_P2P%E6%A9%9F%E8%83%BD%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E3%80%81SSI%20%E3%81%AE%20ASRC_P2P%20%E6%A9%9F%E8%83%BD%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E5%8F%82%E7%85%A7%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%85%A5%E5%8A%9B%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%AC%E3%83%BC%E3%83%88%E3%82%9244.1K_16bit%2F44.1K_24bit%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8A%E3%82%88%E3%81%B348K_16bit%2F48K_24bit%E3%80%82%E3%83%9C%E3%83%BC%E3%83%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E6%A7%8B%E6%88%90%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%A1%E3%81%AA%E3%81%BF%E3%81%AB%E3%80%81SSI%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%81%AF%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E6%9B%B4%E6%96%B0%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%AE%E6%97%A2%E7%9F%A5%E3%81%AE%E5%88%B6%E9%99%90%20%3A%3C%2FP%3E%3CP%3E--%20SDMA%20%E3%81%AF%E3%80%81ASRC_P2P%20%E6%A9%9F%E8%83%BD%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81SSI%20%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%20FIFO%20%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E-%E6%B3%A2%E5%BD%A2%E3%81%8B%E3%82%89%E3%80%81%E5%A4%89%E6%8F%9B%E3%81%95%E3%82%8C%E3%81%9F24%E3%83%93%E3%83%83%E3%83%88%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AB%E3%81%AF%E7%95%B0%E5%B8%B8%E3%81%AA%E3%83%87%E3%83%BC%E3%82%BF(0%E3%80%9C1%E3%81%AE%E5%80%A4)%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%98%E3%83%83%E3%83%89%E3%83%95%E3%82%A9%E3%83%B3%E3%81%8B%E3%82%89%E7%95%B0%E5%B8%B8%E3%81%AA%E9%9F%B3%E3%81%AF%E8%81%9E%E3%81%93%E3%81%88%E3%81%BE%E3%81%9B%E3%82%93%E3%80%821%E3%81%A4%E3%81%AE%E6%8F%90%E6%A1%88%E3%81%AF%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-95340%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-95340%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-TEASER%3E
評価なし
バージョン履歴
最終更新日:
‎08-07-2013 12:25 AM
更新者:
