Measure SDMA Memory To Memory Copy Performance on i.MX6Q
Overview
The document describes the procedure to measure the memory to memory copy performance by using SDMA on i.MX6Q.
Materials
  • i.MX6Q Sabre SD board
  • L3.0.35_4.1.0_130816 BSP
Procedure
  • Install BSP and build kernel
  • Extract imx unit test source:
    • ./ltib -p imx-test -m prep
  • Apply attached patch to sdma memcopy code
    • cd ltib/rpm/BUILD/imx-test-3.0.35-4.1.0
    • patch -p1 -i LTIB_4.1.0_sdma_m2m_test.patch
  • Build imx unit test
    • ./ltib -p imx-test -f
  • Copy kernel and rootfs to SD Card.
  • Boot kernel and login
  • Insert the kernel module for SDMA memory copy test:
    • insmod /lib/modules/XXX/test/mxc_sdma_memcopy_test.ko
  • Start SDMA memory copy test
    • /unit_tests/mxc_sdma_test.out
Result
root@freescale ~$ insmod /lib/modules/3.0.35-2666-gbdde708-g1c42f8b/test/mxc_sdma_memcopy_test.ko
SDMA test major number = 248
SDMA test Driver Module loaded
root@freescale ~$ /unit_tests/mxc_sdma_test.out
in dma_m2m_callback
65532byte / 0.003382sec
buffer 1 copy passed!
in dma_m2m_callback
65532byte / 0.003367sec
in dma_m2m_callback
65532byte / 0.003364sec
In summary, > 19Mbyte/sec
附件
评论
I am getting Failed open error on executing mxc_sdm_test.out. Do es anybody now what the problem could be?
%3CLINGO-SUB%20id%3D%22lingo-sub-1098944%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%B5%8B%E9%87%8F%20i.MX6Q%20%E4%B8%8A%E7%9A%84%20SDMA%20%E5%86%85%E5%AD%98%E5%88%B0%E5%86%85%E5%AD%98%E5%A4%8D%E5%88%B6%E6%80%A7%E8%83%BD%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1098944%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSTRONG%3EOverview%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AF%A5%E6%96%87%E6%A1%A3%E6%8F%8F%E8%BF%B0%E4%BA%86%E5%9C%A8%20i.MX6Q%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20SDMA%20%E6%B5%8B%E9%87%8F%E5%86%85%E5%AD%98%E5%88%B0%E5%86%85%E5%AD%98%E5%A4%8D%E5%88%B6%E6%80%A7%E8%83%BD%E7%9A%84%E8%BF%87%E7%A8%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E6%9D%90%E6%96%99%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3Ei.MX6Q%20Sabre%20SD%20%E6%9D%BF%3C%2FLI%3E%3CLI%3EL3.0.35_4.1.0_130816BSP%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E6%B5%81%E7%A8%8B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E5%AE%89%E8%A3%85BSP%E5%B9%B6%E6%9E%84%E5%BB%BA%E5%86%85%E6%A0%B8%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E6%8F%90%E5%8F%96%20imx%20%E5%8D%95%E5%85%83%E6%B5%8B%E8%AF%95%E6%BA%90%EF%BC%9A%3C%2FSPAN%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E.%2Fltib-p%20imx%E6%B5%8B%E8%AF%95-m%E5%87%86%E5%A4%87%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E5%B0%86%E9%99%84%E5%8A%A0%E8%A1%A5%E4%B8%81%E5%BA%94%E7%94%A8%E4%BA%8E%20sdma%20memcopy%20%E4%BB%A3%E7%A0%81%3C%2FSPAN%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3Ecd%20ltib%2Frpm%2FBUILD%2Fimx-test-3.0.35-4.1.0%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E8%A1%A5%E4%B8%81-p1-i%20LTIB_4.1.0_sdma_m2m_test.patch%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E6%9E%84%E5%BB%BA%20imx%20%E5%8D%95%E5%85%83%E6%B5%8B%E8%AF%95%3C%2FSPAN%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E.%2Fltib-p%20imx%E6%B5%8B%E8%AF%95-f%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E5%B0%86%E5%86%85%E6%A0%B8%E5%92%8C%20rootfs%20%E5%A4%8D%E5%88%B6%E5%88%B0%20SD%20%E5%8D%A1%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E5%90%AF%E5%8A%A8%E5%86%85%E6%A0%B8%E5%B9%B6%E7%99%BB%E5%BD%95%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E6%8F%92%E5%85%A5%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%E8%BF%9B%E8%A1%8CSDMA%E5%86%85%E5%AD%98%E5%A4%8D%E5%88%B6%E6%B5%8B%E8%AF%95%EF%BC%9A%3CBR%20%2F%3E%3C%2FSPAN%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3Einsmod%20%2Flib%2Fmodules%2FXXX%2Ftest%2Fmxc_sdma_memcopy_test.ko%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E5%90%AF%E5%8A%A8SDMA%E5%86%85%E5%AD%98%E5%A4%8D%E5%88%B6%E6%B5%8B%E8%AF%95%3C%2FSPAN%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%2F%E5%8D%95%E5%85%83%E6%B5%8B%E8%AF%95%2Fmxc_sdma_%E6%B5%8B%E8%AF%95.out%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E7%BB%93%E6%9E%9C%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3Eroot%40freescale%20~%24%20insmod%20%2Flib%2Fmodules%2F3.0.35-2666-gbdde708-g1c42f8b%2Ftest%2Fmxc_sdma_memcopy_test.ko%3C%2FP%3E%3CP%3ESDMA%20%E6%B5%8B%E8%AF%95%E4%B8%BB%E7%BC%96%E5%8F%B7%20%3D%20248%3C%2FP%3E%3CP%3ESDMA%20%E6%B5%8B%E8%AF%95%E9%A9%B1%E5%8A%A8%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3C%2FP%3E%3CP%3Eroot%40freescale%20~%24%20%2Funit_tests%2Fmxc_sdma_test.out%3C%2FP%3E%3CP%3E%E5%9C%A8%20dma_m2m_callback%20%E4%B8%AD%3C%2FP%3E%3CP%3E65532%E5%AD%97%E8%8A%82%20%2F%200.003382%E7%A7%92%3C%2FP%3E%3CP%3E%E7%BC%93%E5%86%B2%E5%8C%BA%201%20%E5%A4%8D%E5%88%B6%E5%B7%B2%E9%80%9A%E8%BF%87%EF%BC%81%3C%2FP%3E%3CP%3Eroot%40freescale%20~%24%20%2Funit_tests%2Fmxc_sdma_test.out%3C%2FP%3E%3CP%3E%E5%9C%A8%20dma_m2m_callback%20%E4%B8%AD%3C%2FP%3E%3CP%3E65532%E5%AD%97%E8%8A%82%20%2F%200.003367%E7%A7%92%3C%2FP%3E%3CP%3E%E7%BC%93%E5%86%B2%E5%8C%BA%201%20%E5%A4%8D%E5%88%B6%E5%B7%B2%E9%80%9A%E8%BF%87%EF%BC%81%3C%2FP%3E%3CP%3Eroot%40freescale%20~%24%20%2Funit_tests%2Fmxc_sdma_test.out%3C%2FP%3E%3CP%3E%E5%9C%A8%20dma_m2m_callback%20%E4%B8%AD%3C%2FP%3E%3CP%3E65532%E5%AD%97%E8%8A%82%20%2F%200.003364%E7%A7%92%3C%2FP%3E%3CP%3E%E7%BC%93%E5%86%B2%E5%8C%BA%201%20%E5%A4%8D%E5%88%B6%E5%B7%B2%E9%80%9A%E8%BF%87%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%80%BB%E7%BB%93%E4%B8%80%E4%B8%8B%EF%BC%8C%26gt%3B%2019Mbyte%2Fsec%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1098945%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%B5%8B%E9%87%8Fi.MX6Q%E4%B8%8A%E7%9A%84SDMA%E5%86%85%E5%AD%98%E5%88%B0%E5%86%85%E5%AD%98%E5%A4%8D%E5%88%B6%E6%80%A7%E8%83%BD%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1098945%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%89%A7%E8%A1%8C%20mxc_sdm_test.out%20%E6%97%B6%E5%87%BA%E7%8E%B0%E6%89%93%E5%BC%80%E5%A4%B1%E8%B4%A5%E9%94%99%E8%AF%AF%E3%80%82%E6%9C%89%E4%BA%BA%E7%9F%A5%E9%81%93%E9%97%AE%E9%A2%98%E5%8F%AF%E8%83%BD%E5%87%BA%E5%9C%A8%E5%93%AA%E9%87%8C%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎12-16-2014 12:10 AM
更新人:
