LMbench Benchmarks on i.MX
Installation
  1. Build the development image (fsl-image-gui-sdk) using Yocto and flash it into the board
  2. Download LMbench's tarball from LMbench - Tools for Performance Analysis
  3. Untar the file and move the created folder
  4. Run the benchmarks following these steps:
lmbench $ cd src
lmbench/src $ make results
lmbench/src $ cd ..
lmbench $ make see
Benchmarks
Attached are the benchmarks results from several machines. In case you run them in a different machine, please attach your results file on this document. For more robust results, rerun several times the test and create the result document following these steps:
lmbench $ make results
lmbench $ make rerun
lmbench $ cd results
lmbench/results $ make > results # results is the output file you may want to attach to this document
タグ(3)
添付
%3CLINGO-SUB%20id%3D%22lingo-sub-1126982%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX%20%E3%81%AELMbench%E3%83%99%E3%83%B3%E3%83%81%E3%83%9E%E3%83%BC%E3%82%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126982%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CH1%20id%3D%22toc-hId-382519662%22%20id%3D%22toc-hId-1303351569%22%3E%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3COL%3E%3CLI%3EYocto%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E9%96%8B%E7%99%BA%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%20(%3CEM%3Efsl-image-gui-sdk%3C%2FEM%3E)%20%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%BE%E3%81%99%3C%2FLI%3E%3CLI%3ELMbench%20%E3%81%8B%E3%82%89%20LMbench%20%E3%81%AE%20tarball%20%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%20%3CA%20href%3D%22http%3A%2F%2Flmbench.sourceforge.net%2F%22%20title%3D%22http%3A%2F%2Flmbench.sourceforge.net%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E-%20%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E5%88%86%E6%9E%90%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AE%E3%83%84%E3%83%BC%E3%83%AB%3C%2FA%3E%3C%2FLI%3E%3CLI%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%A7%A3%E5%87%8D%E3%81%97%E3%80%81%E4%BD%9C%E6%88%90%E3%81%97%E3%81%9F%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%82%92%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%3C%2FLI%3E%3CLI%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%83%99%E3%83%B3%E3%83%81%E3%83%9E%E3%83%BC%E3%82%AF%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3C%2FOL%3E%3CBLOCKQUOTE%3E%0A%3CP%3Elmbench%20%24%20cd%20src%3C%2FP%3E%0A%3CP%3Elmbench%2Fsrc%20%24%20%E7%B5%90%E6%9E%9C%E3%82%92%E4%BD%9C%E3%82%8B%3C%2FP%3E%0A%3CP%3Elmbench%2Fsrc%20%24%20cd%20..%3C%2FP%3E%0A%3CP%3Elmbench%20%24%20make%20see%3C%2FP%3E%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId--1424934801%22%20id%3D%22toc-hId--504102894%22%3E%E3%83%99%E3%83%B3%E3%83%81%E3%83%9E%E3%83%BC%E3%82%AF%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%B7%BB%E4%BB%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%AF%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%8B%E3%82%89%E3%81%AE%E3%83%99%E3%83%B3%E3%83%81%E3%83%9E%E3%83%BC%E3%82%AF%E7%B5%90%E6%9E%9C%E3%81%A7%E3%81%99%E3%80%82%E5%88%A5%E3%81%AE%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E7%B5%90%E6%9E%9C%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%82%88%E3%82%8A%E5%A0%85%E7%89%A2%E3%81%AA%E7%B5%90%E6%9E%9C%E3%82%92%E5%BE%97%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%83%86%E3%82%B9%E3%83%88%E3%82%92%E6%95%B0%E5%9B%9E%E5%86%8D%E5%AE%9F%E8%A1%8C%E3%81%97%E3%80%81%E6%AC%A1%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E7%B5%90%E6%9E%9C%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3Elmbench%20%24%20%E7%B5%90%E6%9E%9C%E3%82%92%E4%BD%9C%E3%82%8B%3C%2FP%3E%0A%3CP%3Elmbench%20%24%20make%20%E5%86%8D%E5%AE%9F%E8%A1%8C%3C%2FP%3E%0A%3CP%3Elmbench%20%24%20make%20%E5%86%8D%E5%AE%9F%E8%A1%8C%3C%2FP%3E%0A%3CP%3Elmbench%20%24%20make%20%E5%86%8D%E5%AE%9F%E8%A1%8C%3C%2FP%3E%0A%3CP%3Elmbench%20%24%20cd%E3%81%AE%E7%B5%90%E6%9E%9C%3C%2FP%3E%0A%3CP%3Elmbench%2Fresults%20%24%20make%20%26gt%3B%20results%20%23%20results%20%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%9F%E3%81%84%E5%87%BA%E5%8A%9B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%99%3C%2FP%3E%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎04-15-2013 12:51 PM
更新者:
