How to install misc JDK in Ubuntu for Android build
To build Android version earlier than Lollipop from source code, you need the Sun's 1.6 SDK to be installed for ubuntu as the link Initializing a Build Environment | Android Developers.
You may still cannot get the Sun's JDK  with below instruction:
$ sudo add-apt-repository "deb http://archive.canonical.com/ lucid partner"
$ sudo apt
-get update
$ sudo apt
-get install sun-java6-jdk
There are below options to help install the Sun's JDK  if you cannot find a valid source through apt-get commands:
$ wget --no-cookies --header "Cookie: gpw_e24=http%3A%2F%2Fwww.oracle.com%2F" http://download.oracle.com/otn-pub/java/jdk/6u45-b06/jdk-6u45-linux-x64.bin
$ chmod u+x jdk-6u45-linux-x64.bin
$ ./jdk-6u45-linux-x64.bin
$ sudo mv jdk1.6.0_45 /opt
$ sudo update-alternatives --install /usr/bin/java java /opt/java/64/jdk1.6.0_45/bin/java 1
$ sudo update-alternatives --install /usr/bin/javac javac /opt/java/64/jdk1.6.0_45/bin/javac 1
$ sudo update-alternatives --install /usr/bin/jar jar /opt/java/64/jdk1.6.0_45/bin/jar 1
# if you have already install some other version of JDK, please export the JAVA_HOME env before your android build every time
$ export JAVA_HOME=/opt/jdk1.6.0_45/
#or you can directly link the java binary to the sdk version you need as below:
sudo ln -s /opt/java/64/jdk1.6.0_45/bin/jar /bin/jar
sudo ln -s/opt/java/64/jdk1.6.0_45/java /bin/java
sudo ln -s/opt/java/64/jdk1.6.0_45/javac /bin/javac
sudo ln -s/opt/java/64/jdk1.6.0_45/javah /bin/javah
sudo ln -s/opt/java/64/jdk1.6.0_45/javadoc /bin/javadoc
javaws /bin/javaws
To built the Android version Lollipop and Marshmallow from source code, you need the OpenJDK 7 to be installed for ubuntu as the link Initializing a Build Environment | Android Developers.
$ sudo apt-get update
$ sudo apt-get install openjdk-7-jdk
You may have both openjdk7 and SUN JDK 1.6 intalled in your ubuntu to build different Android version. If you have default java SDK to be Sun's JDK 1.6, you can just use below commands to make android build system use the openjdk7 for Lollipop built
$ export JAVA_HOME=/usr/lib/jvm/java-7-openjdk-amd64/
$ cd myandroid
$ . ./build/envsetup.sh           //be sure to resetup the envsetup, and pick the platform to be built
$ lunch
标签 (3)
评论
Thanks for the useful guide.
I had a couple of problems with it, which I will explain here in case it helps anyone else.
1)  sudo mv jdk1.6.0_45 /opt
This seems to put the code in the wrong place. Instead I used:
sudo mkdir -p /opt/java/64
sudo mv jdk1.6.0_45 /opt/java/64
2) sudo ln -s/opt/java/64/jdk1.6.0_45/java /bin/java
There seems to be a space missing so if you just copy/paste these symlink commands they don't work.(The first one is OK, the other 5 fail).
Here are copies with the space added:
sudo ln -s /opt/java/64/jdk1.6.0_45/java /bin/java
sudo ln -s /opt/java/64/jdk1.6.0_45/javac /bin/javac
sudo ln -s /opt/java/64/jdk1.6.0_45/javah /bin/javah
sudo ln -s /opt/java/64/jdk1.6.0_45/javadoc /bin/javadoc
javaws /bin/javaws
All comments welcome! :smileyhappy:
Thanks for sharing! I had the same problems on the directory structure and had to use a similar approach.
I also had to add --no-check-certificate when using wget in order to successfully download the .bin, so the command ended up as follow:
$ wget --no-cookies --no-check-certificate --header "Cookie: gpw_e24=http%3A%2F%2Fwww.oracle.com%2F" http://download.oracle.com/otn-pub/java/jdk/6u45-b06/jdk-6u45-linux-x64.bin
The easiest way to do this is to go to:
Java Archive Downloads - Java SE 6
Look for "jdk-6u45-linux-x64.bin" and manually download it. You will have to login (or create an account). Once it has finished downloading, I usually will copy the jdk (jdk-6u45-linux-x64.bin) to the home directory.
Then we need to run the binary and move it to a shared location:
$ chmod +x jdk-6u45-linux-x64.bin
$ sudo ./jdk-6u45-linux-x64.bin
$ sudo mv jdk1.6.0_45 /usr/lib/jvm/
Now you have to install all binaries and give them highest priority, This will also overwrite the previous version of Java Binaries in your computer.
$ sudo update-alternatives --install /usr/bin/java java /usr/lib/jvm/jdk1.6.0_45/bin/java 1
$ sudo update-alternatives --install /usr/bin/javac javac /usr/lib/jvm/jdk1.6.0_45/bin/javac 1
$ sudo update-alternatives --install /usr/bin/javaws javaws /usr/lib/jvm/jdk1.6.0_45/bin/javaws 1
$ sudo update-alternatives --install /usr/bin/jar jar /usr/lib/jvm/jdk1.6.0_45/bin/jar 1
$ sudo update-alternatives --install /usr/bin/javadoc javadoc /usr/lib/jvm/jdk1.6.0_45/bin/javadoc 1
Now check if JDK 1.6 is selected on this:
$ sudo update-alternatives --config java
$ sudo update-alternatives --config javac
$ sudo update-alternatives --config javaws
$ sudo update-alternatives --config jar
$ sudo update-alternatives --config javadoc
Now JDK is configured! To check if it is done
Execute this is Terminal:
$ java -version
Output will be similar to this:
java version "1.6.0_45"
Java(TM) SE Runtime Environment (build 1.6.0_45-b06)
Java HotSpot(TM) 64-Bit Server VM (build 20.45-b01, mixed mode)
Now the copy of "jdk-6u45-linux-x64.bin" in your home directory can be deleted, and you can save the one you downloaded for future use.
I know this works for Ubuntu 12.04 LTS (Precise) through Ubuntu 14.04 LTS (Trusty).
Hope this helps out.
Dave
The "deb http://archive.canonical.com/ lucid partner" source doesn't work. Now we can try:
$ sudo add-apt-repository "deb http://ppa.launchpad.net/ferramroberto/java/ubuntu natty main"
$ sudo apt-get install sun-java6-jdk
%3CLINGO-SUB%20id%3D%22lingo-sub-1117165%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%A6%82%E4%BD%95%E5%9C%A8%20Ubuntu%20%E4%B8%AD%E5%AE%89%E8%A3%85%E5%85%B6%E4%BB%96%20JDK%20%E4%BB%A5%E6%9E%84%E5%BB%BA%20Android%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117165%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%A6%81%E4%BB%8E%E6%BA%90%E4%BB%A3%E7%A0%81%E6%9E%84%E5%BB%BA%E6%97%A9%E4%BA%8E%20Lollipop%20%E7%9A%84%20Android%20%E7%89%88%E6%9C%AC%EF%BC%8C%E6%82%A8%E9%9C%80%E8%A6%81%E4%B8%BA%20ubuntu%20%E5%AE%89%E8%A3%85%20Sun%20%E7%9A%84%201.6%20SDK%EF%BC%8C%E5%A6%82%E9%93%BE%E6%8E%A5%3CA%20href%3D%22http%3A%2F%2Fsource.android.com%2Fsource%2Finitializing.html%22%20title%3D%22http%3A%2F%2Fsource.android.com%2Fsource%2Finitializing.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E5%88%9D%E5%A7%8B%E5%8C%96%E6%9E%84%E5%BB%BA%E7%8E%AF%E5%A2%83%20%7C%20Android%20%E5%BC%80%E5%8F%91%E4%BA%BA%E5%91%98%E6%89%80%E8%BF%B0%3C%2FA%3E%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E5%8F%AF%E8%83%BD%E4%BB%8D%E7%84%B6%E6%97%A0%E6%B3%95%E9%80%9A%E8%BF%87%E4%BB%A5%E4%B8%8B%E8%AF%B4%E6%98%8E%E8%8E%B7%E5%8F%96%20Sun%20%E7%9A%84%20JDK%EF%BC%9A%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%22%3E%24%20sudo%20add%3C%2FSPAN%3E%3CSPAN%20class%3D%22pun%22%20style%3D%22color%3A%20%23666600%3B%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%22%3Eapt%3C%2FSPAN%3E%3CSPAN%20class%3D%22pun%22%20style%3D%22color%3A%20%23666600%3B%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%22%3Erepository%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22str%22%20style%3D%22color%3A%20%23008800%3B%22%3E%3CSPAN%3E%22deb%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Farchive.canonical.com%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Farchive.canonical.com%2F%3C%2FA%3E%3CSPAN%3E%20lucid%20partner%22%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%22%3E%3CBR%20%2F%3E%24%20sudo%20apt%3C%2FSPAN%3E%3CSPAN%20class%3D%22pun%22%20style%3D%22color%3A%20%23666600%3B%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22kwd%22%20style%3D%22color%3A%20%23000088%3B%22%3Eget%3C%2FSPAN%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%22%3E%20update%3CBR%20%2F%3E%24%20sudo%20apt%3C%2FSPAN%3E%3CSPAN%20class%3D%22pun%22%20style%3D%22color%3A%20%23666600%3B%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22kwd%22%20style%3D%22color%3A%20%23000088%3B%22%3Eget%3C%2FSPAN%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%22%3E%20install%20sun%3C%2FSPAN%3E%3CSPAN%20class%3D%22pun%22%20style%3D%22color%3A%20%23666600%3B%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%22%3Ejava6%3C%2FSPAN%3E%3CSPAN%20class%3D%22pun%22%20style%3D%22color%3A%20%23666600%3B%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%22%3Ejdk%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FP%3E%26nbsp%3B%26nbsp%3B%20%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E6%97%A0%E6%B3%95%E9%80%9A%E8%BF%87%20apt-get%20%E5%91%BD%E4%BB%A4%E6%89%BE%E5%88%B0%E6%9C%89%E6%95%88%E7%9A%84%E6%BA%90%EF%BC%8C%E5%88%99%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E9%80%89%E9%A1%B9%E6%9D%A5%E5%B8%AE%E5%8A%A9%E5%AE%89%E8%A3%85%20Sun%20%E7%9A%84%20JDK%EF%BC%9A%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3E%24%20wget%20--no-cookies%20--header%20%22Cookie%3A%20gpw_e24%3Dhttp%20%253A%25%202F%20%252Fwww.oracle.com%25%202F%22%20%3CA%20href%3D%22http%3A%2F%2Fdownload.oracle.com%2Fotn-pub%2Fjava%2Fjdk%2F6u45-b06%2Fjdk-6u45-linux-x64.bin%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fdownload.oracle.com%2Fotn-pub%2Fjava%2Fjdk%2F6u45-b06%2Fjdk-6u45-linux-x64.bin%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%22%3E%24%20chmod%20u%2Bx%20jdk-6u45-linux-x64.bin%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%22%3E%24%20.%2Fjdk-6u45-linux-x64.bin%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%22%3E%24%20sudo%20mv%20jdk1.6.0_45%20%2Fopt%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%22%3E%24%20sudo%20update-alternatives%20--install%20%2Fusr%2Fbin%2Fjava%20java%20%2Fopt%2Fjava%2F64%2Fjdk1.6.0_45%2Fbin%2Fjava%201%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%22%3E%24%20sudo%20update-alternatives%20--install%20%2Fusr%2Fbin%2Fjavac%20javac%20%2Fopt%2Fjava%2F64%2Fjdk1.6.0_45%2Fbin%2Fjavac%201%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%22%3E%24%20sudo%20update-alternatives%20--install%20%2Fusr%2Fbin%2Fjar%20jar%20%2Fopt%2Fjava%2F64%2Fjdk1.6.0_45%2Fbin%2Fjar%201%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%22%3E%23%20%E5%A6%82%E6%9E%9C%E6%82%A8%E5%B7%B2%E7%BB%8F%E5%AE%89%E8%A3%85%E4%BA%86%E5%85%B6%E4%BB%96%E7%89%88%E6%9C%AC%E7%9A%84%20JDK%EF%BC%8C%E8%AF%B7%E5%9C%A8%E6%AF%8F%E6%AC%A1%E6%9E%84%E5%BB%BA%20Android%20%E4%B9%8B%E5%89%8D%E5%AF%BC%E5%87%BA%20JAVA_HOME%20%E7%8E%AF%E5%A2%83%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%22%3E%24%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E5%AF%BC%E5%87%BAJAVA_HOME%20%3D%20%2F%20opt%20%2F%20jdk1.6.0_45%20%2F%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3E%23%E6%88%96%E8%80%85%E6%82%A8%E5%8F%AF%E4%BB%A5%E7%9B%B4%E6%8E%A5%E5%B0%86%20java%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E9%93%BE%E6%8E%A5%E5%88%B0%E6%82%A8%E9%9C%80%E8%A6%81%E7%9A%84%20sdk%20%E7%89%88%E6%9C%AC%EF%BC%8C%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%20color%3A%20%23000000%3B%22%3Esudo%20ln%20-s%20%2Fopt%2Fjava%2F64%2Fjdk1.6.0_45%2Fbin%2Fjar%2Fbin%2Fjar%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%20color%3A%20%23000000%3B%22%3Esudo%20ln%20-s%2Fopt%2Fjava%2F64%2Fjdk1.6.0_45%2Fjava%20%2Fbin%2Fjava%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3Esudo%20ln%20-s%2Fopt%2Fjava%2F64%2Fjdk1.6.0_45%2Fjavac%20%2Fbin%2Fjavac%3CBR%20%2F%3Esudo%20ln%20-s%2Fopt%2Fjava%2F64%2Fjdk1.6.0_45%2Fjavah%20%2Fbin%2Fjavah%3CBR%20%2F%3Esudo%20ln%20-s%2Fopt%2Fjava%2F64%2Fjdk1.6.0_45%2Fjavadoc%20%2Fbin%2Fjavadoc%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3Esudo%20ln%20-s%2Fopt%2Fjava%2F64%2Fjdk1.6.0_45%2F%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3Ejavaws%20%2Fbin%2Fjavaws%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%26nbsp%3B%26nbsp%3B%20%3C%2FBLOCKQUOTE%3E%3CP%3E%E8%A6%81%E4%BB%8E%E6%BA%90%E4%BB%A3%E7%A0%81%E6%9E%84%E5%BB%BA%20Android%20%E7%89%88%E6%9C%AC%20Lollipop%20%E5%92%8C%20Marshmallow%EF%BC%8C%E6%82%A8%E9%9C%80%E8%A6%81%E4%B8%BA%20ubuntu%20%E5%AE%89%E8%A3%85%20OpenJDK%207%EF%BC%8C%E5%A6%82%E9%93%BE%E6%8E%A5%3CA%20href%3D%22http%3A%2F%2Fsource.android.com%2Fsource%2Finitializing.html%22%20title%3D%22http%3A%2F%2Fsource.android.com%2Fsource%2Finitializing.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E5%88%9D%E5%A7%8B%E5%8C%96%E6%9E%84%E5%BB%BA%E7%8E%AF%E5%A2%83%20%7C%20Android%20%E5%BC%80%E5%8F%91%E4%BA%BA%E5%91%98%E6%89%80%E8%BF%B0%3C%2FA%3E%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3E%3CSPAN%20class%3D%22ch-inject-variable%22%20style%3D%22color%3A%20%23d0d0d0%3B%20font-family%3A%20monospace%3B%22%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%22%3E%24%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22ch-inject-identifier%22%20style%3D%22color%3A%20%23d0d0d0%3B%20font-family%3A%20monospace%3B%22%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%22%3Esudo%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20monospace%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22ch-inject-identifier%22%20style%3D%22color%3A%20%23d0d0d0%3B%20font-family%3A%20monospace%3B%22%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%22%3Eapt%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22pun%22%20style%3D%22color%3A%20%23666600%3B%20font-family%3A%20monospace%3B%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22ch-inject-identifier%22%20style%3D%22color%3A%20%23d0d0d0%3B%20font-family%3A%20monospace%3B%22%3E%3CSPAN%20class%3D%22kwd%22%20style%3D%22color%3A%20%23000088%3B%22%3Eget%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20monospace%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22ch-inject-identifier%22%20style%3D%22color%3A%20%23d0d0d0%3B%20font-family%3A%20monospace%3B%22%3E%3CSPAN%20class%3D%22ch-inject-keymethods%22%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%22%3Eupdate%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20monospace%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22ch-inject-variable%22%20style%3D%22color%3A%20%23d0d0d0%3B%20font-family%3A%20monospace%3B%22%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%22%3E%24%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22ch-inject-identifier%22%20style%3D%22color%3A%20%23d0d0d0%3B%20font-family%3A%20monospace%3B%22%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%22%3Esudo%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20monospace%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22ch-inject-identifier%22%20style%3D%22color%3A%20%23d0d0d0%3B%20font-family%3A%20monospace%3B%22%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%22%3Eapt%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22pun%22%20style%3D%22color%3A%20%23666600%3B%20font-family%3A%20monospace%3B%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22ch-inject-identifier%22%20style%3D%22color%3A%20%23d0d0d0%3B%20font-family%3A%20monospace%3B%22%3E%3CSPAN%20class%3D%22kwd%22%20style%3D%22color%3A%20%23000088%3B%22%3Eget%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20monospace%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22ch-inject-identifier%22%20style%3D%22color%3A%20%23d0d0d0%3B%20font-family%3A%20monospace%3B%22%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%22%3Einstall%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20monospace%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22ch-inject-identifier%22%20style%3D%22color%3A%20%23d0d0d0%3B%20font-family%3A%20monospace%3B%22%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%22%3Eopenjdk%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22pun%22%20style%3D%22color%3A%20%23666600%3B%20font-family%3A%20monospace%3B%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22ch-inject-number%22%20style%3D%22color%3A%20%233677a9%3B%20font-family%3A%20monospace%3B%22%3E%3CSPAN%20class%3D%22lit%22%20style%3D%22color%3A%20%23006666%3B%22%3E7%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22pun%22%20style%3D%22color%3A%20%23666600%3B%20font-family%3A%20monospace%3B%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22ch-inject-identifier%22%20style%3D%22color%3A%20%23d0d0d0%3B%20font-family%3A%20monospace%3B%22%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%22%3Ejdk%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%20%3C%2FBLOCKQUOTE%3E%3CP%3E%E6%82%A8%E5%8F%AF%E8%83%BD%E5%9C%A8%20ubuntu%20%E4%B8%AD%E5%AE%89%E8%A3%85%E4%BA%86%20openjdk7%20%E5%92%8C%20SUN%20JDK%201.6%20%E6%9D%A5%E6%9E%84%E5%BB%BA%E4%B8%8D%E5%90%8C%E7%9A%84%20Android%20%E7%89%88%E6%9C%AC%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E7%9A%84%E9%BB%98%E8%AE%A4%20Java%20SDK%20%E6%98%AF%20Sun%20%E7%9A%84%20JDK%201.6%EF%BC%8C%E9%82%A3%E4%B9%88%E6%82%A8%E5%8F%AA%E9%9C%80%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E5%8D%B3%E5%8F%AF%E4%BD%BF%20Android%20%E6%9E%84%E5%BB%BA%E7%B3%BB%E7%BB%9F%E4%BD%BF%E7%94%A8%20OpenJDK7%20for%20Lollipop%20%E6%9E%84%E5%BB%BA%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3E%24%20%E5%AF%BC%E5%87%BA%20JAVA_HOME%3D%2Fusr%2Flib%2Fjvm%2Fjava-7-openjdk-amd64%2F%3C%2FP%3E%3CP%3E%24%20cd%20myandroid%3C%2FP%3E%3CP%3E%24%20%E3%80%82.%2Fbuild%2Fenvsetup.sh%20%2F%2F%E7%A1%AE%E4%BF%9D%E9%87%8D%E7%BD%AEenvsetup%EF%BC%8C%E5%B9%B6%E9%80%89%E6%8B%A9%E8%A6%81%E6%9E%84%E5%BB%BA%E7%9A%84%E5%B9%B3%E5%8F%B0%3C%2FP%3E%3CP%3E%24%E5%8D%88%E9%A4%90%3C%2FP%3E%20%3C%2FBLOCKQUOTE%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1117165%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAndroid%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6_%E5%85%A8%E9%83%A8%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6SL%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117169%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E5%9C%A8%20Ubuntu%20%E4%B8%AD%E5%AE%89%E8%A3%85%E5%85%B6%E4%BB%96%20JDK%20%E4%BB%A5%E6%9E%84%E5%BB%BA%20Android%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117169%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E2%80%9Cdeb%20%3CA%20class%3D%22jive-link-external-small%22%20data-content-finding%3D%22Community%22%20href%3D%22http%3A%2F%2Farchive.canonical.com%2F%22%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20monospace%3B%20color%3A%20%236a737b%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Farchive.canonical.com%2F%3C%2FA%3E%20%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20monospace%3B%20color%3A%20%23008800%3B%22%3Elucid%20partner%E2%80%9D%E6%BA%90%3C%2FSPAN%3E%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%E7%8E%B0%E5%9C%A8%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%3E%24%20sudo%20add-apt-repository%E2%80%9Cdeb%3C%2FSPAN%3E%20%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fppa.launchpad.net%2Fferramroberto%2Fjava%2Fubuntu%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fppa.launchpad.net%2Fferramroberto%2Fjava%2Fubuntu%3C%2FA%3E%20%3CSPAN%3Enatty%20main%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%24%20sudo%20apt-get%20update%3C%2FP%3E%3CP%3E%24%20sudo%20apt-get%20install%20sun-java6-jdk%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117168%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E5%9C%A8%20Ubuntu%20%E4%B8%AD%E5%AE%89%E8%A3%85%E5%85%B6%E4%BB%96%20JDK%20%E4%BB%A5%E6%9E%84%E5%BB%BA%20Android%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117168%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%80%E7%AE%80%E5%8D%95%E7%9A%84%E6%96%B9%E6%B3%95%E6%98%AF%E8%AE%BF%E9%97%AE%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fwww.oracle.com%2Ftechnetwork%2Fjava%2Fjavasebusiness%2Fdownloads%2Fjava-archive-downloads-javase6-419409.html%22%20title%3D%22http%3A%2F%2Fwww.oracle.com%2Ftechnetwork%2Fjava%2Fjavasebusiness%2Fdownloads%2Fjava-archive-downloads-javase6-419409.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EJava%20%E5%AD%98%E6%A1%A3%E4%B8%8B%E8%BD%BD%20-%20Java%20SE%206%3C%2FA%3E%3C%2FP%3E%3CP%3E%E6%9F%A5%E6%89%BE%E2%80%9Cjdk-6u45-linux-x64.bin%E2%80%9D%E5%B9%B6%E6%89%8B%E5%8A%A8%E4%B8%8B%E8%BD%BD%E3%80%82%E6%82%A8%E5%BF%85%E9%A1%BB%E7%99%BB%E5%BD%95%EF%BC%88%E6%88%96%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E5%B8%90%E6%88%B7%EF%BC%89%E3%80%82%E4%B8%8B%E8%BD%BD%E5%AE%8C%E6%88%90%E5%90%8E%EF%BC%8C%E6%88%91%E9%80%9A%E5%B8%B8%E4%BC%9A%E5%B0%86%20jdk%EF%BC%88jdk-6u45-linux-x64.bin%EF%BC%89%E5%A4%8D%E5%88%B6%E5%88%B0%E4%B8%BB%E7%9B%AE%E5%BD%95%E3%80%82%3C%2FP%3E%3CP%3E%E7%84%B6%E5%90%8E%E6%88%91%E4%BB%AC%E9%9C%80%E8%A6%81%E8%BF%90%E8%A1%8C%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E5%B9%B6%E5%B0%86%E5%85%B6%E7%A7%BB%E5%8A%A8%E5%88%B0%E5%85%B1%E4%BA%AB%E4%BD%8D%E7%BD%AE%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%24%20chmod%20%2Bx%20jdk-6u45-linux-x64.bin%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%24%20sudo%20.%2Fjdk-6u45-linux-x64.bin%3C%2FP%3E%3CP%3E%24%20sudo%20mv%20jdk1.6.0_45%20%2Fusr%2Flib%2Fjvm%2F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%8E%B0%E5%9C%A8%E6%82%A8%E5%BF%85%E9%A1%BB%E5%AE%89%E8%A3%85%E6%89%80%E6%9C%89%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E5%B9%B6%E8%B5%8B%E4%BA%88%E5%AE%83%E4%BB%AC%E6%9C%80%E9%AB%98%E4%BC%98%E5%85%88%E7%BA%A7%EF%BC%8C%E8%BF%99%E4%B9%9F%E5%B0%86%E8%A6%86%E7%9B%96%E6%82%A8%E8%AE%A1%E7%AE%97%E6%9C%BA%E4%B8%AD%E4%BB%A5%E5%89%8D%E7%89%88%E6%9C%AC%E7%9A%84%20Java%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%24%20sudo%20update-alternatives%20--install%20%2Fusr%2Fbin%2Fjava%20java%20%2Fusr%2Flib%2Fjvm%2Fjdk1.6.0_45%2Fbin%2Fjava%201%3C%2FP%3E%3CP%3E%24%20sudo%20update-alternatives%20--install%20%2Fusr%2Fbin%2Fjavac%20javac%20%2Fusr%2Flib%2Fjvm%2Fjdk1.6.0_45%2Fbin%2Fjavac%201%3C%2FP%3E%3CP%3E%24%20sudo%20update-alternatives%20--install%20%2Fusr%2Fbin%2Fjavaws%20javaws%20%2Fusr%2Flib%2Fjvm%2Fjdk1.6.0_45%2Fbin%2Fjavaws%201%3C%2FP%3E%3CP%3E%24%20sudo%20update-alternatives%20--install%20%2Fusr%2Fbin%2Fjar%20jar%20%2Fusr%2Flib%2Fjvm%2Fjdk1.6.0_45%2Fbin%2Fjar%201%3C%2FP%3E%3CP%3E%24%20sudo%20update-alternatives%20--install%20%2Fusr%2Fbin%2Fjavadoc%20javadoc%20%2Fusr%2Flib%2Fjvm%2Fjdk1.6.0_45%2Fbin%2Fjavadoc%201%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E7%8E%B0%E5%9C%A8%E6%A3%80%E6%9F%A5%E6%98%AF%E5%90%A6%E9%80%89%E6%8B%A9%E4%BA%86%20JDK%201.6%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%24%20sudo%20update-alternatives%20--config%20java%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%24%20sudo%20%E6%9B%B4%E6%96%B0%E6%9B%BF%E4%BB%A3%E6%96%B9%E6%A1%88%20--config%20javac%3C%2FP%3E%3CP%3E%24%20sudo%20update-alternatives%20--config%20javaws%3C%2FP%3E%3CP%3E%24%20sudo%20%E6%9B%B4%E6%96%B0%E6%9B%BF%E4%BB%A3%E6%96%B9%E6%A1%88%E2%80%94%E2%80%94%E9%85%8D%E7%BD%AE%20jar%3C%2FP%3E%3CP%3E%24%20sudo%20update-alternatives%20--config%20javadoc%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E7%8E%B0%E5%9C%A8JDK%E5%B7%B2%E9%85%8D%E7%BD%AE%E5%AE%8C%E6%AF%95%EF%BC%81%E6%A3%80%E6%9F%A5%E6%98%AF%E5%90%A6%E5%AE%8C%E6%88%90%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%E7%BB%88%E7%AB%AF%E6%89%A7%E8%A1%8C%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%24%20java%20-%E7%89%88%E6%9C%AC%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E8%BE%93%E5%87%BA%E5%B0%86%E7%B1%BB%E4%BC%BC%E4%BA%8E%E6%AD%A4%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3EJava%E7%89%88%E6%9C%AC%E2%80%9C1.6.0_45%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EJava(TM)%20SE%20%E8%BF%90%E8%A1%8C%E6%97%B6%E7%8E%AF%E5%A2%83%EF%BC%88%E7%89%88%E6%9C%AC%201.6.0_45-b06%EF%BC%89%3C%2FP%3E%3CP%3EJava%20HotSpot(TM)%2064%20%E4%BD%8D%E6%9C%8D%E5%8A%A1%E5%99%A8%20VM%EF%BC%88%E7%89%88%E6%9C%AC%2020.45-b01%EF%BC%8C%E6%B7%B7%E5%90%88%E6%A8%A1%E5%BC%8F%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%8E%B0%E5%9C%A8%E5%8F%AF%E4%BB%A5%E5%88%A0%E9%99%A4%E4%B8%BB%E7%9B%AE%E5%BD%95%E4%B8%AD%E7%9A%84%E2%80%9Cjdk-6u45-linux-x64.bin%E2%80%9D%E5%89%AF%E6%9C%AC%EF%BC%8C%E5%B9%B6%E4%BF%9D%E5%AD%98%E4%B8%8B%E8%BD%BD%E7%9A%84%E5%89%AF%E6%9C%AC%E4%BB%A5%E4%BE%9B%E5%B0%86%E6%9D%A5%E4%BD%BF%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E7%9F%A5%E9%81%93%E8%BF%99%E9%80%82%E7%94%A8%E4%BA%8E%20Ubuntu%2012.04%20LTS%EF%BC%88Precise%EF%BC%89%E5%88%B0%20Ubuntu%2014.04%20LTS%EF%BC%88Trusty%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E5%B8%8C%E6%9C%9B%E8%BF%99%E8%83%BD%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3EDave%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117167%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E5%9C%A8%20Ubuntu%20%E4%B8%AD%E5%AE%89%E8%A3%85%E5%85%B6%E4%BB%96%20JDK%20%E4%BB%A5%E6%9E%84%E5%BB%BA%20Android%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117167%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%B0%A2%E8%B0%A2%E5%88%86%E4%BA%AB%EF%BC%81%E6%88%91%E5%9C%A8%E7%9B%AE%E5%BD%95%E7%BB%93%E6%9E%84%E4%B8%8A%E9%81%87%E5%88%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E4%B8%8D%E5%BE%97%E4%B8%8D%E4%BD%BF%E7%94%A8%E7%B1%BB%E4%BC%BC%E7%9A%84%E6%96%B9%E6%B3%95%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E4%B8%BA%E4%BA%86%E6%88%90%E5%8A%9F%E4%B8%8B%E8%BD%BD%20.bin%EF%BC%8C%E6%88%91%E8%BF%98%E5%BF%85%E9%A1%BB%E5%9C%A8%E4%BD%BF%E7%94%A8%20wget%20%E6%97%B6%E6%B7%BB%E5%8A%A0%20--no-check-certificate%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%91%BD%E4%BB%A4%E6%9C%80%E7%BB%88%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3E%24%20wget%20--no-cookies%20--no-check-certificate%20--header%20%22Cookie%3A%20gpw_e24%3Dhttp%20%253A%25%202F%20%252Fwww.oracle.com%25%202F%22%20%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fdownload.oracle.com%2Fotn-pub%2Fjava%2Fjdk%2F6u45-b06%2Fjdk-6u45-linux-x64.bin%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fdownload.oracle.com%2Fotn-pub%2Fjava%2Fjdk%2F6u45-b06%2Fjdk-6u45-linux-x64.bin%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117166%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E5%9C%A8%20Ubuntu%20%E4%B8%AD%E5%AE%89%E8%A3%85%E5%85%B6%E4%BB%96%20JDK%20%E4%BB%A5%E6%9E%84%E5%BB%BA%20Android%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117166%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E5%AE%9E%E7%94%A8%E6%8C%87%E5%8D%97%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E5%87%A0%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E6%88%91%E5%B0%86%E5%9C%A8%E8%BF%99%E9%87%8C%E8%A7%A3%E9%87%8A%E4%B8%80%E4%B8%8B%EF%BC%8C%E5%B8%8C%E6%9C%9B%E5%AE%83%E8%83%BD%E5%B8%AE%E5%8A%A9%E5%88%B0%E5%85%B6%E4%BB%96%E4%BA%BA%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E1)%26nbsp%3B%20sudo%20mv%20jdk1.6.0_45%20%2Fopt%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E4%BC%BC%E4%B9%8E%E5%B0%86%E4%BB%A3%E7%A0%81%E6%94%BE%E5%9C%A8%E4%BA%86%E9%94%99%E8%AF%AF%E7%9A%84%E4%BD%8D%E7%BD%AE%E3%80%82%E7%9B%B8%E5%8F%8D%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E4%BA%86%EF%BC%9A%3C%2FP%3E%3CP%3Esudo%20mkdir%20-p%20%2Fopt%2Fjava%2F64%3C%2FP%3E%3CP%3Esudo%20mv%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%20jdk1.6.0_45%20%2Fopt%2Fjava%2F64%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CSTRONG%3E2)%20sudo%20ln%20-s%2Fopt%2Fjava%2F64%2Fjdk1.6.0_45%2Fjava%20%2Fbin%2Fjava%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E4%BC%BC%E4%B9%8E%E7%BC%BA%E5%B0%91%E4%B8%80%E4%B8%AA%E7%A9%BA%E6%A0%BC%EF%BC%8C%E6%89%80%E4%BB%A5%E5%A6%82%E6%9E%9C%E4%BD%A0%E5%8F%AA%E6%98%AF%E5%A4%8D%E5%88%B6%2F%E7%B2%98%E8%B4%B4%E8%BF%99%E4%BA%9B%E7%AC%A6%E5%8F%B7%E9%93%BE%E6%8E%A5%E5%91%BD%E4%BB%A4%EF%BC%8C%E5%AE%83%E4%BB%AC%E5%B0%86%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%EF%BC%88%E7%AC%AC%E4%B8%80%E4%B8%AA%E6%88%90%E5%8A%9F%EF%BC%8C%E5%85%B6%E4%BB%96%205%20%E4%B8%AA%E5%A4%B1%E8%B4%A5%EF%BC%89%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E6%B7%BB%E5%8A%A0%E4%BA%86%E7%A9%BA%E6%A0%BC%E7%9A%84%E5%89%AF%E6%9C%AC%EF%BC%9A%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3Esudo%20ln%20-s%20%2Fopt%2Fjava%2F64%2Fjdk1.6.0_45%2Fjava%20%2Fbin%2Fjava%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3Esudo%20ln%20-s%20%2Fopt%2Fjava%2F64%2Fjdk1.6.0_45%2Fjavac%20%2Fbin%2Fjavac%3CBR%20%2F%3Esudo%20ln%20-s%20%2Fopt%2Fjava%2F64%2Fjdk1.6.0_45%2Fjavah%20%2Fbin%2Fjavah%3CBR%20%2F%3Esudo%20ln%20-s%20%2Fopt%2Fjava%2F64%2Fjdk1.6.0_45%2Fjavadoc%20%2Fbin%2Fjavadoc%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3Esudo%20ln%20-s%20%2Fopt%2Fjava%2F64%2Fjdk1.6.0_45%2F%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3Ejavaws%20%2Fbin%2Fjavaws%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AC%A2%E8%BF%8E%E6%89%80%E6%9C%89%E8%AF%84%E8%AE%BA%EF%BC%81%3A%E7%AC%91%E8%84%B8%3A%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎11-17-2013 10:31 PM
更新人:
