How to find the crash point: Android Native crash
There is a very quick way to find out which line cause the crash in logcat,
Generally, if some native service crashes, look in the crash log in logcat like this:
I/DEBUG ( 2253): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
I/DEBUG ( 2253): Build fingerprint: 'freescale/sabresd_6dq/sabresd_6dq:4.0.4/R13.3-rc3/eng.b18293.20120710.124535:user/test-keys'
I/DEBUG ( 2253): pid: 3043, tid: 3080 >>> /system/bin/mediaserver <<<
I/DEBUG ( 2253): signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr deadbaad
I/DEBUG ( 2253): r0 deadbaad r1 00000001 r2 a0000000 r3 00000000
I/DEBUG ( 2253): r4 00000000 r5 00000027 r6 00bfd370 r7 40c1ef18
I/DEBUG ( 2253): r8 00004349 r9 00000000 10 000003f5 fp 00000000
I/DEBUG ( 2253): ip ffffffff sp 418876a0 lr 400ff1b5 pc 400fb91c cpsr 60000030
We can see it’s possibly related to some code that we debugged, but don’t know exactly where or which line of code,
Android has a tool to convert this log to a more precise log. As a quick example, if you got this crash in logcat:
F/libc ( 3043): Fatal signal 11 (SIGSEGV) at 0xdeadbaad (code=1)
I/DEBUG ( 2253): d0 3e4ccccd00000000 d1 7e37e43c3e4ccccd
I/DEBUG ( 2253): d2 0000004042000000 d3 4200000000000000
I/DEBUG ( 2253): d4 3ff0000000000000 d5 3ff0000000000000
I/DEBUG ( 2253): d6 4220000041300000 d7 3e4ccccd3e4ccccd
I/DEBUG ( 2253): d8 000000000000685d d9 00000000010bee7c
I/DEBUG ( 2253): d10 0000000000000000 d11 0000000000000000
I/DEBUG ( 2253): d12 0000000000000000 d13 0000000000000000
I/DEBUG ( 2253): d14 0000000000000000 d15 0000000000000000
I/DEBUG ( 2253): d16 0000000000000000 d17 3ff0000000000000
I/DEBUG ( 2253): d18 7e37e43c8800759c d19 0000000000000000
I/DEBUG ( 2253): d20 bfe0000000000000 d21 405443dab91ed79f
I/DEBUG ( 2253): d22 0000000000000000 d23 3f40624dd2f1a9fc
I/DEBUG ( 2253): d24 7fff80007fff0000 d25 3f6328e1cb8c85e0
I/DEBUG ( 2253): d26 0000000000000000 d27 0000000000000000
I/DEBUG ( 2253): d28 0000000000000000 d29 0000000000000000
I/DEBUG ( 2253): d30 0000000000000000 d31 0000000000000000
I/DEBUG ( 2253): scr 28000010
I/DEBUG ( 2253):
I/DEBUG ( 2253): #00 pc 0001791c /system/lib/libc.so
I/DEBUG ( 2253): #01 pc 00003f3e /system/lib/libcutils.so (__android_log_assert)
I/DEBUG ( 2253): #02 pc 0006c436 /system/lib/libstagefright.so (_ZN7android8OMXCodec16drainInputBufferEPNS0_10BufferInfoE)
I/DEBUG ( 2253): #03 pc 0006cbc2 /system/lib/libstagefright.so (_ZN7android8OMXCodec17drainInputBuffersEv)
I/DEBUG ( 2253): #04 pc 0006f570 /system/lib/libstagefright.so (_ZN7android8OMXCodec4readEPPNS_11MediaBufferEPKNS_11MediaSource11ReadOpti
onsE)
I/DEBUG ( 2253): #05 pc 00051aba /system/lib/libstagefright.so (_ZN7android11AudioPlayer5startEb)
I/DEBUG ( 2253): #06 pc 0005411e /system/lib/libstagefright.so (_ZN7android13AwesomePlayer18startAudioPlayer_lEb)
I/DEBUG ( 2253): #07 pc 0005554a /system/lib/libstagefright.so (_ZN7android13AwesomePlayer6play_lEv)
I/DEBUG ( 2253): #08 pc 000558e0 /system/lib/libstagefright.so (_ZN7android13AwesomePlayer4playEv)
I/DEBUG ( 2253): #09 pc 00027f4e /system/lib/libmediaplayerservice.so (_ZN7android17StagefrightPlayer5startEv)
I/DEBUG ( 2253): #10 pc 00024dda /system/lib/libmediaplayerservice.so (_ZN7android18MediaPlayerService6decodeEixxPjPiS2_)
I/DEBUG ( 2253):
I/DEBUG ( 2253): code around pc:
I/DEBUG ( 2253): 400fb8fc 4623b15c 2c006824 e026d1fb b12368db \.#F$h.,..&..h#.
I/DEBUG ( 2253): 400fb90c 21014a17 6011447a 48124798 24002527 .J.!zD.`.G.H'%.$
I/DEBUG ( 2253): 400fb91c f7f47005 2106ee22 eebef7f5 f04fa901 .p.."..!......O.
I/DEBUG ( 2253): 400fb92c 460a5380 93032006 94029401 ea7af7f5 .S.F. ........z.
I/DEBUG ( 2253): 400fb93c 4622a905 f7f52002 f7f4ea84 2106ee0e .."F. .........!
I/DEBUG ( 2253):
I/DEBUG ( 2253): code around lr:
I/DEBUG ( 2253): 400ff194 41f0e92d 4c0c4680 447c2600 68a56824 -..A.F.L.&|D$h.h
I/DEBUG ( 2253): 400ff1a4 e0076867 300cf9b5 dd022b00 47c04628 gh.....0.+..(F.G
I/DEBUG ( 2253): 400ff1b4 35544306 37fff117 6824d5f4 d1ee2c00 .CT5...7..$h.,..
I/DEBUG ( 2253): 400ff1c4 e8bd4630 bf0081f0 00028346 41f0e92d 0F......F...-..A
I/DEBUG ( 2253): 400ff1d4 9004b086 f602fb01 460c461f 46154814 .........F.F.H.F
I/DEBUG ( 2253):
I/DEBUG ( 2253): memory map around addr deadbaad:
I/DEBUG ( 2253): becef000-bed10000 [stack]
I/DEBUG ( 2253): (no map for address)
I/DEBUG ( 2253): ffff0000-ffff1000 [vectors]
I/DEBUG ( 2253):
You can see it’s related to which lib, but don’t know which line.
So, let’s go to your source code, for example:
mydroid;
after do
$. build/envsetup.sh$ lunch sabresd_6dp-eng
$ development/scripts/stack
Then you have a prompt:
Reading native crash info from stdin
The you just copy all the crash log in above to this prompt.
And then Key in EOF (CTRL+D) in this prompt.
You will get output like this:
Reading symbols from /home/b33651/proj/ics/out/target/product/sabresd_6dq/symbols
Stack Trace:
  RELADDR FUNCTION FILE:LINE
  0001791c __libc_android_abort+92 /home/b33651/proj/ics/bionic/libc/unistd/abort.c:82
  00003f3e __android_log_assert+94 /home/b33651/proj/ics/system/core/liblog/logd_write.c:246
  0006c436 android::OMXCodec::drainInputBuffer(android::OMXCodec::BufferInfo*)+138 /home/b33651/proj/ics/frameworks/base/media/libstagefright/OMXCodec.cpp:3181
  0006cbc2 android::OMXCodec::drainInputBuffers()+102 /home/b33651/proj/ics/frameworks/base/media/libstagefright/OMXCodec.cpp:3125
  0006f570 android::OMXCodec::read(android::MediaBuffer**, android::MediaSource::ReadOptions const*)+136 /home/b33651/proj/ics/frameworks/base/media/libstagefright/OMXCodec.cpp:4020
  00051aba android::AudioPlayer::start(bool)+134 /home/b33651/proj/ics/frameworks/base/media/libstagefright/AudioPlayer.cpp:93
  0005411e android::AwesomePlayer::startAudioPlayer_l(bool)+70 /home/b33651/proj/ics/frameworks/base/media/libstagefright/AwesomePlayer.cpp:953
  0005554a android::AwesomePlayer::play_l()+202 /home/b33651/proj/ics/frameworks/base/media/libstagefright/AwesomePlayer.cpp:888
  000558e0 android::AwesomePlayer::play()+20 /home/b33651/proj/ics/frameworks/base/media/libstagefright/AwesomePlayer.cpp:837
  00027f4e android::StagefrightPlayer::start()+6 /home/b33651/proj/ics/frameworks/base/media/libmediaplayerservice/StagefrightPlayer.cpp:90
  00024dda android::MediaPlayerService::decode(int, long long, long long, unsigned int*, int*, int*)+206 /home/b33651/proj/ics/frameworks/base/media/libmediaplayerservice/MediaPlayerService.cpp:1428
So, you get more reason logs.
  1. The Android directory must have built once.
  2. The crash log better aligns with your Android build environment.
标签 (1)
标记 (2)
评论
is it only for imx6 debug?
actually, this method can be applied for all android release and all soc of IMX.
So, would be better to tag the file as any imx, and not for imx6 only. :smileywink:
Hi Jiejing,
I tried on JB4.2.2 but it didn't work as it used to do on ICS.
%3CLINGO-SUB%20id%3D%22lingo-sub-1116921%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%A6%82%E4%BD%95%E6%89%BE%E5%88%B0%E5%B4%A9%E6%BA%83%E7%82%B9%EF%BC%9AAndroid%20Native%20%E5%B4%A9%E6%BA%83%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116921%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22font-size%3A%2013.333333015441895px%3B%20color%3A%20%23000000%3B%20margin%3A%2010px%200px%3B%20font-family%3A%20Helvetica%2C%20Arial%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E6%9C%89%E4%B8%80%E7%A7%8D%E9%9D%9E%E5%B8%B8%E5%BF%AB%E6%8D%B7%E7%9A%84%E6%96%B9%E6%B3%95%E5%8F%AF%E4%BB%A5%E6%89%BE%E5%87%BA%20logcat%20%E4%B8%AD%E5%93%AA%E4%B8%80%E8%A1%8C%E5%AF%BC%E8%87%B4%E5%B4%A9%E6%BA%83%EF%BC%8C%3C%2FP%3E%3CP%20style%3D%22font-size%3A%2013.333333015441895px%3B%20color%3A%20%23000000%3B%20margin%3A%2010px%200px%3B%20font-family%3A%20Helvetica%2C%20Arial%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E4%B8%80%E8%88%AC%E6%9D%A5%E8%AF%B4%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%9F%90%E4%B8%AA%E5%8E%9F%E7%94%9F%E6%9C%8D%E5%8A%A1%E5%B4%A9%E6%BA%83%E4%BA%86%EF%BC%8C%E5%8F%AF%E4%BB%A5%E5%9C%A8logcat%E4%B8%AD%E6%9F%A5%E7%9C%8B%E5%B4%A9%E6%BA%83%E6%97%A5%E5%BF%97%EF%BC%8C%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%EF%BC%9A%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3EI%2FDEBUG%20(%202253)%3A%20***%20***%20***%20***%20***%20***%20***%20***%20***%20***%20***%20***%20***%20***%20***%20***%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%20(%202253)%3A%20Build%20fingerprint%3A%20'freescale%2Fsabresd_6dq%2Fsabresd_6dq%3A4.0.4%2FR13.3-rc3%2Feng.b18293.20120710.124535%3Auser%2Ftest-keys'%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%20(%202253)%3A%20pid%3A%203043%2C%20tid%3A%203080%20%26gt%3B%26gt%3B%26gt%3B%20%2Fsystem%2Fbin%2Fmediaserver%20%26lt%3B%26lt%3B%26lt%3B%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%20(2253)%EF%BC%9A%E4%BF%A1%E5%8F%B7%2011%20(SIGSEGV)%EF%BC%8C%E4%BB%A3%E7%A0%81%201%20(SEGV_MAPERR)%EF%BC%8C%E6%95%85%E9%9A%9C%E5%9C%B0%E5%9D%80%20deadbaad%3C%2FP%3E%0A%3CP%3E%E6%88%91%2F%E8%B0%83%E8%AF%95%EF%BC%882253%EF%BC%89%EF%BC%9Ar0%20%E6%AD%BB%E5%8C%BA%20r1%2000000001%20r2%20a0000000%20r3%2000000000%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%20(%202253)%3A%20r4%2000000000%20r5%2000000027%20r6%2000bfd370%20r7%2040c1ef18%3C%2FP%3E%0A%3CP%3E%E6%88%91%2F%E8%B0%83%E8%AF%95%EF%BC%882253%EF%BC%89%EF%BC%9Ar8%2000004349%20r9%2000000000%2010%20000003f5%20fp%2000000000%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%20(%202253)%3A%20ip%20ffffffff%20sp%20418876a0%20lr%20400ff1b5%20pc%20400fb91c%20cpsr%2060000030%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%26nbsp%3B%26nbsp%3B%20(%202253)%3A%26nbsp%3B%20ip%20ffffffff%26nbsp%3B%20sp%20418876a0%26nbsp%3B%20lr%20400ff1b5%26nbsp%3B%20pc%20400fb91c%26nbsp%3B%20cpsr%2060000030%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%0A%20%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FBLOCKQUOTE%3E%3CP%20style%3D%22font-size%3A%2013.333333015441895px%3B%20color%3A%20%23000000%3B%20margin%3A%2010px%200px%3B%20font-family%3A%20Helvetica%2C%20Arial%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%88%B0%E5%AE%83%E5%8F%AF%E8%83%BD%E4%B8%8E%E6%88%91%E4%BB%AC%E8%B0%83%E8%AF%95%E7%9A%84%E6%9F%90%E4%BA%9B%E4%BB%A3%E7%A0%81%E6%9C%89%E5%85%B3%EF%BC%8C%E4%BD%86%E4%B8%8D%E7%9F%A5%E9%81%93%E5%85%B7%E4%BD%93%E5%9C%A8%E5%93%AA%E9%87%8C%E6%88%96%E5%93%AA%E4%B8%80%E8%A1%8C%E4%BB%A3%E7%A0%81%EF%BC%8C%3C%2FP%3E%3CP%20style%3D%22font-size%3A%2013.333333015441895px%3B%20color%3A%20%23000000%3B%20margin%3A%2010px%200px%3B%20font-family%3A%20Helvetica%2C%20Arial%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3EAndroid%20%E6%9C%89%E4%B8%80%E4%B8%AA%E5%B7%A5%E5%85%B7%E5%8F%AF%E4%BB%A5%E5%B0%86%E6%AD%A4%E6%97%A5%E5%BF%97%E8%BD%AC%E6%8D%A2%E4%B8%BA%E6%9B%B4%E7%B2%BE%E7%A1%AE%E7%9A%84%E6%97%A5%E5%BF%97%E3%80%82%E4%B8%BE%E4%B8%80%E4%B8%AA%E7%AE%80%E5%8D%95%E7%9A%84%E4%BE%8B%E5%AD%90%EF%BC%8C%3CSPAN%20style%3D%22font-size%3A%2013.333333015441895px%3B%20line-height%3A%201.5em%3B%22%3E%E5%A6%82%E6%9E%9C%E4%BD%A0%E5%9C%A8%20logcat%20%E4%B8%AD%E9%81%87%E5%88%B0%E4%BA%86%E8%BF%99%E4%B8%AA%E5%B4%A9%E6%BA%83%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3EF%2Flibc%EF%BC%883043%EF%BC%89%EF%BC%9A0xdeadbaad%20%E5%A4%84%E7%9A%84%E8%87%B4%E5%91%BD%E4%BF%A1%E5%8F%B7%2011%EF%BC%88SIGSEGV%EF%BC%89%EF%BC%88%E4%BB%A3%E7%A0%81%3D1%EF%BC%89%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%20(%202253)%3A%20***%20***%20***%20***%20***%20***%20***%20***%20***%20***%20***%20***%20***%20***%20***%20***%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%20(%202253)%3A%20Build%20fingerprint%3A%20'freescale%2Fsabresd_6dq%2Fsabresd_6dq%3A4.0.4%2FR13.3-rc3%2Feng.b18293.20120710.124535%3Auser%2Ftest-keys'%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%20(%202253)%3A%20pid%3A%203043%2C%20tid%3A%203080%20%26gt%3B%26gt%3B%26gt%3B%20%2Fsystem%2Fbin%2Fmediaserver%20%26lt%3B%26lt%3B%26lt%3B%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%20(2253)%EF%BC%9A%E4%BF%A1%E5%8F%B7%2011%20(SIGSEGV)%EF%BC%8C%E4%BB%A3%E7%A0%81%201%20(SEGV_MAPERR)%EF%BC%8C%E6%95%85%E9%9A%9C%E5%9C%B0%E5%9D%80%20deadbaad%3C%2FP%3E%0A%3CP%3E%E6%88%91%2F%E8%B0%83%E8%AF%95%EF%BC%882253%EF%BC%89%EF%BC%9Ar0%20%E6%AD%BB%E5%8C%BA%20r1%2000000001%20r2%20a0000000%20r3%2000000000%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%20(%202253)%3A%20r4%2000000000%20r5%2000000027%20r6%2000bfd370%20r7%2040c1ef18%3C%2FP%3E%0A%3CP%3E%E6%88%91%2F%E8%B0%83%E8%AF%95%EF%BC%882253%EF%BC%89%EF%BC%9Ar8%2000004349%20r9%2000000000%2010%20000003f5%20fp%2000000000%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%20(%202253)%3A%20ip%20ffffffff%20sp%20418876a0%20lr%20400ff1b5%20pc%20400fb91c%20cpsr%2060000030%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%20(%202253)%3A%20d0%203e4ccccd00000000%20d1%207e37e43c3e4ccccd%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%20(%202253)%3A%20d2%200000004042000000%20d3%204200000000000000%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%20(%202253)%3A%20d4%203ff0000000000000%20d5%203ff0000000000000%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%20(%202253)%3A%20d6%204220000041300000%20d7%203e4ccccd3e4ccccd%3C%2FP%3E%0A%3CP%3E%E6%88%91%2F%E8%B0%83%E8%AF%95%EF%BC%882253%EF%BC%89%EF%BC%9Ad8%20000000000000685d%20d9%2000000000010bee7c%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%20(%202253)%3A%20d10%200000000000000000%20d11%200000000000000000%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%20(%202253)%3A%20d12%200000000000000000%20d13%200000000000000000%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%20(%202253)%3A%20d14%200000000000000000%20d15%200000000000000000%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%20(%202253)%3A%20d16%200000000000000000%20d17%203ff0000000000000%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%20(%202253)%3A%20d18%207e37e43c8800759c%20d19%200000000000000000%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%20(%202253)%3A%20d20%20bfe0000000000000%20d21%20405443dab91ed79f%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%20(%202253)%3A%20d22%200000000000000000%20d23%203f40624dd2f1a9fc%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%20(%202253)%3A%20d24%207fff80007fff0000%20d25%203f6328e1cb8c85e0%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%20(%202253)%3A%20d26%200000000000000000%20d27%200000000000000000%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%20(%202253)%3A%20d28%200000000000000000%20d29%200000000000000000%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%20(%202253)%3A%20d30%200000000000000000%20d31%200000000000000000%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%20(%202253)%3A%20scr%2028000010%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%20(%202253)%3A%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%20(%202253)%3A%20%2300%20pc%200001791c%20%2Fsystem%2Flib%2Flibc.so%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%20(%202253)%3A%20%2301%20pc%2000003f3e%20%2Fsystem%2Flib%2Flibcutils.so%20(__android_log_assert)%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%EF%BC%882253%EF%BC%89%EF%BC%9A%2302%20pc%200006c436%20%2Fsystem%2Flib%2Flibstagefright.so%EF%BC%88_ZN7android8OMXCodec16drainInputBufferEPNS0_10BufferInfoE%EF%BC%89%3C%2FP%3E%0A%3CP%3E%E6%88%91%2F%E8%B0%83%E8%AF%95%EF%BC%882253%EF%BC%89%EF%BC%9A%2303%20pc%200006cbc2%20%2Fsystem%2Flib%2Flibstagefright.so%EF%BC%88_ZN7android8OMXCodec17drainInputBuffersEv%EF%BC%89%3C%2FP%3E%0A%3CP%3E%E6%88%91%2F%E8%B0%83%E8%AF%95%EF%BC%882253%EF%BC%89%EF%BC%9A%EF%BC%8304%20pc%200006f570%20%2Fsystem%2Flib%2Flibstagefright.so%EF%BC%88_ZN7android8OMXCodec4readEPPNS_11MediaBufferEPKNS_11MediaSource11ReadOpti%3C%2FP%3E%0A%3CP%3EonsE)%3C%2FP%3E%0A%3CP%3E%E6%88%91%2F%E8%B0%83%E8%AF%95%EF%BC%882253%EF%BC%89%EF%BC%9A%2305%20pc%2000051aba%20%2Fsystem%2Flib%2Flibstagefright.so%EF%BC%88_ZN7android11AudioPlayer5startEb%EF%BC%89%3C%2FP%3E%0A%3CP%3E%E6%88%91%2F%E8%B0%83%E8%AF%95%EF%BC%882253%EF%BC%89%EF%BC%9A%2306%20pc%200005411e%20%2Fsystem%2Flib%2Flibstagefright.so%EF%BC%88_ZN7android13AwesomePlayer18startAudioPlayer_lEb%EF%BC%89%3C%2FP%3E%0A%3CP%3E%E6%88%91%2F%E8%B0%83%E8%AF%95%EF%BC%882253%EF%BC%89%EF%BC%9A%2307%20pc%200005554a%20%2Fsystem%2Flib%2Flibstagefright.so%EF%BC%88_ZN7android13AwesomePlayer6play_lEv%EF%BC%89%3C%2FP%3E%0A%3CP%3E%E6%88%91%2F%E8%B0%83%E8%AF%95%EF%BC%882253%EF%BC%89%EF%BC%9A%2308%20pc%20000558e0%20%2Fsystem%2Flib%2Flibstagefright.so%EF%BC%88_ZN7android13AwesomePlayer4playEv%EF%BC%89%3C%2FP%3E%0A%3CP%3E%E6%88%91%2F%E8%B0%83%E8%AF%95%EF%BC%882253%EF%BC%89%EF%BC%9A%2309%20pc%2000027f4e%20%2Fsystem%2Flib%2Flibmediaplayerservice.so%EF%BC%88_ZN7android17StagefrightPlayer5startEv%EF%BC%89%3C%2FP%3E%0A%3CP%3E%E6%88%91%2F%E8%B0%83%E8%AF%95%EF%BC%882253%EF%BC%89%EF%BC%9A%2310%20pc%2000024dda%20%2Fsystem%2Flib%2Flibmediaplayerservice.so%EF%BC%88_ZN7android18MediaPlayerService6decodeEixxPjPiS2_%EF%BC%89%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%20(%202253)%3A%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%EF%BC%882253%EF%BC%89%EF%BC%9APC%20%E5%91%A8%E5%9B%B4%E7%9A%84%E4%BB%A3%E7%A0%81%EF%BC%9A%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%20(%202253)%3A%20400fb8fc%204623b15c%202c006824%20e026d1fb%20b12368db%20%5C.%23F%24h.%2C..%26amp%3B..h%23.%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%20(%202253)%3A%20400fb90c%2021014a17%206011447a%2048124798%2024002527%20.J.!zD.%60.G.H'%25.%24%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%EF%BC%882253%EF%BC%89%EF%BC%9A400fb91c%20f7f47005%202106ee22%20eebef7f5%20f04fa901%20.p..%22..%EF%BC%81......O.%3C%2FP%3E%0A%3CP%3E%E6%88%91%2F%E8%B0%83%E8%AF%95%EF%BC%882253%EF%BC%89%EF%BC%9A400fb92c%20460a5380%2093032006%2094029401%20ea7af7f5%20.SF........z%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%2F%E8%B0%83%E8%AF%95%EF%BC%882253%EF%BC%89%EF%BC%9A400fb93c%204622a905%20f7f52002%20f7f4ea84%202106ee0e%20..%E2%80%9DF..........%EF%BC%81%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%20(%202253)%3A%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%EF%BC%882253%EF%BC%89%EF%BC%9Alr%20%E5%91%A8%E5%9B%B4%E7%9A%84%E4%BB%A3%E7%A0%81%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%E6%88%91%2F%E8%B0%83%E8%AF%95%EF%BC%882253%EF%BC%89%EF%BC%9A400ff194%2041f0e92d%204c0c4680%20447c2600%2068a56824%20-..AFL%26amp%3B%7CD%24hh%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%20(%202253)%3A%20400ff1a4%20e0076867%20300cf9b5%20dd022b00%2047c04628%20gh.....0.%2B..(F.G%3C%2FP%3E%0A%3CP%3E%E6%88%91%2F%E8%B0%83%E8%AF%95%EF%BC%882253%EF%BC%89%EF%BC%9A400ff1b4%2035544306%2037fff117%206824d5f4%20d1ee2c00%20.CT5...7..%24h.%EF%BC%8C..%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%20(%202253)%3A%20400ff1c4%20e8bd4630%20bf0081f0%2000028346%2041f0e92d%200F......F...-..A%3C%2FP%3E%0A%3CP%3E%E6%88%91%2F%E8%B0%83%E8%AF%95%EF%BC%882253%EF%BC%89%EF%BC%9A400ff1d4%209004b086%20f602fb01%20460c461f%2046154814%20.........FFHF%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%20(%202253)%3A%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%EF%BC%882253%EF%BC%89%EF%BC%9A%E5%9C%B0%E5%9D%80%20deadbaad%20%E5%91%A8%E5%9B%B4%E7%9A%84%E5%86%85%E5%AD%98%E6%98%A0%E5%B0%84%EF%BC%9A%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%EF%BC%882253%EF%BC%89%EF%BC%9Abecef000-bed10000%20%5B%E5%A0%86%E6%A0%88%5D%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%EF%BC%882253%EF%BC%89%EF%BC%9A%EF%BC%88%E6%B2%A1%E6%9C%89%E5%9C%B0%E5%9D%80%3CSPAN%20class%3D%22code-keyword%22%20style%3D%22color%3A%20%23000091%3B%20background-color%3A%20inherit%3B%22%3E%E6%98%A0%E5%B0%84%3C%2FSPAN%3E%EF%BC%89%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%EF%BC%882253%EF%BC%89%EF%BC%9Affff0000-ffff1000%20%5B%E5%90%91%E9%87%8F%5D%3C%2FP%3E%0A%3CP%3EI%2FDEBUG%20(%202253)%3A%3C%2FP%3E%0A%0A%20%3C%2FBLOCKQUOTE%3E%3CP%20style%3D%22font-size%3A%2013.333333015441895px%3B%20color%3A%20%23000000%3B%20margin%3A%2010px%200px%3B%20font-family%3A%20Helvetica%2C%20Arial%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%88%B0%E5%AE%83%E4%B8%8E%E5%93%AA%E4%B8%AA%E5%BA%93%E7%9B%B8%E5%85%B3%EF%BC%8C%E4%BD%86%E4%B8%8D%E7%9F%A5%E9%81%93%E5%93%AA%E4%B8%80%E8%A1%8C%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-size%3A%2013.333333015441895px%3B%20color%3A%20%23000000%3B%20margin%3A%2010px%200px%3B%20font-family%3A%20Helvetica%2C%20Arial%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E8%AE%A9%E6%88%91%E4%BB%AC%E8%BD%AC%E5%88%B0%E6%82%A8%E7%9A%84%E6%BA%90%E4%BB%A3%E7%A0%81%EF%BC%8C%E4%BE%8B%E5%A6%82%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22font-size%3A%2013.333333015441895px%3B%20color%3A%20%23000000%3B%20margin%3A%2010px%200px%3B%20font-family%3A%20Helvetica%2C%20Arial%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3Emydroid%3B%3C%2FP%3E%3CP%20style%3D%22font-size%3A%2013.333333015441895px%3B%20color%3A%20%23000000%3B%20margin%3A%2010px%200px%3B%20font-family%3A%20Helvetica%2C%20Arial%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E5%81%9A%E5%AE%8C%E4%B9%8B%E5%90%8E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%24.build%2Fenvsetup.sh%24%E5%8D%88%E9%A4%90%20sabresd_6dp-eng%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3E%24%20%E5%BC%80%E5%8F%91%2F%E8%84%9A%E6%9C%AC%2F%E5%A0%86%E6%A0%88%3C%2FP%3E%0A%0A%20%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Helvetica%2C%20Arial%2C%20sans-serif%3B%20font-size%3A%2013.333333015441895px%3B%20background-color%3A%20%23ffffff%3B%22%3E%E7%84%B6%E5%90%8E%E4%BD%A0%E4%BC%9A%E7%9C%8B%E5%88%B0%E4%B8%80%E4%B8%AA%E6%8F%90%E7%A4%BA%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Helvetica%2C%20Arial%2C%20sans-serif%3B%20font-size%3A%2013.333333015441895px%3B%20background-color%3A%20%23ffffff%3B%22%3E%E4%BB%8E%E6%A0%87%E5%87%86%E8%BE%93%E5%85%A5%E8%AF%BB%E5%8F%96%3CSPAN%20class%3D%22code-keyword%22%20style%3D%22color%3A%20%23000091%3B%20background-color%3A%20inherit%3B%22%3E%E6%9C%AC%E6%9C%BA%3C%2FSPAN%3E%E5%B4%A9%E6%BA%83%E4%BF%A1%E6%81%AF%3C%2FSPAN%3E%3C%2FP%3E%0A%0A%20%3C%2FBLOCKQUOTE%3E%3CP%20style%3D%22font-size%3A%2013.333333015441895px%3B%20color%3A%20%23000000%3B%20margin%3A%2010px%200px%3B%20font-family%3A%20Helvetica%2C%20Arial%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E6%82%A8%E5%8F%AA%E9%9C%80%E5%B0%86%E4%B8%8A%E9%9D%A2%E7%9A%84%E6%89%80%E6%9C%89%E5%B4%A9%E6%BA%83%E6%97%A5%E5%BF%97%E5%A4%8D%E5%88%B6%E5%88%B0%E6%AD%A4%E6%8F%90%E7%A4%BA%E5%8D%B3%E5%8F%AF%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-size%3A%2013.333333015441895px%3B%20color%3A%20%23000000%3B%20margin%3A%2010px%200px%3B%20font-family%3A%20Helvetica%2C%20Arial%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E7%84%B6%E5%90%8E%E5%9C%A8%E6%AD%A4%E6%8F%90%E7%A4%BA%E4%B8%AD%E8%BE%93%E5%85%A5%20EOF%20(CTRL%2BD)%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-size%3A%2013.333333015441895px%3B%20color%3A%20%23000000%3B%20margin%3A%2010px%200px%3B%20font-family%3A%20Helvetica%2C%20Arial%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E6%82%A8%E5%B0%86%E8%8E%B7%E5%BE%97%E5%A6%82%E4%B8%8B%E8%BE%93%E5%87%BA%EF%BC%9A%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%E4%BB%8E%20%2Fhome%2Fb33651%2Fproj%2Fics%2Fout%2Ftarget%2Fproduct%2Fsabresd_6dq%2Fsymbols%20%E8%AF%BB%E5%8F%96%E7%AC%A6%E5%8F%B7%3C%2FP%3E%0A%3CP%3Epid%3A%203043%2C%20tid%3A%203080%20%26gt%3B%26gt%3B%26gt%3B%20%2Fsystem%2Fbin%2Fmediaserver%20%26lt%3B%26lt%3B%26lt%3B%3C%2FP%3E%0A%3CP%3E%E4%BF%A1%E5%8F%B7%2011%20(SIGSEGV)%EF%BC%8C%E4%BB%A3%E7%A0%81%201%20(SEGV_MAPERR)%EF%BC%8C%E6%95%85%E9%9A%9C%E5%9C%B0%E5%9D%80%20deadbaad%3C%2FP%3E%0A%3CP%3Er0%20%E6%AD%BB%E5%8C%BA%20r1%2000000001%20r2%20a0000000%20r3%2000000000%3C%2FP%3E%0A%3CP%3Er4%2000000000%20r5%2000000027%20r6%2000bfd370%20r7%2040c1ef18%3C%2FP%3E%0A%3CP%3Er8%2000004349%20r9%2000000000%2010%20000003f5%20fp%2000000000%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%20ip%20ffffffff%20sp%20418876a0%20lr%20400ff1b5%20pc%20400fb91c%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3E%E5%A0%86%E6%A0%88%E8%B7%9F%E8%B8%AA%EF%BC%9A%3C%2FP%3E%0A%3CP%3ERELADDR%20%E5%87%BD%E6%95%B0%E6%96%87%E4%BB%B6%3A%E8%A1%8C%3C%2FP%3E%0A%3CP%3E0001791c%20__libc_android_abort%2B92%20%2Fhome%2Fb33651%2Fproj%2Fics%2Fbionic%2Flibc%2Funistd%2Fabort.c%3A82%3C%2FP%3E%0A%3CP%3E00003f3e%20__android_log_assert%2B94%20%2Fhome%2Fb33651%2Fproj%2Fics%2Fsystem%2Fcore%2Fliblog%2Flogd_write.c%3A246%3C%2FP%3E%0A%3CP%3E0006c436%20android%3A%3AOMXCodec%3A%3AdrainInputBuffer%EF%BC%88android%3A%3AOMXCodec%3A%3ABufferInfo*%EF%BC%89%2B138%20%2Fhome%2Fb33651%2Fproj%2Fics%2Fframeworks%2Fbase%2Fmedia%2Flibstagefright%2FOMXCodec.cpp%3A3181%3C%2FP%3E%0A%3CP%3E0006cbc2%20android%3A%3AOMXCodec%3A%3AdrainInputBuffers()%2B102%20%2Fhome%2Fb33651%2Fproj%2Fics%2Fframeworks%2Fbase%2Fmedia%2Flibstagefright%2FOMXCodec.cpp%3A3125%3C%2FP%3E%0A%3CP%3E0006f570%20android%3A%3AOMXCodec%3A%3Aread%EF%BC%88android%3A%3AMediaBuffer**%EF%BC%8Candroid%3A%3AMediaSource%3A%3AReadOptions%20%3CSPAN%20class%3D%22code-keyword%22%20style%3D%22color%3A%20%23000091%3B%20background-color%3A%20inherit%3B%22%3Econst%3C%2FSPAN%3E%20*%EF%BC%89%2B136%20%2Fhome%2Fb33651%2Fproj%2Fics%2Fframeworks%2Fbase%2Fmedia%2Flibstagefright%2FOMXCodec.cpp%3A4020%3C%2FP%3E%0A%3CP%3E00051aba%20android%3A%3AAudioPlayer%3A%3Astart(bool)%2B134%20%2Fhome%2Fb33651%2Fproj%2Fics%2Fframeworks%2Fbase%2Fmedia%2Flibstagefright%2FAudioPlayer.cpp%3A93%3C%2FP%3E%0A%3CP%3E0005411e%20android%3A%3AAwesomePlayer%3A%3AstartAudioPlayer_l(bool)%2B70%20%2Fhome%2Fb33651%2Fproj%2Fics%2Fframeworks%2Fbase%2Fmedia%2Flibstagefright%2FAwesomePlayer.cpp%3A953%3C%2FP%3E%0A%3CP%3E0005554a%20android%3A%3AAwesomePlayer%3A%3Aplay_l()%2B202%20%2Fhome%2Fb33651%2Fproj%2Fics%2Fframeworks%2Fbase%2Fmedia%2Flibstagefright%2FAwesomePlayer.cpp%3A888%3C%2FP%3E%0A%3CP%3E000558e0%20android%3A%3AAwesomePlayer%3A%3Aplay()%2B20%20%2Fhome%2Fb33651%2Fproj%2Fics%2Fframeworks%2Fbase%2Fmedia%2Flibstagefright%2FAwesomePlayer.cpp%3A837%3C%2FP%3E%0A%3CP%3E00027f4e%20android%3A%3AStagefrightPlayer%3A%3Astart()%2B6%20%2Fhome%2Fb33651%2Fproj%2Fics%2Fframeworks%2Fbase%2Fmedia%2Flibmediaplayerservice%2FStagefrightPlayer.cpp%3A90%3C%2FP%3E%0A%3CP%3E00024dda%20android%3A%3AMediaPlayerService%3A%3Adecode(%20%3CSPAN%20class%3D%22code-object%22%20style%3D%22color%3A%20%23910091%3B%20background-color%3A%20inherit%3B%22%3Eint%3C%2FSPAN%3E%20%EF%BC%8C%20%3CSPAN%20class%3D%22code-object%22%20style%3D%22color%3A%20%23910091%3B%20background-color%3A%20inherit%3B%22%3Elong%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22code-object%22%20style%3D%22color%3A%20%23910091%3B%20background-color%3A%20inherit%3B%22%3Elong%3C%2FSPAN%3E%20%EF%BC%8C%20%3CSPAN%20class%3D%22code-object%22%20style%3D%22color%3A%20%23910091%3B%20background-color%3A%20inherit%3B%22%3Elong%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22code-object%22%20style%3D%22color%3A%20%23910091%3B%20background-color%3A%20inherit%3B%22%3Elong%3C%2FSPAN%3E%20%EF%BC%8Cunsigned%20%3CSPAN%20class%3D%22code-object%22%20style%3D%22color%3A%20%23910091%3B%20background-color%3A%20inherit%3B%22%3Eint%3C%2FSPAN%3E%20*%EF%BC%8C%20%3CSPAN%20class%3D%22code-object%22%20style%3D%22color%3A%20%23910091%3B%20background-color%3A%20inherit%3B%22%3Eint%3C%2FSPAN%3E%20*%EF%BC%8C%20%3CSPAN%20class%3D%22code-object%22%20style%3D%22color%3A%20%23910091%3B%20background-color%3A%20inherit%3B%22%3Eint%3C%2FSPAN%3E%20*)%2B206%20%2Fhome%2Fb33651%2Fproj%2Fics%2Fframeworks%2Fbase%2Fmedia%2Flibmediaplayerservice%2FMediaPlayerService.cpp%3A1428%3C%2FP%3E%0A%0A%20%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22font-size%3A%2013.333333015441895px%3B%20color%3A%20%23000000%3B%20margin%3A%2010px%200px%3B%20font-family%3A%20Helvetica%2C%20Arial%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E8%8E%B7%E5%BE%97%E6%9B%B4%E5%A4%9A%E5%8E%9F%E5%9B%A0%E6%97%A5%E5%BF%97%E3%80%82%3C%2FP%3E%3CH3%20style%3D%22font-size%3A%2015pt%3B%20margin%3A%2028px%200%204px%3B%20color%3A%20%23003366%3B%20font-family%3A%20Helvetica%2C%20Arial%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%20id%3D%22toc-hId-1082660532%22%20id%3D%22toc-hId-2005309879%22%3E%3CA%20name%3D%22HOWTOAndroidNativecrash%252Cfindthecrashpoint.-Note%253A%22%20target%3D%22_blank%22%3E%3C%2FA%3E%E7%AC%94%E8%AE%B0%EF%BC%9A%3C%2FH3%3E%3COL%20style%3D%22font-size%3A%2013.333333015441895px%3B%20color%3A%20%23000000%3B%20font-family%3A%20Helvetica%2C%20Arial%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CLI%3EAndroid%E7%9B%AE%E5%BD%95%E5%BF%85%E9%A1%BB%E5%B7%B2%E7%BB%8F%E5%BB%BA%E7%AB%8B%E8%BF%87%E4%B8%80%E6%AC%A1%E3%80%82%3C%2FLI%3E%3CLI%3E%E5%B4%A9%E6%BA%83%E6%97%A5%E5%BF%97%E4%B8%8E%E6%82%A8%E7%9A%84%20Android%20%E6%9E%84%E5%BB%BA%E7%8E%AF%E5%A2%83%E6%9B%B4%E5%8A%A0%E4%B8%80%E8%87%B4%E3%80%82%3C%2FLI%3E%3C%2FOL%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1116921%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAndroid%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116925%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%89%BE%E5%88%B0%E5%B4%A9%E6%BA%83%E7%82%B9%EF%BC%9AAndroid%20Native%20%E5%B4%A9%E6%BA%83%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116925%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Jiejing%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E8%BF%87%E5%9C%A8%20JB4.2.2%20%E4%B8%8A%E4%BD%BF%E7%94%A8%E5%AE%83%EF%BC%8C%E4%BD%86%E5%AE%83%E4%B8%8D%E5%83%8F%E5%9C%A8%20ICS%20%E4%B8%8A%E9%82%A3%E6%A0%B7%E5%B7%A5%E4%BD%9C%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116924%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%89%BE%E5%88%B0%E5%B4%A9%E6%BA%83%E7%82%B9%EF%BC%9AAndroid%20Native%20%E5%B4%A9%E6%BA%83%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116924%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%9C%80%E5%A5%BD%E5%B0%86%E6%96%87%E4%BB%B6%E6%A0%87%E8%AE%B0%E4%B8%BA%E4%BB%BB%E4%BD%95%20imx%EF%BC%8C%E8%80%8C%E4%B8%8D%E4%BB%85%E4%BB%85%E6%98%AF%20imx6%E3%80%82%E7%AC%91%E8%84%B8%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116923%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%89%BE%E5%88%B0%E5%B4%A9%E6%BA%83%E7%82%B9%EF%BC%9AAndroid%20Native%20%E5%B4%A9%E6%BA%83%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116923%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%AE%9E%E9%99%85%E4%B8%8A%EF%BC%8C%E6%AD%A4%E6%96%B9%E6%B3%95%E5%8F%AF%E4%BB%A5%E9%80%82%E7%94%A8%E4%BA%8E%E6%89%80%E6%9C%89android%E7%89%88%E6%9C%AC%E5%92%8C%E6%89%80%E6%9C%89IMX%E7%9A%84soc%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116922%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%89%BE%E5%88%B0%E5%B4%A9%E6%BA%83%E7%82%B9%EF%BC%9AAndroid%20Native%20%E5%B4%A9%E6%BA%83%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116922%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%AE%83%E4%BB%85%E9%80%82%E7%94%A8%E4%BA%8Eimx6%E8%B0%83%E8%AF%95%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎09-20-2012 08:47 PM
更新人:
