How to Print Function Caller Stack in Android Log File
Print caller stack may help you to analyze the program and find out the caller stack more easily.
You can write your code like this:
Java:
     Exception e = new Exception();
     Log.e(TAG,"xxx",e);
C++ file:
      #include <utils/Callstack.h>
     android::CallStack stack;
     stack.update(1,30);
     stacn.dump("xxx");
Then you can see the function's caller stack in Android main log file.
C file:
#include <corkscrew/backtrace.h>
#define MAX_DEPTH 31
#define MAX_BACKTRACE_LINE_LENGTH 800
static backtrace_frame_t mStack[MAX_DEPTH];
static size_t mCount;
void csupdate(int32_t ignoreDepth, int32_t maxDepth) {
    if (maxDepth > MAX_DEPTH) {
        maxDepth = MAX_DEPTH;
    ssize_t count = unwind_backtrace(mStack, ignoreDepth + 1, maxDepth);
    mCount = count > 0 ? count : 0;
void csdump(const char* prefix)\
size_t i = 0;
    backtrace_symbol_t symbols[MAX_DEPTH];
    get_backtrace_symbols(mStack, mCount, symbols);
    for (i = 0; i < mCount; i++) {
        char line[MAX_BACKTRACE_LINE_LENGTH];
        format_backtrace_line(i, &mStack[i], &symbols[i],
                line, MAX_BACKTRACE_LINE_LENGTH);
        ALOGE("%s%s", prefix, line);
    free_backtrace_symbols(symbols, mCount);
void myFunc()
     csupdate(1, 30);
     csdump("myprefix");
In Android.mk, add libcorkscrew, as below
LOCAL_SHARED_LIBRARIES := libxxx libyyy libcorkscrew
Tags (2)
%3CLINGO-SUB%20id%3D%22lingo-sub-1107523%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHow%20to%20Print%20Function%20Caller%20Stack%20in%20Android%20Log%20File%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1107523%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EPrint%20caller%20stack%20may%20help%20you%20to%20analyze%20the%20program%20and%20find%20out%20the%20caller%20stack%20more%20easily.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EYou%20can%20write%20your%20code%20like%20this%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EJava%3A%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Exception%20e%20%3D%20new%20Exception()%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Log.e(TAG%2C%22xxx%22%2Ce)%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EC%2B%2B%20file%3A%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23include%20%3CUTILS%3E%3C%2FUTILS%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20android%3A%3ACallStack%20stack%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20stack.update(1%2C30)%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20stacn.dump(%22xxx%22)%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThen%20you%20can%20see%20the%20function's%20caller%20stack%20in%20Android%20main%20log%20file.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EC%20file%3A%3C%2FP%3E%3CP%3E%23include%20%3CCORKSCREW%3E%3C%2FCORKSCREW%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23define%20MAX_DEPTH%2031%3CBR%20%2F%3E%23define%20MAX_BACKTRACE_LINE_LENGTH%20800%3C%2FP%3E%3CP%3Estatic%20backtrace_frame_t%20mStack%5BMAX_DEPTH%5D%3B%3CBR%20%2F%3Estatic%20size_t%20mCount%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Evoid%20csupdate(int32_t%20ignoreDepth%2C%20int32_t%20maxDepth)%20%7B%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20if%20(maxDepth%20%26gt%3B%20MAX_DEPTH)%20%7B%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20maxDepth%20%3D%20MAX_DEPTH%3B%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ssize_t%20count%20%3D%20unwind_backtrace(mStack%2C%20ignoreDepth%20%2B%201%2C%20maxDepth)%3B%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20mCount%20%3D%20count%20%26gt%3B%200%20%3F%20count%20%3A%200%3B%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3Evoid%20csdump(const%20char*%20prefix)%5C%3CBR%20%2F%3E%7B%3CBR%20%2F%3Esize_t%20i%20%3D%200%3B%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20backtrace_symbol_t%20symbols%5BMAX_DEPTH%5D%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20get_backtrace_symbols(mStack%2C%20mCount%2C%20symbols)%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20for%20(i%20%3D%200%3B%20i%20%26lt%3B%20mCount%3B%20i%2B%2B)%20%7B%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20char%20line%5BMAX_BACKTRACE_LINE_LENGTH%5D%3B%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20format_backtrace_line(i%2C%20%26amp%3BmStack%5Bi%5D%2C%20%26amp%3Bsymbols%5Bi%5D%2C%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20line%2C%20MAX_BACKTRACE_LINE_LENGTH)%3B%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ALOGE(%22%25s%25s%22%2C%20prefix%2C%20line)%3B%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20free_backtrace_symbols(symbols%2C%20mCount)%3B%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Evoid%20myFunc()%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20csupdate(1%2C%2030)%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20csdump(%22myprefix%22)%3B%20%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3EIn%20Android.mk%2C%20add%20libcorkscrew%2C%20as%20below%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3ELOCAL_SHARED_LIBRARIES%20%3A%3D%20libxxx%20libyyy%20libcorkscrew%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1107523%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAndroid%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
No ratings
Version history
Last update:
‎10-13-2012 12:57 AM
Updated by:
