Generate random ethernet mac And program it to eFuse
Abstract:
On the time otp driver initializes, it will check the mac bits of eFuse,  when the value is invalid, generate a random mac, and program  it to eFuse.
Environment:
i.mx6dl
android-4.2.2
kernel-3.0.35
Changes:
1. kernel_imx/arch/arm/mach-mx6/mx6_fec.c
void __init imx6_init_fec(struct fec_platform_data fec_data)
  fec_get_mac_addr(fec_data.mac);
  if (!is_valid_ether_addr(fec_data.mac))
      fec_data.mac[0] = 0x10; // changed by xxx
  if (cpu_is_mx6sl())
  imx6sl_add_fec(&fec_data);
  else
  imx6q_add_fec(&fec_data);
2. kernel_imx/drivers/char/fsl_otp.c
//add by xxx
static void check_otp_mac(void)
  unsigned int index_mac0 = 34;
  unsigned int index_mac1 = 35;
  u32 value_mac0 = 0;
  u32 value_mac1 = 0;
  u32 value_random_mac0 = 0;
  u32 value_random_mac1 = 0;
  char otp_mac[6], random_mac[6];
  memset(otp_mac, 0, sizeof(otp_mac));
  memset(random_mac, 0, sizeof(random_mac));
  mutex_lock(&otp_mutex);
  //get
  if (otp_read_prepare(otp_data)) {
  mutex_unlock(&otp_mutex);
  return 0;
  value_mac0 = __raw_readl(REGS_OCOTP_BASE + HW_OCOTP_CUSTn(index_mac0));
  value_mac1 = __raw_readl(REGS_OCOTP_BASE + HW_OCOTP_CUSTn(index_mac1));
  otp_read_post(otp_data);
  if(value_mac0 != 0 && value_mac1 != 0)
  otp_mac[5] = value_mac0 & 0xff;
  otp_mac[4] = (value_mac0 >> 8) & 0xff;
  otp_mac[3] = (value_mac0 >> 16) & 0xff;
  otp_mac[2] = (value_mac0 >> 24) & 0xff;
  otp_mac[1] = value_mac1 & 0xff;
  otp_mac[0] = (value_mac1 >> 8) & 0xff;
  printk("otp_mac=%pM\n", otp_mac);
  //check
  if (!is_valid_ether_addr(otp_mac))
  random_ether_addr(random_mac);
  printk("get random mac:%pM\n", random_mac);
  //set
  value_random_mac0 = value_random_mac0 | random_mac[2];
  value_random_mac0 = (value_random_mac0 << 8) | random_mac[3];
  value_random_mac0 = (value_random_mac0 << 8) | random_mac[4];
  value_random_mac0 = (value_random_mac0 << 8) | random_mac[5];
  value_random_mac1 = value_random_mac1 | random_mac[0];
  value_random_mac1 = (value_random_mac1 << 8) | random_mac[1];
  if (otp_write_prepare(otp_data)) {
  return 0;
  otp_write_bits(index_mac0, value_random_mac0, 0x3e77);
  otp_write_bits(index_mac1, value_random_mac1, 0x3e77);
  otp_write_post(otp_data);
//end
3.  kernel_imx/drivers/char/fsl_otp.c
static int __devinit fsl_otp_probe(struct platform_device *pdev)
  retval = sysfs_create_group(otp_kobj, &attr_group);
  if (retval)
  goto error;
  mutex_init(&otp_mutex);
  //add by xxx
  check_otp_mac();
  //end
标记 (2)
%3CLINGO-SUB%20id%3D%22lingo-sub-1103747%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E7%94%9F%E6%88%90%E9%9A%8F%E6%9C%BA%E4%BB%A5%E5%A4%AA%E7%BD%91%20mac%20%E5%B9%B6%E5%B0%86%E5%85%B6%E7%BC%96%E7%A8%8B%E5%88%B0%20eFuse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103747%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%3E%E6%8A%BD%E8%B1%A1%E7%9A%84%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%20otp%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%88%9D%E5%A7%8B%E5%8C%96%E6%97%B6%EF%BC%8C%E5%AE%83%E5%B0%86%E6%A3%80%E6%9F%A5%20eFuse%20%E7%9A%84%20mac%20%E4%BD%8D%EF%BC%8C%E5%BD%93%E8%AF%A5%E5%80%BC%E6%97%A0%E6%95%88%E6%97%B6%EF%BC%8C%E7%94%9F%E6%88%90%E4%B8%80%E4%B8%AA%E9%9A%8F%E6%9C%BA%20mac%EF%BC%8C%E5%B9%B6%E5%B0%86%E5%85%B6%E7%BC%96%E7%A8%8B%E5%88%B0%20eFuse%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%3E%E7%8E%AF%E5%A2%83%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3Ei.mx6dl%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3Eandroid-4.2.2%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3Ekernel-3.0.35%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%23303030%3B%22%3E%E6%9B%B4%E6%94%B9%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22color%3A%20%23505050%3B%22%3E1.%20kernel_imx%2Farch%2Farm%2Fmach-mx6%2Fmx6_fec.c%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23505050%3B%22%3E----------------------------------------------------------------%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Evoid%20__init%20imx6_init_fec%EF%BC%88%E7%BB%93%E6%9E%84fec_platform_data%20fec_data%EF%BC%89%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20fec_get_mac_addr(fec_data.mac)%3B%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%EF%BC%88%EF%BC%81is_valid_ether_addr%EF%BC%88fec_data.mac%EF%BC%89%EF%BC%89%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3Efec_%E6%95%B0%E6%8D%AE.mac%5B0%5D%3D%200x10%3B%20%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%2F%2F%E7%94%B1xxx%E6%9B%B4%E6%94%B9%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20if%20(cpu_is_mx6sl())%3C%2FP%3E%3CP%3E%26nbsp%3B%20imx6sl_add_fec(%26amp%3Bfec_data)%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%20else%3C%2FP%3E%3CP%3E%26nbsp%3B%20imx6q_add_fec(%26amp%3Bfec_data)%3B%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E2.%20kernel_imx%2Fdrivers%2Fchar%2Ffsl_otp.c%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23505050%3B%22%3E----------------------------------------------------------------%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%2F%2F%E7%94%B1xxx%E6%B7%BB%E5%8A%A0%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3Estatic%20void%20check_otp_mac(void)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%E6%97%A0%E7%AC%A6%E5%8F%B7%E6%95%B4%E6%95%B0index_mac0%20%3D%2034%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%E6%97%A0%E7%AC%A6%E5%8F%B7%E6%95%B4%E6%95%B0index_mac1%20%3D%2035%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%26nbsp%3B%20u32%20value_mac0%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%26nbsp%3B%20u32%20value_mac1%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%26nbsp%3B%20u32%20value_random_mac0%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%26nbsp%3B%20u32%20value_random_mac1%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%26nbsp%3B%20char%20otp_mac%5B6%5D%2C%20random_mac%5B6%5D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3Ememset%EF%BC%88otp_mac%EF%BC%8C%200%EF%BC%8Csizeof%EF%BC%88otp_mac%EF%BC%89%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3Ememset%EF%BC%88random_mac%EF%BC%8C%200%EF%BC%8Csizeof%EF%BC%88random_mac%EF%BC%89%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%E4%BA%92%E6%96%A5%E9%94%81%EF%BC%88%26amp%3Botp_mutex%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%26nbsp%3B%20%2F%2Fget%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%E5%A6%82%E6%9E%9C%EF%BC%88otp_read_prepare%EF%BC%88otp_data%EF%BC%89%EF%BC%89%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%E4%BA%92%E6%96%A5%E9%94%81%E8%A7%A3%E9%94%81%EF%BC%88%26amp%3Botp_mutex%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%26nbsp%3B%20return%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3Evalue_mac0%20%3D%20__raw_readl(REGS_OCOTP_BASE%20%2B%20HW_OCOTP_CUSTn(index_mac0))%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3Evalue_mac1%20%3D%20__raw_readl(REGS_OCOTP_BASE%20%2B%20HW_OCOTP_CUSTn(index_mac1))%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3Eotp_read_post%EF%BC%88otp_data%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%E4%BA%92%E6%96%A5%E9%94%81%E8%A7%A3%E9%94%81%EF%BC%88%26amp%3Botp_mutex%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%26nbsp%3B%20if(value_mac0%20!%3D%200%20%26amp%3B%26amp%3B%20value_mac1%20!%3D%200)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%26nbsp%3B%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3Eotp_mac%5B5%5D%20%3D%20value_mac0%20%26amp%3B%200xff%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3Eotp_mac%5B4%5D%20%3D%20(value_mac0%20%26gt%3B%26gt%3B%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-sunglasses%22%20title%3D%22%3Asmiling_face_with_sunglasses%3A%22%3E%3C%2FLI-EMOJI%3E%20%26amp%3B%200xff%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3Eotp_mac%5B3%5D%20%3D%20(value_mac0%20%26gt%3B%26gt%3B%2016)%20%26amp%3B%200xff%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3Eotp_mac%5B2%5D%20%3D%20(value_mac0%20%26gt%3B%26gt%3B%2024)%20%26amp%3B%200xff%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3Eotp_mac%5B1%5D%20%3D%20value_mac1%20%26amp%3B%200xff%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3Eotp_mac%5B0%5D%20%3D%20(value_mac1%20%26gt%3B%26gt%3B%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-sunglasses%22%20title%3D%22%3Asmiling_face_with_sunglasses%3A%22%3E%3C%2FLI-EMOJI%3E%20%26amp%3B%200xff%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3Eprintk(%22otp_mac%3D%25pM%5Cn%22%2C%20otp_mac)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%26nbsp%3B%20%2F%2Fcheck%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%26nbsp%3B%20if%20(!is_valid_ether_addr(otp_mac))%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%26nbsp%3B%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%26nbsp%3B%20random_ether_addr(random_mac)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%26nbsp%3B%20printk(%22get%20random%20mac%3A%25pM%5Cn%22%2C%20random_mac)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%2F%2F%E6%94%BE%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%26nbsp%3B%20value_random_mac0%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%26nbsp%3B%20value_random_mac0%20%3D%20value_random_mac0%20%7C%20random_mac%5B2%5D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%26nbsp%3B%20value_random_mac0%20%3D%20(value_random_mac0%20%26lt%3B%26lt%3B%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-sunglasses%22%20title%3D%22%3Asmiling_face_with_sunglasses%3A%22%3E%3C%2FLI-EMOJI%3E%20%7C%20random_mac%5B3%5D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%26nbsp%3B%20value_random_mac0%20%3D%20(value_random_mac0%20%26lt%3B%26lt%3B%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-sunglasses%22%20title%3D%22%3Asmiling_face_with_sunglasses%3A%22%3E%3C%2FLI-EMOJI%3E%20%7C%20random_mac%5B4%5D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%26nbsp%3B%20value_random_mac0%20%3D%20(value_random_mac0%20%26lt%3B%26lt%3B%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-sunglasses%22%20title%3D%22%3Asmiling_face_with_sunglasses%3A%22%3E%3C%2FLI-EMOJI%3E%20%7C%20random_mac%5B5%5D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%26nbsp%3B%20value_random_mac1%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%26nbsp%3B%20value_random_mac1%20%3D%20value_random_mac1%20%7C%20random_mac%5B0%5D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%26nbsp%3B%20value_random_mac1%20%3D%20(value_random_mac1%20%26lt%3B%26lt%3B%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-sunglasses%22%20title%3D%22%3Asmiling_face_with_sunglasses%3A%22%3E%3C%2FLI-EMOJI%3E%20%7C%20random_mac%5B1%5D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%E4%BA%92%E6%96%A5%E9%94%81%EF%BC%88%26amp%3Botp_mutex%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%E5%A6%82%E6%9E%9C%EF%BC%88otp_write_prepare%EF%BC%88otp_data%EF%BC%89%EF%BC%89%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%E4%BA%92%E6%96%A5%E9%94%81%E8%A7%A3%E9%94%81%EF%BC%88%26amp%3Botp_mutex%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%26nbsp%3B%20return%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3Eotp_write_bits%EF%BC%88index_mac0%EF%BC%8Cvalue_random_mac0%EF%BC%8C0x3e77%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3Eotp_write_bits%EF%BC%88index_mac1%EF%BC%8Cvalue_random_mac1%EF%BC%8C0x3e77%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3Eotp_write_post%EF%BC%88otp_data%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%E4%BA%92%E6%96%A5%E9%94%81%E8%A7%A3%E9%94%81%EF%BC%88%26amp%3Botp_mutex%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%2F%2F%E7%BB%93%E5%B0%BE%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E3.%26nbsp%3B%20kernel_imx%2Fdrivers%2Fchar%2Ffsl_otp.c%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23505050%3B%22%3E----------------------------------------------------------------%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E9%9D%99%E6%80%81int%20__devinit%20fsl_otp_probe%EF%BC%88struct%20platform_device%20*pdev%EF%BC%89%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3E%26nbsp%3B%20...%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eretval%20%3D%20sysfs_create_group%EF%BC%88otp_kobj%EF%BC%8C%EF%BC%86attr_group%EF%BC%89%EF%BC%9B%3C%2FP%3E%3CP%3Eif%20(%E8%BF%94%E5%9B%9E%E5%80%BC)%3C%2FP%3E%3CP%3E%26nbsp%3B%20goto%20error%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Emutex_init%EF%BC%88%26amp%3Botp_mutex%EF%BC%89%EF%BC%9B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F%2F%E7%94%B1xxx%E6%B7%BB%E5%8A%A0%3C%2FP%3E%3CP%3E%26nbsp%3B%20%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3Echeck_otp_mac()%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%2F%2F%E7%BB%93%E5%B0%BE%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎07-07-2015 10:10 PM
更新人:
