GStreamer Miscellaneous
Dumping the pipeline elements into a image file
# On target, run the pipeline
$ export GST_DEBUG_DUMP_DOT_DIR=<folder where dot files are created>
$ gst-launch playbin2 uri=file://${avi}
$ # Move the .dot files to a host machine (scp, etc)
# On Host
# dot command is part the the graphviz package
Querying which elements are being used on a gst-launch commandGST_DEBUG=GST_ELEMENT_FACTORY:3 gst-launch playbin2 uri=file://`pwd`/<media file>
Interrupting a gst-launch process running in the background
kill -INT $PID
# where $PID is the process ID
Using only SW codecs
# Backup and remove
$ find /usr/lib/gstreamer-0.10 -name "libmfw*" | grep -v sink | xargs tar cvf /libmfw_gst.tar
$ find /usr/lib/gstreamer-0.10 -name "libmfw*" | grep -v sink | xargs rm
# Run your pipeline. This time SW codecs are used
$ gst-launch playbin2 uri=file://`pwd`/media_file
# To 'install' FSL plugins again, just untar the file
$ cd / && tar xvf libmfw_gst.tar && cd -
# then run your pipeline. This time HW codecs are used
标签 (2)
标记 (3)
评论
The instructions for 'Using only SW codecs' don't work for me.  I have a SabreSD board with i.MX6Q CPU and 4.0.0 version of the Linux SDK with patched ffmpeg plugins installed.  Here is my output:
root@freescale ~$ gst-launch playbin2 uri=file:///root/RecordedTs-coreel-720p5994.ts
Setting pipeline to PAUSED ...
Pipeline is PREROLLING ...
WARNING: from element /GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0: No decoder available for type 'video/mpegts, systemstream=(boolean)true, packetsize=(int)188'.
Additional debug info:
gsturidecodebin.c(867): unknown_type_cb (): /GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0
ERROR: from element /GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20: Your GStreamer installation is missing a plug-in.
gstdecodebin2.c(3233): gst_decode_bin_expose (): /GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20:
no suitable plugins found
ERROR: pipeline doesn't want to preroll.
Setting pipeline to NULL ...
Freeing pipeline ...
root@freescale ~$ gst-launch playbin2 uri=file:///root/sample_mpeg4.mp4
WARNING: from element /GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0: No decoder available for type 'audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)2, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)1290, rate=(int)32000, channels=(int)2'.
ERROR: from element /GstPlayBin2:playbin20/GstPlaySink:playsink0: The autovideosink element is not working.
gstplaysink.c(1353): gen_video_chain (): /GstPlayBin2:playbin20/GstPlaySink:playsink0
Try these steps:
rm .gstreamer-0.10/registry.arm.bin # this is done to force plugins reloading
gst-inspect | grep ff # To check if ffmpeg plugins are there
gst-launch playbin2 ....
Actually, you may need the Freescale video sinks, so do not move/remove these. Let me know if it works.
Leo
Ok, I removed all libmfw_* EXCEPT libmfw_gst_isink.so and libmfw_gst_v4lsink.so and that works. Thanks.
I have updated the recipe! Thanks!
Leo
%3CLINGO-SUB%20id%3D%22lingo-sub-1117877%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EGStreamer%20%E6%9D%82%E9%A1%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117877%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CTABLE%20border%3D%221%22%20class%3D%22jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23000000%3B%20width%3A%20100%25%3B%22%3E%3CTBODY%3E%3CTR%3E%3CTH%20style%3D%22text-align%3A%20center%3B%20background-color%3A%20%236690bc%3B%20color%3A%20%23ffffff%3B%20padding%3A%202px%3B%22%20valign%3D%22middle%22%3E%3C%2FTH%3E%3CTH%20style%3D%22text-align%3A%20center%3B%20background-color%3A%20%236690bc%3B%20color%3A%20%23ffffff%3B%20padding%3A%202px%3B%22%20valign%3D%22middle%22%3E%3C%2FTH%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E%3CSTRONG%3E%E5%B0%86%E7%AE%A1%E9%81%93%E5%85%83%E7%B4%A0%E8%BD%AC%E5%82%A8%E5%88%B0%E5%9B%BE%E5%83%8F%E6%96%87%E4%BB%B6%E4%B8%AD%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%23%20%E6%8C%89%E7%85%A7%E7%9B%AE%E6%A0%87%E8%BF%90%E8%A1%8C%E7%AE%A1%E9%81%93%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%24%20export%20GST_DEBUG_DUMP_DOT_DIR%3D%3CFOLDER%20where%3D%22%22%20dot%3D%22%22%20files%3D%22%22%20are%3D%22%22%20created%3D%22%22%3E%3C%2FFOLDER%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%24%20gst-launch%20playbin2%20uri%3Dfile%3A%2F%2F%20%24%7Bavi%7D%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%24%20%23%20%E7%A7%BB%E5%8A%A8%20.dot%E6%96%87%E4%BB%B6%E5%88%B0%E4%B8%BB%E6%9C%BA%EF%BC%88scp%20%E7%AD%89%EF%BC%89%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%3CBR%20style%3D%22color%3A%20%23000000%3B%22%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%23%20%E5%9C%A8%E4%B8%BB%E6%9C%BA%E4%B8%8A%20%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3Edot%20%3CDOT%20file%3D%22%22%3E%20-Tpng%20-o%20out.png%3C%2FDOT%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%23%20dot%20%E5%91%BD%E4%BB%A4%E6%98%AF%20graphviz%20%E5%8C%85%E7%9A%84%E4%B8%80%E9%83%A8%E5%88%86%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E%3CSTRONG%3E%E6%9F%A5%E8%AF%A2%20gst-launch%20%E5%91%BD%E4%BB%A4%E4%B8%AD%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E5%93%AA%E4%BA%9B%E5%85%83%E7%B4%A0%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3EGST_DEBUG%3DGST_ELEMENT_FACTORY%3A3%20gst-launch%20playbin2%20uri%3Dfile%3A%2F%2F%60pwd%60%2F%3CMEDIA%20file%3D%22%22%3E%3C%2FMEDIA%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E%3CSTRONG%3E%E4%B8%AD%E6%96%AD%E5%90%8E%E5%8F%B0%E8%BF%90%E8%A1%8C%E7%9A%84%20gst-launch%20%E8%BF%9B%E7%A8%8B%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%E6%9D%80%E6%AD%BB-INT%20%24PID%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%23%20%E5%85%B6%E4%B8%AD%20%24PID%20%E6%98%AF%E8%BF%9B%E7%A8%8B%20ID%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E%3CSTRONG%3E%E4%BB%85%E4%BD%BF%E7%94%A8%20SW%20%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%23%20%E5%A4%87%E4%BB%BD%E5%B9%B6%E5%88%A0%E9%99%A4%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%24%20%E6%9F%A5%E6%89%BE%20%2Fusr%2Flib%2Fgstreamer-0.10%20-name%20%22libmfw*%22%20%7C%20grep%20-v%20%E6%8E%A5%E6%94%B6%E5%99%A8%20%7C%20xargs%20tar%20cvf%20%2Flibmfw_gst.tar%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%24%20find%20%2Fusr%2Flib%2Fgstreamer-0.10%20-name%E2%80%9Clibmfw*%E2%80%9D%7C%20grep%20-v%20sink%20%7C%20xargs%20rm%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%23%20%E8%BF%90%E8%A1%8C%E4%BD%A0%E7%9A%84%E7%AE%A1%E9%81%93%E3%80%82%E8%BF%99%E6%AC%A1%E4%BD%BF%E7%94%A8%E4%BA%86%20SW%20%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%24%20gst-launch%20playbin2%20uri%3Dfile%3A%2F%2F%60pwd%60%2Fmedia_file%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%23%20%E8%A6%81%E5%86%8D%E6%AC%A1%E2%80%9C%E5%AE%89%E8%A3%85%E2%80%9DFSL%E6%8F%92%E4%BB%B6%EF%BC%8C%E5%8F%AA%E9%9C%80%E8%A7%A3%E5%8E%8B%E6%96%87%E4%BB%B6%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%24%20cd%20%2F%20%26amp%3B%26amp%3B%20tar%20xvf%20libmfw_gst.tar%20%26amp%3B%26amp%3B%20cd%20-%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%23%20%E7%84%B6%E5%90%8E%E8%BF%90%E8%A1%8C%E4%BD%A0%E7%9A%84%E7%AE%A1%E9%81%93%E3%80%82%E8%BF%99%E6%AC%A1%E4%BD%BF%E7%94%A8%E4%BA%86%E7%A1%AC%E4%BB%B6%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%24%20gst-launch%20playbin2%20uri%3Dfile%3A%2F%2F%60pwd%60%2Fmedia_file%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CSTRONG%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%3C%2FTD%3E%3CTD%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1117877%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX6_%E5%85%A8%E9%83%A8%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E5%A4%9A%E5%AA%92%E4%BD%93%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117882%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AGStreamer%20%E6%9D%82%E9%A1%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117882%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E6%9B%B4%E6%96%B0%E4%BA%86%E9%A3%9F%E8%B0%B1%EF%BC%81%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELeo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117881%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AGStreamer%20%E6%9D%82%E9%A1%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117881%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A5%BD%E7%9A%84%EF%BC%8C%E6%88%91%E5%88%A0%E9%99%A4%E4%BA%86%E6%89%80%E6%9C%89%20libmfw_*%EF%BC%8C%E9%99%A4%E4%BA%86%20libmfw_gst_isink.so%20%E5%92%8C%20libmfw_gst_v4lsink.so%EF%BC%8C%E8%BF%99%E6%A0%B7%E5%B0%B1%E5%8F%AF%E4%BB%A5%E4%BA%86%E3%80%82%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117880%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AGStreamer%20%E6%9D%82%E9%A1%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117880%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%AE%9E%E9%99%85%E4%B8%8A%EF%BC%8C%E6%82%A8%E5%8F%AF%E8%83%BD%E9%9C%80%E8%A6%81%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E8%A7%86%E9%A2%91%E6%8E%A5%E6%94%B6%E5%99%A8%EF%BC%8C%E5%9B%A0%E6%AD%A4%E8%AF%B7%E4%B8%8D%E8%A6%81%E7%A7%BB%E5%8A%A8%2F%E5%88%A0%E9%99%A4%E5%AE%83%E4%BB%AC%E3%80%82%E5%A6%82%E6%9E%9C%E6%9C%89%E6%95%88%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELeo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117879%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AGStreamer%20%E6%9D%82%E9%A1%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117879%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%AF%B7%E5%B0%9D%E8%AF%95%E4%BB%A5%E4%B8%8B%E6%AD%A5%E9%AA%A4%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3Erm%20.gstreamer-0.10%2Fregistry.arm.bin%20%23%20%E8%BF%99%E6%A0%B7%E5%81%9A%E6%98%AF%E4%B8%BA%E4%BA%86%E5%BC%BA%E5%88%B6%E6%8F%92%E4%BB%B6%E9%87%8D%E6%96%B0%E5%8A%A0%E8%BD%BD%3C%2FP%3E%0A%3CP%3Egst-inspect%20%7C%20grep%20ff%20%23%20%E6%A3%80%E6%9F%A5%20ffmpeg%20%E6%8F%92%E4%BB%B6%E6%98%AF%E5%90%A6%E5%AD%98%E5%9C%A8%3C%2FP%3E%0A%3CP%3Egst-%E5%90%AF%E5%8A%A8%20playbin2%20....%20%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117878%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AGStreamer%20%E6%9D%82%E9%A1%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117878%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E2%80%9C%E4%BB%85%E4%BD%BF%E7%94%A8%20SW%20%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%E2%80%9D%E7%9A%84%E8%AF%B4%E6%98%8E%E5%AF%B9%E6%88%91%E6%9D%A5%E8%AF%B4%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%E6%88%91%E6%9C%89%E4%B8%80%E5%9D%97%E5%B8%A6%E6%9C%89%20i.MX6Q%20CPU%20%E5%92%8C%204.0.0%20%E7%89%88%E6%9C%AC%E7%9A%84%20Linux%20SDK%20%E7%9A%84%20SabreSD%20%E6%9D%BF%EF%BC%8C%E5%85%B6%E4%B8%AD%E5%AE%89%E8%A3%85%E4%BA%86%E4%BF%AE%E8%A1%A5%E7%9A%84%20ffmpeg%20%E6%8F%92%E4%BB%B6%E3%80%82%E8%BF%99%E6%98%AF%E6%88%91%E7%9A%84%E8%BE%93%E5%87%BA%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eroot%40freescale%20~%24%20gst-launch%20playbin2%20uri%3Dfile%3A%2F%2F%2Froot%2FRecordedTs-coreel-720p5994.ts%3C%2FP%3E%3CP%3E%E5%B0%86%E7%AE%A1%E9%81%93%E8%AE%BE%E7%BD%AE%E4%B8%BA%E6%9A%82%E5%81%9C%E7%8A%B6%E6%80%81...%3C%2FP%3E%3CP%3E%E5%B0%86%E7%AE%A1%E9%81%93%E8%AE%BE%E7%BD%AE%E4%B8%BAPREROLLING...%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%EF%BC%9A%E6%9D%A5%E8%87%AA%E5%85%83%E7%B4%A0%2FGstPlayBin2%EF%BC%9Aplaybin20%2FGstURIDecodeBin%EF%BC%9Auridecodebin0%EF%BC%9A%E6%B2%A1%E6%9C%89%E5%8F%AF%E7%94%A8%E4%BA%8E%E7%B1%BB%E5%9E%8B%E2%80%9Cvideo%2Fmpegts%E3%80%81systemstream%3D(boolean)true%E3%80%81packetize%3D(int)188%E2%80%9D%E7%9A%84%E8%A7%A3%E7%A0%81%E5%99%A8%E3%80%82%3C%2FP%3E%3CP%3E%E9%99%84%E5%8A%A0%E8%B0%83%E8%AF%95%E4%BF%A1%E6%81%AF%EF%BC%9A%3C%2FP%3E%3CP%3Egsturidecodebin.c(867)%3A%20unknown_type_cb%20()%3A%20%2FGstPlayBin2%3Aplaybin20%2FGstURIDecodeBin%3Auridecodebin0%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E6%9D%A5%E8%87%AA%E5%85%83%E7%B4%A0%2FGstPlayBin2%EF%BC%9Aplaybin20%2FGstURIDecodeBin%EF%BC%9Auridecodebin0%2FGstDecodeBin2%EF%BC%9Adecodebin20%EF%BC%9A%E6%82%A8%E7%9A%84%20GStreamer%20%E5%AE%89%E8%A3%85%E7%BC%BA%E5%B0%91%E4%B8%80%E4%B8%AA%E6%8F%92%E4%BB%B6%E3%80%82%3C%2FP%3E%3CP%3E%E9%99%84%E5%8A%A0%E8%B0%83%E8%AF%95%E4%BF%A1%E6%81%AF%EF%BC%9A%3C%2FP%3E%3CP%3Egstdecodebin2.c(3233)%3A%20gst_decode_bin_expose()%3A%2FGstPlayBin2%3Aplaybin20%2FGstURIDecodeBin%3Auridecodebin0%2FGstDecodeBin2%3Adecodebin20%3A%3C%2FP%3E%3CP%3E%E6%9C%AA%E6%89%BE%E5%88%B0%E5%90%88%E9%80%82%E7%9A%84%E6%8F%92%E4%BB%B6%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E7%AE%A1%E9%81%93%E4%B8%8D%E6%83%B3%E9%A2%84%E5%8D%B7%E3%80%82%3C%2FP%3E%3CP%3E%E5%B0%86%E7%AE%A1%E9%81%93%E8%AE%BE%E7%BD%AE%E4%B8%BA%20NULL%20...%3C%2FP%3E%3CP%3E%E9%87%8A%E6%94%BE%E7%AE%A1%E9%81%93...%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eroot%40freescale%20~%24%20gst-launch%20playbin2%20uri%3Dfile%3A%2F%2F%2Froot%2Fsample_mpeg4.mp4%3C%2FP%3E%3CP%3E%E5%B0%86%E7%AE%A1%E9%81%93%E8%AE%BE%E7%BD%AE%E4%B8%BA%E6%9A%82%E5%81%9C%E7%8A%B6%E6%80%81...%3C%2FP%3E%3CP%3E%E5%B0%86%E7%AE%A1%E9%81%93%E8%AE%BE%E7%BD%AE%E4%B8%BAPREROLLING...%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%EF%BC%9A%E6%9D%A5%E8%87%AA%E5%85%83%E7%B4%A0%2FGstPlayBin2%EF%BC%9Aplaybin20%2FGstURIDecodeBin%EF%BC%9Auridecodebin0%EF%BC%9A%E6%B2%A1%E6%9C%89%E5%8F%AF%E7%94%A8%E4%BA%8E%E7%B1%BB%E5%9E%8B%E2%80%9Caudio%2Fmpeg%E3%80%81mpegversion%3D(int)4%E3%80%81framed%3D(boolean)true%E3%80%81stream-format%3D(string)raw%E3%80%81level%3D(string)2%E3%80%81base-profile%3D(string)lc%E3%80%81profile%3D(string)lc%E3%80%81codec_data%3D(buffer)1290%E3%80%81rate%3D(int)32000%E3%80%81channels%3D(int)2%E2%80%9D%E7%9A%84%E8%A7%A3%E7%A0%81%E5%99%A8%E3%80%82%3C%2FP%3E%3CP%3E%E9%99%84%E5%8A%A0%E8%B0%83%E8%AF%95%E4%BF%A1%E6%81%AF%EF%BC%9A%3C%2FP%3E%3CP%3Egsturidecodebin.c(867)%3A%20unknown_type_cb%20()%3A%20%2FGstPlayBin2%3Aplaybin20%2FGstURIDecodeBin%3Auridecodebin0%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E6%9D%A5%E8%87%AA%E5%85%83%E7%B4%A0%2FGstPlayBin2%EF%BC%9Aplaybin20%2FGstPlaySink%EF%BC%9Aplaysink0%EF%BC%9Aautovideosink%20%E5%85%83%E7%B4%A0%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%E9%99%84%E5%8A%A0%E8%B0%83%E8%AF%95%E4%BF%A1%E6%81%AF%EF%BC%9A%3C%2FP%3E%3CP%3Egstplaysink.c(1353)%3Agen_video_chain%EF%BC%88%EF%BC%89%EF%BC%9A%2FGstPlayBin2%3Aplaybin20%2FGstPlaySink%3Aplaysink0%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E7%AE%A1%E9%81%93%E4%B8%8D%E6%83%B3%E9%A2%84%E5%8D%B7%E3%80%82%3C%2FP%3E%3CP%3E%E5%B0%86%E7%AE%A1%E9%81%93%E8%AE%BE%E7%BD%AE%E4%B8%BA%20NULL%20...%3C%2FP%3E%3CP%3E%E9%87%8A%E6%94%BE%E7%AE%A1%E9%81%93...%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎09-28-2012 02:21 PM
更新人:
