Extending your Android app display
One of the features that many users have asked about but still is a work in progress for android, is the extended desktop capabilities. Currently android allows you to mirror your desktop in two displays, but you are still unable to extend your desktop like you would with any other OS like Linux or Windows.
This tutorial is intended to show you how to use a special object that allows you to control what should appear on a secondary or external display, replacing the screen mirroring.
So how do we do this?
A presentation is a container to display a user interface, in the form of a view hierarchy on an external display. This is pretty much like a Dialog since it displays its UI separated from its activity, but the difference is that the presentation shows in an external display while the dialog displays it in the primary screen. Now, because of this, the resources that are to be used by the UI on an external display are different then the resources used in the primary screen, the context of the presentation is NOT the activity.
How do we choose where to send this presentation?
The easiest way to do this is to use the MediaRouter API. What the mediarouter does is it keeps track of which audio and video routes are available on the system. The MediaRouter sends notifications whenever routes are selected or unselected. An application can simple watch for these notifications and show or dismiss a presentation on the preferred presentation display automatically.
The preferred presentation display is the display that the mediarouter recommends that the application should use if it wants to show content on the secondary display. IF there is not a preferred presentation display, the application should show its content locally without using a presentation.
Using the Mediarouter
The MediaRouter is a system service obtained by calling getSystemService() and asking for the MEDIA_ROUTER_SERVICE.
We should use the mediarouter to create and show a presentation on the preferred presentation display:
MediaRouter mediaRouter = (MediaRouter) context.getSystemService(Context.MEDIA_ROUTER_SERVICE);
MediaRouter.RouteInfo route = mediaRouter.getSelectedRoute();
if (route != null) {
Display presentationDisplay = route.getPresentationDisplay();
if (presentationDisplay != null) {
Presentation presentation = new MyPresentation(context, presentationDisplay);
presentation
.show();
In order to use this framework in your app, you need to get an instance of the MediaRouter framework object and attach a MediaRouter.Callback object to listen for event in available media routes.
The android apps that implement the media router API need to include a Cast button to allow users to select a media route to play media on a secondary output device. The recommended way to implement the Cast button  is to extend your activity from ActionBarActivity() and use the onCreateOptionMenu() method to add an options menu. The Cast button must use the MediaRouteActionProvider class as its action:
<?xml version="1.0" encoding="utf-8"?>
<menu xmlns:android="http://schemas.android.com/apk/res/android"
xmlns:app="http://schemas.android.com/apk/res-auto"
<item android:id="@+id/media_route_menu_item"
android:title="@string/media_route_menu_title"
app:actionProviderClass="android.support.v7.app.MediaRouteActionProvider"
app:showAsAction="always"
</menu>
The media router framework communicates with an app through a callback object that you attach to the mediarouter framework object.  Its necessary to extend the callback object in order to receive messages when a media route is connected.
Once your callback is defined for the media router,  you need to attach it to the media router object.  The following sample demonstrates how to use the lifecycle methos to appropriately add and remove your app’s media router callback object. You need to add and remove it because it needs to be free for whenever you close the app or have it in the background so other apps use it if necessary.
public class MediaRouterPlaybackActivity extends ActionBarActivity {
private MediaRouter mMediaRouter;
private MediaRouteSelector mSelector;
private Callback mMediaRouterCallback;
// your app works with so the framework can discover them.
@Override
protected void onCreate(Bundle savedInstanceState) {
super.onCreate(savedInstanceState);
setContentView
(R.layout.activity_main);
// Get the media router service.
mMediaRouter
= MediaRouter.getInstance(this);
// Add the callback on start to tell the media router what kinds of routes
@Override
public void onStart() {
mMediaRouter
.addCallback(mSelector, mMediaRouterCallback,
MediaRouter.CALLBACK_FLAG_REQUEST_DISCOVERY);
super.onStart();
// Remove the selector on stop to tell the media router that it no longer
// needs to discover routes for your app.
@Override
public void onStop() {
mMediaRouter
.removeCallback(mMediaRouterCallback);
super.onStop();
Remote playback
This approach sends control commands to a secondary device to initiate playback and to control the playback that is in progress (play, stop, fast-forward, rewind, etc). When your app supports this type of media route, you must need to create a RemotePlaybackClient boject using a remote playback MediaRoute.RouteInfo object received through your app’s MediaRouter.Callback object.
The following sample code demonstrates a controller method that creates a new remote playback cliente and sends it a video for playback.
private void updateRemotePlayer(RouteInfo route) {
// Changed route: tear down previous client
if (mRoute != null && mRemotePlaybackClient != null) {
.release();
= null;
// Save new route
mRoute
= route;
// Attach new playback client
= new RemotePlaybackClient(this, mRoute);
// Send file for playback
.play(Uri.parse(
"http://archive.org/download/Sintel/sintel-2048-stereo_512kb.mp4"),
"video/mp4", null, 0, null, new ItemActionCallback() {
@Override
public void onResult(Bundle data, String sessionId,
MediaSessionStatus sessionStatus,
String itemId, MediaItemStatus itemStatus) {
logStatus
("play: succeeded for item " + itemId);
@Override
public void onError(String error, int code, Bundle data) {
logStatus
("play: failed - error:"+ code +" - "+ error);
For more information on how to use the media router, you can visit developer.android.com
%3CLINGO-SUB%20id%3D%22lingo-sub-1122743%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EExtending%20your%20Android%20app%20display%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122743%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EOne%20of%20the%20features%20that%20many%20users%20have%20asked%20about%20but%20still%20is%20a%20work%20in%20progress%20for%20android%2C%20is%20the%20extended%20desktop%20capabilities.%20Currently%20android%20allows%20you%20to%20mirror%20your%20desktop%20in%20two%20displays%2C%20but%20you%20are%20still%20unable%20to%20extend%20your%20desktop%20like%20you%20would%20with%20any%20other%20OS%20like%20Linux%20or%20Windows.%3C%2FP%3E%3CP%3EThis%20tutorial%20is%20intended%20to%20show%20you%20how%20to%20use%20a%20special%20object%20that%20allows%20you%20to%20control%20what%20should%20appear%20on%20a%20secondary%20or%20external%20display%2C%20replacing%20the%20screen%20mirroring.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3ESo%20how%20do%20we%20do%20this%3F%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CBR%20%2F%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3EA%20presentation%20is%20a%20container%20to%20display%20a%20user%20interface%2C%20in%20the%20form%20of%20a%20view%20hierarchy%20on%20an%20external%20display.%20This%20is%20pretty%20much%20like%20a%20Dialog%20since%20it%20displays%20its%20UI%20separated%20from%20its%20activity%2C%20but%20the%20difference%20is%20that%20the%20presentation%20shows%20in%20an%20external%20display%20while%20the%20dialog%20displays%20it%20in%20the%20primary%20screen.%20Now%2C%20because%20of%20this%2C%20the%20resources%20that%20are%20to%20be%20used%20by%20the%20UI%20on%20an%20external%20display%20are%20different%20then%20the%20resources%20used%20in%20the%20primary%20screen%2C%20the%20context%20of%20the%20presentation%20is%20NOT%20the%20activity.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3EHow%20do%20we%20choose%20where%20to%20send%20this%20presentation%3F%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThe%20easiest%20way%20to%20do%20this%20is%20to%20use%20the%20MediaRouter%20API.%20What%20the%20mediarouter%20does%20is%20it%20keeps%20track%20of%20which%20audio%20and%20video%20routes%20are%20available%20on%20the%20system.%20The%20MediaRouter%20sends%20notifications%20whenever%20routes%20are%20selected%20or%20unselected.%20An%20application%20can%20simple%20watch%20for%20these%20notifications%20and%20show%20or%20dismiss%20a%20presentation%20on%20the%20preferred%20presentation%20display%20automatically.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThe%20preferred%20presentation%20display%20is%20the%20display%20that%20the%20mediarouter%20recommends%20that%20the%20application%20should%20use%20if%20it%20wants%20to%20show%20content%20on%20the%20secondary%20display.%20IF%20there%20is%20not%20a%20preferred%20presentation%20display%2C%20the%20application%20should%20show%20its%20content%20locally%20without%20using%20a%20presentation.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3EUsing%20the%20Mediarouter%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThe%20MediaRouter%20is%20a%20system%20service%20obtained%20by%20calling%20getSystemService()%20and%20asking%20for%20the%20MEDIA_ROUTER_SERVICE.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EWe%20should%20use%20the%20mediarouter%20to%20create%20and%20show%20a%20presentation%20on%20the%20preferred%20presentation%20display%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23660066%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CTABLE%20border%3D%221%22%20class%3D%22jiveBorder%22%20style%3D%22border%3A%201px%20solid%20rgb(0%2C%200%2C%200)%3B%20width%3A%20100%25%3B%22%3E%3CTBODY%3E%3CTR%3E%3CTH%20style%3D%22text-align%3A%20center%3B%20background-color%3A%20%236690bc%3B%20color%3A%20%23ffffff%3B%20padding%3A%202px%3B%22%20valign%3D%22middle%22%3E%3C%2FTH%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E%3CP%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23660066%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23660066%3B%22%3EMediaRouter%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%20mediaRouter%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23660066%3B%22%3EMediaRouter%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%20context%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3EgetSystemService%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23660066%3B%22%3EContext%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3EMEDIA_ROUTER_SERVICE%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E)%3B%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23660066%3B%22%3EMediaRouter%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23660066%3B%22%3ERouteInfo%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%20route%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%20mediaRouter%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3EgetSelectedRoute%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E()%3B%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3Eif%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3Eroute%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E!%3D%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3Enull%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E)%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%7B%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23660066%3B%22%3EDisplay%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%20presentationDisplay%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%20route%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3EgetPresentationDisplay%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E()%3B%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3Eif%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3EpresentationDisplay%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E!%3D%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3Enull%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E)%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%7B%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23660066%3B%22%3EPresentation%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%20presentation%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3Enew%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23660066%3B%22%3EMyPresentation%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3Econtext%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%20presentationDisplay%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E)%3B%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20presentation%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3Eshow%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E()%3B%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EIn%20order%20to%20use%20this%20framework%20in%20your%20app%2C%20you%20need%20to%20get%20an%20instance%20of%20the%20MediaRouter%20framework%20object%20and%20attach%20a%20MediaRouter.Callback%20object%20to%20listen%20for%20event%20in%20available%20media%20routes.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThe%20android%20apps%20that%20implement%20the%20media%20router%20API%20need%20to%20include%20a%20Cast%20button%20to%20allow%20users%20to%20select%20a%20media%20route%20to%20play%20media%20on%20a%20secondary%20output%20device.%20The%20recommended%20way%20to%20implement%20the%20Cast%20button%26nbsp%3B%20is%20to%20extend%20your%20activity%20from%20ActionBarActivity()%20and%20use%20the%20onCreateOptionMenu()%20method%20to%20add%20an%20options%20menu.%20The%20Cast%20button%20must%20use%20the%20MediaRouteActionProvider%20class%20as%20its%20action%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CTABLE%20border%3D%221%22%20class%3D%22jiveBorder%22%20style%3D%22border%3A%201px%20solid%20rgb(0%2C%200%2C%200)%3B%20width%3A%20100%25%3B%22%3E%3CTBODY%3E%3CTR%3E%3CTH%20style%3D%22text-align%3A%20center%3B%20background-color%3A%20%236690bc%3B%20color%3A%20%23ffffff%3B%20padding%3A%202px%3B%22%20valign%3D%22middle%22%3E%3C%2FTH%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E%3CP%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3Exml%20version%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23880000%3B%22%3E%221.0%22%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%20encoding%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23880000%3B%22%3E%22utf-8%22%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%3F%26gt%3B%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3E%3CMENU%3E%3C%2FMENU%3E%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23882288%3B%22%3Exmlns%3Aandroid%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23880000%3B%22%3E%3CSPAN%3E%22%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fschemas.android.com%2Fapk%2Fres%2Fandroid%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fschemas.android.com%2Fapk%2Fres%2Fandroid%3C%2FA%3E%3CSPAN%3E%22%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23882288%3B%22%3Exmlns%3Aapp%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23880000%3B%22%3E%3CSPAN%3E%22%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fschemas.android.com%2Fapk%2Fres-auto%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fschemas.android.com%2Fapk%2Fres-auto%3C%2FA%3E%3CSPAN%3E%22%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3E%3CITEM%3E%3C%2FITEM%3E%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23882288%3B%22%3Eandroid%3Aid%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23880000%3B%22%3E%22%40%2Bid%2Fmedia_route_menu_item%22%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23882288%3B%22%3Eandroid%3Atitle%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23880000%3B%22%3E%22%40string%2Fmedia_route_menu_title%22%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23882288%3B%22%3Eapp%3AactionProviderClass%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23880000%3B%22%3E%22android.support.v7.app.MediaRouteActionProvider%22%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23882288%3B%22%3Eapp%3AshowAsAction%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23880000%3B%22%3E%22always%22%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3E%2F%26gt%3B%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThe%20media%20router%20framework%20communicates%20with%20an%20app%20through%20a%20callback%20object%20that%20you%20attach%20to%20the%20mediarouter%20framework%20object.%26nbsp%3B%20Its%20necessary%20to%20extend%20the%20callback%20object%20in%20order%20to%20receive%20messages%20when%20a%20media%20route%20is%20connected.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EOnce%20your%20callback%20is%20defined%20for%20the%20media%20router%2C%26nbsp%3B%20you%20need%20to%20attach%20it%20to%20the%20media%20router%20object.%26nbsp%3B%20The%20following%20sample%20demonstrates%20how%20to%20use%20the%20lifecycle%20methos%20to%20appropriately%20add%20and%20remove%20your%20app%E2%80%99s%20media%20router%20callback%20object.%20You%20need%20to%20add%20and%20remove%20it%20because%20it%20needs%20to%20be%20free%20for%20whenever%20you%20close%20the%20app%20or%20have%20it%20in%20the%20background%20so%20other%20apps%20use%20it%20if%20necessary.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CTABLE%20border%3D%221%22%20class%3D%22jiveBorder%22%20style%3D%22border%3A%201px%20solid%20rgb(0%2C%200%2C%200)%3B%20width%3A%20100%25%3B%22%3E%3CTBODY%3E%3CTR%3E%3CTH%20style%3D%22text-align%3A%20center%3B%20background-color%3A%20%236690bc%3B%20color%3A%20%23ffffff%3B%20padding%3A%202px%3B%22%20valign%3D%22middle%22%3E%3C%2FTH%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E%3CP%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3Epublic%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3Eclass%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23660066%3B%22%3EMediaRouterPlaybackActivity%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3Eextends%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23660066%3B%22%3EActionBarActivity%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%7B%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3Eprivate%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23660066%3B%22%3EMediaRouter%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%20mMediaRouter%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%3B%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3Eprivate%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23660066%3B%22%3EMediaRouteSelector%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%20mSelector%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%3B%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3Eprivate%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23660066%3B%22%3ECallback%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%20mMediaRouterCallback%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%3B%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23006600%3B%22%3E%2F%2F%20your%20app%20works%20with%20so%20the%20framework%20can%20discover%20them.%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23006666%3B%22%3E%40Override%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3Eprotected%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3Evoid%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%20onCreate%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23660066%3B%22%3EBundle%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%20savedInstanceState%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E)%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%7B%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3Esuper%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3EonCreate%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3EsavedInstanceState%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E)%3B%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20setContentView%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3ER%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3Elayout%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3Eactivity_main%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E)%3B%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23006600%3B%22%3E%2F%2F%20Get%20the%20media%20router%20service.%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20mMediaRouter%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23660066%3B%22%3EMediaRouter%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3EgetInstance%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3Ethis%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E)%3B%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E...%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23006600%3B%22%3E%2F%2F%20Add%20the%20callback%20on%20start%20to%20tell%20the%20media%20router%20what%20kinds%20of%20routes%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23006600%3B%22%3E%2F%2F%20your%20app%20works%20with%20so%20the%20framework%20can%20discover%20them.%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23006666%3B%22%3E%40Override%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3Epublic%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3Evoid%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%20onStart%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E()%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%7B%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20mMediaRouter%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3EaddCallback%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3EmSelector%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%20mMediaRouterCallback%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23660066%3B%22%3EMediaRouter%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3ECALLBACK_FLAG_REQUEST_DISCOVERY%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E)%3B%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3Esuper%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3EonStart%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E()%3B%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23006600%3B%22%3E%2F%2F%20Remove%20the%20selector%20on%20stop%20to%20tell%20the%20media%20router%20that%20it%20no%20longer%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23006600%3B%22%3E%2F%2F%20needs%20to%20discover%20routes%20for%20your%20app.%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23006666%3B%22%3E%40Override%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3Epublic%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3Evoid%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%20onStop%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E()%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%7B%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20mMediaRouter%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3EremoveCallback%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3EmMediaRouterCallback%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E)%3B%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3Esuper%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3EonStop%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E()%3B%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E...%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3CSTRONG%3E%3CEM%3ERemote%20playback%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThis%20approach%20sends%20control%20commands%20to%20a%20secondary%20device%20to%20initiate%20playback%20and%20to%20control%20the%20playback%20that%20is%20in%20progress%20(play%2C%20stop%2C%20fast-forward%2C%20rewind%2C%20etc).%20When%20your%20app%20supports%20this%20type%20of%20media%20route%2C%20you%20must%20need%20to%20create%20a%20RemotePlaybackClient%20boject%20using%20a%20remote%20playback%20MediaRoute.RouteInfo%20object%20received%20through%20your%20app%E2%80%99s%20MediaRouter.Callback%20object.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThe%20following%20sample%20code%20demonstrates%20a%20controller%20method%20that%20creates%20a%20new%20remote%20playback%20cliente%20and%20sends%20it%20a%20video%20for%20playback.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CTABLE%20border%3D%221%22%20class%3D%22jiveBorder%22%20style%3D%22border%3A%201px%20solid%20rgb(0%2C%200%2C%200)%3B%20width%3A%20100%25%3B%22%3E%3CTBODY%3E%3CTR%3E%3CTH%20style%3D%22text-align%3A%20center%3B%20background-color%3A%20%236690bc%3B%20color%3A%20%23ffffff%3B%20padding%3A%202px%3B%22%20valign%3D%22middle%22%3E%3C%2FTH%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E%3CP%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3Eprivate%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3Evoid%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%20updateRemotePlayer%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23660066%3B%22%3ERouteInfo%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%20route%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E)%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%7B%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23006600%3B%22%3E%2F%2F%20Changed%20route%3A%20tear%20down%20previous%20client%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3Eif%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3EmRoute%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E!%3D%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3Enull%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%26amp%3B%26amp%3B%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%20mRemotePlaybackClient%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E!%3D%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3Enull%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E)%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%7B%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20mRemotePlaybackClient%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3Erelease%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E()%3B%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20mRemotePlaybackClient%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3Enull%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%3B%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23006600%3B%22%3E%2F%2F%20Save%20new%20route%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20mRoute%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%20route%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%3B%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23006600%3B%22%3E%2F%2F%20Attach%20new%20playback%20client%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20mRemotePlaybackClient%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3Enew%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23660066%3B%22%3ERemotePlaybackClient%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3Ethis%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%20mRoute%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E)%3B%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23006600%3B%22%3E%2F%2F%20Send%20file%20for%20playback%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20mRemotePlaybackClient%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3Eplay%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23660066%3B%22%3EUri%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3Eparse%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23880000%3B%22%3E%3CSPAN%3E%22%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Farchive.org%2Fdownload%2FSintel%2Fsintel-2048-stereo_512kb.mp4%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Farchive.org%2Fdownload%2FSintel%2Fsintel-2048-stereo_512kb.mp4%3C%2FA%3E%3CSPAN%3E%22%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E)%2C%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23880000%3B%22%3E%22video%2Fmp4%22%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3Enull%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23006666%3B%22%3E0%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3Enull%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3Enew%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23660066%3B%22%3EItemActionCallback%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E()%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%7B%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23006666%3B%22%3E%40Override%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3Epublic%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3Evoid%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%20onResult%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23660066%3B%22%3EBundle%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%20data%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23660066%3B%22%3EString%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%20sessionId%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23660066%3B%22%3EMediaSessionStatus%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%20sessionStatus%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23660066%3B%22%3EString%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%20itemId%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23660066%3B%22%3EMediaItemStatus%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%20itemStatus%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E)%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%7B%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20logStatus%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23880000%3B%22%3E%22play%3A%20succeeded%20for%20item%20%22%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%2B%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%20itemId%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E)%3B%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23006666%3B%22%3E%40Override%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3Epublic%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3Evoid%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%20onError%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23660066%3B%22%3EString%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%20error%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23000088%3B%22%3Eint%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%20code%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23660066%3B%22%3EBundle%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%20data%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E)%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%7B%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20logStatus%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23880000%3B%22%3E%22play%3A%20failed%20-%20error%3A%22%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%2B%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%20code%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%2B%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23880000%3B%22%3E%22%20-%20%22%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%2B%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%20error%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E)%3B%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%7D)%3B%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Courier%3B%20color%3A%20%23666600%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EFor%20more%20information%20on%20how%20to%20use%20the%20media%20router%2C%20you%20can%20visit%20developer.android.com%3C%2FP%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎03-23-2015 07:28 AM
Updated by:
