Enable Ethernet for Android Auto with mek_8q
Default Ethernet feature is removed for Android Auto (both Android_Pie9.0 and Android10)
Below are the patched to bring Ethernet feature back to Android Auto. Please try to apply the according patches if you want to enable Ethernet.
For Android_Pie9.0_Auto(example with car2 build):
--- a/arch/arm64/configs/android_car2_defconfig
+++b/arch/arm64/configs/android_car2_defconfig
@@ -245,7 +245,7 @@ CONFIG_DM_VERITY_FEC=y
CONFIG_NETDEVICES=y
CONFIG_MACVTAP=m
CONFIG_TUN=y
-# CONFIG_ETHERNET is not set
+CONFIG_ETHERNET=y
CONFIG_MDIO_BUS_MUX_MMIOREG=m
CONFIG_AT803X_PHY=m
CONFIG_MARVELL_PHY=m
@@ -517,7 +517,7 @@ CONFIG_SQUASHFS=y
CONFIG_SQUASHFS_DECOMP_MULTI=y
CONFIG_SQUASHFS_XATTR=y
CONFIG_SQUASHFS_LZ4=y
-# CONFIG_NETWORK_FILESYSTEMS is not set
+CONFIG_NETWORK_FILESYSTEMS=y
--- a/imx8q/mek_8q/mek_8q.mk
+++ b/imx8q/mek_8q/mek_8q.mk
@@ -46,6 +46,7 @@ PRODUCT_COPY_FILES += \
     $(IMX_DEVICE_PATH)/fstab.freescale.car:$(TARGET_COPY_OUT_VENDOR)/etc/fstab.freescale \
     $(IMX_DEVICE_PATH)/early.init_car.cfg:$(TARGET_COPY_OUT_VENDOR)/etc/early.init.cfg \
     $(IMX_DEVICE_PATH)/required_hardware_auto.xml:$(TARGET_COPY_OUT_VENDOR)/etc/permissions/required_hardware.xml \
+    frameworks/native/data/etc/android.hardware.ethernet.xml:$(TARGET_COPY_OUT_VENDOR)/etc/permissions/android.hardware.ethernet.xml \
     device/fsl/imx8q/init.recovery.freescale.car.rc:root/init.recovery.freescale.rc
For Android10_Auto,(example with car build):
--- a/arch/arm64/configs/android_car_defconfig
+++ b/arch/arm64/configs/android_car_defconfig
@@ -23,6 +23,8 @@ CONFIG_SCHED_AUTOGROUP=y
CONFIG_SCHED_TUNE=y
CONFIG_RELAY=y
CONFIG_BLK_DEV_INITRD=y
+CONFIG_FEC=y
+CONFIG_AT803X_PHY=y
# CONFIG_RD_BZIP2 is not set
# CONFIG_RD_LZMA is not set
# CONFIG_RD_XZ is not set
@@ -246,7 +248,6 @@ CONFIG_DM_VERITY=y
CONFIG_NETDEVICES=y
CONFIG_TUN=y
Note: Please also check for below file, if fec1 is disabled, please also apply below diff.
--- a/arch/arm64/boot/dts/freescale/imx8qm-mek-car2.dts
+++ b/arch/arm64/boot/dts/freescale/imx8qm-mek-car2.dts
@@ -147,10 +147,6 @@
status = "disabled";
-&fec1 {
- status = "disabled";
&fec2 {
添付
コメント
Hello Andy,
I applied the patch above, now I have the kernel printing eth messages and ifconfig shows eth0.
However, when I assign a static ip on a direct connection with a host, ping does not work, I get host unreachable.
If I connect to a router with DHCP server, it doesn't acquire an IP.
Are there other Android packages that needed to be installed to enable networking?
Thanks!
mek_8q:/ # dmesg | grep eth
[ 0.000000] psci: probing for conduit method from DT.
[ 1.062988] fec 5b040000.ethernet: 5b040000.ethernet supply phy not found, us ing dummy regulator
[ 1.088689] fec 5b040000.ethernet eth0: registered PHC device 0
[ 5.671765] using random self ethernet address
[ 5.676348] using random host ethernet address
[ 12.257932] Generic PHY 5b040000.ethernet-1:00: attached PHY driver [Generic PHY] (mii_bus:phy_addr=5b040000.ethernet-1:00, irq=POLL)
[ 12.270536] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 12.302364] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 12.465029] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 14.300010] fec 5b040000.ethernet eth0: Link is Up - 100Mbps/Full - flow cont rol rx/tx
[ 14.308841] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
I am also facing the same issue. Any findings?
Customer went a different route, I never received feedback on this.
Please reply here if you find anything.
Disabling ethernet by default in demo images make no sense. Without internet connection Android in most cases is useless.
Tested locally with android10_5.4.y mainline, the patches above will get ethernet working.
For static IP, there is a CL need to apply in frameworks/opt/net/ethernet.git
the patch is attached as  611749f.diff
I tried the build with Android 10.0.0_2.2.0 but had a weird error during the build:
my commands to build (after clean download of source, deleted android_build folder prior...)
  • cd ${MY_ANDROID}
  • source build/envsetup.sh
  • lunch mek_8q_car2-userdebug (i don't want M4 in this case... maybe that is the problem)
  • ./imx-make.sh -j16 (note i have 16 cores in my build machine)
from the community appnote, i also updated the following files per instructions in post (and no other files touched):
file:  mek_8q.mk
location: ./android_build/device/fsl/imx8q/mek_8q/mek_8q.mk
file:  imx_v8_android_car2_defconfig
location: ~/android_build/vendor/nxp-opensource/kernel_imx/arch/arm64/configs
I did not touch/modify any other file anywhere in the build.   should i have used the mek_8q_car2.mk file instead of mek_8q.mk from the community post?
The out folder is being generated but the errors are below.   Do I ignore or have I done something incorrect?
[ 99% 630/634] including vendor/nxp/imx_android_mm/CactusPlayer/Android.mk ...
[ 99% 631/634] including vendor/nxp/imx_android_mm/codec2/store/registry/Android.mk ...
[ 99% 632/634] including vendor/nxp/linux-firmware-imx/firmware/Android.mk ...
[ 99% 633/634] finishing build rules ...
platform_testing/build/tasks/tests/instrumentation_test_list.mk: warning: continuous_instrumentation_tests: Unknown installed file for module 'NexusLauncherOutOfProcTests'
platform_testing/build/tasks/tests/instrumentation_test_list.mk: warning: continuous_instrumentation_tests: Unknown installed file for module 'NexusLauncherDebug'
platform_testing/build/tasks/tests/instrumentation_test_list.mk: warning: continuous_instrumentation_tests: Unknown installed file for module 'NexusLauncherTests'
platform_testing/build/tasks/tests/platform_test_list.mk: warning: platform_tests: Unknown installed file for module 'LauncherRotationStressTest'
platform_testing/build/tasks/tests/platform_test_list.mk: warning: platform_tests: Unknown installed file for module 'PlatformScenarioTests'
[100% 634/634] writing build rules ...
FAILED:
device/fsl/imx8q/mek_8q/mek_8q.mk:512: error: writing to readonly directory: "device/fsl/imx8q/init.recovery.freescale.car.rc"
09:50:03 ckati failed with: exit status 1
#### failed to build some targets (08:26 (mm:ss)) ####
Andy, where are you applying the CL argument to ethernet.git?  what is the CL exactly you need to enter?  i've applied the patches, android 10 is up, but ifconfig (via adb shell) shows a dummy0 link (though that does look fully functional).  but i cannot access the network so i'm assuming android needs a static IP?   also under Kitchen Sink--> connectivity in android 10, i cannot find that the ethernet is enabled... previously on android10, if ethernet was working i'd see an IP address in that screen.
further investigation... i have my MEK attached to a network with full DHCP.  But i don't get an IP address (e.g. no eth0).   What i do get is a dummy0 connection (not sure if this is actually eth0...).  Second, under Kitchen Sink-->connectivity, i'd usually see the network there (via ethernet).
under adb shell:
kyle@kyle-System-Product-Name:~/android_build/out/target/product/mek_8q$ adb shell
mek_8q:/ $ su
mek_8q:/ # ifconfig
dummy0 Link encap:Ethernet HWaddr ba:e1:9e:2e:20:90
inet6 addr: fe80::b8e1:9eff:fe2e:2090/64 Scope: Link
UP BROADCAST RUNNING NOARP MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:10 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 TX bytes:700
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope: Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 TX bytes:0
mek_8q:/ #
mek_8q:/ # ping 192.168.1.1
connect: Network is unreachable
2|mek_8q:/ #
Hi fox,
Firstly, if you correctly apply the patch to kernel defconfig and device/fsl.git, you should be able to see eth0 interface with "ifconfig -a"  , not dummy0
And the CL 611749f.diff I attached is  to apply on frameworks/opt/net/ethernet.git , it's for static IP assign issue.
%3CLINGO-SUB%20id%3D%22lingo-sub-1100866%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Emek_8q%E3%81%A7%E3%82%A2%E3%83%B3%E3%83%89%E3%83%AD%E3%82%A4%E3%83%89%E3%82%AA%E3%83%BC%E3%83%88%E7%94%A8%E3%81%AE%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100866%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%3CSTRONG%3E%E3%82%A2%E3%83%B3%E3%83%89%E3%83%AD%E3%82%A4%E3%83%89%E3%82%AA%E3%83%BC%E3%83%88%EF%BC%88%E4%B8%A1%E6%96%B9%E3%81%A8%E3%82%82Android_Pie9.0%EF%BC%89%E3%81%A7%E3%81%AF%E3%80%81%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E6%A9%9F%E8%83%BD%E3%81%8C%E5%89%8A%E9%99%A4%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%A8Android10%EF%BC%89%3CBR%20%2F%3E%E4%BB%A5%E4%B8%8B%E3%81%AF%E3%80%81Android%20Auto%E3%81%AB%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E6%A9%9F%E8%83%BD%E3%82%92%E6%88%BB%E3%81%99%E3%81%9F%E3%82%81%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%A7%E3%81%99%E3%80%82%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%9F%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%9F%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%3CSTRONG%3E%E3%82%A2%E3%83%B3%E3%83%89%E3%83%AD%E3%82%A4%E3%83%89_Pie9.0_Auto%EF%BC%88%E3%82%AB%E3%83%BC2%E3%83%93%E3%83%AB%E3%83%89%E3%81%AE%E4%BE%8B%EF%BC%89%E3%81%AE%E5%A0%B4%E5%90%88%EF%BC%9A%3C%2FSTRONG%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%3CEM%3E---%20a%2Farch%2Farm64%2Fconfigs%2Fandroid_car2_defconfig%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%3CEM%3E%2B%2B%2Bb%2Farch%2Farm64%2Fconfigs%2Fandroid_car2_defconfig%20%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%40%40%20-245%2C7%20%2B245%2C7%20%40%40%20CONFIG_DM_VERITY_FEC%3Dy%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%E3%82%B3%E3%83%B3%E3%83%95%E3%82%A3%E3%82%B0_%E3%83%8D%E3%83%83%E3%83%88%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3DY%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3ECONFIG_MACVTAP%3Dm%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3ECONFIG_TUN%3Dy%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E-%23%20CONFIG_ETHERNET%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%2B%E3%82%B3%E3%83%B3%E3%83%95%E3%82%A3%E3%82%B0_%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%3DY%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3ECONFIG_MDIO_BUS_MUX_MMIOREG%3Dm%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3ECONFIG_AT803X_PHY%3D%E3%83%A1%E3%83%BC%E3%83%88%E3%83%AB%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%E3%82%B3%E3%83%B3%E3%83%95%E3%82%A3%E3%82%B0_%E3%83%9E%E3%83%BC%E3%83%99%E3%83%AB_PHY%3DM%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%40%40%20-517%2C7%20%2B517%2C7%20%40%40%20config_squashfs%3DY%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%E3%82%B3%E3%83%B3%E3%83%95%E3%82%A3%E3%82%B0_%E3%82%B9%E3%82%AB%E3%83%83%E3%82%B7%E3%83%A5FS_%E3%83%87%E3%82%B3%E3%83%B3%E3%83%97_%E3%83%9E%E3%83%AB%E3%83%81%3DY%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%E3%82%B3%E3%83%B3%E3%83%95%E3%82%A3%E3%82%B0_%E3%82%B9%E3%82%AB%E3%83%83%E3%82%B7%E3%83%A5FS_XATTR%3DY%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3ECONFIG_SQUASHFS_LZ4%3Dy%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E-%23%20CONFIG_%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF_%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%2B%E8%A8%AD%E5%AE%9A_%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF_%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3DY%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%3CEM%3E---%20a%2Fimx8q%2Fmek_8q%2Fmek_8q.mk%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%3CEM%3E%2B%2B%2B%20b%2Fimx8q%2Fmek_8q%2Fmek_8q.mk%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%40%40%20-46%2C6%20%2B46%2C7%20%40%40%20%E8%A3%BD%E5%93%81%E3%81%AE%E3%82%B3%E3%83%94%E3%83%BC%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%2B%3D%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%20%24(IMX_DEVICE_PATH)%2Ffstab.freescale.car%3A%24(TARGET_COPY_OUT_VENDOR)%2Fetc%2Ffstab.freescale%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%24%20(IMX_DEVICE_PATH)%20%2Fearly.init_car.cfg%3A%20%24%20(%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88_%E3%82%B3%E3%83%94%E3%83%BC_%E3%82%A2%E3%82%A6%E3%83%88_%E3%83%99%E3%83%B3%E3%83%80%E3%83%BC)%20%2Fetc%2Fearly.init.cfg%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%24%20(IMX_DEVICE_PATH)%20%2Frequired_hardware_auto.xml%3A%20%24%20(TARGET_COPY_OUT_VENDOR)%20%2Fetc%2Fpermissions%2Frequired_hardware.xml%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%2B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%20frameworks%2Fnative%2Fdata%2Fetc%2Fandroid.hardware.ethernet.xml%3A%24(TARGET_COPY_OUT_VENDOR)%2Fetc%2Fpermissions%2Fandroid.hardware.ethernet.xml%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%20device%2Ffsl%2Fimx8q%2Finit.recovery.freescale.car.rc%3Aroot%2Finit.recovery.freescale.rc%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%3CSTRONG%3E%E3%82%A2%E3%83%B3%E3%83%89%E3%83%AD%E3%82%A4%E3%83%8910_Auto%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%EF%BC%88%E8%BB%8A%E3%82%92%E4%BD%9C%E3%81%A3%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AE%E4%BE%8B%EF%BC%89%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%3CEM%3E---%20a%2Farch%2Farm64%2Fconfigs%2Fandroid_car_defconfig%20%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%3CEM%3E%2B%2B%2B%20b%2Farch%2Farm64%2Fconfigs%2Fandroid_car_defconfig%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%40%40%20-23%2C6%20%2B23%2C8%20%40%40%20config_sched_autogroup%3DY%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3ECONFIG_SCHED_TUNE%3Dy%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%E3%82%B3%E3%83%B3%E3%83%95%E3%82%A3%E3%82%B0_%E3%83%AA%E3%83%AC%E3%83%BC%3DY%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3Econfig_blk_dev_initrd%3DY%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%2BCONFIG_FEC%3Dy%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%2Bconfig_at803X_PHY%3DY%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%23%20%E3%82%B3%E3%83%B3%E3%83%95%E3%82%A3%E3%82%B0_RD_BZIP2%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%23%20%E3%82%B3%E3%83%B3%E3%83%95%E3%82%A3%E3%82%B0_RD_LZMA%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%23%20CONFIG_RD_XZ%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%40%40%20-246%2C7%20%2B248%2C6%20%40%40%20CONFIG_DM_VERITY%3Dy%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3ECONFIG_DM_VERITY_FEC%3Dy%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%E3%82%B3%E3%83%B3%E3%83%95%E3%82%A3%E3%82%B0_%E3%83%8D%E3%83%83%E3%83%88%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3DY%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3ECONFIG_TUN%3Dy%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E-%23%20CONFIG_ETHERNET%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%3CEM%3E%26nbsp%3B%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%3CEM%3E---%20a%2Fimx8q%2Fmek_8q%2Fmek_8q.mk%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%3CEM%3E%2B%2B%2B%20b%2Fimx8q%2Fmek_8q%2Fmek_8q.mk%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%40%40%20-46%2C6%20%2B46%2C7%20%40%40%20%E8%A3%BD%E5%93%81%E3%81%AE%E3%82%B3%E3%83%94%E3%83%BC%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%2B%3D%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%20%24(IMX_DEVICE_PATH)%2Ffstab.freescale.car%3A%24(TARGET_COPY_OUT_VENDOR)%2Fetc%2Ffstab.freescale%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%24%20(IMX_DEVICE_PATH)%20%2Fearly.init_car.cfg%3A%20%24%20(%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88_%E3%82%B3%E3%83%94%E3%83%BC_%E3%82%A2%E3%82%A6%E3%83%88_%E3%83%99%E3%83%B3%E3%83%80%E3%83%BC)%20%2Fetc%2Fearly.init.cfg%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%24%20(IMX_DEVICE_PATH)%20%2Frequired_hardware_auto.xml%3A%20%24%20(TARGET_COPY_OUT_VENDOR)%20%2Fetc%2Fpermissions%2Frequired_hardware.xml%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%2B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%20frameworks%2Fnative%2Fdata%2Fetc%2Fandroid.hardware.ethernet.xml%3A%24(TARGET_COPY_OUT_VENDOR)%2Fetc%2Fpermissions%2Fandroid.hardware.ethernet.xml%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%20device%2Ffsl%2Fimx8q%2Finit.recovery.freescale.car.rc%3Aroot%2Finit.recovery.freescale.rc%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22font-size%3A%2010.5pt%3B%20%22%3E%E6%B3%A8%EF%BC%9A%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%82%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82fec1%E3%81%8C%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AEdiff%E3%82%82%E9%81%A9%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E---a%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescal%2Fimx8qm-mek-car2.dts%20%3CBR%20%2F%3E%2B%2B%2B%20b%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescal%2Fimx8qm-mek-car2.dts%20%3CBR%20%2F%3E%40%40%20-147%2C10%20%2B147%2C6%20%40%40%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%3CBR%20%2F%3E%20%22%20%E7%84%A1%E5%8A%B9%20%22%3B%7D%3B%20%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E-%26amp%3B%20fec1%20%7B%3CBR%20%2F%3E-%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%20%E7%84%A1%E5%8A%B9%20%22%3B%20%3CBR%20%2F%3E-%7D%3B%20%3CBR%20%2F%3E-%3CBR%20%2F%3E%20%26amp%3B%20fec2%20%7B%3CBR%20%2F%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%20%E7%84%A1%E5%8A%B9%20%22%3B%3CBR%20%2F%3E%7D%3B%3C%2FP%3E%3CDIV%20style%3D%22position%3A%20absolute%3B%20left%3A%20546px%3B%20top%3A%201536.6px%3B%22%3E%3CDIV%20class%3D%22gtx-trans-icon%22%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1100866%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAndroid%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX%208%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%20%7C%20i.MX%208QuadMax%E2%80%AF(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100876%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20mek_8q%E3%81%A7%E3%82%A2%E3%83%B3%E3%83%89%E3%83%AD%E3%82%A4%E3%83%89%E3%82%AA%E3%83%BC%E3%83%88%E7%94%A8%E3%81%AE%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100876%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20fox%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9A%E3%80%81%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%ABdefconfig%E3%81%A8device%2Ffsl.git%E3%81%AB%E6%AD%A3%E3%81%97%E3%81%8F%E9%81%A9%E7%94%A8%E3%81%99%E3%82%8C%E3%81%B0%E3%80%81%3CSTRONG%3Eeth0%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%E3%82%B9%E3%81%AF%E3%80%81dummy0%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%3C%2FSTRONG%3E%20%22%20ifconfig-a%20%22%20%E3%81%A7%E8%A6%8B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E7%A7%81%E3%81%8C%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%9FCL%20%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E611749f.diff%E3%81%AF%3C%2FSPAN%3E%E3%80%81%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AF%E3%83%BC%E3%82%AF%2Fopt%2Fnet%2Fethernet.git%E3%81%AB%E9%81%A9%E7%94%A8%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%E9%9D%99%E7%9A%84IP%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100875%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20mek_8q%E3%81%A7%E3%82%A2%E3%83%B3%E3%83%89%E3%83%AD%E3%82%A4%E3%83%89%E3%82%AA%E3%83%BC%E3%83%88%E7%94%A8%E3%81%AE%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100875%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%95%E3%82%89%E3%81%AB%E8%AA%BF%E6%9F%BB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84...%20MEK%E3%82%92%E5%AE%8C%E5%85%A8%E3%81%AADHCP%E3%81%AE%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81IP%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%EF%BC%88%E4%BE%8B%E3%81%88%E3%81%B0%E3%81%84%E3%81%84%E3%81%88%E3%80%81eth0)%E3%80%82%E7%A7%81%E3%81%8C%E5%BE%97%E3%82%8B%E3%81%AE%E3%81%AF%E3%83%80%E3%83%9F%E3%83%BC0%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%99%EF%BC%88%E3%81%93%E3%82%8C%E3%81%8C%E5%AE%9F%E9%9A%9B%E3%81%ABeth0%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93...%EF%BC%89%E3%80%82%E6%AC%A1%E3%81%AB%E3%80%81%E3%82%AD%E3%83%83%E3%83%81%E3%83%B3%E3%82%B7%E3%83%B3%E3%82%AF--%26gt%3B%20%E6%8E%A5%E7%B6%9A%E3%81%AE%E4%B8%8B%E3%81%AB%E3%81%AF%E3%80%81%E9%80%9A%E5%B8%B8%E3%80%81%E3%81%9D%E3%81%93%E3%81%AB%EF%BC%88%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E7%B5%8C%E7%94%B1%E3%81%A7%EF%BC%89%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eadb%E3%82%B7%E3%82%A7%E3%83%AB%E3%81%AE%E4%B8%8B%E3%81%A7%EF%BC%9A%3C%2FP%3E%3CP%3E%E3%82%AB%E3%82%A4%E3%83%AB%20%3Ca%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F35979%22%3E%40Kyle%3C%2Fa%3E-%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0-%E8%A3%BD%E5%93%81%E5%90%8D%3A~%2Fandroid_build%2Fout%2Ftarget%2Fproduct%2Fmek_8q%24%20adb%20shell%20mek_8q%3A%2F%24%20su%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20mek_8q%3A%2F%23%20ifconfig%20%3CBR%20%2F%3E%20dummy0%20%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%A8%E3%83%B3%E3%82%AD%E3%83%A3%E3%83%83%E3%83%97%3A%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%99%E3%83%BC%E3%82%B9%3A1%3A9%20e%3A%202e%3A%2020%3A90%20inet6%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3Afe80%3A%3A%20b8e%201%3A9%20eff%3A%20fe9%202e%3A%202090%2F64%20%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%97%3A%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%83%96%E3%83%AD%E3%83%BC%E3%83%89%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%E3%83%A9%E3%83%B3%E3%83%8B%E3%83%B3%E3%82%B0%20NOARP%20MTU%3A%201500%20%E3%83%A1%E3%83%88%E3%83%AA%E3%83%83%E3%82%AF%3A1%20RX%20%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%3A0%20%E3%82%A8%E3%83%A9%E3%83%BC%3A0%20%E3%82%A8%E3%83%A9%E3%83%BC%3A0%20%E3%82%A8%E3%83%A9%E3%83%BC%3A0%20%E3%82%A8%E3%83%A9%E3%83%BC%3A0%20%E3%83%89%E3%83%AD%E3%83%83%E3%83%97%3A0%20%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%A9%E3%83%B3%3A0%20%E3%82%AD%E3%83%A3%E3%83%AA%E3%82%A2%3A0%20%E8%A1%9D%E7%AA%81%3A0%20TX%E3%82%AD%E3%83%A5%E3%83%BC%E3%82%A8%E3%83%AC%E3%83%B3%3A1000%20RX%20%E3%83%90%E3%82%A4%E3%83%88%3A0%20TX%20%E3%83%90%E3%82%A4%E3%83%88%3A700%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E3%83%AD%E3%82%B0%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%A8%E3%83%B3%E3%82%AD%E3%83%A3%E3%83%83%E3%83%97%3A%3CBR%20%2F%3E%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E3%83%AB%E3%83%BC%E3%83%97%E3%83%90%E3%83%83%E3%82%AF%E3%82%A4%E3%83%B3%E3%83%AC%E3%83%83%E3%83%88%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A127.0.0.1%20%E3%83%9E%E3%82%B9%E3%82%AF%3A255.0.0.0%20%3CBR%20%2F%3E%20inet6%20addr%3A%3A%201%2F128%20%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%97%3AMTU%20%E3%82%92%E5%AE%9F%E8%A1%8C%E4%B8%AD%E3%81%AE%E3%83%9B%E3%82%B9%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%3A65536%20%E3%83%A1%E3%83%88%E3%83%AA%E3%83%83%E3%82%AF%3A1%20RX%20%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%3A0%20%E3%82%A8%E3%83%A9%E3%83%BC%3A0%20%E3%82%A8%E3%83%A9%E3%83%BC%3A0%20%E3%83%89%E3%83%AD%E3%83%83%E3%83%97%3A0%20%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%A9%E3%83%B3%3A0%20%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%A9%E3%83%B3%3A0%20%E3%82%AD%E3%83%A3%E3%83%AA%E3%82%A2%3A0%20%E8%A1%9D%E7%AA%81%3A0%20TX%E3%82%AD%E3%83%A5%E3%83%BC%E3%82%A8%E3%83%AC%E3%83%B3%3A1000%20RX%E3%83%90%E3%82%A4%E3%83%88%3A0%20TX%E3%83%90%E3%82%A4%E3%83%88%3A0%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3C%2FP%3E%3CP%3Emek_8q%3A%2F%20%23%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Emek_8q%3A%2F%23%20ping%20192.168.1.1%20%3CBR%20%2F%3E%E6%8E%A5%E7%B6%9A%3A%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%20%3CBR%20%2F%3E%202%7Cmek_8q%3A%2F%23%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100874%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20mek_8q%E3%81%A7%E3%82%A2%E3%83%B3%E3%83%89%E3%83%AD%E3%82%A4%E3%83%89%E3%82%AA%E3%83%BC%E3%83%88%E7%94%A8%E3%81%AE%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100874%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%A2%E3%83%B3%E3%83%87%E3%82%A3%E3%80%81%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88.git%E3%81%AE%E3%81%A9%E3%81%93%E3%81%A7CL%E5%BC%95%E6%95%B0%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E6%AD%A3%E7%A2%BA%E3%81%AB%E5%85%A5%E5%8A%9B%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8BCL%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%A2%E3%83%B3%E3%83%89%E3%83%AD%E3%82%A4%E3%83%8910%E3%81%AF%E7%A8%BC%E5%83%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81ifconfig%EF%BC%88adb%E3%82%B7%E3%82%A7%E3%83%AB%E7%B5%8C%E7%94%B1%EF%BC%89%E3%81%AB%E3%83%80%E3%83%9F%E3%83%BC0%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%EF%BC%88%E5%AE%8C%E5%85%A8%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A6%8B%E3%81%88%E3%81%BE%E3%81%99%E3%81%8C%EF%BC%89%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%A7%81%E3%81%AF%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%80%81%E3%82%A2%E3%83%B3%E3%83%89%E3%83%AD%E3%82%A4%E3%83%89%E3%81%AB%E3%81%AF%E9%9D%99%E7%9A%84IP%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%81%BE%E3%81%9F%E3%80%81Android%2010%E3%81%AEKitchen%20Sink--%26gt%3B%20%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%80%81%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93...%20%E4%BB%A5%E5%89%8D%E3%81%AEandroid10%E3%81%A7%E3%81%AF%E3%80%81%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8C%E3%81%B0%E3%80%81%E3%81%9D%E3%81%AE%E7%94%BB%E9%9D%A2%E3%81%ABIP%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100873%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20mek_8q%E3%81%A7%E3%82%A2%E3%83%B3%E3%83%89%E3%83%AD%E3%82%A4%E3%83%89%E3%82%AA%E3%83%BC%E3%83%88%E7%94%A8%E3%81%AE%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100873%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EAndroid%2010.0.0_2.2.0%E3%81%A7%E3%83%93%E3%83%AB%E3%83%89%E3%82%92%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%E4%B8%AD%E3%81%AB%E5%A5%87%E5%A6%99%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E7%A7%81%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%EF%BC%88%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E5%89%8D%E3%81%ABandroid_build%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F...%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%20style%3D%22color%3A%20black%3B%22%3Ecd%20%24%7BMY_ANDROID%7D%3C%2FLI%3E%3CLI%20style%3D%22color%3A%20black%3B%22%3E%E3%82%BD%E3%83%BC%E3%82%B9%20build%2Fenvsetup.sh%3C%2FLI%3E%3CLI%20style%3D%22color%3A%20black%3B%22%3Elunch%20mek_8q_car2-userdebug%EF%BC%88%E3%81%93%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81M4%E3%81%AF%E6%AC%B2%E3%81%97%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93...%20%E5%A4%9A%E5%88%86%E3%81%9D%E3%82%8C%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%99%EF%BC%89%3C%2FLI%3E%3CLI%20style%3D%22color%3A%20black%3B%22%3E%E3%80%82%2Fimx-make.sh-j16%EF%BC%88%E7%A7%81%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%AB%E3%81%AF16%E3%82%B3%E3%82%A2%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%EF%BC%89%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%82%A2%E3%83%97%E3%83%AA%E3%83%8E%E3%83%BC%E3%83%88%E3%81%8B%E3%82%89%E3%80%81%E6%8A%95%E7%A8%BF%E3%81%AE%E6%8C%87%E7%A4%BA%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E6%AC%A1%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%82%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%88%E4%BB%96%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%81%AF%E8%A7%A6%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%EF%BC%89%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3Efile%3A%26nbsp%3B%20mek_8q.mk%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3Elocation%3A%26nbsp%3B.%2Fandroid_build%2Fdevice%2Ffsl%2Fimx8q%2Fmek_8q%2Fmek_8q.mk%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3Efile%3A%26nbsp%3B%26nbsp%3B%3CSPAN%20style%3D%22background%3A%20white%3B%22%3Eimx_v8_android_car2_defconfig%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E5%A0%B4%E6%89%80%3A%3CSPAN%20style%3D%22background%3A%20white%3B%22%3E~%2Fandroid_build%2Fvendor%2Fnxp-opensource%2Fkernel_imx%2Farch%2Farm64%2Fconfigs%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E3%83%93%E3%83%AB%E3%83%89%E3%81%AE%E3%81%A9%E3%81%93%E3%81%AB%E3%82%82%E4%BB%96%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E8%A7%A6%E3%82%8C%E3%81%9F%E3%82%8A%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%9F%E3%82%8A%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E6%8A%95%E7%A8%BF%E3%81%AEmek_8q.mk%E3%81%AE%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%ABmek_8q_car2.mk%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%B9%E3%81%8D%E3%81%A0%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3Eout%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AF%E7%94%9F%E6%88%90%E4%B8%AD%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%E7%84%A1%E8%A6%96%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E4%BD%95%E3%81%8B%E9%96%93%E9%81%95%E3%81%A3%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5B99%25%20630%2F634%5D%20%E3%83%99%E3%83%B3%E3%83%80%E3%83%BC%2FNXP%2FIMX_android_MM%2FCactusPlayer%2Fandroid.mk%E3%82%92%E5%90%AB%E3%82%80...%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5B99%25%20631%2F634%5D%20%E3%83%99%E3%83%B3%E3%83%80%E3%83%BC%2FNXP%2FIMX_android_MM%2Fcodec2%2FStore%2F%E3%83%AC%E3%82%B8%E3%82%B9%E3%83%88%E3%83%AA%2FAndroid.mk%E3%82%92%E5%90%AB%E3%81%BF%E3%81%BE%E3%81%99...%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5B99%25%20632%2F634%5D%20%E3%83%99%E3%83%B3%E3%83%80%E3%83%BC%2FNXP%2FLinux%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2-IMX%2F%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%2FAndroid.mk%E3%82%92%E5%90%AB%E3%82%80...%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5B99%25%20633%2F634%5D%20%E3%83%93%E3%83%AB%E3%83%89%E3%83%AB%E3%83%BC%E3%83%AB%E3%82%92%E7%B5%82%E4%BA%86%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3Eplatform_testing%2Fbuild%2Ftasks%2Ftest%2Finstrumentation_test_list.mk%3A%20%E8%AD%A6%E5%91%8A%3Acontinuous_instrumentation_tests%3A%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%20'NexusLauncherOutOfProcTests'%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E4%B8%8D%E6%98%8E%E3%81%A7%E3%81%99%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0_%E3%83%86%E3%82%B9%E3%83%88%2F%E3%83%93%E3%83%AB%E3%83%89%2F%E3%82%BF%E3%82%B9%E3%82%AF%2F%E3%83%86%E3%82%B9%E3%83%88%2F%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%82%A5%E3%83%AB%E3%83%A1%E3%83%B3%E3%83%86%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3_%E3%83%86%E3%82%B9%E3%83%88_list.mk%3A%20%E8%AD%A6%E5%91%8A%3Acontinuous_instrumentation_tests%3A%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%20'NexusLauncherDebug'%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E4%B8%8D%E6%98%8E%E3%81%A7%E3%81%99%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0_%E3%83%86%E3%82%B9%E3%83%88%2F%E3%83%93%E3%83%AB%E3%83%89%2F%E3%82%BF%E3%82%B9%E3%82%AF%2F%E3%83%86%E3%82%B9%E3%83%88%2F%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%82%A5%E3%83%AB%E3%83%A1%E3%83%B3%E3%83%86%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3_%E3%83%86%E3%82%B9%E3%83%88_list.mk%3A%20%E8%AD%A6%E5%91%8A%3Acontinuous_instrumentation_tests%3A%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%20'NexusLauncherTests'%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E4%B8%8D%E6%98%8E%E3%81%A7%E3%81%99%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3Eplatform_testing%2Fbuild%2Ftasks%2Ftests%2Fplatform_test_list.mk%3A%20%E8%AD%A6%E5%91%8A%3Aplatform_tests%3A%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%8CLauncherRotationStress%20Test%E3%80%8D%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E4%B8%8D%E6%98%8E%E3%81%A7%E3%81%99%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3Eplatform_testing%2Fbuild%2Ftasks%2Ftests%2Fplatform_test_list.mk%3A%20%E8%AD%A6%E5%91%8A%3Aplatform_tests%3A%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%20'PlatformScenarioTests'%20%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E4%B8%8D%E6%98%8E%E3%81%A7%E3%81%99%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5B100%25%20634%2F634%5D%20%E3%83%93%E3%83%AB%E3%83%89%E3%83%AB%E3%83%BC%E3%83%AB%E3%82%92%E6%9B%B8%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%2Ffsl%2Fimx8q%2Fmek_8q_8q.mk%3A%20512%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E5%B0%82%E7%94%A8%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%B8%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%3A%22%20device%2Ffsl%2Fimx8q%2Finit.recovery.freescale.car.rc%20%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E09%3A50%3A03%20ckati%E3%81%8C%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%E7%B5%82%E4%BA%86%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%201%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E%23%23%23%23%20failed%20to%20build%20some%20targets%20(08%3A26%20(mm%3Ass))%20%23%23%23%23%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100872%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20mek_8q%E3%81%A7%E3%82%A2%E3%83%B3%E3%83%89%E3%83%AD%E3%82%A4%E3%83%89%E3%82%AA%E3%83%BC%E3%83%88%E7%94%A8%E3%81%AE%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100872%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%91%E3%83%83%E3%83%81%E3%81%AF611749f.diff%E3%81%A8%E3%81%97%E3%81%A6%E6%B7%BB%E4%BB%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100871%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20mek_8q%E3%81%A7%E3%82%A2%E3%83%B3%E3%83%89%E3%83%AD%E3%82%A4%E3%83%89%E3%82%AA%E3%83%BC%E3%83%88%E7%94%A8%E3%81%AE%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100871%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Eandroid10_5.4.y%E3%81%AE%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%A7%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E4%B8%8A%E8%A8%98%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%A7%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%81%8C%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E9%9D%99%E7%9A%84IP%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AF%E3%83%BC%E3%82%AF%2Fopt%2Fnet%2Fethernet.git%E3%81%ABCL%E3%82%92%E9%81%A9%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100870%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20mek_8q%E3%81%A7%E3%82%A2%E3%83%B3%E3%83%89%E3%83%AD%E3%82%A4%E3%83%89%E3%82%AA%E3%83%BC%E3%83%88%E7%94%A8%E3%81%AE%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100870%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%87%E3%83%A2%E7%94%BB%E5%83%8F%E3%81%A7%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%92%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%A6%E3%82%82%E6%84%8F%E5%91%B3%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%8D%E3%83%83%E3%83%88%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%A8%E3%80%81%E3%81%BB%E3%81%A8%E3%82%93%E3%81%A9%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81Android%E3%81%AF%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100869%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20mek_8q%E3%81%A7%E3%82%A2%E3%83%B3%E3%83%89%E3%83%AD%E3%82%A4%E3%83%89%E3%82%AA%E3%83%BC%E3%83%88%E7%94%A8%E3%81%AE%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100869%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E5%88%A5%E3%81%AE%E3%83%AB%E3%83%BC%E3%83%88%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%83%95%E3%82%A3%E3%83%BC%E3%83%89%E3%83%90%E3%83%83%E3%82%AF%E3%81%AF%E5%8F%97%E3%81%91%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%95%E3%81%8B%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%E3%82%89%E3%81%93%E3%81%A1%E3%82%89%E3%81%8B%E3%82%89%E8%BF%94%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100868%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20mek_8q%E3%81%A7%E3%82%A2%E3%83%B3%E3%83%89%E3%83%AD%E3%82%A4%E3%83%89%E3%82%AA%E3%83%BC%E3%83%88%E7%94%A8%E3%81%AE%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100868%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%82%82%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%AB%E7%9B%B4%E9%9D%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E4%BD%95%E3%81%8B%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100867%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20mek_8q%E3%81%A7%E3%82%A2%E3%83%B3%E3%83%89%E3%83%AD%E3%82%A4%E3%83%89%E3%82%AA%E3%83%BC%E3%83%88%E7%94%A8%E3%81%AE%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100867%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%20Andy%2C%3C%2FP%3E%3CP%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%8Ceth%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E5%87%BA%E5%8A%9B%E3%81%97%E3%80%81ifconfig%E3%81%ABeth0%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%83%9B%E3%82%B9%E3%83%88%E3%81%A8%E3%81%AE%E7%9B%B4%E6%8E%A5%E6%8E%A5%E7%B6%9A%E3%81%AB%E9%9D%99%E7%9A%84IP%E3%82%92%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%8B%E3%81%A8%E3%80%81ping%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%9B%E3%81%9A%E3%80%81%E3%83%9B%E3%82%B9%E3%83%88%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EDHCP%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%A7%E3%83%AB%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%82%82%E3%80%81IP%E3%81%AF%E5%8F%96%E5%BE%97%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%AE%E3%81%82%E3%82%8BAndroid%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AF%E4%BB%96%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3Emek_8q%3A%2F%20%23%20dmesg%20%7Cgrep%20ETH%3CBR%20%2F%3E%5B%200.000000%5D%20PSCI%3A%20DT%20%E3%81%8B%E3%82%89%E3%81%AE%E3%82%B3%E3%83%B3%E3%82%B8%E3%83%83%E3%83%88%E6%B3%95%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%80%82%3CBR%20%2F%3E%5B%201.062988%5D%20FEC%205B040000.Ethernet%3A5b040000.%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E4%BE%9B%E7%B5%A6PHY%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81ing%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%3CBR%20%2F%3E%5B%201.088689%5D%20fec%205b040000.ethernet%20eth0%3A%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%E3%81%AEPHC%E3%83%87%E3%83%90%E3%82%A4%E3%82%B90%3CBR%20%2F%3E%5B%205.671765%5D%20%E3%83%A9%E3%83%B3%E3%83%80%E3%83%A0%E3%81%AA%E8%87%AA%E5%B7%B1%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%3CBR%20%2F%3E%5B%205.676348%5D%20%E3%83%A9%E3%83%B3%E3%83%80%E3%83%A0%E3%81%AA%E3%83%9B%E3%82%B9%E3%83%88%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%3CBR%20%2F%3E%5B%2012.257932%5D%20%E6%B1%8E%E7%94%A8%20PHY%205b040000.ethernet-1%3A00%3A%E4%BB%98%E5%B1%9E%20PHY%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20%5B%E6%B1%8E%E7%94%A8%20PHY%5D%20(mii_bus%3Aphy_addr%3D5b040000.ethernet-1%3A00%2C%20irq%3DPOLL)%3CBR%20%2F%3E%5B%2012.270536%5D%20IPv6%3A%20ADDRCONF(NETDEV_UP)%3A%20eth0%3A%20%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AE%E6%BA%96%E5%82%99%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B%2012.302364%5D%20IPv6%3A%20ADDRCONF(NETDEV_UP)%3A%20eth0%3A%20%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AE%E6%BA%96%E5%82%99%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B%2012.465029%5D%20IPv6%3A%20ADDRCONF(NETDEV_UP)%3A%20eth0%3A%20%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AE%E6%BA%96%E5%82%99%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B%2014.300010%5D%20fec%205b040000.ethernet%20eth0%3A%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%8C%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20-%20100Mbps%20%2F%E3%83%95%E3%83%AB%20-%20%E3%83%95%E3%83%AD%E3%83%BC%E7%B6%9A%E3%81%8Drx%20%2F%20tx%3CBR%20%2F%3E%5B%2014.308841%5D%20IPv6%3A%20ADDRCONF(NETDEV_CHANGE)%3A%20eth0%3A%20%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AE%E6%BA%96%E5%82%99%E3%81%8C%E6%95%B4%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎02-12-2020 07:28 AM
更新者:
