Enable Ethernet for Android Auto with mek_8q
Default Ethernet feature is removed for Android Auto (both Android_Pie9.0 and Android10)
Below are the patched to bring Ethernet feature back to Android Auto. Please try to apply the according patches if you want to enable Ethernet.
For Android_Pie9.0_Auto(example with car2 build):
--- a/arch/arm64/configs/android_car2_defconfig
+++b/arch/arm64/configs/android_car2_defconfig
@@ -245,7 +245,7 @@ CONFIG_DM_VERITY_FEC=y
CONFIG_NETDEVICES=y
CONFIG_MACVTAP=m
CONFIG_TUN=y
-# CONFIG_ETHERNET is not set
+CONFIG_ETHERNET=y
CONFIG_MDIO_BUS_MUX_MMIOREG=m
CONFIG_AT803X_PHY=m
CONFIG_MARVELL_PHY=m
@@ -517,7 +517,7 @@ CONFIG_SQUASHFS=y
CONFIG_SQUASHFS_DECOMP_MULTI=y
CONFIG_SQUASHFS_XATTR=y
CONFIG_SQUASHFS_LZ4=y
-# CONFIG_NETWORK_FILESYSTEMS is not set
+CONFIG_NETWORK_FILESYSTEMS=y
--- a/imx8q/mek_8q/mek_8q.mk
+++ b/imx8q/mek_8q/mek_8q.mk
@@ -46,6 +46,7 @@ PRODUCT_COPY_FILES += \
     $(IMX_DEVICE_PATH)/fstab.freescale.car:$(TARGET_COPY_OUT_VENDOR)/etc/fstab.freescale \
     $(IMX_DEVICE_PATH)/early.init_car.cfg:$(TARGET_COPY_OUT_VENDOR)/etc/early.init.cfg \
     $(IMX_DEVICE_PATH)/required_hardware_auto.xml:$(TARGET_COPY_OUT_VENDOR)/etc/permissions/required_hardware.xml \
+    frameworks/native/data/etc/android.hardware.ethernet.xml:$(TARGET_COPY_OUT_VENDOR)/etc/permissions/android.hardware.ethernet.xml \
     device/fsl/imx8q/init.recovery.freescale.car.rc:root/init.recovery.freescale.rc
For Android10_Auto,(example with car build):
--- a/arch/arm64/configs/android_car_defconfig
+++ b/arch/arm64/configs/android_car_defconfig
@@ -23,6 +23,8 @@ CONFIG_SCHED_AUTOGROUP=y
CONFIG_SCHED_TUNE=y
CONFIG_RELAY=y
CONFIG_BLK_DEV_INITRD=y
+CONFIG_FEC=y
+CONFIG_AT803X_PHY=y
# CONFIG_RD_BZIP2 is not set
# CONFIG_RD_LZMA is not set
# CONFIG_RD_XZ is not set
@@ -246,7 +248,6 @@ CONFIG_DM_VERITY=y
CONFIG_NETDEVICES=y
CONFIG_TUN=y
Note: Please also check for below file, if fec1 is disabled, please also apply below diff.
--- a/arch/arm64/boot/dts/freescale/imx8qm-mek-car2.dts
+++ b/arch/arm64/boot/dts/freescale/imx8qm-mek-car2.dts
@@ -147,10 +147,6 @@
status = "disabled";
-&fec1 {
- status = "disabled";
&fec2 {
附件
评论
Hello Andy,
I applied the patch above, now I have the kernel printing eth messages and ifconfig shows eth0.
However, when I assign a static ip on a direct connection with a host, ping does not work, I get host unreachable.
If I connect to a router with DHCP server, it doesn't acquire an IP.
Are there other Android packages that needed to be installed to enable networking?
Thanks!
mek_8q:/ # dmesg | grep eth
[ 0.000000] psci: probing for conduit method from DT.
[ 1.062988] fec 5b040000.ethernet: 5b040000.ethernet supply phy not found, us ing dummy regulator
[ 1.088689] fec 5b040000.ethernet eth0: registered PHC device 0
[ 5.671765] using random self ethernet address
[ 5.676348] using random host ethernet address
[ 12.257932] Generic PHY 5b040000.ethernet-1:00: attached PHY driver [Generic PHY] (mii_bus:phy_addr=5b040000.ethernet-1:00, irq=POLL)
[ 12.270536] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 12.302364] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 12.465029] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 14.300010] fec 5b040000.ethernet eth0: Link is Up - 100Mbps/Full - flow cont rol rx/tx
[ 14.308841] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
I am also facing the same issue. Any findings?
Customer went a different route, I never received feedback on this.
Please reply here if you find anything.
Disabling ethernet by default in demo images make no sense. Without internet connection Android in most cases is useless.
Tested locally with android10_5.4.y mainline, the patches above will get ethernet working.
For static IP, there is a CL need to apply in frameworks/opt/net/ethernet.git
the patch is attached as  611749f.diff
I tried the build with Android 10.0.0_2.2.0 but had a weird error during the build:
my commands to build (after clean download of source, deleted android_build folder prior...)
  • cd ${MY_ANDROID}
  • source build/envsetup.sh
  • lunch mek_8q_car2-userdebug (i don't want M4 in this case... maybe that is the problem)
  • ./imx-make.sh -j16 (note i have 16 cores in my build machine)
from the community appnote, i also updated the following files per instructions in post (and no other files touched):
file:  mek_8q.mk
location: ./android_build/device/fsl/imx8q/mek_8q/mek_8q.mk
file:  imx_v8_android_car2_defconfig
location: ~/android_build/vendor/nxp-opensource/kernel_imx/arch/arm64/configs
I did not touch/modify any other file anywhere in the build.   should i have used the mek_8q_car2.mk file instead of mek_8q.mk from the community post?
The out folder is being generated but the errors are below.   Do I ignore or have I done something incorrect?
[ 99% 630/634] including vendor/nxp/imx_android_mm/CactusPlayer/Android.mk ...
[ 99% 631/634] including vendor/nxp/imx_android_mm/codec2/store/registry/Android.mk ...
[ 99% 632/634] including vendor/nxp/linux-firmware-imx/firmware/Android.mk ...
[ 99% 633/634] finishing build rules ...
platform_testing/build/tasks/tests/instrumentation_test_list.mk: warning: continuous_instrumentation_tests: Unknown installed file for module 'NexusLauncherOutOfProcTests'
platform_testing/build/tasks/tests/instrumentation_test_list.mk: warning: continuous_instrumentation_tests: Unknown installed file for module 'NexusLauncherDebug'
platform_testing/build/tasks/tests/instrumentation_test_list.mk: warning: continuous_instrumentation_tests: Unknown installed file for module 'NexusLauncherTests'
platform_testing/build/tasks/tests/platform_test_list.mk: warning: platform_tests: Unknown installed file for module 'LauncherRotationStressTest'
platform_testing/build/tasks/tests/platform_test_list.mk: warning: platform_tests: Unknown installed file for module 'PlatformScenarioTests'
[100% 634/634] writing build rules ...
FAILED:
device/fsl/imx8q/mek_8q/mek_8q.mk:512: error: writing to readonly directory: "device/fsl/imx8q/init.recovery.freescale.car.rc"
09:50:03 ckati failed with: exit status 1
#### failed to build some targets (08:26 (mm:ss)) ####
Andy, where are you applying the CL argument to ethernet.git?  what is the CL exactly you need to enter?  i've applied the patches, android 10 is up, but ifconfig (via adb shell) shows a dummy0 link (though that does look fully functional).  but i cannot access the network so i'm assuming android needs a static IP?   also under Kitchen Sink--> connectivity in android 10, i cannot find that the ethernet is enabled... previously on android10, if ethernet was working i'd see an IP address in that screen.
further investigation... i have my MEK attached to a network with full DHCP.  But i don't get an IP address (e.g. no eth0).   What i do get is a dummy0 connection (not sure if this is actually eth0...).  Second, under Kitchen Sink-->connectivity, i'd usually see the network there (via ethernet).
under adb shell:
kyle@kyle-System-Product-Name:~/android_build/out/target/product/mek_8q$ adb shell
mek_8q:/ $ su
mek_8q:/ # ifconfig
dummy0 Link encap:Ethernet HWaddr ba:e1:9e:2e:20:90
inet6 addr: fe80::b8e1:9eff:fe2e:2090/64 Scope: Link
UP BROADCAST RUNNING NOARP MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:10 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 TX bytes:700
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope: Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 TX bytes:0
mek_8q:/ #
mek_8q:/ # ping 192.168.1.1
connect: Network is unreachable
2|mek_8q:/ #
Hi fox,
Firstly, if you correctly apply the patch to kernel defconfig and device/fsl.git, you should be able to see eth0 interface with "ifconfig -a"  , not dummy0
And the CL 611749f.diff I attached is  to apply on frameworks/opt/net/ethernet.git , it's for static IP assign issue.
%3CLINGO-SUB%20id%3D%22lingo-sub-1100866%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%BF%E7%94%A8%20mek_8q%20%E4%B8%BA%20Android%20Auto%20%E5%90%AF%E7%94%A8%E4%BB%A5%E5%A4%AA%E7%BD%91%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100866%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%3CSTRONG%3EAndroid%20Auto%20%E7%9A%84%E9%BB%98%E8%AE%A4%E4%BB%A5%E5%A4%AA%E7%BD%91%E5%8A%9F%E8%83%BD%E5%B7%B2%E8%A2%AB%E7%A7%BB%E9%99%A4%EF%BC%88Android_Pie9.0%E5%92%8C%20Android10)%3CBR%20%2F%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E5%B0%86%E4%BB%A5%E5%A4%AA%E7%BD%91%E5%8A%9F%E8%83%BD%E9%87%8D%E6%96%B0%E5%BC%95%E5%85%A5%20Android%20Auto%20%E7%9A%84%E8%A1%A5%E4%B8%81%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E6%83%B3%E5%90%AF%E7%94%A8%E4%BB%A5%E5%A4%AA%E7%BD%91%EF%BC%8C%E8%AF%B7%E5%B0%9D%E8%AF%95%E5%BA%94%E7%94%A8%E7%9B%B8%E5%BA%94%E7%9A%84%E8%A1%A5%E4%B8%81%E3%80%82%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%3CSTRONG%3E%E5%AF%B9%E4%BA%8E%20Android_Pie9.0_Auto%EF%BC%88%E4%BB%A5%20car2%20%E6%9E%84%E5%BB%BA%E4%B8%BA%E4%BE%8B%EF%BC%89%EF%BC%9A%3C%2FSTRONG%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%3CEM%3E---%20a%2Farch%2Farm64%2Fconfigs%2Fandroid_car2_defconfig%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%3CEM%3E%2B%2B%2Bb%2Farch%2Farm64%2Fconfigs%2Fandroid_car2_defconfig%20%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%40%40%20-245%2C7%20%2B245%2C7%20%40%40%20CONFIG_DM_VERITY_FEC%3Dy%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3ECONFIG_NETDEVICES%3Dy%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3ECONFIG_MACVTAP%3Dm%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3ECONFIG_TUN%3Dy%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E-%23%20CONFIG_ETHERNET%20%E6%9C%AA%E8%AE%BE%E7%BD%AE%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%2BCONFIG_ETHERNET%3Dy%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3ECONFIG_MDIO_BUS_MUX_MMIOREG%3Dm%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3ECONFIG_AT803X_PHY%3Dm%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3ECONFIG_MARVELL_PHY%3Dm%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%40%40%20-517%2C7%20%2B517%2C7%20%40%40%20CONFIG_SQUASHFS%3Dy%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3ECONFIG_SQUASHFS_DECOMP_MULTI%3Dy%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3ECONFIG_SQUASHFS_XATTR%3Dy%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3ECONFIG_SQUASHFS_LZ4%3Dy%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E-%23%20CONFIG_NETWORK_FILESYSTEMS%20%E6%9C%AA%E8%AE%BE%E7%BD%AE%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%2B%E9%85%8D%E7%BD%AE%E7%BD%91%E7%BB%9C%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%3Dy%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%3CEM%3E---%20a%2Fimx8q%2Fmek_8q%2Fmek_8q.mk%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%3CEM%3E%2B%2B%2B%20b%2Fimx8q%2Fmek_8q%2Fmek_8q.mk%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%40%40%20-46%2C6%20%2B46%2C7%20%40%40%20PRODUCT_COPY_FILES%20%2B%3D%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%24%EF%BC%88IMX_DEVICE_PATH%EF%BC%89%2Ffstab.freescale.car%3A%24%EF%BC%88TARGET_COPY_OUT_VENDOR%EF%BC%89%2Fetc%2Ffstab.freescale%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%24(IMX_DEVICE_PATH)%2Fearly.init_car.cfg%3A%24(TARGET_COPY_OUT_VENDOR)%2Fetc%2Fearly.init.cfg%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%24(IMX_DEVICE_PATH)%2Frequired_hardware_auto.xml%3A%24(TARGET_COPY_OUT_VENDOR)%2Fetc%2Fpermissions%2Frequired_hardware.xml%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%2B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%E6%A1%86%E6%9E%B6%2F%E6%9C%AC%E6%9C%BA%2F%E6%95%B0%E6%8D%AE%2Fetc%2Fandroid.hardware.ethernet.xml%3A%24(TARGET_COPY_OUT_VENDOR)%2Fetc%2Fpermissions%2Fandroid.hardware.ethernet.xml%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%E8%AE%BE%E5%A4%87%2Ffsl%2Fimx8q%2Finit.recovery.freescale.car.rc%3Aroot%2Finit.recovery.freescale.rc%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%3CSTRONG%3E%E5%AF%B9%E4%BA%8EAndroid10_Auto%EF%BC%88%E4%BB%A5%E6%B1%BD%E8%BD%A6%E5%88%B6%E9%80%A0%E4%B8%BA%E4%BE%8B%EF%BC%89%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%3CEM%3E---%20a%2Farch%2Farm64%2Fconfigs%2Fandroid_car_defconfig%20%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%3CEM%3E%2B%2B%2B%20b%2Farch%2Farm64%2Fconfigs%2Fandroid_car_defconfig%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%40%40%20-23%2C6%20%2B23%2C8%20%40%40%20CONFIG_SCHED_AUTOGROUP%3Dy%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3ECONFIG_SCHED_TUNE%3Dy%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%E9%85%8D%E7%BD%AE%E4%B8%AD%E7%BB%A7%3Dy%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3ECONFIG_BLK_DEV_INITRD%3Dy%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%2BCONFIG_FEC%3Dy%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%2BCONFIG_AT803X_PHY%3Dy%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%23%20CONFIG_RD_BZIP2%20%E6%9C%AA%E8%AE%BE%E7%BD%AE%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%23%20CONFIG_RD_LZMA%20%E6%9C%AA%E8%AE%BE%E7%BD%AE%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%23%20CONFIG_RD_XZ%20%E6%9C%AA%E8%AE%BE%E7%BD%AE%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%40%40%20-246%2C7%20%2B248%2C6%20%40%40%20CONFIG_DM_VERITY%3Dy%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3ECONFIG_DM_VERITY_FEC%3Dy%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3ECONFIG_NETDEVICES%3Dy%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3ECONFIG_TUN%3Dy%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E-%23%20CONFIG_ETHERNET%20%E6%9C%AA%E8%AE%BE%E7%BD%AE%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%3CEM%3E%26nbsp%3B%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%3CEM%3E---%20a%2Fimx8q%2Fmek_8q%2Fmek_8q.mk%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%3CEM%3E%2B%2B%2B%20b%2Fimx8q%2Fmek_8q%2Fmek_8q.mk%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%40%40%20-46%2C6%20%2B46%2C7%20%40%40%20PRODUCT_COPY_FILES%20%2B%3D%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%24%EF%BC%88IMX_DEVICE_PATH%EF%BC%89%2Ffstab.freescale.car%3A%24%EF%BC%88TARGET_COPY_OUT_VENDOR%EF%BC%89%2Fetc%2Ffstab.freescale%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%24(IMX_DEVICE_PATH)%2Fearly.init_car.cfg%3A%24(TARGET_COPY_OUT_VENDOR)%2Fetc%2Fearly.init.cfg%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%24(IMX_DEVICE_PATH)%2Frequired_hardware_auto.xml%3A%24(TARGET_COPY_OUT_VENDOR)%2Fetc%2Fpermissions%2Frequired_hardware.xml%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%2B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%E6%A1%86%E6%9E%B6%2F%E6%9C%AC%E6%9C%BA%2F%E6%95%B0%E6%8D%AE%2Fetc%2Fandroid.hardware.ethernet.xml%3A%24(TARGET_COPY_OUT_VENDOR)%2Fetc%2Fpermissions%2Fandroid.hardware.ethernet.xml%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%E8%AE%BE%E5%A4%87%2Ffsl%2Fimx8q%2Finit.recovery.freescale.car.rc%3Aroot%2Finit.recovery.freescale.rc%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22font-size%3A%2010.5pt%3B%20%22%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E8%AF%B7%E6%A3%80%E6%9F%A5%E4%BB%A5%E4%B8%8B%E6%96%87%E4%BB%B6%EF%BC%8C%E5%A6%82%E6%9E%9C%20fec1%20%E8%A2%AB%E7%A6%81%E7%94%A8%EF%BC%8C%E8%AF%B7%E5%BA%94%E7%94%A8%E4%BB%A5%E4%B8%8B%E5%B7%AE%E5%BC%82%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E---%20a%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx8qm-mek-car2.dts%3CBR%20%2F%3E%2B%2B%2Bb%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx8qm-mek-car2.dts%3CBR%20%2F%3E%40%40%20-147%2C10%20%2B147%2C6%20%40%40%3CBR%20%2F%3E%E7%8A%B6%E6%80%81%3D%E2%80%9C%E5%B7%B2%E7%A6%81%E7%94%A8%E2%80%9D%EF%BC%9B%3CBR%20%2F%3E%20%7D%3B%3C%2FP%3E%3CP%3E-%26amp%3Bfec1%20%7B%3CBR%20%2F%3E%20%E2%80%94%20%E7%8A%B6%E6%80%81%20%3D%20%E2%80%9C%E5%B7%B2%E7%A6%81%E7%94%A8%E2%80%9D%EF%BC%9B%3CBR%20%2F%3E%20-%7D%3B%3CBR%20%2F%3E%20-%3CBR%20%2F%3E%20%26amp%3Bfec2%20%7B%3CBR%20%2F%3E%E7%8A%B6%E6%80%81%3D%E2%80%9C%E5%B7%B2%E7%A6%81%E7%94%A8%E2%80%9D%EF%BC%9B%3CBR%20%2F%3E%20%7D%3B%3C%2FP%3E%3CDIV%20style%3D%22position%3A%20absolute%3B%20left%3A%20546px%3B%20top%3A%201536.6px%3B%22%3E%3CDIV%20class%3D%22gtx-trans-icon%22%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1100866%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAndroid%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX%208%20%E7%B3%BB%E5%88%97%20%7C%20i.MX%208QuadMax%20(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100876%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20mek_8q%20%E4%B8%BA%20Android%20Auto%20%E5%90%AF%E7%94%A8%E4%BB%A5%E5%A4%AA%E7%BD%91%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100876%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20fox%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%A6%96%E5%85%88%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%82%A8%E6%AD%A3%E7%A1%AE%E5%9C%B0%E5%B0%86%E8%A1%A5%E4%B8%81%E5%BA%94%E7%94%A8%E5%88%B0%E5%86%85%E6%A0%B8defconfig%E5%92%8Cdevice%2Ffsl.git%EF%BC%8C%E6%82%A8%E5%BA%94%E8%AF%A5%E8%83%BD%E5%A4%9F%E4%BD%BF%E7%94%A8%E2%80%9Cifconfig%20-a%E2%80%9D%E7%9C%8B%E5%88%B0%3CSTRONG%3Eeth0%3C%2FSTRONG%3E%E6%8E%A5%E5%8F%A3%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%20dummy0%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E9%99%84%E5%8A%A0%E7%9A%84%20CL%20%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E611749f.diff%3C%2FSPAN%3E%E9%80%82%E7%94%A8%E4%BA%8E%20frameworks%2Fopt%2Fnet%2Fethernet.git%EF%BC%8C%E7%94%A8%E4%BA%8E%E8%A7%A3%E5%86%B3%E9%9D%99%E6%80%81%20IP%20%E5%88%86%E9%85%8D%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100875%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20mek_8q%20%E4%B8%BA%20Android%20Auto%20%E5%90%AF%E7%94%A8%E4%BB%A5%E5%A4%AA%E7%BD%91%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100875%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%BF%9B%E4%B8%80%E6%AD%A5%E8%B0%83%E6%9F%A5...%E6%88%91%E5%B7%B2%E5%B0%86%20MEK%20%E8%BF%9E%E6%8E%A5%E5%88%B0%E5%85%B7%E6%9C%89%E5%AE%8C%E6%95%B4%20DHCP%20%E7%9A%84%E7%BD%91%E7%BB%9C%E3%80%82%E4%BD%86%E6%88%91%E6%B2%A1%E6%9C%89%E8%8E%B7%E5%BE%97%20IP%20%E5%9C%B0%E5%9D%80%EF%BC%88%E4%BE%8B%E5%A6%82%E6%B2%A1%E6%9C%89%20eth0)%E3%80%82%E6%88%91%E5%BE%97%E5%88%B0%E7%9A%84%E6%98%AF%E4%B8%80%E4%B8%AA%20dummy0%20%E8%BF%9E%E6%8E%A5%EF%BC%88%E4%B8%8D%E7%A1%AE%E5%AE%9A%E8%BF%99%E6%98%AF%E5%90%A6%E7%9C%9F%E7%9A%84%E6%98%AF%20eth0......%EF%BC%89%E3%80%82%E5%85%B6%E6%AC%A1%EF%BC%8C%E5%9C%A8%20Kitchen%20Sink--%26gt%3Bconnectivity%20%E4%B8%8B%EF%BC%8C%E6%88%91%E9%80%9A%E5%B8%B8%E4%BC%9A%E5%9C%A8%E9%82%A3%E9%87%8C%E7%9C%8B%E5%88%B0%E7%BD%91%E7%BB%9C%EF%BC%88%E9%80%9A%E8%BF%87%E4%BB%A5%E5%A4%AA%E7%BD%91%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%20adb%20shell%20%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CP%3Ekyle%40kyle-System-Product-Name%3A~%2Fandroid_build%2Fout%2Ftarget%2Fproduct%2Fmek_8q%24%20adb%20shell%3CBR%20%2F%3E%20mek_8q%3A%2F%24su%3CBR%20%2F%3E%20mek_8q%3A%2F%23ifconfig%3CBR%20%2F%3E%20dummy0%20%E9%93%BE%E8%B7%AF%E5%B0%81%E8%A3%85%EF%BC%9A%E4%BB%A5%E5%A4%AA%E7%BD%91%20HWaddr%20ba%3Ae1%3A9e%3A2e%3A20%3A90%3CBR%20%2F%3E%20inet6%20%E5%9C%B0%E5%9D%80%EF%BC%9Afe80%3A%3Ab8e1%3A9eff%3Afe2e%3A2090%2F64%20%E8%8C%83%E5%9B%B4%EF%BC%9A%E9%93%BE%E6%8E%A5%3CBR%20%2F%3E%E5%90%91%E4%B8%8A%E5%B9%BF%E6%92%AD%E8%BF%90%E8%A1%8C%20NOARP%20MTU%3A1500%20%E5%BA%A6%E9%87%8F%3A1%3CBR%20%2F%3E%20RX%20%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%9A0%20%E9%94%99%E8%AF%AF%EF%BC%9A0%20%E4%B8%A2%E5%BC%83%EF%BC%9A0%20%E6%BA%A2%E5%87%BA%EF%BC%9A0%20%E5%B8%A7%EF%BC%9A0%3CBR%20%2F%3E%20TX%20%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%9A10%20%E9%94%99%E8%AF%AF%EF%BC%9A0%20%E4%B8%A2%E5%BC%83%EF%BC%9A0%20%E8%B6%85%E9%99%90%EF%BC%9A0%20%E8%BD%BD%E6%B3%A2%EF%BC%9A0%3CBR%20%2F%3E%E7%A2%B0%E6%92%9E%EF%BC%9A0%20txqueuelen%EF%BC%9A1000%3CBR%20%2F%3E%20RX%E5%AD%97%E8%8A%82%EF%BC%9A0%20TX%E5%AD%97%E8%8A%82%EF%BC%9A700%3C%2FP%3E%3CP%3Elo%20%E9%93%BE%E8%B7%AF%E5%B0%81%E8%A3%85%EF%BC%9A%E6%9C%AC%E5%9C%B0%E7%8E%AF%E5%9B%9E%3CBR%20%2F%3Einet%20%E5%9C%B0%E5%9D%80%EF%BC%9A127.0.0.1%20%E6%8E%A9%E7%A0%81%EF%BC%9A255.0.0.0%3CBR%20%2F%3E%20inet6%20%E5%9C%B0%E5%9D%80%3A%20%3A%3A1%2F128%20%E8%8C%83%E5%9B%B4%3A%20%E4%B8%BB%E6%9C%BA%3CBR%20%2F%3E%E4%B8%8A%E8%A1%8C%E7%8E%AF%E5%9B%9E%E8%BF%90%E8%A1%8C%20MTU%EF%BC%9A65536%20%E5%BA%A6%E9%87%8F%EF%BC%9A1%3CBR%20%2F%3E%20RX%20%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%9A0%20%E9%94%99%E8%AF%AF%EF%BC%9A0%20%E4%B8%A2%E5%BC%83%EF%BC%9A0%20%E6%BA%A2%E5%87%BA%EF%BC%9A0%20%E5%B8%A7%EF%BC%9A0%3CBR%20%2F%3E%20TX%20%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%9A0%20%E9%94%99%E8%AF%AF%EF%BC%9A0%20%E4%B8%A2%E5%BC%83%EF%BC%9A0%20%E8%B6%85%E9%99%90%EF%BC%9A0%20%E8%BD%BD%E6%B3%A2%EF%BC%9A0%3CBR%20%2F%3E%E7%A2%B0%E6%92%9E%EF%BC%9A0%20txqueuelen%EF%BC%9A1000%3CBR%20%2F%3E%20RX%20%E5%AD%97%E8%8A%82%EF%BC%9A0%20TX%20%E5%AD%97%E8%8A%82%EF%BC%9A0%3C%2FP%3E%3CP%3Emek_8q%3A%2F%20%23%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Emek_8q%3A%2F%23ping%20192.168.1.1%3CBR%20%2F%3E%E8%BF%9E%E6%8E%A5%EF%BC%9A%E7%BD%91%E7%BB%9C%E4%B8%8D%E5%8F%AF%E8%BE%BE%3CBR%20%2F%3E2%7Cmek_8q%3A%2F%20%23%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100874%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20mek_8q%20%E4%B8%BA%20Android%20Auto%20%E5%90%AF%E7%94%A8%E4%BB%A5%E5%A4%AA%E7%BD%91%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100874%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EAndy%EF%BC%8C%E4%BD%A0%E5%9C%A8%E5%93%AA%E9%87%8C%E5%B0%86%20CL%20%E5%8F%82%E6%95%B0%E5%BA%94%E7%94%A8%E5%88%B0%20ethernet.git%20%E4%B8%AD%EF%BC%9F%E4%BD%A0%E5%88%B0%E5%BA%95%E9%9C%80%E8%A6%81%E8%BE%93%E5%85%A5%E5%93%AA%E4%B8%AA%20CL%EF%BC%9F%E6%88%91%E5%B7%B2%E7%BB%8F%E6%89%93%E4%BA%86%E8%A1%A5%E4%B8%81%EF%BC%8CAndroid%2010%20%E4%B9%9F%E5%90%AF%E5%8A%A8%E4%BA%86%EF%BC%8C%E4%BD%86%E6%98%AF%20ifconfig%EF%BC%88%E9%80%9A%E8%BF%87%20adb%20shell%EF%BC%89%E6%98%BE%E7%A4%BA%E7%9A%84%E6%98%AF%20dummy0%20%E9%93%BE%E6%8E%A5%EF%BC%88%E8%99%BD%E7%84%B6%E7%9C%8B%E8%B5%B7%E6%9D%A5%E5%8A%9F%E8%83%BD%E9%BD%90%E5%85%A8%EF%BC%89%E3%80%82%E4%BD%86%E6%98%AF%E6%88%91%E6%97%A0%E6%B3%95%E8%AE%BF%E9%97%AE%E7%BD%91%E7%BB%9C%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E5%81%87%E8%AE%BEAndroid%E9%9C%80%E8%A6%81%E4%B8%80%E4%B8%AA%E9%9D%99%E6%80%81IP%EF%BC%9F%E5%90%8C%E6%A0%B7%E5%9C%A8Android%2010%E4%B8%AD%E7%9A%84Kitchen%20Sink--%26gt%3B%E8%BF%9E%E6%8E%A5%E4%B8%8B%EF%BC%8C%E6%88%91%E6%89%BE%E4%B8%8D%E5%88%B0%E4%BB%A5%E5%A4%AA%E7%BD%91%E5%B7%B2%E5%90%AF%E7%94%A8...%E4%BB%A5%E5%89%8D%E5%9C%A8Android%2010%E4%B8%8A%EF%BC%8C%E5%A6%82%E6%9E%9C%E4%BB%A5%E5%A4%AA%E7%BD%91%E6%AD%A3%E5%9C%A8%E5%B7%A5%E4%BD%9C%EF%BC%8C%E6%88%91%E4%BC%9A%E5%9C%A8%E9%82%A3%E4%B8%AA%E5%B1%8F%E5%B9%95%E4%B8%8A%E7%9C%8B%E5%88%B0%E4%B8%80%E4%B8%AAIP%E5%9C%B0%E5%9D%80%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100873%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20mek_8q%20%E4%B8%BA%20Android%20Auto%20%E5%90%AF%E7%94%A8%E4%BB%A5%E5%A4%AA%E7%BD%91%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100873%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20Android%2010.0.0_2.2.0%20%E8%BF%9B%E8%A1%8C%E6%9E%84%E5%BB%BA%EF%BC%8C%E4%BD%86%E5%9C%A8%E6%9E%84%E5%BB%BA%E8%BF%87%E7%A8%8B%E4%B8%AD%E5%87%BA%E7%8E%B0%E4%BA%86%E4%B8%80%E4%B8%AA%E5%A5%87%E6%80%AA%E7%9A%84%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E6%88%91%E8%A6%81%E6%9E%84%E5%BB%BA%E7%9A%84%E5%91%BD%E4%BB%A4%EF%BC%88%E5%B9%B2%E5%87%80%E4%B8%8B%E8%BD%BD%E6%BA%90%E4%BB%A3%E7%A0%81%E5%90%8E%EF%BC%8C%E5%85%88%E5%88%A0%E9%99%A4%20android_build%20%E6%96%87%E4%BB%B6%E5%A4%B9...%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%20style%3D%22color%3A%20black%3B%22%3E%E5%85%89%E7%9B%98%24%7BMY_ANDROID%7D%3C%2FLI%3E%3CLI%20style%3D%22color%3A%20black%3B%22%3E%E6%BA%90%E6%9E%84%E5%BB%BA%2Fenvsetup.sh%3C%2FLI%3E%3CLI%20style%3D%22color%3A%20black%3B%22%3E%E5%8D%88%E9%A4%90%20mek_8q_car2-userdebug%EF%BC%88%E5%9C%A8%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E4%B8%8B%E6%88%91%E4%B8%8D%E6%83%B3%E8%A6%81%20M4...%E4%B9%9F%E8%AE%B8%E8%BF%99%E5%B0%B1%E6%98%AF%E9%97%AE%E9%A2%98%E6%89%80%E5%9C%A8%EF%BC%89%3C%2FLI%3E%3CLI%20style%3D%22color%3A%20black%3B%22%3E.%2Fimx-make.sh%20-j16%EF%BC%88%E6%B3%A8%E6%84%8F%E6%88%91%E7%9A%84%E6%9E%84%E5%BB%BA%E6%9C%BA%E5%99%A8%E4%B8%AD%E6%9C%89%2016%20%E4%B8%AA%E6%A0%B8%E5%BF%83%EF%BC%89%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E4%BB%8E%E7%A4%BE%E5%8C%BA%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E8%AF%B4%E6%98%8E%E4%B8%AD%EF%BC%8C%E6%88%91%E8%BF%98%E6%A0%B9%E6%8D%AE%E5%B8%96%E5%AD%90%E4%B8%AD%E7%9A%84%E8%AF%B4%E6%98%8E%E6%9B%B4%E6%96%B0%E4%BA%86%E4%BB%A5%E4%B8%8B%E6%96%87%E4%BB%B6%EF%BC%88%E6%B2%A1%E6%9C%89%E8%A7%A6%E5%8F%8A%E5%85%B6%E4%BB%96%E6%96%87%E4%BB%B6%EF%BC%89%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3Efile%3A%26nbsp%3B%20mek_8q.mk%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3Elocation%3A%26nbsp%3B.%2Fandroid_build%2Fdevice%2Ffsl%2Fimx8q%2Fmek_8q%2Fmek_8q.mk%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3Efile%3A%26nbsp%3B%26nbsp%3B%3CSPAN%20style%3D%22background%3A%20white%3B%22%3Eimx_v8_android_car2_defconfig%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E4%BD%8D%E7%BD%AE%EF%BC%9A%20%3CSPAN%20style%3D%22background%3A%20white%3B%22%3E~%2Fandroid_build%2Fvendor%2Fnxp-opensource%2Fkernel_imx%2Farch%2Farm64%2Fconfigs%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E6%88%91%E6%B2%A1%E6%9C%89%E8%A7%A6%E7%A2%B0%2F%E4%BF%AE%E6%94%B9%E6%9E%84%E5%BB%BA%E8%BF%87%E7%A8%8B%E4%B8%AD%E4%BB%BB%E4%BD%95%E5%9C%B0%E6%96%B9%E7%9A%84%E4%BB%BB%E4%BD%95%E5%85%B6%E4%BB%96%E6%96%87%E4%BB%B6%E3%80%82%E6%88%91%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%20mek_8q_car2.mk%20%E6%96%87%E4%BB%B6%E8%80%8C%E4%B8%8D%E6%98%AF%E7%A4%BE%E5%8C%BA%E5%B8%96%E5%AD%90%E4%B8%AD%E7%9A%84%20mek_8q.mk%20%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E6%AD%A3%E5%9C%A8%E7%94%9F%E6%88%90%E8%BE%93%E5%87%BA%E6%96%87%E4%BB%B6%E5%A4%B9%EF%BC%8C%E4%BD%86%E9%94%99%E8%AF%AF%E5%A6%82%E4%B8%8B%E3%80%82%E6%88%91%E6%98%AF%E5%90%A6%E5%BF%BD%E7%95%A5%E4%BA%86%E4%BB%80%E4%B9%88%E6%88%96%E8%80%85%E6%88%91%E5%81%9A%E9%94%99%E4%BA%86%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5B99%25%20630%2F634%5D%E5%8C%85%E6%8B%AC%20vendor%2Fnxp%2Fimx_android_mm%2FCactusPlayer%2FAndroid.mk%E2%80%A6%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5B99%25%20631%2F634%5D%E5%8C%85%E6%8B%AC%20vendor%2Fnxp%2Fimx_android_mm%2Fcodec2%2Fstore%2Fregistry%2FAndroid.mk%E2%80%A6%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5B99%25%20632%2F634%5D%E5%8C%85%E6%8B%AC%20vendor%2Fnxp%2Flinux-firmware-imx%2Ffirmware%2FAndroid.mk%E2%80%A6%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5B%2099%25%20633%2F634%5D%20%E5%AE%8C%E6%88%90%E6%9E%84%E5%BB%BA%E8%A7%84%E5%88%99...%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3Eplatform_testing%2Fbuild%2Ftasks%2Ftests%2Finstrumentation_test_list.mk%EF%BC%9A%E8%AD%A6%E5%91%8A%EF%BC%9Acontinuous_instrumentation_tests%EF%BC%9A%E6%A8%A1%E5%9D%97%E2%80%9CNexusLauncherOutOfProcTests%E2%80%9D%E7%9A%84%E6%9C%AA%E7%9F%A5%E5%AE%89%E8%A3%85%E6%96%87%E4%BB%B6%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3Eplatform_testing%2Fbuild%2Ftasks%2Ftests%2Finstrumentation_test_list.mk%EF%BC%9A%E8%AD%A6%E5%91%8A%EF%BC%9Acontinuous_instrumentation_tests%EF%BC%9A%E6%A8%A1%E5%9D%97%E2%80%9CNexusLauncherDebug%E2%80%9D%E7%9A%84%E6%9C%AA%E7%9F%A5%E5%AE%89%E8%A3%85%E6%96%87%E4%BB%B6%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3Eplatform_testing%2Fbuild%2Ftasks%2Ftests%2Finstrumentation_test_list.mk%EF%BC%9A%E8%AD%A6%E5%91%8A%EF%BC%9Acontinuous_instrumentation_tests%EF%BC%9A%E6%A8%A1%E5%9D%97%E2%80%9CNexusLauncherTests%E2%80%9D%E7%9A%84%E6%9C%AA%E7%9F%A5%E5%AE%89%E8%A3%85%E6%96%87%E4%BB%B6%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3Eplatform_testing%2Fbuild%2Ftasks%2Ftests%2Fplatform_test_list.mk%EF%BC%9A%E8%AD%A6%E5%91%8A%EF%BC%9Aplatform_tests%EF%BC%9A%E6%A8%A1%E5%9D%97%E2%80%9CLauncherRotationStressTest%E2%80%9D%E7%9A%84%E6%9C%AA%E7%9F%A5%E5%AE%89%E8%A3%85%E6%96%87%E4%BB%B6%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3Eplatform_testing%2Fbuild%2Ftasks%2Ftests%2Fplatform_test_list.mk%EF%BC%9A%E8%AD%A6%E5%91%8A%EF%BC%9Aplatform_tests%EF%BC%9A%E6%A8%A1%E5%9D%97%E2%80%9CPlatformScenarioTests%E2%80%9D%E7%9A%84%E6%9C%AA%E7%9F%A5%E5%AE%89%E8%A3%85%E6%96%87%E4%BB%B6%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5B100%25%20634%2F634%5D%20%E7%BC%96%E5%86%99%E6%9E%84%E5%BB%BA%E8%A7%84%E5%88%99...%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E%E5%A4%B1%E8%B4%A5%E7%9A%84%EF%BC%9A%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E%E8%AE%BE%E5%A4%87%2Ffsl%2Fimx8q%2Fmek_8q%2Fmek_8q.mk%3A512%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9A%E5%86%99%E5%85%A5%E5%8F%AA%E8%AF%BB%E7%9B%AE%E5%BD%95%EF%BC%9A%E2%80%9Cdevice%2Ffsl%2Fimx8q%2Finit.recovery.freescale.car.rc%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E09%3A50%3A03%20ckati%20%E5%A4%B1%E8%B4%A5%EF%BC%9A%E9%80%80%E5%87%BA%E7%8A%B6%E6%80%81%201%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E%23%23%23%23%20failed%20to%20build%20some%20targets%20(08%3A26%20(mm%3Ass))%20%23%23%23%23%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100872%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20mek_8q%20%E4%B8%BA%20Android%20Auto%20%E5%90%AF%E7%94%A8%E4%BB%A5%E5%A4%AA%E7%BD%91%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100872%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%A1%A5%E4%B8%81%E6%96%87%E4%BB%B6%E4%B8%BA%20611749f.diff%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100871%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20mek_8q%20%E4%B8%BA%20Android%20Auto%20%E5%90%AF%E7%94%A8%E4%BB%A5%E5%A4%AA%E7%BD%91%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100871%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%BF%E7%94%A8%20android10_5.4.y%20%E4%B8%BB%E7%BA%BF%E8%BF%9B%E8%A1%8C%E6%9C%AC%E5%9C%B0%E6%B5%8B%E8%AF%95%EF%BC%8C%E4%B8%8A%E8%BF%B0%E8%A1%A5%E4%B8%81%E5%B0%86%E4%BD%BF%E4%BB%A5%E5%A4%AA%E7%BD%91%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%3CBR%20%2F%3E%E5%AF%B9%E4%BA%8E%E9%9D%99%E6%80%81%20IP%EF%BC%8C%E9%9C%80%E8%A6%81%E5%9C%A8%20frameworks%2Fopt%2Fnet%2Fethernet.git%20%E4%B8%AD%E7%94%B3%E8%AF%B7%20CL%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100870%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20mek_8q%20%E4%B8%BA%20Android%20Auto%20%E5%90%AF%E7%94%A8%E4%BB%A5%E5%A4%AA%E7%BD%91%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100870%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%9C%A8%E6%BC%94%E7%A4%BA%E5%9B%BE%E5%83%8F%E4%B8%AD%E9%BB%98%E8%AE%A4%E7%A6%81%E7%94%A8%E4%BB%A5%E5%A4%AA%E7%BD%91%E6%98%AF%E6%B2%A1%E6%9C%89%E6%84%8F%E4%B9%89%E7%9A%84%E3%80%82%E5%A6%82%E6%9E%9C%E6%B2%A1%E6%9C%89%E4%BA%92%E8%81%94%E7%BD%91%E8%BF%9E%E6%8E%A5%EF%BC%8C%E5%A4%A7%E5%A4%9A%E6%95%B0%E6%83%85%E5%86%B5%E4%B8%8B%20Android%20%E9%83%BD%E6%98%AF%E6%97%A0%E7%94%A8%E7%9A%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100869%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20mek_8q%20%E4%B8%BA%20Android%20Auto%20%E5%90%AF%E7%94%A8%E4%BB%A5%E5%A4%AA%E7%BD%91%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100869%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%AE%A2%E6%88%B7%E8%B5%B0%E4%BA%86%E4%B8%8D%E5%90%8C%E7%9A%84%E8%B7%AF%E7%BA%BF%EF%BC%8C%E6%88%91%E4%BB%8E%E6%9C%AA%E6%94%B6%E5%88%B0%E6%9C%89%E5%85%B3%E6%AD%A4%E7%9A%84%E5%8F%8D%E9%A6%88%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E5%8F%91%E7%8E%B0%E4%BB%BB%E4%BD%95%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%9C%A8%E6%AD%A4%E5%A4%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100868%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20mek_8q%20%E4%B8%BA%20Android%20Auto%20%E5%90%AF%E7%94%A8%E4%BB%A5%E5%A4%AA%E7%BD%91%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100868%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E4%B9%9F%E9%9D%A2%E4%B8%B4%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E6%9C%89%E4%BB%80%E4%B9%88%E5%8F%91%E7%8E%B0%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100867%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20mek_8q%20%E4%B8%BA%20Android%20Auto%20%E5%90%AF%E7%94%A8%E4%BB%A5%E5%A4%AA%E7%BD%91%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100867%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%20Andy%2C%3C%2FP%3E%3CP%3E%E6%88%91%E5%BA%94%E7%94%A8%E4%BA%86%E4%B8%8A%E8%BF%B0%E8%A1%A5%E4%B8%81%EF%BC%8C%E7%8E%B0%E5%9C%A8%E6%88%91%E7%9A%84%E5%86%85%E6%A0%B8%E5%8F%AF%E4%BB%A5%E6%89%93%E5%8D%B0%20eth%20%E6%B6%88%E6%81%AF%EF%BC%8C%E5%B9%B6%E4%B8%94%20ifconfig%20%E6%98%BE%E7%A4%BA%20eth0%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E5%BD%93%E6%88%91%E5%9C%A8%E4%B8%8E%E4%B8%BB%E6%9C%BA%E7%9A%84%E7%9B%B4%E6%8E%A5%E8%BF%9E%E6%8E%A5%E4%B8%8A%E5%88%86%E9%85%8D%E9%9D%99%E6%80%81%20IP%20%E6%97%B6%EF%BC%8Cping%20%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%EF%BC%8C%E5%87%BA%E7%8E%B0%E4%B8%BB%E6%9C%BA%E4%B8%8D%E5%8F%AF%E8%BE%BE%E7%9A%84%E6%83%85%E5%86%B5%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%88%91%E8%BF%9E%E6%8E%A5%E5%88%B0%E5%B8%A6%E6%9C%89%20DHCP%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E7%9A%84%E8%B7%AF%E7%94%B1%E5%99%A8%EF%BC%8C%E5%AE%83%E5%B0%B1%E6%97%A0%E6%B3%95%E8%8E%B7%E5%8F%96%20IP%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E5%AE%89%E8%A3%85%E5%85%B6%E4%BB%96%20Android%20%E8%BD%AF%E4%BB%B6%E5%8C%85%E6%89%8D%E8%83%BD%E5%90%AF%E7%94%A8%E7%BD%91%E7%BB%9C%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3Emek_8q%3A%2F%23%20dmesg%20%7C%20grep%20eth%3CBR%20%2F%3E%20%5B%200.000000%5D%20psci%3A%E4%BB%8E%20DT%20%E6%8E%A2%E6%B5%8B%E5%AF%BC%E7%AE%A1%E6%96%B9%E6%B3%95%E3%80%82%3CBR%20%2F%3E%20%5B1.062988%5Dfec%205b040000.%E4%BB%A5%E5%A4%AA%E7%BD%91%EF%BC%9A5b040000.%E6%9C%AA%E6%89%BE%E5%88%B0%E4%BB%A5%E5%A4%AA%E7%BD%91%E4%BE%9B%E7%94%B5%20phy%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%99%9A%E6%8B%9F%E8%B0%83%E8%8A%82%E5%99%A8%3CBR%20%2F%3E%5B1.088689%5Dfec%205b040000.%E4%BB%A5%E5%A4%AA%E7%BD%91eth0%3A%E6%B3%A8%E5%86%8C%E7%9A%84PHC%E8%AE%BE%E5%A4%870%3CBR%20%2F%3E%20%5B%205.671765%5D%20%E4%BD%BF%E7%94%A8%E9%9A%8F%E6%9C%BA%E8%87%AA%E4%BB%A5%E5%A4%AA%E7%BD%91%E5%9C%B0%E5%9D%80%3CBR%20%2F%3E%5B%205.676348%5D%20%E4%BD%BF%E7%94%A8%E9%9A%8F%E6%9C%BA%E4%B8%BB%E6%9C%BA%E4%BB%A5%E5%A4%AA%E7%BD%91%E5%9C%B0%E5%9D%80%3CBR%20%2F%3E%5B12.257932%5D%E9%80%9A%E7%94%A8PHY%205b040000.%E4%BB%A5%E5%A4%AA%E7%BD%91-1%3A00%EF%BC%9A%E9%99%84%E5%8A%A0%E7%9A%84%20PHY%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5B%E9%80%9A%E7%94%A8%20PHY%5D%20(mii_bus%3Aphy_addr%3D5b040000.ethernet-1%3A00%2C%20irq%3DPOLL)%3CBR%20%2F%3E%20%5B%2012.270536%5D%20IPv6%3A%20ADDRCONF(NETDEV_UP)%3A%20eth0%3A%20%E9%93%BE%E6%8E%A5%E6%9C%AA%E5%87%86%E5%A4%87%E5%A5%BD%3CBR%20%2F%3E%5B%2012.302364%5D%20IPv6%3A%20ADDRCONF(NETDEV_UP)%3A%20eth0%3A%20%E9%93%BE%E6%8E%A5%E6%9C%AA%E5%87%86%E5%A4%87%E5%A5%BD%3CBR%20%2F%3E%5B%2012.465029%5D%20IPv6%3A%20ADDRCONF(NETDEV_UP)%3A%20eth0%3A%20%E9%93%BE%E6%8E%A5%E6%9C%AA%E5%87%86%E5%A4%87%E5%A5%BD%3CBR%20%2F%3E%5B14.300010%5D%20fec%205b040000.ethernet%20eth0%3A%20%E9%93%BE%E8%B7%AF%E5%B7%B2%E5%90%AF%E5%8A%A8%20-%20100Mbps%2F%E6%BB%A1%E9%80%9F%20-%20%E6%B5%81%E9%87%8F%E6%8E%A7%E5%88%B6%20rx%2Ftx%3CBR%20%2F%3E%20%5B%2014.308841%5D%20IPv6%EF%BC%9AADDRCONF%EF%BC%88NETDEV_CHANGE%EF%BC%89%EF%BC%9Aeth0%EF%BC%9A%E9%93%BE%E6%8E%A5%E5%87%86%E5%A4%87%E5%B0%B1%E7%BB%AA%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎02-12-2020 07:28 AM
更新人:
