Continental Yocto Tutorial / August 2013
Continental Yocto Training
Author:
          Leonardo Sandoval
Material:
PDF Tutorial: i.MX Yocto Project: Freescale Yocto Project Tutorial
Provided Virtual Machine
Wandboard Dual Wandboard - Freescale i.MX6 ARM Cortex-A9 Opensource Community Development Board - BLOG
Tasks:
Task 1: Build and Boot your board in N-steps
    1.    Create a new folder ($ mkdir conti-fsl-community-bsp)
    2.    Follow all N-steps (from the tutorial, page 2) EXCEPT the baking
    3.     Baking has been done for you, so assume that the bake is done!
    4.    Flash:
        conti-fsl-community-bsp $ cd
        $ cd fsl-community-bsp/build
        build $ dd if=tmp/deploy/images/core-image-minimal-wandboard-dual.sdcard of=/dev/sdb bs=1M
        build $ sync # NEVER FORGET THIS STEP, You have been warned!
    5.    Boot
  • Task 2:    Folders
    1. Tree structure & size
        fsl-comunity-bsp $ tree -d -L 2
        fsl-comunity-bsp $ du -h --max-depth=2
  • Task 3:    Architecture
  • Task 4:    Metadata
  • Task 5:    Config files
        build $ cat conf/local.conf
        build $ cat conf/bblayer.conf
  • Task 6:     Layers
build $ bitbake-layers show-layers
sources $ cat meta-fsl-arm/conf/layer.conf
  • Task 7:    Adding an existing layer
    1. Clone the repo
sources $ git clone https://github.com/lsandoval/meta-fsl-test.git
    2. Add the layer to build/bblayers.conf
sources $ cd ../build
build $ vi conf/bblayers.conf
    3. Browse the new layer files
    4. Compile the kernel
build $ bitbake -f -c compile linux-wandboard
build $ bitbake -c deploy linux-wandboard
    5. Flash
   build $ sudo mkdir /media/boot
        build $ sudo mount /dev/sdb1 /media/boot
        build $ cp tmp/deploy/images/uImage /media/boot
        build $ sudo umount /media/boot
    6. Boot
  • Task 8: (Optional)
    • Check the core-image-minimal-test image, bake and flash it.
    • Run the 'helloworld' app
  • Task 9: Q&A
%3CLINGO-SUB%20id%3D%22lingo-sub-1104856%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EContinental%20Yocto%20%E6%95%99%E7%A8%8B%20%2F%202013%20%E5%B9%B4%208%20%E6%9C%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104856%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22%3B%20font-size%3A%2018pt%3B%20text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E5%A4%A7%E9%99%86Yocto%E5%9F%B9%E8%AE%AD%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%9C%E8%80%85%EF%BC%9A%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Leonardo%20Sandoval%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9D%90%E6%96%99%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3EPDF%20Tutorial%3A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-95096%22%20target%3D%22_blank%22%3Ei.MX%20Yocto%20Project%3A%20Freescale%20Yocto%20Project%20Tutorial%3C%2FA%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%E6%8F%90%E4%BE%9B%E7%9A%84%E8%99%9A%E6%8B%9F%E6%9C%BA%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3EWandboard%20Dual%20%3CA%20href%3D%22http%3A%2F%2Fwww.wandboard.org%2F%22%20title%3D%22http%3A%2F%2Fwww.wandboard.org%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EWandboard%20-%20Freescale%20i.MX6%20ARM%20Cortex-A9%20%E5%BC%80%E6%BA%90%E7%A4%BE%E5%8C%BA%E5%BC%80%E5%8F%91%E6%9D%BF%20-%20%E5%8D%9A%E5%AE%A2%3C%2FA%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BB%BB%E5%8A%A1%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%3E%E4%BB%BB%E5%8A%A1%201%EF%BC%9A%E5%88%86%20N%20%E6%AD%A5%E6%9E%84%E5%BB%BA%E5%B9%B6%E5%90%AF%E5%8A%A8%E6%82%A8%E7%9A%84%E5%BC%80%E5%8F%91%E6%9D%BF%20%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1.%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E6%96%B0%E6%96%87%E4%BB%B6%E5%A4%B9%EF%BC%88%24%20mkdir%20conti-fsl-community-bsp%EF%BC%89%3C%2FP%3E%3CP%3E2.%E6%8C%89%E7%85%A7%E6%95%99%E7%A8%8B%E7%AC%AC%202%20%E9%A1%B5%E7%9A%84%E6%89%80%E6%9C%89%20N%20%E6%AD%A5%E9%AA%A4%E6%93%8D%E4%BD%9C%EF%BC%8C%E7%83%98%E7%84%99%E9%99%A4%E5%A4%96%3C%2FP%3E%3CP%3E3.%E7%83%98%E7%84%99%E5%B7%B2%E7%BB%8F%E4%B8%BA%E6%82%A8%E5%AE%8C%E6%88%90%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%81%87%E8%AE%BE%E7%83%98%E7%84%99%E5%B7%B2%E7%BB%8F%E5%AE%8C%E6%88%90%EF%BC%81%3C%2FP%3E%3CP%3E4.%E9%97%AA%E5%85%89%EF%BC%9A%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3Econti-fsl-%E7%A4%BE%E5%8C%BA-bsp%20%24%20cd%3C%2FP%3E%0A%3CP%3E%24%20cd%20fsl-community-bsp%2Fbuild%3C%2FP%3E%0A%3CP%3E%E6%9E%84%E5%BB%BA%20%24%20dd%20if%3Dtmp%2Fdeploy%2Fimages%2Fcore-image-minimal-wandboard-dual.sdcard%20of%3D%2Fdev%2Fsdb%20bs%3D1M%3C%2FP%3E%0A%3CP%3E%E6%9E%84%E5%BB%BA%20%24%20sync%20%23%20%E6%B0%B8%E8%BF%9C%E4%B8%8D%E8%A6%81%E5%BF%98%E8%AE%B0%E8%BF%99%E4%B8%80%E6%AD%A5%EF%BC%8C%E4%BD%A0%E5%B7%B2%E7%BB%8F%E8%A2%AB%E8%AD%A6%E5%91%8A%E4%BA%86%EF%BC%81%3C%2FP%3E%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E5.%E5%BC%95%E5%AF%BC%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%3E%20%E4%BB%BB%E5%8A%A1%202%EF%BC%9A%E6%96%87%E4%BB%B6%E5%A4%B9%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E1.%E6%A0%91%E7%BB%93%E6%9E%84%E5%92%8C%E5%A4%A7%E5%B0%8F%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3Efsl%E7%A4%BE%E5%8C%BA-bsp%24tree-d-L%202%3C%2FP%3E%0A%3CP%3Efsl-%E7%A4%BE%E5%8C%BA-bsp%20%24%20du%20-h%20--max-depth%3D2%3C%2FP%3E%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%3E%E4%BB%BB%E5%8A%A1%203%EF%BC%9A%E6%9E%B6%E6%9E%84%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%3ETask%204%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Metadata%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%3E%E4%BB%BB%E5%8A%A1%205%EF%BC%9A%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%E6%9E%84%E5%BB%BA%20%24%20cat%20conf%2Flocal.conf%3C%2FP%3E%0A%3CP%3E%E6%9E%84%E5%BB%BA%20%24%20cat%20conf%2Fbblayer.conf%3C%2FP%3E%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%3E%20%E4%BB%BB%E5%8A%A1%206%EF%BC%9A%E5%9B%BE%E5%B1%82%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%E6%9E%84%E5%BB%BA%20%24%20bitbake-layers%20%E6%98%BE%E7%A4%BA%E5%B1%82%3C%2FP%3E%0A%3CP%3E%E6%9D%A5%E6%BA%90%24%20cat%20meta-fsl-arm%2Fconf%2Flayer.conf%3C%2FP%3E%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%3E%20%E4%BB%BB%E5%8A%A1%207%EF%BC%9A%E6%B7%BB%E5%8A%A0%E7%8E%B0%E6%9C%89%E5%B1%82%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E1.%E5%85%8B%E9%9A%86%20repo%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%3CSPAN%3E%E6%BA%90%24%20git%20clone%3C%2FSPAN%3E%20%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fgithub.com%2Flsandoval%2Fmeta-fsl-test.git%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2Flsandoval%2Fmeta-fsl-test.git%3C%2FA%3E%3C%2FP%3E%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E2.%E5%B0%86%E5%B1%82%E6%B7%BB%E5%8A%A0%E5%88%B0%20build%2Fbblayers.conf%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%E6%9D%A5%E6%BA%90%20%24%20cd%20..%2Fbuild%3C%2FP%3E%0A%3CP%3E%E6%9E%84%E5%BB%BA%20%24%20vi%20conf%2Fbblayers.conf%3C%2FP%3E%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E3.%E6%B5%8F%E8%A7%88%E6%96%B0%E7%9A%84%E5%9B%BE%E5%B1%82%E6%96%87%E4%BB%B6%3C%2FP%3E%3CP%3E4.%E7%BC%96%E8%AF%91%E5%86%85%E6%A0%B8%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%E6%9E%84%E5%BB%BA%20%24%20bitbake%20-f%20-c%20%E7%BC%96%E8%AF%91%20linux-wandboard%3C%2FP%3E%0A%3CP%3E%E6%9E%84%E5%BB%BA%24%20bitbake%20-c%20%E9%83%A8%E7%BD%B2%20linux-wandboard%3C%2FP%3E%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E5.%E9%97%AA%E5%85%89%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%20build%20%24%20sudo%20mkdir%20%2Fmedia%2Fboot%3C%2FP%3E%0A%3CP%3E%E6%9E%84%E5%BB%BA%20%24%20sudo%20mount%20%2Fdev%2Fsdb1%20%2Fmedia%2Fboot%3C%2FP%3E%0A%3CP%3E%E6%9E%84%E5%BB%BA%20%24%20cp%20tmp%2Fdeploy%2Fimages%2FuImage%20%2Fmedia%2Fboot%3C%2FP%3E%0A%3CP%3E%E6%9E%84%E5%BB%BA%20%24%20sudo%20umount%20%2Fmedia%2Fboot%3C%2FP%3E%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E6.%E5%BC%95%E5%AF%BC%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%3E%E4%BB%BB%E5%8A%A1%208%EF%BC%9A%EF%BC%88%E5%8F%AF%E9%80%89%EF%BC%89%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CUL%3E%3CLI%3E%E6%A3%80%E6%9F%A5%20core-image-minimal-test%20%E5%9B%BE%E5%83%8F%EF%BC%8C%E7%83%98%E7%84%99%E5%B9%B6%E5%88%B7%E6%96%B0%E5%AE%83%E3%80%82%3C%2FLI%3E%3CLI%3E%E8%BF%90%E8%A1%8C%E2%80%9C%20%3CEM%3Ehelloworld%3C%2FEM%3E%20%E2%80%9D%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%3ETask%209%3A%20Q%26amp%3BA%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎08-09-2013 11:13 AM
更新人:
