Compile L3.0.35_4.1.0 on Ubuntu 14.04 64bit OS
This is the procedure and patch to set up Ubuntu 14.04 64bit Linux Host PC and building i.MX6x L3.0.35_4.1.0. It has been tested to build GNOME profile and with FSL Standard MM Codec for i.MX6Q SDP with LVDS display.
Add suggestion about compiling "gstreamer-plugins-good" when selecting "Min profile" rootfs.  Please refer to the Note session.
A) Basic Requirement:
  • Set up the Linux Host PC using ubuntu-14.04-desktop-amd64.iso
  • Make sure the previous LTIB installation and the /opt/freescale have been removed
B) Installed the needed packages to the Linux Host PC
     Needed packages:
$ sudo apt-get install gettext libgtk2.0-dev rpm bison m4 libfreetype6-dev
$ sudo apt-get install libdbus-glib-1-dev liborbit2-dev intltool
$ sudo apt-get install ccache ncurses-dev zlib1g zlib1g-dev gcc g++ libtool
$ sudo apt-get install uuid-dev liblzo2-dev
$ sudo apt-get install tcl dpkg
$ sudo apt-get install asciidoc texlive-latex-base dblatex xutils-dev
$ sudo apt-get install texlive texinfo
$ sudo apt-get install lib32z1 lib32ncurses5 lib32bz2-1.0
$ sudo apt-get install libc6-dev-i386
$ sudo apt-get install u-boot-tools
$ sudo apt-get install scrollkeeper
$ sudo ln -s /usr/lib/x86_64-linux-gnu/librt.so   /usr/lib/librt.so
     Useful tools:
$ sudo apt-get install gparted
$ sudo apt-get install nfs-common nfs-kernel-server
$ sudo apt-get install git-core git-doc git-email git-gui gitk
$ sudo apt-get install meld atftpd
     Note: this operation "$ sudo ln -s /usr/lib/x86_64-linux-gnu/librt.so /usr/lib/librt.so" is used to fix rpm-fs build issue; which is taking reference from: LTIB - Strange problem building IMX6 Linux BSP from fresh on Ubuntu 13.10
C) Unpack and install the LTIB source package and assume done on the home directory:
$ cd ~
$ tar -zxvf L3.0.35_4.1.0_130816_source. tar.gz
$ ./L3.0.35_4.1.0_130816_source/install
D) Apply the patch to make L3.0.35_4.1.0 could be installed and compiled on Ubuntu 14.04 64bit OS
$ cd ~/ltib
$ git apply 0001_make_L3.0.35_4.1.0_compile_on_Ubuntu_14.04_64bit_OS
What the patch is doing:
a) The patch modifies the following files:
    • bin/Ltibutils.pm
    • dist/lfs-5.1/base_libs/base_libs.spec
    • dist/lfs-5.1/m4/m4.spec
    • dist/lfs-5.1/ncurses/ncurses.spec
    • dist/lfs-5.1/openssl/openssl.spec
    • dist/lfs-5.1/xorg-server/xorg-server.spec
b) Add the following files to the pkgs directory:
    • pkgs/m4-1.4.16-1383761043.patch
    • pkgs/m4-1.4.16-1383761043.patch.md5
    • pkgs/openssl-1.0.1c-1398677566.patch
    • pkgs/openssl-1.0.1c-1398677566.patch.md5
    • pkgs/xorg-server-1.6.1-1398785267.patch
    • pkgs/xorg-server-1.6.1-1398785267.patch.md5
E) Then, it is ready to proceed the rest of the LTIB env setup process:
$ cd ~/ltib
$ ./ltib -m config
$ ./ltib
F) about the patch:
  • LTIB script warning when running with Perl v5.18.2
    • associated change:
      • bin/Ltibutils.pm
    • description:
It prints out the following warning when doing package unpack, the patch is used to remove the warning.
defined(@array) is deprecated at bin/Ltibutils.pm line 259
        (Maybe you should just omit the defined()?)
  • xorg-server configuration fail:
    • description: When doing configuration, it stops at saying tslib not found.  It could be fixed by adding -dl when doing tslib test in configuration stage.
NOTE:
A) During the LTIB setup and compilation, these warnings were pop up.  Just ignore them and it seems okay.
B) the dist/lfs-5.1/gst-plugins-good.spec is used to configurate/compile/install the "gstreamer-plugins-good" package.  It set up the environment variables pointing to libcairo but disable it when doing configuration. Thus, libcairo is actually not being used.
In Gnome profile, cario has been selected by default.  Thus, it does not experience the problem when compiling "gstreamer-plugins-good".
However, in Min profile, if you select gstreamer-plugins-good to compile and install to your rootfs but without selecting cario as well, you will experience the error described in this thread: Re: gst-fsl-plugins build failed
Thus, you could follow the solution provide in the Re: gst-fsl-plugins build failed or simply select cairo in your package list.
附件
评论
sure.
fine for me.
Yixing
My ubuntu version is 14.04, thus the patch above should be correct for installing linux target image builder.
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 14.04.1 LTS
Release: 14.04
Codename: trusty
unziping and running git apply, mention the patch is not valid. I can't install ltib and thus not able to download linaro BSP onto my imx6. Please kindly assist.
git apply 0001_make_L3.0.35_4.1.0_compile_on_Ubuntu_14.04_64bit_OS.patch
0001_make_L3.0.35_4.1.0_compile_on_Ubuntu_14.04_64bit_OS.patch:106: trailing whitespace.
%patch1 -p1
0001_make_L3.0.35_4.1.0_compile_on_Ubuntu_14.04_64bit_OS.patch:144: trailing whitespace.
0001_make_L3.0.35_4.1.0_compile_on_Ubuntu_14.04_64bit_OS.patch:164: trailing whitespace.
0001_make_L3.0.35_4.1.0_compile_on_Ubuntu_14.04_64bit_OS.patch:166: trailing whitespace.
0001_make_L3.0.35_4.1.0_compile_on_Ubuntu_14.04_64bit_OS.patch:169: trailing whitespace.
error: patch failed: dist/lfs-5.1/base_libs/base_libs.spec:296
error: dist/lfs-5.1/base_libs/base_libs.spec: patch does not apply
alvin@ubuntu:~/ltib/ltib$ git apply 0001_make_L3.0.35_4.1.0_compile_on_Ubuntu_14.04_64bit_OS.patch
%patch1 -p1
Have commented on this discussion: Re: patch not working in my ubuntu(14.04), LTiB not able to install
Please make sure the patch is just apply one time to a newly created LTIB build environment based on L3.0.35_4.1.0.
Thank u very much.
Hi Heifatisaac Ng ,I met the same problem, but I am unauthorized to view the contents of the link you provided, could you tell me how to be "authorized" ? Thank in advance!
thanks.
i met the problem same as mu qiao ,could you tell me how to be "authorized" ? Thank in advance!
It seems that the link quoted on reply dated 2014/08/10 is no longer exist.  Nevertheless, it was just emphasized the patch is just needed to apply ONCE.
Also, L3.0.35_4.1.0 is a legacy BSP release, it is suggested to use latest Yocto BSP for new development.  The latest one is L3.14.52_1.1.0-GA and could be found in: SABRE Board Reference Design|NXP
Thank you for your prompt reply!
On Mon, 28 Mar 2016 23:43:08 -0700, isaac.ng wrote
Heifatisaac Ng
[https://community.freescale.com/people/isaac.ng?
et=watches.email.document_comment] commented on the document "Compile
L3.0.35_4.1.0 on Ubuntu 14.04 64bit OS"
To view all comments on this document, visit:
https://community.freescale.com/docs/DOC-
100725?et=watches.email.document_comment#comment-34895
I am new to Linux environment and I am facing the issue ring installation of LTIB.
I got error as Can't get: gcc-4.4.4-glibc-2.11.1-multilib-1.0-1.i386.rpm at ./ltib line 2560. Died at ./ltib line 2560.
Please guide me where things went wrong.
Also I am started working on old project which is based on LTIB. But I am new to both LTIB and yocto.
Shall I start using yocto or continue LTIB ??
First of all, if you are working on i.MX6 and i.MX7, would suggest to use latest Yocto BSP.
Details on Yocto Projects could be found in: https://www.yoctoproject.org/
In the i.MX Yocto BSP release, there is also a Yocto Project User's Guide; which will be helpful to setup the build environment specific to i.MX.
Go back to the LTIB environment setup, please advise if you have got the L3.0.35_4.1.0 BSP release.  The toolchain is kept in the BSP package.  Although it is not advise to use LTIB for new project. Nevertheless, you could still find it in: Embedded Linux for i.MX Applications Processors|NXP  and you need to expand the "Board Support Package" sub-session
and scroll down to find the L3.0.35_4.1.0 BSP release:
The setup is specific to Ubuntu 14.04 64bit OS and which was the first 14.04 release.  Thus, you need to have an exact match on that.  It should be able to find ubuntu-14.04-desktop-amd64.iso in Ubuntu 14.04.2 LTS (Trusty Tahr)
Once all the needed packages are ready, it could go thru the steps from A - D accordingly.
%3CLINGO-SUB%20id%3D%22lingo-sub-1129387%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E7%BC%96%E8%AF%91L3.0.35_4.1.0%E5%9C%A8%20Ubuntu%2014.04%2064%20%E4%BD%8D%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E4%B8%8A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1129387%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E8%BF%99%E6%98%AF%E8%AE%BE%E7%BD%AE%20Ubuntu%2014.04%2064%20%E4%BD%8D%20Linux%20%E4%B8%BB%E6%9C%BA%20PC%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20inherit%3B%22%3E%E5%B9%B6%E6%9E%84%E5%BB%BA%20i.MX6x%20L3.0.35_4.1.0%20%E7%9A%84%E6%AD%A5%E9%AA%A4%E5%92%8C%E8%A1%A5%E4%B8%81%E3%80%82%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%22%3E%E5%B7%B2%E6%B5%8B%E8%AF%95%E6%9E%84%E5%BB%BA%20GNOME%20%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%EF%BC%8C%E5%B9%B6%E4%BD%BF%E7%94%A8%20FSL%20%E6%A0%87%E5%87%86%20MM%20%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%E4%B8%BA%E5%B8%A6%20LVDS%20%E6%98%BE%E7%A4%BA%E5%B1%8F%E7%9A%84%20i.MX6Q%20SDP%20%E8%BF%9B%E8%A1%8C%E9%85%8D%E7%BD%AE%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E6%B7%BB%E5%8A%A0%E6%9C%89%E5%85%B3%E5%9C%A8%E9%80%89%E6%8B%A9%E2%80%9C%E6%9C%80%E5%B0%8F%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%E2%80%9Drootfs%20%E6%97%B6%E7%BC%96%E8%AF%91%E2%80%9Cgstreamer-plugins-good%E2%80%9D%E7%9A%84%E5%BB%BA%E8%AE%AE%E3%80%82%E8%AF%B7%E5%8F%82%E9%98%85%3CSTRONG%3E%E6%B3%A8%E9%87%8A%3C%2FSTRONG%3E%E9%83%A8%E5%88%86%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20font-weight%3A%20inherit%3B%22%3E%3CSTRONG%3EA)%20%E5%9F%BA%E6%9C%AC%E8%A6%81%E6%B1%82%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E4%BD%BF%E7%94%A8%20ubuntu-14.04-desktop-amd64.iso%20%E8%AE%BE%E7%BD%AE%20Linux%20%E4%B8%BB%E6%9C%BA%3C%2FLI%3E%3CLI%3E%E7%A1%AE%E4%BF%9D%E5%85%88%E5%89%8D%E7%9A%84%20LTIB%20%E5%AE%89%E8%A3%85%E5%92%8C%20%2Fopt%2Ffreescale%20%E5%B7%B2%E8%A2%AB%E5%88%A0%E9%99%A4%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22line-height%3A%201.5em%3B%20color%3A%20%233d3d3d%3B%20font-size%3A%2012pt%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20font-weight%3A%20inherit%3B%22%3E%3CSTRONG%3EB)%20%E5%AE%89%E8%A3%85%E6%89%80%E9%9C%80%E7%9A%84%E8%BD%AF%E4%BB%B6%E5%8C%85%E5%88%B0%20Linux%20%E4%B8%BB%E6%9C%BA%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSTRONG%3E%E6%89%80%E9%9C%80%E8%BD%AF%E4%BB%B6%E5%8C%85%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20install%20gettext%20libgtk2.0-devrpm%20bison%20m4%20libfreetype6-dev%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20install%20libdbus-glib-1-dev%20liborbit2-dev%20intltool%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20%E5%AE%89%E8%A3%85%20ccache%20ncurses-dev%20zlib1g%20zlib1g-dev%20gcc%20g%2B%2B%20libtool%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20install%20uuid-dev%20liblzo2-dev%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20%E5%AE%89%E8%A3%85%20tcl%20dpkg%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20install%20asciidoc%20texlive-latex-base%20dblatex%20xutils-dev%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20%E5%AE%89%E8%A3%85%20texlive%20texinfo%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20install%20lib32z1%20lib32ncurses5%20lib32bz2-1.0%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20install%20libc6-dev-i386%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20%E5%AE%89%E8%A3%85%20u-boot-tools%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20install%20scrollkeeper%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20ln%20-s%20%2Fusr%2Flib%2Fx86_64-linux-gnu%2Flibrt.so%26nbsp%3B%26nbsp%3B%20%2Fusr%2Flib%2Flibrt.so%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSTRONG%3E%E6%9C%89%E7%94%A8%E7%9A%84%E5%B7%A5%E5%85%B7%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%24%20sudo%20apt-get%20install%20gparted%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20install%20nfs-common%20nfs-kernel-server%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20install%20git-core%20git-doc%20git-email%20git-gui%20gitk%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20install%20meld%20atftpd%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSTRONG%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E6%AD%A4%E6%93%8D%E4%BD%9C%E2%80%9C%24%20sudo%20ln%20-s%20%2Fusr%2Flib%2Fx86_64-linux-gnu%2Flibrt.so%20%2Fusr%2Flib%2Flibrt.so%E2%80%9D%E7%94%A8%E4%BA%8E%E4%BF%AE%E5%A4%8D%20rpm-fs%20%E6%9E%84%E5%BB%BA%E9%97%AE%E9%A2%98%EF%BC%9B%E5%8F%82%E8%80%83%E8%87%AA%EF%BC%9A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fmessage%2F355771%22%20target%3D%22_blank%22%3ELTIB%20-%20%E5%9C%A8%20Ubuntu%2013.10%20%E4%B8%8A%E4%BB%8E%E6%96%B0%E6%9E%84%E5%BB%BA%20IMX6%20Linux%20BSP%20%E6%97%B6%E5%87%BA%E7%8E%B0%E5%A5%87%E6%80%AA%E7%9A%84%E9%97%AE%E9%A2%98%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22line-height%3A%201.5em%3B%20color%3A%20%233d3d3d%3B%20font-size%3A%2012pt%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20font-weight%3A%20inherit%3B%22%3E%3CSTRONG%3EC)%20%E8%A7%A3%E5%8E%8B%E5%B9%B6%E5%AE%89%E8%A3%85%20LTIB%20%E6%BA%90%E5%8C%85%EF%BC%8C%E5%B9%B6%E5%81%87%E8%AE%BE%E5%9C%A8%E4%B8%BB%E7%9B%AE%E5%BD%95%E4%B8%8A%E5%AE%8C%E6%88%90%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20cd%20~%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20tar%20-zxvf%20L3.0.35_4.1.0_130816_source.%20tar.gz%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20.%2FL3.0.35_4.1.0_130816_source%2Finstall%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22line-height%3A%201.5em%3B%20color%3A%20%233d3d3d%3B%20font-size%3A%2012pt%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20font-weight%3A%20inherit%3B%22%3E%3CSTRONG%3ED)%20%E5%BA%94%E7%94%A8%E8%A1%A5%E4%B8%81%E7%A8%8B%E5%BA%8F%E4%BB%A5%E7%94%9F%E6%88%90%20L3.0.35_4.1.0%E5%8F%AF%E4%BB%A5%E5%9C%A8%20Ubuntu%2014.04%2064%20%E4%BD%8D%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E4%B8%8A%E5%AE%89%E8%A3%85%E5%92%8C%E7%BC%96%E8%AF%91%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20cd%20~%2Fltib%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20git%20apply%200001_make_L3.0.35_4.1.0_compile_on_Ubuntu_14.04_64bit_OS%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E8%AF%A5%E8%A1%A5%E4%B8%81%E7%9A%84%E4%BD%9C%E7%94%A8%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CSTRONG%3Ea)%20%E8%AF%A5%E8%A1%A5%E4%B8%81%E4%BF%AE%E6%94%B9%E4%BA%86%E4%BB%A5%E4%B8%8B%E6%96%87%E4%BB%B6%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3Ebin%2FLtibutils.pm%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3Edist%2Flfs-5.1%2Fbase_libs%2Fbase_libs.spec%3C%2FLI%3E%3CLI%3Edist%2Flfs-5.1%2Fm4%2Fm4.spec%3C%2FLI%3E%3CLI%3Edist%2Flfs-5.1%2Fncurses%2Fncurses.spec%3C%2FLI%3E%3CLI%3Edist%2Flfs-5.1%2Fopenssl%2Fopenssl.spec%3C%2FLI%3E%3CLI%3Edist%2Flfs-5.1%2Fxorg-server%2Fxorg-server.spec%3C%2FLI%3E%3C%2FUL%3E%3C%2FUL%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CSTRONG%3Eb)%20%E5%B0%86%E4%BB%A5%E4%B8%8B%E6%96%87%E4%BB%B6%E6%B7%BB%E5%8A%A0%E5%88%B0%20pkgs%20%E7%9B%AE%E5%BD%95%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E5%8C%85%2Fm4-1.4.16-1383761043.%E8%A1%A5%E4%B8%81%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%E5%8C%85%2Fm4-1.4.16-1383761043.%E8%A1%A5%E4%B8%81.md5%3C%2FLI%3E%3CLI%3E%E5%8C%85%2Fopenssl-1.0.1c-1398677566.%E8%A1%A5%E4%B8%81%3C%2FLI%3E%3CLI%3Epkgs%2Fopenssl-1.0.1c-1398677566.patch.md5%3C%2FLI%3E%3CLI%3Epkgs%2Fxorg-server-1.6.1-1398785267.patch%3C%2FLI%3E%3CLI%3Epkgs%2Fxorg-server-1.6.1-1398785267.patch.md5%3C%2FLI%3E%3C%2FUL%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20inherit%3B%20font-size%3A%2012pt%3B%20font-style%3A%20inherit%3B%20color%3A%20%233d3d3d%3B%20line-height%3A%201.5em%3B%22%3E%3CSTRONG%3EE)%20%E7%84%B6%E5%90%8E%EF%BC%8C%E5%B0%B1%E5%8F%AF%E4%BB%A5%E7%BB%A7%E7%BB%AD%E6%89%A7%E8%A1%8C%E5%85%B6%E4%BD%99%E7%9A%84%20LTIB%20%E7%8E%AF%E5%A2%83%E8%AE%BE%E7%BD%AE%E8%BF%87%E7%A8%8B%E4%BA%86%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-style%3A%20inherit%3B%20font-weight%3A%20inherit%3B%20line-height%3A%201.5em%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%20padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-style%3A%20inherit%3B%20font-weight%3A%20inherit%3B%20line-height%3A%201.5em%3B%22%3E%24%20cd%20~%2Fltib%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20inherit%3B%22%3E%24%20.%2Fltib%20-m%20config%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20inherit%3B%22%3E%24%20.%2Fltib%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20inherit%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20inherit%3B%20font-size%3A%2012pt%3B%20font-style%3A%20inherit%3B%20color%3A%20%233d3d3d%3B%20line-height%3A%201.5em%3B%22%3E%3CSTRONG%3EF%EF%BC%89%E5%85%B3%E4%BA%8E%E8%A1%A5%E4%B8%81%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSTRONG%3E%E4%BD%BF%E7%94%A8%20Perl%20v5.18.2%20%E8%BF%90%E8%A1%8C%E6%97%B6%E5%87%BA%E7%8E%B0%20LTIB%20%E8%84%9A%E6%9C%AC%E8%AD%A6%E5%91%8A%3C%2FSTRONG%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CSTRONG%3E%E7%9B%B8%E5%85%B3%E5%8F%98%E6%9B%B4%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3Ebin%2FLtibutils.pm%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E8%AF%B4%E6%98%8E%EF%BC%9A%3C%2FSTRONG%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22padding-left%3A%2090px%3B%22%3E%E5%9C%A8%E8%A7%A3%E5%8C%85%E6%97%B6%E4%BC%9A%E6%89%93%E5%8D%B0%E5%87%BA%E4%BB%A5%E4%B8%8B%E8%AD%A6%E5%91%8A%EF%BC%8C%E8%AF%A5%E8%A1%A5%E4%B8%81%E7%94%A8%E4%BA%8E%E6%B6%88%E9%99%A4%E8%AF%A5%E8%AD%A6%E5%91%8A%E3%80%82%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2090px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%20120px%3B%22%3E%E5%9C%A8%20bin%2FLtibutils.pm%20%E7%AC%AC%20259%20%E8%A1%8C%EF%BC%8Cdefined(%40array)%20%E5%B7%B2%E8%A2%AB%E5%BC%83%E7%94%A8%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%20120px%3B%22%3E%EF%BC%88%E4%B9%9F%E8%AE%B8%E4%BD%A0%E5%BA%94%E8%AF%A5%E7%9C%81%E7%95%A5defined()%EF%BC%9F%EF%BC%89%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%20120px%3B%22%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSTRONG%3Ebusybox%20%E7%BC%96%E8%AF%91%E9%97%AE%E9%A2%98%EF%BC%9A%3C%2FSTRONG%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSTRONG%3E%E7%9B%B8%E5%85%B3%E5%8F%98%E6%9B%B4%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Edist%2Flfs-5.1%2Fbase_libs%2Fbase_libs.spec%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CSTRONG%3E%E5%8F%82%E8%80%83%EF%BC%9A%3C%2FSTRONG%3E%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fmessage%2F332385%22%20target%3D%22_blank%22%3ERe%3A%20Ubuntu%2013.04%20%E4%B8%8A%E7%9A%84%20LTIB%3C%2FA%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSTRONG%3Em4%20%E7%BC%96%E8%AF%91%E9%97%AE%E9%A2%98%EF%BC%9A%3C%2FSTRONG%3E%3CUL%3E%3CLI%3E%3CSTRONG%3E%E7%9B%B8%E5%85%B3%E5%8F%98%E6%9B%B4%EF%BC%9A%3C%2FSTRONG%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%20dist%2Flfs-5.1%2Fm4%2Fm4.spec%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%E5%8C%85%2Fm4-1.4.16-1383761043.%E8%A1%A5%E4%B8%81%3C%2FLI%3E%3CLI%3E%E5%8C%85%2Fm4-1.4.16-1383761043.%E8%A1%A5%E4%B8%81.md5%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E5%8F%82%E8%80%83%EF%BC%9A%3C%2FSTRONG%3E%20%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fsources.gentoo.org%2Fcgi-bin%2Fviewvc.cgi%2Fgentoo-x86%2Fsys-devel%2Fm4%2Ffiles%2Fm4-1.4.16-no-gets.patch%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3C%2FA%3E%3C%2FSPAN%3E%20%3A%2F%2Fsources.gentoo.org%2Fcgi-bin%2Fviewvc.cgi%2Fgentoo-x86%2Fsys-devel%2Fm4%2Ffiles%2Fm4-1.4.16-no-gets.patch%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSTRONG%3Ealsa-utils%20%E7%BC%96%E8%AF%91%E9%97%AE%E9%A2%98%EF%BC%9A%3C%2FSTRONG%3E%3CUL%3E%3CLI%3E%3CSTRONG%3E%E7%9B%B8%E5%85%B3%E5%8F%98%E6%9B%B4%EF%BC%9A%3C%2FSTRONG%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%20dist%2Flfs-5.1%2Fncurses%2Fncurses.spec%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E5%8F%82%E8%80%83%EF%BC%9A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fmessage%2F360556%22%20target%3D%22_blank%22%3ERe%3A%20Android%20%E5%92%8C%20LTIB%20%E5%9C%A8%20ubuntu%2012.04%20x86_64%20%E4%B8%AD%E7%9A%84%E6%9E%84%E5%BB%BA%E9%94%99%E8%AF%AF%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CSTRONG%3E%E7%94%B1%E4%BA%8E%20Perl%20v5.18.2%20%E5%AF%BC%E8%87%B4%E7%9A%84%20openssl%20%E7%BC%96%E8%AF%91%E9%97%AE%E9%A2%98%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CUL%3E%3CLI%3E%3CSTRONG%3E%E7%9B%B8%E5%85%B3%E5%8F%98%E6%9B%B4%EF%BC%9A%3C%2FSTRONG%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3Edist%2Flfs-5.1%2Fopenssl%2Fopenssl.spec%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%E5%8C%85%2Fopenssl-1.0.1c-1398677566.%E8%A1%A5%E4%B8%81%3C%2FLI%3E%3CLI%3Epkgs%2Fopenssl-1.0.1c-1398677566.patch.md5%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E8%AF%B4%E6%98%8E%EF%BC%9A%3C%2FSTRONG%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E5%9C%A8%E5%B0%9D%E8%AF%95%E4%BB%8E%20pod%20%E6%96%87%E4%BB%B6%E7%94%9F%E6%88%90%E6%89%8B%E5%86%8C%E9%A1%B5%E6%97%B6%EF%BC%8Cpod2man%20%E4%B8%AD%E7%9A%84%E6%9E%84%E5%BB%BA%E5%A4%B1%E8%B4%A5%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%E5%8F%82%E8%80%83%E8%B5%84%E6%96%99%EF%BC%9A%3CUL%3E%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fforums.freebsd.org%2Fviewtopic.php%3F%26amp%3Bt%3D41478%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fforums.freebsd.org%2Fviewtopic.php%3F%26amp%3Bt%3D41478%3C%2FA%3E%3C%2FLI%3E%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fgist.github.com%2Fmartensms%2F10107481%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgist.github.com%2Fmartensms%2F10107481%3C%2FA%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSTRONG%3Exorg-server%20%E9%85%8D%E7%BD%AE%E5%A4%B1%E8%B4%A5%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CUL%3E%3CLI%3E%3CSTRONG%3E%E7%9B%B8%E5%85%B3%E5%8F%98%E6%9B%B4%EF%BC%9A%3C%2FSTRONG%3E%3CUL%3E%3CLI%3Edist%2Flfs-5.1%2Fxorg-server%2Fxorg-server.spec%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3Epkgs%2Fxorg-server-1.6.1-1398785267.patch%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3Epkgs%2Fxorg-server-1.6.1-1398785267.patch.md5%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E6%8F%8F%E8%BF%B0%EF%BC%9A%3C%2FSTRONG%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E9%85%8D%E7%BD%AE%E6%97%B6%EF%BC%8C%E6%8F%90%E7%A4%BA%E2%80%9Ctslib%20%E6%9C%AA%E6%89%BE%E5%88%B0%E2%80%9D%E8%80%8C%E5%81%9C%E6%AD%A2%E3%80%82%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E5%9C%A8%E9%85%8D%E7%BD%AE%E9%98%B6%E6%AE%B5%E8%BF%9B%E8%A1%8C%20tslib%20%E6%B5%8B%E8%AF%95%E6%97%B6%E6%B7%BB%E5%8A%A0%20-dl%20%E6%9D%A5%E4%BF%AE%E5%A4%8D%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22line-height%3A%2024px%3B%20color%3A%20%233d3d3d%3B%20font-size%3A%2012pt%3B%22%3E%3CSTRONG%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3EA)%20%E5%9C%A8%20LTIB%20%E8%AE%BE%E7%BD%AE%E5%92%8C%E7%BC%96%E8%AF%91%E6%9C%9F%E9%97%B4%EF%BC%8C%E4%BC%9A%E5%BC%B9%E5%87%BA%E8%BF%99%E4%BA%9B%E8%AD%A6%E5%91%8A%E3%80%82%E5%8F%AA%E8%A6%81%E5%BF%BD%E7%95%A5%E5%AE%83%E4%BB%AC%E5%B0%B1%E6%B2%A1%E9%97%AE%E9%A2%98%E4%BA%86%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22panel01.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22panel01.jpg%22%20style%3D%22width%3A%20563px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F44282i47C34C3F621BF9F5%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22panel01.jpg%22%20alt%3D%22panel01.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22panel2.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22panel2.jpg%22%20style%3D%22width%3A%20535px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111651i15A75CD484FB006D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22panel2.jpg%22%20alt%3D%22panel2.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3EB)%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3Edist%2Flfs-5.1%2F%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3Egst-plugins-good.spec%20%E7%94%A8%E4%BA%8E%E9%85%8D%E7%BD%AE%2F%E7%BC%96%E8%AF%91%2F%E5%AE%89%E8%A3%85%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E2%80%9Cgstreamer-plugins-good%E2%80%9D%E8%BD%AF%E4%BB%B6%E5%8C%85%E3%80%82%E5%AE%83%E8%AE%BE%E7%BD%AE%E4%BA%86%E6%8C%87%E5%90%91%20libcairo%20%E7%9A%84%E7%8E%AF%E5%A2%83%E5%8F%98%E9%87%8F%EF%BC%8C%E4%BD%86%E5%9C%A8%E9%85%8D%E7%BD%AE%E6%97%B6%E7%A6%81%E7%94%A8%E4%BA%86%E5%AE%83%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8Clibcairo%20%E5%AE%9E%E9%99%85%E4%B8%8A%E5%B9%B6%E6%9C%AA%E8%A2%AB%E4%BD%BF%E7%94%A8%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Clipboard011.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Clipboard011.jpg%22%20style%3D%22width%3A%20329px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F45522i50DE9E29DF4D97F4%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Clipboard011.jpg%22%20alt%3D%22Clipboard011.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E5%9C%A8%20Gnome%20%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%E4%B8%AD%EF%BC%8Ccario%20%E5%B7%B2%E8%A2%AB%E9%BB%98%E8%AE%A4%E9%80%89%E4%B8%AD%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E7%BC%96%E8%AF%91%E2%80%9Cgstreamer-plugins-good%E2%80%9D%E6%97%B6%E4%B8%8D%E4%BC%9A%E9%81%87%E5%88%B0%E9%97%AE%E9%A2%98%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E7%84%B6%E8%80%8C%EF%BC%8C%E5%9C%A8%20Min%20%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%E4%B8%AD%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%82%A8%E9%80%89%E6%8B%A9%20gstreamer-plugins-good%20%E8%BF%9B%E8%A1%8C%E7%BC%96%E8%AF%91%E5%B9%B6%E5%AE%89%E8%A3%85%E5%88%B0%E6%82%A8%E7%9A%84%20rootfs%20%E4%BD%86%E6%B2%A1%E6%9C%89%E9%80%89%E6%8B%A9%20cario%EF%BC%8C%E6%82%A8%E5%B0%86%E9%81%87%E5%88%B0%E6%AD%A4%E7%BA%BF%E7%A8%8B%E4%B8%AD%E6%8F%8F%E8%BF%B0%E7%9A%84%E9%94%99%E8%AF%AF%EF%BC%9A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fmessage%2F333151%22%20target%3D%22_blank%22%3ERe%3A%20gst-fsl-plugins%20%E6%9E%84%E5%BB%BA%E5%A4%B1%E8%B4%A5%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E6%8C%89%E7%85%A7%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fmessage%2F333138%22%20target%3D%22_blank%22%3ERe%3A%20gst-fsl-plugins%20%E6%9E%84%E5%BB%BA%E5%A4%B1%E8%B4%A5%3C%2FA%3E%E4%B8%AD%E6%8F%90%E4%BE%9B%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E8%BF%9B%E8%A1%8C%E6%93%8D%E4%BD%9C%EF%BC%8C%E6%88%96%E8%80%85%E7%AE%80%E5%8D%95%E5%9C%B0%E5%9C%A8%E6%82%A8%E7%9A%84%E5%8C%85%E5%88%97%E8%A1%A8%E4%B8%AD%E9%80%89%E6%8B%A9%20cairo%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Clipboard0111.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Clipboard0111.jpg%22%20style%3D%22width%3A%20423px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111652iB2CDC5B35B9277D3%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Clipboard0111.jpg%22%20alt%3D%22Clipboard0111.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1129400%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E7%BC%96%E8%AF%91%20L3.0.35_4.1.0%E5%9C%A8%20Ubuntu%2014.04%2064%20%E4%BD%8D%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E4%B8%8A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1129400%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E9%A6%96%E5%85%88%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%82%A8%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20i.MX6%20%E5%92%8C%20i.MX7%EF%BC%8C%E5%BB%BA%E8%AE%AE%E4%BD%BF%E7%94%A8%E6%9C%80%E6%96%B0%E7%9A%84%20Yocto%20BSP%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%89%E5%85%B3%20Yocto%20%E9%A1%B9%E7%9B%AE%E7%9A%84%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E8%AE%BF%E9%97%AE%EF%BC%9A%20%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fwww.yoctoproject.org%2F%22%20title%3D%22https%3A%2F%2Fwww.yoctoproject.org%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fwww.yoctoproject.org%2F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%20i.MX%20Yocto%20BSP%20%E7%89%88%E6%9C%AC%E4%B8%AD%EF%BC%8C%E8%BF%98%E6%9C%89%E4%B8%80%E4%B8%AA%20Yocto%20%E9%A1%B9%E7%9B%AE%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%EF%BC%9B%E8%BF%99%E5%B0%86%E6%9C%89%E5%8A%A9%E4%BA%8E%E8%AE%BE%E7%BD%AE%E7%89%B9%E5%AE%9A%E4%BA%8E%20i.MX%20%E7%9A%84%E6%9E%84%E5%BB%BA%E7%8E%AF%E5%A2%83%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%94%E5%9B%9E%20LTIB%20%E7%8E%AF%E5%A2%83%E8%AE%BE%E7%BD%AE%EF%BC%8C%E8%AF%B7%E5%91%8A%E7%9F%A5%E6%82%A8%E6%98%AF%E5%90%A6%E5%B7%B2%E8%8E%B7%E5%BE%97%20L3.0.35_4.1.0BSP%20%E5%8F%91%E5%B8%83%E3%80%82%E5%B7%A5%E5%85%B7%E9%93%BE%E4%BF%9D%E5%AD%98%E5%9C%A8%20BSP%20%E5%8C%85%E4%B8%AD%E3%80%82%E5%B0%BD%E7%AE%A1%E4%B8%8D%E5%BB%BA%E8%AE%AE%E5%9C%A8%E6%96%B0%E9%A1%B9%E7%9B%AE%E4%B8%AD%E4%BD%BF%E7%94%A8%20LTIB%E3%80%82%E5%B0%BD%E7%AE%A1%E5%A6%82%E6%AD%A4%EF%BC%8C%E6%82%A8%E4%BB%8D%E7%84%B6%E5%8F%AF%E4%BB%A5%E5%9C%A8%3CA%20class%3D%22link-titled%22%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsoftware-and-tools%2Fsoftware-development-tools%2Fi.mx-software-and-tools%2Fembedded-linux-for-i.mx-applications-processors%3AIMXLINUX%3Fcode%3DIMXLINUX%26amp%3BnodeId%3D015210BAF78711%26amp%3Bfpsp%3D1%26amp%3Btab%3DDesign_Tools_Tab%22%20title%3D%22http%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsoftware-and-tools%2Fsoftware-development-tools%2Fi.mx-software-and-tools%2Fembedded-linux-for-i.mx-applications-processors%3AIMXLINUX%EF%BC%9Fcode%3DIMXLINUX%26amp%3BnodeId%3D015210BAF78711%26amp%3Bfpsp%3D1%26amp%3Btab%3DDesign_Tools_Tab%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E2%80%9Ci.MX%20%E5%BA%94%E7%94%A8%E5%A4%84%E7%90%86%E5%99%A8%E5%B5%8C%E5%85%A5%E5%BC%8F%20Linux%7CNXP%E2%80%9D%3C%2FA%3E%E4%B8%AD%E6%89%BE%E5%88%B0%E5%AE%83%EF%BC%8C%E5%B9%B6%E4%B8%94%E6%82%A8%E9%9C%80%E8%A6%81%E6%89%A9%E5%B1%95%E2%80%9C%E6%9D%BF%E7%BA%A7%E6%94%AF%E6%8C%81%E5%8C%85%E2%80%9D%E5%AD%90%E4%BC%9A%E8%AF%9D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%20style%3D%22width%3A%20771px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F4188iC59F6BC817E64409%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_2.png%22%20alt%3D%22pastedImage_2.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B9%B6%E5%90%91%E4%B8%8B%E6%BB%9A%E5%8A%A8%E6%89%BE%E5%88%B0%20L3.0.35_4.1.0BSP%E7%89%88%E6%9C%AC%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_4.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_4.png%22%20style%3D%22width%3A%20777px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F4107i67B55D0CDE500759%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_4.png%22%20alt%3D%22pastedImage_4.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AF%A5%E8%AE%BE%E7%BD%AE%E7%89%B9%E5%AE%9A%E4%BA%8E%20Ubuntu%2014.04%2064%20%E4%BD%8D%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%EF%BC%8C%E8%BF%99%E6%98%AF%E7%AC%AC%E4%B8%80%E4%B8%AA%2014.04%20%E7%89%88%E6%9C%AC%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%82%A8%E9%9C%80%E8%A6%81%E5%AF%B9%E6%AD%A4%E8%BF%9B%E8%A1%8C%E7%B2%BE%E7%A1%AE%E5%8C%B9%E9%85%8D%E3%80%82%E5%AE%83%E5%BA%94%E8%AF%A5%E8%83%BD%E5%A4%9F%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E5%9C%A8%3CA%20class%3D%22link-titled%22%20href%3D%22http%3A%2F%2Fold-releases.ubuntu.com%2Freleases%2F14.04.0%2F%22%20title%3D%22http%3A%2F%2Fold-releases.ubuntu.com%2Freleases%2F14.04.0%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EUbuntu%2014.04.2%20LTS%20(Trusty%20Tahr)%3C%2FA%3E%E4%B8%AD%E6%89%BE%E5%88%B0%20ubuntu-14.04-desktop-amd64.iso%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%80%E6%97%A6%E6%89%80%E6%9C%89%E9%9C%80%E8%A6%81%E7%9A%84%E5%8C%85%E9%83%BD%E5%87%86%E5%A4%87%E5%A5%BD%E4%BA%86%EF%BC%8C%E5%B0%B1%E5%8F%AF%E4%BB%A5%E7%9B%B8%E5%BA%94%E5%9C%B0%E6%89%A7%E8%A1%8C%E4%BB%8E%20A%20%E5%88%B0%20D%20%E7%9A%84%E6%AD%A5%E9%AA%A4%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1129399%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E7%BC%96%E8%AF%91%20L3.0.35_4.1.0%E5%9C%A8%20Ubuntu%2014.04%2064%20%E4%BD%8D%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E4%B8%8A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1129399%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%26nbsp%3B%3C%2FP%3E%3CP%3E%E6%88%91%E6%98%AF%20Linux%20%E7%8E%AF%E5%A2%83%E7%9A%84%E6%96%B0%E6%89%8B%EF%BC%8C%E6%88%91%E9%9D%A2%E4%B8%B4%20LTIB%20%E5%AE%89%E8%A3%85%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%94%B6%E5%88%B0%E9%94%99%E8%AF%AF%EF%BC%8C%E6%97%A0%E6%B3%95%E8%8E%B7%E5%8F%96%EF%BC%9Agcc-4.4.4-glibc-2.11.1-multilib-1.0-1.i386.rpm%EF%BC%8C%E4%BD%8D%E4%BA%8E.%2Fltib%20%E7%AC%AC%202560%20%E8%A1%8C%E3%80%82%E6%AD%BB%E4%BA%8E.%2Fltib%20%E7%AC%AC%202560%20%E8%A1%8C%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E6%8C%87%E5%AF%BC%E6%88%91%E5%93%AA%E9%87%8C%E5%87%BA%E4%BA%86%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%B9%9F%E5%BC%80%E5%A7%8B%E4%BB%8E%E4%BA%8B%E5%9F%BA%E4%BA%8E%20LTIB%20%E7%9A%84%E6%97%A7%E9%A1%B9%E7%9B%AE%E3%80%82%E4%BD%86%E6%88%91%E5%AF%B9%20LTIB%20%E5%92%8C%20yocto%20%E9%83%BD%E5%BE%88%E9%99%8C%E7%94%9F%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%BA%94%E8%AF%A5%E5%BC%80%E5%A7%8B%E4%BD%BF%E7%94%A8%20yocto%20%E8%BF%98%E6%98%AF%E7%BB%A7%E7%BB%AD%20LTIB%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1129398%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E7%BC%96%E8%AF%91%20L3.0.35_4.1.0%E5%9C%A8%20Ubuntu%2014.04%2064%20%E4%BD%8D%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E4%B8%8A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1129398%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%8F%8A%E6%97%B6%E5%9B%9E%E5%A4%8D%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2016%20%E5%B9%B4%203%20%E6%9C%88%2028%20%E6%97%A5%E6%98%9F%E6%9C%9F%E4%B8%80%2023%3A43%3A08%20-0700%EF%BC%8Cisaac.ng%20%E5%86%99%E9%81%93%3C%2FP%3E%3CBLOCKQUOTE%20level%3D%221%22%3E%3CP%3E%E6%B5%B7%E6%B3%95%E8%92%82%E8%90%A8%E5%85%8B%C2%B7%E5%90%B4%20%3C%2FP%3E%3CP%3E%5B%3CA%20href%3D%22https%3A%2F%2Fcommunity.freescale.com%2Fpeople%2Fisaac.ng%EF%BC%9F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fpeople%2Fisaac.ng%EF%BC%9F%3C%2FA%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3Eet%3Dwatches.email.document_comment%5D%E5%AF%B9%E6%96%87%E4%BB%B6%E2%80%9C%E7%BC%96%E8%AF%91%20%3C%2FP%3E%3CP%3EL3.0.35_4.1.0%E5%9C%A8%20Ubuntu%2014.04%2064%20%E4%BD%8D%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E4%B8%8A%E2%80%9D%3C%2FP%3E%3CBLOCKQUOTE%20level%3D%221%22%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%A6%81%E6%9F%A5%E7%9C%8B%E6%AD%A4%E6%96%87%E6%A1%A3%E7%9A%84%E6%89%80%E6%9C%89%E8%AF%84%E8%AE%BA%EF%BC%8C%E8%AF%B7%E8%AE%BF%E9%97%AE%EF%BC%9A%20%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-%22%20target%3D%22test_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-%3C%2FA%3E%3C%2FP%3E%3CP%3E100725%3Fet%3Dwatches.email.document_comment%23comment-34895%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%26gt%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1129397%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E7%BC%96%E8%AF%91%20L3.0.35_4.1.0%E5%9C%A8%20Ubuntu%2014.04%2064%20%E4%BD%8D%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E4%B8%8A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1129397%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E2014%20%E5%B9%B4%208%20%E6%9C%88%2010%20%E6%97%A5%E5%9B%9E%E5%A4%8D%E4%B8%AD%E5%BC%95%E7%94%A8%E7%9A%84%E9%93%BE%E6%8E%A5%E4%BC%BC%E4%B9%8E%E5%B7%B2%E4%B8%8D%E5%AD%98%E5%9C%A8%E3%80%82%E5%B0%BD%E7%AE%A1%E5%A6%82%E6%AD%A4%EF%BC%8C%E5%8F%AA%E6%98%AF%E5%BC%BA%E8%B0%83%E8%A1%A5%E4%B8%81%E5%8F%AA%E9%9C%80%E5%BA%94%E7%94%A8%E4%B8%80%E6%AC%A1%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E5%A4%96%EF%BC%8CL3.0.35_4.1.0%20%E6%98%AF%E6%97%A7%E7%89%88%20BSP%20%E7%89%88%E6%9C%AC%EF%BC%8C%E5%BB%BA%E8%AE%AE%E4%BD%BF%E7%94%A8%E6%9C%80%E6%96%B0%E7%9A%84%20Yocto%20BSP%20%E8%BF%9B%E8%A1%8C%E6%96%B0%E5%BC%80%E5%8F%91%E3%80%82%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%E6%98%AF%20L3.14.52_1.1.0-GA%E5%8F%AF%E4%BB%A5%E5%9C%A8%E4%BB%A5%E4%B8%8B%E4%BD%8D%E7%BD%AE%E6%89%BE%E5%88%B0%EF%BC%9A%20%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fproducts%2Fmicrocontrollers-and-processors%2Farm-processors%2Fi.mx-applications-processors%2Fi.mx-6-processors%2Fi.mx6qp%2Fsabre-board-for-smart-devices-reference-design-based-on-the-i.mx-6-series%3ARDIMX6SABREBRD%3Ffpsp%3D1%26amp%3Btab%3DDocumentation_Tab%22%20title%3D%22http%3A%2F%2Fwww.nxp.com%2Fproducts%2Fmicrocontrollers-and-processors%2Farm-processors%2Fi.mx-applications-processors%2Fi.mx-6-processors%2Fi.mx6qp%2Fsabre-board-for-smart-devices-reference-design-based-on-the-i.mx-6-series%3ARDIMX6SABREBRD%3Ffpsp%3D1%26amp%3Btab%3DDocumentation_Tab%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ESABRE%20%E6%9D%BF%E5%8F%82%E8%80%83%E8%AE%BE%E8%AE%A1%20%7C%20NXP%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%20style%3D%22width%3A%20789px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F2841i66567BE14F50A1DE%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_3.png%22%20alt%3D%22pastedImage_3.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1129396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E7%BC%96%E8%AF%91%20L3.0.35_4.1.0%E5%9C%A8%20Ubuntu%2014.04%2064%20%E4%BD%8D%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E4%B8%8A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1129396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E5%92%8C%E6%9C%A8%E4%B9%94%E4%B8%80%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%E8%AF%B7%E9%97%AE%E5%A6%82%E4%BD%95%E8%8E%B7%E5%BE%97%E6%8E%88%E6%9D%83%EF%BC%9F%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%E5%85%88%E8%A1%8C%E6%84%9F%E8%B0%A2%EF%BC%81%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1129395%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E7%BC%96%E8%AF%91%20L3.0.35_4.1.0%E5%9C%A8%20Ubuntu%2014.04%2064%20%E4%BD%8D%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E4%B8%8A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1129395%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1129394%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E7%BC%96%E8%AF%91%20L3.0.35_4.1.0%E5%9C%A8%20Ubuntu%2014.04%2064%20%E4%BD%8D%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E4%B8%8A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1129394%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%A8%EF%BC%8C%3CSPAN%20class%3D%22replyToName%22%3E%E4%BB%96%3C%2FSPAN%3E%3CSPAN%20class%3D%22replyToName%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22replyToName%22%3E%E4%BC%8A%E6%B3%95%E8%92%82%E8%90%A8%E5%85%8B%C2%B7%E5%90%B4%3C%2FSPAN%3E%3CSTRONG%20class%3D%22replyTo%20font-color-meta%22%3E%3CSPAN%20class%3D%22replyToName%22%3E%20%3C%2FSPAN%3E%3C%2FSTRONG%3E%EF%BC%8C%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BD%86%E6%88%91%E6%97%A0%E6%9D%83%E6%9F%A5%E7%9C%8B%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E9%93%BE%E6%8E%A5%E7%9A%84%E5%86%85%E5%AE%B9%EF%BC%8C%E6%82%A8%E8%83%BD%E5%91%8A%E8%AF%89%E6%88%91%E5%A6%82%E4%BD%95%E8%8E%B7%E5%BE%97%E2%80%9C%E6%8E%88%E6%9D%83%E2%80%9D%E5%90%97%EF%BC%9F%E6%8F%90%E5%89%8D%E8%B0%A2%E8%B0%A2%EF%BC%81%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1129393%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E7%BC%96%E8%AF%91%20L3.0.35_4.1.0%E5%9C%A8%20Ubuntu%2014.04%2064%20%E4%BD%8D%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E4%B8%8A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1129393%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1129392%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E7%BC%96%E8%AF%91%20L3.0.35_4.1.0%E5%9C%A8%20Ubuntu%2014.04%2064%20%E4%BD%8D%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E4%B8%8A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1129392%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%B7%B2%E8%AF%84%E8%AE%BA%E6%AD%A4%E8%AE%A8%E8%AE%BA%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fmessage%2F426081%22%20target%3D%22_blank%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E8%A1%A5%E4%B8%81%E5%9C%A8%E6%88%91%E7%9A%84%20ubuntu(14.04)%20%E4%B8%AD%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%EF%BC%8CLTiB%20%E6%97%A0%E6%B3%95%E5%AE%89%E8%A3%85%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AF%B7%E7%A1%AE%E4%BF%9D%E8%AF%A5%E8%A1%A5%E4%B8%81%E4%BB%85%E5%BA%94%E7%94%A8%E4%B8%80%E6%AC%A1%E5%88%B0%E5%9F%BA%E4%BA%8E%20L3.0.35_4.1.0%20%E7%9A%84%E6%96%B0%E5%88%9B%E5%BB%BA%E7%9A%84%20LTIB%20%E6%9E%84%E5%BB%BA%E7%8E%AF%E5%A2%83%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1129391%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E7%BC%96%E8%AF%91%20L3.0.35_4.1.0%E5%9C%A8%20Ubuntu%2014.04%2064%20%E4%BD%8D%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E4%B8%8A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1129391%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E7%9A%84%20ubuntu%20%E7%89%88%E6%9C%AC%E6%98%AF%2014.04%EF%BC%8C%E5%9B%A0%E6%AD%A4%E4%B8%8A%E8%BF%B0%E8%A1%A5%E4%B8%81%E5%BA%94%E8%AF%A5%E9%80%82%E5%90%88%E5%AE%89%E8%A3%85%20linux%20%E7%9B%AE%E6%A0%87%E6%98%A0%E5%83%8F%E7%94%9F%E6%88%90%E5%99%A8%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Elsb_release%20-a%3C%2FP%3E%3CP%3E%E6%B2%A1%E6%9C%89%E5%8F%AF%E7%94%A8%E7%9A%84%20LSB%20%E6%A8%A1%E5%9D%97%E3%80%82%3C%2FP%3E%3CP%3EDistributor%20ID%3A%20Ubuntu%3C%2FP%3E%3CP%3EDescription%3A%20Ubuntu%2014.04.1%20LTS%3C%2FP%3E%3CP%3E%E7%89%88%E6%9C%AC%EF%BC%9A14.04%3C%2FP%3E%3CP%3E%E4%BB%A3%E5%8F%B7%EF%BC%9A%E5%80%BC%E5%BE%97%E4%BF%A1%E8%B5%96%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%A7%A3%E5%8E%8B%E5%B9%B6%E8%BF%90%E8%A1%8C%20git%20apply%EF%BC%8C%E6%8F%90%E7%A4%BA%E8%A1%A5%E4%B8%81%E6%97%A0%E6%95%88%E3%80%82%E6%88%91%E6%97%A0%E6%B3%95%E5%AE%89%E8%A3%85%20ltib%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%97%A0%E6%B3%95%E5%B0%86%20linaro%20BSP%20%E4%B8%8B%E8%BD%BD%E5%88%B0%E6%88%91%E7%9A%84%20imx6%20%E4%B8%8A%E3%80%82%E8%AF%B7%E5%8D%8F%E5%8A%A9%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Egit%20%E5%BA%94%E7%94%A8%200001_make_L3.0.35_4.1.0_compile_on_Ubuntu_14.04_64bit_OS.patch%3C%2FP%3E%3CP%3E0001_make_L3.0.35_4.1.0_compile_on_Ubuntu_14.04_64bit_OS.%E8%A1%A5%E4%B8%81%EF%BC%9A106%EF%BC%9A%E5%B0%BE%E9%9A%8F%E7%A9%BA%E6%A0%BC%E3%80%82%3C%2FP%3E%3CP%3E%25%E8%A1%A5%E4%B8%811-p1%20%3C%2FP%3E%3CP%3E0001_make_L3.0.35_4.1.0_compile_on_Ubuntu_14.04_64bit_OS.%E8%A1%A5%E4%B8%81%EF%BC%9A144%EF%BC%9A%E5%B0%BE%E9%9A%8F%E7%A9%BA%E6%A0%BC%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E0001_make_L3.0.35_4.1.0_compile_on_Ubuntu_14.04_64bit_OS.%E8%A1%A5%E4%B8%81%EF%BC%9A164%EF%BC%9A%E5%B0%BE%E9%9A%8F%E7%A9%BA%E6%A0%BC%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E0001_make_L3.0.35_4.1.0_compile_on_Ubuntu_14.04_64bit_OS.%E8%A1%A5%E4%B8%81%EF%BC%9A166%EF%BC%9A%E5%B0%BE%E9%9A%8F%E7%A9%BA%E6%A0%BC%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E0001_make_L3.0.35_4.1.0_compile_on_Ubuntu_14.04_64bit_OS.%E8%A1%A5%E4%B8%81%EF%BC%9A169%EF%BC%9A%E5%B0%BE%E9%9A%8F%E7%A9%BA%E6%A0%BC%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E8%A1%A5%E4%B8%81%E5%A4%B1%E8%B4%A5%EF%BC%9Adist%2Flfs-5.1%2Fbase_libs%2Fbase_libs.spec%3A296%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9Adist%2Flfs-5.1%2Fbase_libs%2Fbase_libs.spec%EF%BC%9A%E8%A1%A5%E4%B8%81%E4%B8%8D%E9%80%82%E7%94%A8%3C%2FP%3E%3CP%3Ealvin%40ubuntu%3A~%2Fltib%2Fltib%24%20git%20apply%200001_make_L3.0.35_4.1.0_compile_on_Ubuntu_14.04_64bit_OS.patch%3C%2FP%3E%3CP%3E0001_make_L3.0.35_4.1.0_compile_on_Ubuntu_14.04_64bit_OS.%E8%A1%A5%E4%B8%81%EF%BC%9A106%EF%BC%9A%E5%B0%BE%E9%9A%8F%E7%A9%BA%E6%A0%BC%E3%80%82%3C%2FP%3E%3CP%3E%25%E8%A1%A5%E4%B8%811-p1%20%3C%2FP%3E%3CP%3E0001_make_L3.0.35_4.1.0_compile_on_Ubuntu_14.04_64bit_OS.%E8%A1%A5%E4%B8%81%EF%BC%9A144%EF%BC%9A%E5%B0%BE%E9%9A%8F%E7%A9%BA%E6%A0%BC%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E0001_make_L3.0.35_4.1.0_compile_on_Ubuntu_14.04_64bit_OS.%E8%A1%A5%E4%B8%81%EF%BC%9A164%EF%BC%9A%E5%B0%BE%E9%9A%8F%E7%A9%BA%E6%A0%BC%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E0001_make_L3.0.35_4.1.0_compile_on_Ubuntu_14.04_64bit_OS.%E8%A1%A5%E4%B8%81%EF%BC%9A166%EF%BC%9A%E5%B0%BE%E9%9A%8F%E7%A9%BA%E6%A0%BC%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E0001_make_L3.0.35_4.1.0_compile_on_Ubuntu_14.04_64bit_OS.%E8%A1%A5%E4%B8%81%EF%BC%9A169%EF%BC%9A%E5%B0%BE%E9%9A%8F%E7%A9%BA%E6%A0%BC%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E8%A1%A5%E4%B8%81%E5%A4%B1%E8%B4%A5%EF%BC%9Adist%2Flfs-5.1%2Fbase_libs%2Fbase_libs.spec%3A296%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9Adist%2Flfs-5.1%2Fbase_libs%2Fbase_libs.spec%EF%BC%9A%E8%A1%A5%E4%B8%81%E4%B8%8D%E9%80%82%E7%94%A8%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1129390%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E7%BC%96%E8%AF%91%20L3.0.35_4.1.0%E5%9C%A8%20Ubuntu%2014.04%2064%20%E4%BD%8D%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E4%B8%8A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1129390%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E5%AE%9C%E5%85%B4%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1129389%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E7%BC%96%E8%AF%91%20L3.0.35_4.1.0%E5%9C%A8%20Ubuntu%2014.04%2064%20%E4%BD%8D%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E4%B8%8A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1129389%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%AF%B9%E6%88%91%E6%9D%A5%E8%AF%B4%E5%BE%88%E5%A5%BD%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1129388%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E7%BC%96%E8%AF%91%20L3.0.35_4.1.0%E5%9C%A8%20Ubuntu%2014.04%2064%20%E4%BD%8D%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E4%B8%8A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1129388%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%BD%93%E7%84%B6%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎05-02-2014 11:39 PM
更新人:
