1. Making information easier for our members to find, and make the community more effective:
2. Getting FSL help:
If you want to add a "tag" to an existing document, Bookmark the item (look in the upper right for the bookmark tab), then EDIT that bookmark. You can add tags to your bookmark, which now can be used for search / sort.
If you want to make a comment to or alert someone about a particular discussion, you can use the share feature (look in the upper right for the "share" tab), This will send a notice to people (with your comments) and includes a link to the discussion item. These "share" comments do not become part of the discussion thread, nor are they searchable content.
I would like to be able to "share" with someone who is not my 'friend'
Sharing works like direct messages - you need to connect with someone, and vice versa, before you can share or DM with him. That's not a selectable parameter.
thanks grant!
