Building Linux Image with QT5 for UDOO Quad
Hi everybody,
The attached document walks you through to build a Linux image for UDOO Quad board with QT5 support by using a Yocto Project build environment. The Kernel used in this process is 3.14.52.
I hope you find it useful.
Carlos
%3CLINGO-SUB%20id%3D%22lingo-sub-1102842%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EBuilding%20Linux%20Image%20with%20QT5%20for%20UDOO%20Quad%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1102842%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20everybody%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThe%20attached%20document%20walks%20you%20through%20to%20build%20a%20Linux%20image%20for%20UDOO%20Quad%20board%20with%20QT5%20support%20by%20using%20a%20Yocto%20Project%20build%20environment.%20The%20Kernel%20used%20in%20this%20process%20is%203.14.52.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20hope%20you%20find%20it%20useful.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBest%20regards%2C%3C%2FP%3E%3CP%3ECarlos%3C%2FP%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎10-04-2016 03:30 PM
Updated by:
