Boot I.MX6q SABRE over the Network using TFTP and NFS
Host TFTP and NFS Configuration
Now configure the Trivial File Transfer Protocol (TFTP) server and Networked File System (NFS) server. U-Boot will download the Linux kernel and dtb file using tftp and then the kernel will mount (via NFS) its root file system on the computer hard drive.
1. TFTP Setup
1.1.1 Prepare the TFTP Service
Get the required software if not already set up. On host for TFTP:
Install TFTP on Host
$ sudo apt-get install tftpd-hpa
(Note: There are a number of examples in various forums, etc, of how to automatically start the TFTP service - but not all are successful on all Linux distro's it seems! The following may work for you.)
Start the tftpd-hpa service automatically by adding a command to /etc/rc.local.
$ vi /etc/rc.local
Now, just before the exit 0 line edit below command then Save and Exit.
$ service tftpd-hpa start
Now, To control the TFTP service from the command line use:
$ service tftpd-hpa restart
To check the status of the TFTP service from the command line use:
$ service tftpd-hpa status
1.1.1 Setup the TFTP Directories
Now, we have to create the directory which will contain the kernel image and the device tree blob file.
$ mkdir -p /imx-boot/imx6q-sabre/tftp
Then, copy the kernel image and the device tree blob file in this directory.
$ cp {YOCTO_BUILD_DIR}/tmp/deploy/images/{TARGET}/zImage /imx-boot/imx6q-sabre/tftp
$ cp {YOCTO_BUILD_DIR}/tmp/deploy/images/{TARGET}/<dtb file> /imx-boot/imx6q-sabre/tftp
OR
we can use the default directory created by yocto {YOCTO_BUILD_DIR}/tmp/deploy/images/{TARGET}/
The tftpd-hpa service looks for requested files under /imx-boot/imx6q-sabre/tftp
The default tftpd-hpa directory may vary with distribution/release, but it is specified in the configuration file: /etc/default/tfptd-hpa. We have to change this default directory with our directory
Edit default tftp directory
$ vi /etc/default/tftpd-hpa
Now, change the directory defined as TFTP_DIRECTORY with your host system directory which contains kernel and device tree blob file.
Using created directory
TFTP_DIRECTORY=”/imx-boot/imx6q-sabre/tftp”
OR
Using Yocto directory path
TFTP_DIRECTORY=”{YOCTO_BUILD_DIR}/tmp/deploy/images/{TARGET}”
Restart the TFTP service if required
1.2 NFS Setup
1.2.1 Prepare the NFS Service
Get the required software if not already set up. On host for NFS:
Install NFS on Host
$ sudo apt-get install nfs-kernel-server
The NFS service starts automatically. To control NFS services :
$ service nfs-kernel-server restart
To check the status of the NFS service from the command line :
$ service nfs-kernel-server status
1.2.2 Setup the NFS Directories
Now, we have to create the directory which will contain the root file system.
$ mkdir -p /imx-boot/imx6q-sabre/nfs
Then, copy the rootfs in this directory.
$ cp -R {YOCTO_BUILD_DIR}/tmp/work/{TARGET}-poky-linux-gnueabi/{IMAGE}/1.0-r0/rootfs/* /imx-boot/imx6q-sabre/nfs
OR
we can use the default directory created by yocto.
$ {YOCTO_BUILD_DIR}/tmp/work/{TARGET}-poky-linux-gnueabi/{IMAGE}/1.0-r0/rootfs
1.2.3 Update NFS Export File
The NFS server requires /etc/exports to be configured correctly to access NFS filesystem directory to specific hosts.
$ vi /etc/exports
Then, edit below line into the opened file.
<”YOUR NFS DIRECTORY”> <YOUR BOARD IP>(rw,sync,no_root_squash,no_subtree_check)
Ex.
If you created custom directory for NFS then,
/imx-boot/imx6q-sabre/nfs <YOUR BOARD IP>(rw,sync,no_root_squash,no_subtree_check)
Ex: /imx-boot/imx6q-sabre/nfs 192.168.*.*(rw,sync,no_root_squash,no_subtree_check)
OR
/{YOCTO_BUILD_DIR}/tmp/work/{TARGET}-poky-linux-gnueabi/{IMAGE}/1.0-r0/rootfs <YOUR BOARD IP>(rw,sync,no_root_squash,no_subtree_check)
Now, we need to restart the NFS service.
2 Target Setup
We need to set up the network IP address of our target.
Power On the board and hit a key to stop the U-Boot from continuing. Set the below parameters,
setenv serverip 192.168.0.206       //This must be your Host IP address
The path where the rootfs is placed in our host has to be indicated in the U-Boot,
Ex.
// if you choose default folder created by YOCTO
setenv nfsroot /{YOCTO_BUILD_DIR}/tmp/work/{TARGET}-poky-linux-gnueabi/{IMAGE}/1.0-r0/rootfs
OR
// if you create custom directory for NFS
setenv nfsroot /imx-boot/imx6q-sabre/nfs
Now, we have to set kernel image name and device tree blob file name in the u-boot,
setenv image < zImage name >
setenv fdt_file <dtb file name on host>
Now, set the bootargs for the kernel boot,
setenv netargs 'setenv bootargs console=${console},${baudrate} ${smp} root=/dev/nfs ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp'
Use printenv command and check loadaddr and fdt_addr environment variables variables for I.MX6Q SABRE,
loadaddr=0x12000000
fdt_addr=0x18000000
Also, check netboot environment variable. It should be like below,
netboot=echo Booting from net ...; run netargs; if test ${ip_dyn} = yes; then setenv get_cmd dhcp; else setenv get_cmd tftp; fi; ${get_cmd} ${image}; if test ${boot_fdt} = yes || test ${boot_fdt} = try; then if ${get_cmd} ${fdt_addr} ${fdt_file}; then bootz ${loadaddr} - ${fdt_addr}; else if test ${boot_fdt} = try; then bootz; else echo WARN: Cannot load the DT; fi; fi; else bootz; fi;
Now, set environment variable bootcmd to boot every time from the network,
setenv bootcmd run netboot
Now finally save those variable in u-boot:
saveenv
Reset your board; it should now boot from the network:
U-Boot 2016.03-imx_v2016.03_4.1.15_2.0.0_ga+ga57b13b (Apr 17 2018 - 17:13:43 +0530)
Net:   FEC [PRIME]
Normal Boot
Hit any key to stop autoboot:  0
Using FEC device
TFTP from server 192.168.0.206; our IP address is 192.168.3.101
Filename 'zImage'.
Load address: 0x12000000
Loading: #################################################################
        2.1 MiB/s
done
Bytes transferred = 6578216 (646028 hex)
Using FEC device
Filename 'imx6q-sabresd.dtb'.
Load address: 0x18000000
Loading: ####
        1.8 MiB/s
done
Bytes transferred = 45893 (b345 hex)
Kernel image @ 0x12000000 [ 0x000000 - 0x646028 ]
## Flattened Device Tree blob at 18000000
  Booting using the fdt blob at 0x18000000
  Using Device Tree in place at 18000000, end 1800e344
switch to ldo_bypass mode!
Starting kernel ...
コメント
We can publish this document on community.nxp.com public portal, which can help others to utilize this.
karinavalencia‌
Hi Karina,
Help me to publish this document in https://community.nxp.com/community/imx if you found this document helpful and suitable.
Let me know if there is any modification required.
%3CLINGO-SUB%20id%3D%22lingo-sub-1129169%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ETFTP%E3%81%8A%E3%82%88%E3%81%B3NFS%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E7%B5%8C%E7%94%B1%E3%81%A7%E3%81%AEI.MX6q%20SABRE%E3%81%AE%E8%B5%B7%E5%8B%95%20%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1129169%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CH1%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%20id%3D%22toc-hId-382601292%22%20id%3D%22toc-hId-1304042533%22%3E%3CSPAN%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20font-size%3A%2016.5pt%3B%22%3E%3CSTRONG%3E%E3%83%9B%E3%82%B9%E3%83%88%E3%81%AE%20TFTP%20%E3%81%A8%20NFS%20%E3%81%AE%E8%A8%AD%E5%AE%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%AC%A1%E3%81%AB%E3%80%81Trivial%20File%20Transfer%20Protocol(TFTP)%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%A8Networked%20File%20System(NFS)%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%82%92%E6%A7%8B%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82U-Boot%20%E3%81%AF%20tftp%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%A8%20dtb%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AF%20(NFS%20%E7%B5%8C%E7%94%B1%E3%81%A7)%20%E3%81%9D%E3%81%AE%E3%83%AB%E3%83%BC%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%E3%81%AB%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FP%3E%3CH2%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%20id%3D%22toc-hId-1073162766%22%20id%3D%22toc-hId-1994604007%22%3E%3CSPAN%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20font-size%3A%2013.5pt%3B%22%3E%3CSTRONG%3E1.%20TFTP%20Setup%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20font-size%3A%2013.5pt%3B%22%3E%3CSTRONG%3E1.1.1TFTP%20%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%81%AE%E6%BA%96%E5%82%99%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E5%BF%85%E8%A6%81%E3%81%AA%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E3%81%BE%E3%81%A0%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E5%85%A5%E6%89%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82TFTP%20%E3%81%AE%E3%83%9B%E3%82%B9%E3%83%88%E3%81%AE%E5%A0%B4%E5%90%88%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FP%3E%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%3CTHEAD%3E%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%3CTH%3E%E3%83%9B%E3%82%B9%E3%83%88%E3%81%B8%E3%81%AETFTP%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FTH%3E%3C%2FTR%3E%3C%2FTHEAD%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%24%20%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Esudo%20apt-get%20tftpd-hpa%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E(%E6%B3%A8%3A%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AA%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A9%E3%83%A0%E3%81%AA%E3%81%A9%E3%81%AB%E3%81%AF%E3%80%81TFTP%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%82%92%E8%87%AA%E5%8B%95%E7%9A%84%E3%81%AB%E9%96%8B%E5%A7%8B%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AE%E4%BE%8B%E3%81%8C%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AELinux%E3%83%87%E3%82%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%99%E3%81%B9%E3%81%A6%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%99%E3%82%8B%E3%82%8F%E3%81%91%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E5%83%8D%E3%81%8F%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%3CTHEAD%3E%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%3CTH%3E%2Fetc%2Frc.local%20%E3%81%AB%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%80%81tftpd-hpa%20%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%82%92%E8%87%AA%E5%8B%95%E7%9A%84%E3%81%AB%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FTH%3E%3C%2FTR%3E%3C%2FTHEAD%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%24%20%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Evi%20%2Fetc%2Frc.local%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%3CTHEAD%3E%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%3CTH%3E%E6%AC%A1%E3%81%AB%E3%80%81exit%200%E8%A1%8C%E3%81%AE%E7%9B%B4%E5%89%8D%E3%81%AB%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E7%B7%A8%E9%9B%86%E3%81%97%E3%80%81%E6%AC%A1%E3%81%AB%5B%E4%BF%9D%E5%AD%98%E3%81%97%E3%81%A6%E7%B5%82%E4%BA%86%5D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FTH%3E%3C%2FTR%3E%3C%2FTHEAD%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%24%20%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23f9f9f9%3B%20text-decoration%3A%20none%3B%20font-size%3A%2010.5pt%3B%22%3Eservice%20tftpd-hpa%20start%3C%2FSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%3CTHEAD%3E%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%3CTH%3E%E3%81%93%E3%81%93%E3%81%A7%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%8B%E3%82%89TFTP%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%82%92%E5%88%B6%E5%BE%A1%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FTH%3E%3C%2FTR%3E%3C%2FTHEAD%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%24%20%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23f9f9f9%3B%20text-decoration%3A%20none%3B%20font-size%3A%2010.5pt%3B%22%3Eservice%20tftpd-hpa%E3%81%AE%E5%86%8D%E8%B5%B7%E5%8B%95%3C%2FSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20%23f9f9f9%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FP%3E%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%3CTHEAD%3E%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%3CTH%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%8B%E3%82%89TFTP%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%81%AE%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FTH%3E%3C%2FTR%3E%3C%2FTHEAD%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%24%20%3CSPAN%20style%3D%22background-color%3A%20%23f9f9f9%3B%20color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20font-size%3A%2010.5pt%3B%22%3Eservice%20tftpd-hpa%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23f9f9f9%3B%20color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20font-size%3A%2010.5pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FP%3E%3CH3%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%20id%3D%22toc-hId-1763724240%22%20id%3D%22toc-hId--1609801815%22%3E%3CSPAN%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20font-size%3A%2013.5pt%3B%22%3E%3CSTRONG%3E1.1.1TFTP%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FH3%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3C%2FP%3E%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%3CTHEAD%3E%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%3CTH%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%A8%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AE%E3%83%96%E3%83%AD%E3%83%96%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%90%AB%E3%82%80%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FTH%3E%3C%2FTR%3E%3C%2FTHEAD%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%24%20%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Emkdir%20-p%20%2Fimx-boot%2Fimx6q-sabre%2Ftftp%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3C%2FP%3E%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%3CTHEAD%3E%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%3CTH%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%A8%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%83%84%E3%83%AA%E3%83%BC%20BLOB%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%81%93%E3%81%AE%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FTH%3E%3C%2FTR%3E%3C%2FTHEAD%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%24%20%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Ecp%20%7BYOCTO_BUILD_DIR%7D%2Ftmp%2Fdeploy%2Fimages%2F%7BTARGET%7D%2FzImage%20%2Fimx-boot%2Fimx6q-sabre%2Ftftp%3C%2FSPAN%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20margin-right%3A%20-13.5pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23333333%3B%22%3E%24%3C%2FSPAN%3E%20cp%20%7BYOCTO_BUILD_DIR%7D%2Ftmp%2Fdeploy%2Fimages%2F%7BTARGET%7D%2F%3CDTB%20file%3D%22%22%3E%20%2Fimx-boot%2Fimx6q-sabre%2Ftftp%3C%2FDTB%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20margin-right%3A%20-13.5pt%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23f9f9f9%3B%20color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20font-size%3A%2010.5pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23f9f9f9%3B%20color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20font-size%3A%2010.5pt%3B%22%3E%3CSTRONG%3E%E3%81%BE%E3%81%9F%E3%81%AF%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FP%3E%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011pt%3B%22%3Eyocto%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSTRONG%3E%7BYOCTO_BUILD_DIR%7D%2Ftmp%2Fdeploy%2Fimages%2F%7BTARGET%7D%2F%3C%2FSTRONG%3E%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23f9f9f9%3B%20color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20font-size%3A%2010.5pt%3B%22%3E%3CSTRONG%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Etftpd-hpa%20%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%81%AF%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSTRONG%3E%2Fimx-boot%2Fimx6q-sabre%2Ftftp%3C%2FSTRONG%3E%20%E3%81%A7%E8%A6%81%E6%B1%82%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%8E%A2%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%20tftpd-hpa%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%83%87%E3%82%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%2F%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%95%B0%E3%81%AA%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%23000000%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%20font-size%3A%2010.5pt%3B%22%3E%3CEM%3E%2Fetc%2Fdefault%2Ftfptd-hpa%3C%2FEM%3E%3C%2FSPAN%3E%20%E3%81%A7%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E3%80%82%E3%81%93%E3%81%AE%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%82%92%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%A7%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%3CTHEAD%3E%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%3CTH%3E%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%20tftp%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AE%E7%B7%A8%E9%9B%86%3C%2FTH%3E%3C%2FTR%3E%3C%2FTHEAD%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%24%20%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Evi%26nbsp%3B%2Fetc%2Fdefault%2Ftftpd-hpa%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20font-size%3A%2010.5pt%3B%22%3E%3CSTRONG%3E%E6%AC%A1%E3%81%AB%E3%80%81TFTP_DIRECTORY%E3%81%A8%E3%81%97%E3%81%A6%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%82%92%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%20%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%A8%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AEblob%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%20%E3%82%92%E5%90%AB%E3%82%80%E3%83%9B%E3%82%B9%E3%83%88%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%20%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FP%3E%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%3CTHEAD%3E%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%3CTH%3E%E4%BD%9C%E6%88%90%E3%81%97%E3%81%9F%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FTH%3E%3C%2FTR%3E%3C%2FTHEAD%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%20text-decoration%3A%20none%3B%20font-size%3A%2010.5pt%3B%22%3ETFTP_DIRECTORY%3D%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3E%2Fimx-boot%2Fimx6q-sabre%2Ftftp%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%20text-decoration%3A%20none%3B%20font-size%3A%2010.5pt%3B%22%3E%22%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20font-size%3A%2010.5pt%3B%22%3E%3CSTRONG%3E%E3%81%BE%E3%81%9F%E3%81%AF%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FP%3E%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%3CTHEAD%3E%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%3CTH%3EYocto%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%83%91%E3%82%B9%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FTH%3E%3C%2FTR%3E%3C%2FTHEAD%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%20text-decoration%3A%20none%3B%20font-size%3A%2010.5pt%3B%22%3ETFTP_DIRECTORY%3D%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3E%7BYOCTO_BUILD_DIR%7D%2Ftmp%2Fdeploy%2Fimages%2F%7BTARGET%7D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%20text-decoration%3A%20none%3B%20font-size%3A%2010.5pt%3B%22%3E%22%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FP%3E%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%3CTHEAD%3E%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%3CTH%3E%E5%BF%85%E8%A6%81%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6TFTP%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%82%92%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%3C%2FTH%3E%3C%2FTR%3E%3C%2FTHEAD%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%24%20%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Eservice%20tftpd-hpa%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%81%AE%E5%86%8D%E8%B5%B7%E5%8B%95%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CH2%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%20id%3D%22toc-hId-1753221136%22%20id%3D%22toc-hId--1620304919%22%3E%3CSPAN%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20font-size%3A%2013.5pt%3B%22%3E%3CSTRONG%3E1.2%20NFS%20%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FP%3E%3CH3%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%20id%3D%22toc-hId--1851184686%22%20id%3D%22toc-hId--929743445%22%3E%3CSPAN%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20font-size%3A%2013.5pt%3B%22%3E%3CSTRONG%3E1.2.1%20NFS%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%81%AE%E6%BA%96%E5%82%99%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FH3%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E5%BF%85%E8%A6%81%E3%81%AA%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E3%81%BE%E3%81%A0%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E5%85%A5%E6%89%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82NFS%20%E3%81%AE%E3%83%9B%E3%82%B9%E3%83%88%E4%B8%8A%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FP%3E%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%3CTHEAD%3E%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%3CTH%3E%E3%83%9B%E3%82%B9%E3%83%88%E3%81%B8%E3%81%AENFS%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FTH%3E%3C%2FTR%3E%3C%2FTHEAD%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%24%20%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Esudo%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Eapt-get%20nfs-kernel-server%20%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FP%3E%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%3CTHEAD%3E%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%3CTH%3ENFS%20%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%81%8C%E8%87%AA%E5%8B%95%E7%9A%84%E3%81%AB%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82NFS%20%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%82%92%E5%88%B6%E5%BE%A1%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%A7%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FTH%3E%3C%2FTR%3E%3C%2FTHEAD%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%24%20%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Eservice%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Enfs-kernel-server%20restart%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FP%3E%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%3CTHEAD%3E%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%3CTH%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%8B%E3%82%89NFS%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%81%AE%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%A7%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FTH%3E%3C%2FTR%3E%3C%2FTHEAD%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%24%20%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Eservice%20nfs-k%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Eernel-server%20status%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH3%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%20id%3D%22toc-hId-636328147%22%20id%3D%22toc-hId-1557769388%22%3E%3CSPAN%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20font-size%3A%2013.5pt%3B%22%3E%3CSTRONG%3E1.2.2NFS%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FH3%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FP%3E%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%3CTHEAD%3E%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%3CTH%3E%E6%AC%A1%E3%81%AB%E3%80%81%E3%83%AB%E3%83%BC%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E5%90%AB%E3%82%80%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FTH%3E%3C%2FTR%3E%3C%2FTHEAD%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%24%20%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Emkdir%20-p%20%2F%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Eimx-boot%2Fimx6q-sabre%2F%3C%2FSPAN%3Enfs%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%3CTHEAD%3E%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%20height%3A%2025px%3B%22%3E%3CTH%20style%3D%22height%3A%2025px%3B%22%3E%E6%AC%A1%E3%81%AB%E3%80%81%E3%81%93%E3%81%AE%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E5%86%85%E3%81%AE%20rootfs%20%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FTH%3E%3C%2FTR%3E%3C%2FTHEAD%3E%3CTBODY%3E%3CTR%20style%3D%22height%3A%2025px%3B%22%3E%3CTD%20style%3D%22height%3A%2025px%3B%22%3E%24%20%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Ecp%20-R%20%7BYOCTO_BUILD_DIR%7D%2Ftmp%2Fwork%2F%7BTARGET%7D-poky-linux-gnueabi%2F%7BIMAGE%7D%2F1.0-r0%2Frootfs%2F*%20%2Fimx-boot%2Fimx6q-sabre%2Fnfs%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20margin-right%3A%20-13.5pt%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSTRONG%3E%E3%81%BE%E3%81%9F%E3%81%AF%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FP%3E%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%3CTHEAD%3E%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%3CTH%3Eyocto%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%97%E3%81%9F%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FTH%3E%3C%2FTR%3E%3C%2FTHEAD%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%24%20%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7BYOCTO_BUILD_DIR%7D%2Ftmp%2Fwork%2F%7BTARGET%7D-poky-linux-gnueabi%2F%7BIMAGE%7D%2F1.0-r0%2Frootfs%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20font-size%3A%2013.5pt%3B%22%3E%3CSTRONG%3E1.2.3%20NFS%20%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E6%9B%B4%E6%96%B0%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FP%3E%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%3CTHEAD%3E%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%3CTH%3ENFS%20%E3%82%B5%E3%83%BC%E3%83%90%E3%81%A7%E3%81%AF%E3%80%81%E7%89%B9%E5%AE%9A%E3%81%AE%E3%83%9B%E3%82%B9%E3%83%88%E3%81%B8%E3%81%AE%20NFS%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%2Fetc%2Fexports%20%E3%82%92%E6%AD%A3%E3%81%97%E3%81%8F%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FTH%3E%3C%2FTR%3E%3C%2FTHEAD%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%24%20%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Evi%20%2Fetc%2Fexports%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FP%3E%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%3CTHEAD%3E%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%3CTH%3E%E6%AC%A1%E3%81%AB%E3%80%81%E9%96%8B%E3%81%84%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E4%BB%A5%E4%B8%8B%E3%81%AE%E8%A1%8C%E3%82%92%E7%B7%A8%E9%9B%86%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FTH%3E%3C%2FTR%3E%3C%2FTHEAD%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26lt%3B%22%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AENFS%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%22%26gt%3B(%20RW%3CYOUR%20board%3D%22%22%20ip%3D%22%22%3E%20%3C%2FYOUR%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%81SYNC%E3%80%81no_root_squash%E3%80%81no_subtree_check)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20text-decoration%3A%20none%3B%20font-size%3A%2010.5pt%3B%20color%3A%20%23000000%3B%22%3EEx.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20text-decoration%3A%20none%3B%20font-size%3A%2010.5pt%3B%20color%3A%20%23000000%3B%22%3ENFS%20%E3%81%AE%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSTRONG%3E%3CYOUR%20board%3D%22%22%20ip%3D%22%22%3E%2Fimx-boot%2Fimx6q-sabre%2Fnfs(rw%2Csync%2Cno_root_squash%2Cno_subtree_check)%3C%2FYOUR%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSTRONG%3E%E4%BE%8B%3A%20%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSTRONG%3E%3CSTRONG%3E%2Fimx-boot%2Fimx6q-sabre%2Fnfs%20192.168.*.*(rw%2Csync%2Cno_root_squash%2Cno_subtree_check)%3C%2FSTRONG%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSTRONG%3E%E3%81%BE%E3%81%9F%E3%81%AF%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSTRONG%3E%2F%7BYOCTO_BUILD_DIR%7D%2Ftmp%2Fwork%2F%7BTARGET%7D-poky-linux-gnueabi%2F%7BIMAGE%7D%2F1.0-r0%2Frootfs(rw%2Csync%2Cno_root_squash%2Cno_subtree_check)%3CYOUR%20board%3D%22%22%20ip%3D%22%22%3E%3C%2FYOUR%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FP%3E%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%3CTHEAD%3E%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%20height%3A%2025px%3B%22%3E%3CTH%20style%3D%22height%3A%2025px%3B%22%3E%E6%AC%A1%E3%81%AB%E3%80%81NFS%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%82%92%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FTH%3E%3C%2FTR%3E%3C%2FTHEAD%3E%3CTBODY%3E%3CTR%20style%3D%22height%3A%2025px%3B%22%3E%3CTD%20style%3D%22height%3A%2025px%3B%22%3E%24%20%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Eservice%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Enfs-kernel-server%20restart%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CH2%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%20id%3D%22toc-hId-625825043%22%20id%3D%22toc-hId-1547266284%22%3E%3CSPAN%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20font-size%3A%2016.5pt%3B%22%3E%3CSTRONG%3E2%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AE%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AFIP%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FP%3E%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%3CTHEAD%3E%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%3CTH%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E9%9B%BB%E6%BA%90%E3%82%92%E5%85%A5%E3%82%8C%E3%80%81%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6U-Boot%E3%81%AE%E7%B6%9A%E8%A1%8C%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FTH%3E%3C%2FTR%3E%3C%2FTHEAD%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3Esetenv%20serverip%20192.168.0.206%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011pt%3B%22%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%83%9B%E3%82%B9%E3%83%88%E3%81%AEIP%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%A7%E3%81%82%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FP%3E%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%3CTHEAD%3E%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%3CTH%3Erootfs%E3%81%8C%E3%83%9B%E3%82%B9%E3%83%88%E3%81%AB%E9%85%8D%E7%BD%AE%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%91%E3%82%B9%E3%81%AF%E3%80%81U-Boot%E3%81%AB%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FTH%3E%3C%2FTR%3E%3C%2FTHEAD%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011pt%3B%22%3EEx.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011pt%3B%22%3EYOCTO%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%97%E3%81%9F%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3Esetenv%20nfsroot%20%2F%7BYOCTO_BUILD_DIR%7D%2Ftmp%2Fwork%2F%7BTARGET%7D-poky-linux-gnueabi%2F%7BIMAGE%7D%2F1.0-r0%2Frootfs%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3E%E3%81%BE%E3%81%9F%E3%81%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3ENFS%20%E3%81%AE%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3Esetenv%20nfsroot%20%2Fimx-boot%2Fimx6q-sabre%2Fnfs%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FP%3E%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%3CTHEAD%3E%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%3CTH%3E%E6%AC%A1%E3%81%AB%E3%80%81u-boot%E3%81%A7%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E5%90%8D%E3%81%A8%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AEBLOB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%90%8D%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FTH%3E%3C%2FTR%3E%3C%2FTHEAD%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011pt%3B%22%3Esetenv%20image%20%26lt%3B%20zImage%20name%20%26gt%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011pt%3B%22%3Esetenv%20fdt_file%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3E%3CDTB%20file%3D%22%22%20name%3D%22%22%20on%3D%22%22%20host%3D%22%22%3E%3C%2FDTB%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FP%3E%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%3CTHEAD%3E%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%3CTH%3E%E6%AC%A1%E3%81%AB%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%96%E3%83%BC%E3%83%88%E3%81%AEbootargs%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FTH%3E%3C%2FTR%3E%3C%2FTHEAD%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Esetenv%20netargs%20'setenv%20bootargs%20console%3D%24%7Bconsole%7D%2C%24%7Bbaudrate%7D%20%24%7Bsmp%7D%20root%3D%2Fdev%2Fnfs%20ip%3Ddhcp%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3Enfsroot%3D%24%7Bserverip%7D%3A%24%7Bnfsroot%7D%2Cv3%2Ctcp'%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FP%3E%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%3CTHEAD%3E%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%3CTH%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20background-color%3A%20%23efefef%3B%20font-weight%3A%20bold%3B%22%3E%3C%2FSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011pt%3B%22%3E%3CSTRONG%3Eprintenv%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20background-color%3A%20%23efefef%3B%20font-weight%3A%20bold%3B%22%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%20%3C%2FSPAN%3E%20I.MX6Q%20SABRE%E3%81%AE%3CSTRONG%3Eloadaddr%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20background-color%3A%20%23efefef%3B%20font-weight%3A%20bold%3B%22%3E%E3%81%8A%E3%82%88%E3%81%B3%3C%2FSPAN%3E%3CSTRONG%3Efdt_addr%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22background-color%3A%20%23efefef%3B%20color%3A%20%233d3d3d%3B%20font-weight%3A%20bold%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011pt%3B%22%3E%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%E5%A4%89%E6%95%B0%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FTH%3E%3C%2FTR%3E%3C%2FTHEAD%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011pt%3B%22%3Eloadaddr%3D0x12000000%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011pt%3B%22%3Efdt_addr%3D0x18000000%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%3CTHEAD%3E%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%20height%3A%2025px%3B%22%3E%3CTH%20style%3D%22height%3A%2025px%3B%22%3E%E3%81%BE%E3%81%9F%E3%80%81%20%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3Enetboot%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FTH%3E%3C%2FTR%3E%3C%2FTHEAD%3E%3CTBODY%3E%3CTR%20style%3D%22height%3A%2025px%3B%22%3E%3CTD%20style%3D%22height%3A%2025px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%22%3Enetboot%3Decho%20%E3%83%8D%E3%83%83%E3%83%88%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20...%3Bnetargs%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%86%E3%82%B9%E3%83%88%20%24%7Bip_dyn%7D%20%3D%20%E3%81%AF%E3%81%84%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%82%E6%AC%A1%E3%81%AB%20setenv%20get_cmd%20dhcp%3B%E3%81%9D%E3%82%8C%E4%BB%A5%E5%A4%96%E3%81%AE%E5%A0%B4%E5%90%88%20setenv%20get_cmd%20tftp%3Bfi%3B%20%24%7Bget_cmd%7D%20%24%7Bimage%7D%3B%E3%83%86%E3%82%B9%E3%83%88%E3%81%AE%E5%A0%B4%E5%90%88%20%24%7Bboot_fdt%7D%20%3D%20%E3%81%AF%E3%81%84%20%7C%7C%E3%83%86%E3%82%B9%E3%83%88%20%24%7Bboot_fdt%7D%20%3D%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%20%24%7Bget_cmd%7D%20%24%7Bfdt_addr%7D%20%24%7Bfdt_file%7D%E3%81%AE%E5%A0%B4%E5%90%88%3B%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E3%83%96%E3%83%BC%E3%83%84%20%24%7Bloadaddr%7D%20-%20%24%7Bfdt_addr%7D%3B%E3%81%9D%E3%82%8C%E4%BB%A5%E5%A4%96%E3%81%AE%E5%A0%B4%E5%90%88%20test%20%24%7Bboot_fdt%7D%20%3D%20try%3B%E3%81%9D%E3%82%8C%E3%81%8B%E3%82%89%E3%83%96%E3%83%BC%E3%83%84%E3%80%82else%20echo%20WARN%3A%20DT%20%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82fi%3Bfi%3B%E3%81%9D%E3%81%86%E3%81%A7%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%83%96%E3%83%BC%E3%83%84%3Bfi%3B%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FP%3E%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%3CTHEAD%3E%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%3CTH%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011pt%3B%22%3E%E6%AC%A1%E3%81%AB%E3%80%81%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%3C%2FSPAN%3E%3CSPAN%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011pt%3B%22%3E%3CSTRONG%3Ebootcmd%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%82%92%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011pt%3B%22%3E%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%8B%E3%82%89%E6%AF%8E%E5%9B%9E%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FTH%3E%3C%2FTR%3E%3C%2FTHEAD%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Esetenv%20bootcmd%20run%20netboot%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FP%3E%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%3CTHEAD%3E%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%3CTH%3E%E6%AC%A1%E3%81%AB%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E5%A4%89%E6%95%B0%E3%82%92u-boot%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FTH%3E%3C%2FTR%3E%3C%2FTHEAD%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%22%3Esaveenv%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FP%3E%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%3CTHEAD%3E%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%3CTH%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%A7%E3%80%81%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FTH%3E%3C%2FTR%3E%3C%2FTHEAD%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3EU-Boot%202016.03-imx_v2016.03_4.1.15_2.0.0_ga%2Bga57b13b%20(Apr%2017%202018%20-%2017%3A13%3A43%20%2B0530)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3E%20%26nbsp%3B(..)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3E%20Net%3A%20%26nbsp%3B%26nbsp%3BFEC%20%5BPRIME%5D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3E%E9%80%9A%E5%B8%B8%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3E%E8%87%AA%E5%8B%95%E8%B5%B7%E5%8B%95%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E4%BB%BB%E6%84%8F%E3%81%AE%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%BE%E3%81%99%3A0%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3E%E3%83%8D%E3%83%83%E3%83%88%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3EFEC%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3E%E3%82%B5%E3%83%BC%E3%83%90%20192.168.0.206%20%E3%81%8B%E3%82%89%E3%81%AE%20TFTP%E3%80%82%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AEIP%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AF192.168.3.101%E3%81%A7%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3EFilename%20'zImage'.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3E%E3%83%AD%E3%83%BC%E3%83%89%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A0x12000000%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3E%E7%A9%8D%E8%BC%89%EF%BC%9A%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3E%20%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3E%20%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3E%20%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3E%20%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3E%20%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3E%20%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3E%202.1%20MiB%2F%E7%A7%92%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3E%E5%AE%8C%E4%BA%86%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3E%E8%BB%A2%E9%80%81%E3%81%95%E3%82%8C%E3%81%9F%E3%83%90%E3%82%A4%E3%83%88%E6%95%B0%20%3D%206578216%20(646028%2016%20%E9%80%B2%E6%95%B0)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3EFEC%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3E%E3%82%B5%E3%83%BC%E3%83%90%20192.168.0.206%20%E3%81%8B%E3%82%89%E3%81%AE%20TFTP%E3%80%82%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AEIP%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AF192.168.3.101%E3%81%A7%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3EFilename%20'imx6q-sabresd.dtb'.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3E%E3%83%AD%E3%83%BC%E3%83%89%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A0x18000000%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3E%E7%A9%8D%E8%BC%89%EF%BC%9A%23%23%23%23%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3E%201.8MiB%2F%E7%A7%92%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3E%E5%AE%8C%E4%BA%86%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3E%E8%BB%A2%E9%80%81%E3%81%95%E3%82%8C%E3%81%9F%E3%83%90%E3%82%A4%E3%83%88%E6%95%B0%20%3D%2045893%20(b345%20hex)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%20%40%200x12000000%20%5B%200x000000%20-%200x646028%20%5D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3E%23%23%2018000000%20%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%83%88%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%83%96%E3%83%AD%E3%83%96%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3E%20fdt%20blob%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%96%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%200x18000000%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3E%2018000000%20%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%AB%E3%81%82%E3%82%8B%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%83%84%E3%83%AA%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%811800e344%20%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3Eldo_bypass%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84!%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.5pt%3B%22%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD%E2%80%A6%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1129169%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX6_All%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6DL%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6Dual%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6DualPlus6QuadPlus%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6Quad%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6S%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6SL%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6SoloX%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6UL%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX7Dual%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX7Solo%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX7ULP%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EYocto%20Project%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1129171%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20TFTP%E3%81%8A%E3%82%88%E3%81%B3NFS%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E7%B5%8C%E7%94%B1%E3%81%A7I.MX6q%20SABRE%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%20%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1129171%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fkarinavalencia%22%20target%3D%22_blank%22%3Ekarinavalencia%3C%2FA%3E%E2%80%8C%3C%2FP%3E%3CP%3EHi%20Karina%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%8C%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A1%E3%80%81%E9%81%A9%E5%88%87%E3%81%A7%E3%81%82%E3%82%8B%E3%81%A8%E6%84%9F%E3%81%98%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fcommunity%2Fimx%22%20target%3D%22_blank%22%3E%E3%80%81%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%20https%3A%2F%2Fcommunity.nxp.com%2Fcommunity%2Fimx%3C%2FA%3E%20%E3%81%A7%E5%85%AC%E9%96%8B%E3%81%99%E3%82%8B%E3%81%AE%E3%82%92%E6%89%8B%E4%BC%9D%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A4%89%E6%9B%B4%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AF%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1129170%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20TFTP%E3%81%8A%E3%82%88%E3%81%B3NFS%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E7%B5%8C%E7%94%B1%E3%81%A7I.MX6q%20SABRE%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%20%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1129170%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E5%85%AC%E9%96%8B%E3%83%9D%E3%83%BC%E3%82%BF%E3%83%AB%20community.nxp.com%20%E5%85%AC%E9%96%8B%E3%81%97%E3%81%A6%E5%85%AC%E9%96%8B%E3%81%97%E3%80%81%E4%BB%96%E3%81%AE%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%8C%E3%81%93%E3%82%8C%E3%82%92%E5%88%A9%E7%94%A8%E3%81%99%E3%82%8B%E3%81%AE%E3%82%92%E6%94%AF%E6%8F%B4%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎04-24-2018 03:12 AM
更新者:
