Add New i.MX5x Board on LTIB
No ratings
After porting u-boot to your i.MX5x board you might want add it on LTIB menu, "Choose your board for u-boot" section. For this, edit ltib/config/platform/imx/main.lkc to add your board:
Enter board on menu:
comment "Choose your board for u-boot"
choice
prompt "board"
default BOARD_MX51_BBG
depends on PLATFORM = "imx51"
help
This menu will let you choose the board you use.
+ config BOARD_MX53_MYBOARD
+ bool "mx53_myboard"
endchoice
Add the "mx53_myboard_config" that matches your board configuration on the u-boot Makefile to PKG_U_BOOT_CONFIG_TYPE:
config PKG_U_BOOT_CONFIG_TYPE
  string
+ default "mx53_myboard_config" if ( PLATFORM = "imx51" && BOARD_MX53_MYBOARD && !PKG_KERNEL_UPDATER )
Labels (2)
Version history
Last update:
‎07-30-2012 12:36 PM
Updated by:
