iMX95 Arm Mali-G310 GPU benchmarking
Cerviik
Hello all,
I may be missing something, but how come the NXP is showing results of GPU benchmarks from GFXBench and Antutu if none of these has version for Linux Arm?
I am reffering to document E1R05_Prior_NXP_2024.pdf
My understanding is that Arm Mali-G310 is desgin, which is only available with Arm architecture, so these two just dont add up.
Can somebody please explain?
Thank you,
David
jill598muncy
Hello @Cerviik,
Great observation. NXP likely ran GFXBench and Antutu on Android builds for the same Arm-based hardware, not native Linux. These benchmarks are Android-compatible and often used to showcase GPU performance even if the target OS for deployment is Linux.
Jill Muncy
danielchen
Hi @Cerviik
GFXBench we have it for Linux.
Antutu is for Android only.
%3CLINGO-SUB%20id%3D%22lingo-sub-2189780%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EiMX95%20Arm%20Mali-G310%20GPU%20benchmarking%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2189780%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20all%2C%26nbsp%3B%3C%2FP%3E%3CP%3EI%20may%20be%20missing%20something%2C%20but%20how%20come%20the%20NXP%20is%20showing%20results%20of%20GPU%20benchmarks%20from%20GFXBench%20and%20Antutu%20if%20none%20of%20these%20has%20version%20for%20Linux%20Arm%3F%3C%2FP%3E%3CP%3EI%20am%20reffering%20to%20document%20E1R05_Prior_NXP_2024.pdf%3C%2FP%3E%3CP%3EMy%20understanding%20is%20that%20Arm%20Mali-G310%20is%20desgin%2C%20which%20is%20only%20available%20with%20Arm%20architecture%2C%20so%20these%20two%20just%20dont%20add%20up.%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ECan%20somebody%20please%20explain%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThank%20you%2C%26nbsp%3B%3C%2FP%3E%3CP%3EDavid%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2191039%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX95%20Arm%20Mali-G310%20GPU%20benchmarking%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2191039%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F254342%22%20target%3D%22_blank%22%3E%40Cerviik%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EGFXBench%20we%20have%20it%20for%20Linux.%3C%2FP%3E%0A%3CP%3EAntutu%20is%20for%20Android%20only.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERegards%3C%2FP%3E%0A%3CP%3EDaniel%3C%2FP%3E%3C%2FLINGO-BODY%3E
