iMX 8MP android 13 Hardware Codec Hantro VPU
sibrain-himanshu
We are trying to enable Hardware encoder and decoder on aosp 13 iMX 8MP SOC.
We observed that vsidaemonis required for hantro vpu to work. There are entries related to it in device folder, too.
But we are not able to find source of vsidaemon anywhere in android build.
We have tried to build it alone using "m vsidaemon" command but encountered error.
It is already added as a product package in device.mk.
Can you share link for source of vsidaemon service for android build.
IMX8MPLUS
AldoG
This are the Hantro libraries that we use on the BSP, you just need to use the .bin to unpack all the libraries, it is as simple as doing the following:
$ chmod +x <downloaded pakcage>.bin
$ ./<downloaded package>.bin
Once you run it it will require to accept EULA for the libraries and the folder will be created.
Best regards/Saludos,
Aldo.
sibrain-himanshu
In simple words we want code for hantro v4l2 daemon.
I forgot to mention that we have done all required changes at kernel level.
AldoG
I don't know which android 13 version are you working with, but for Android 13.0.0_2.0.0 (L6.1.22_2.0.0 BSP) you may download the package from here:
i.MX VPU Hantro libraries for i.MX 8M Quad, 8M Mini, and 8M Plus
$ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/imx-vpu-hantro-1.29.0.bin
i.MX VPU Hantro vc8000e Encoder libraries for i.MX 8M Plus
$ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/imx-vpu-hantro-vc-1.9.0.bin
Aldo.
sibrain-himanshu
Hi @AldoG
Thanks for reply!
Both of the links contain .bin files.
We don't know how to use those files and what's their purpose.
As we have already mentioned in older our question, We are finding source for vsidaemon service to control hantro vpu codec.
AldoG
Aldo.
