WebGPU Vulkan Support on i.MX8MP (QtWebEngine 6.7.0)
3,935件の閲覧回数
Aaronchou
Installing QtWebEngine 6.7.0 on imx8mp-lpddr4-evk
Chromium in QtWebEngine has started supporting WebGPU.
However, when I try the following flags:
--enable-unsafe-webgpu --enable-vulkan --use-angle=vulkan,
QtWebEngine crashes.
Is it because the BSP Vulkan support is not yet fully implemented?
タグ(1)
4 返答(返信)
3,373件の閲覧回数
Aaronchou
Hi @Manuel_Salas
I upgraded my system to BSP 6.12.3-lts and attempted to enable WebGPU and Vulkan.
The startup flags I used:
--enable-features=Vulkan,UseSkiaRenderer,WebGPUDeveloperFeatures --enable-unsafe-webgpu --ignore-gpu-blocklist --in-process-gpu --use-gl=egl
My Vulkan ICD config file (/etc/vulkan/icd.d/imx_icd.json):
{ "file_format_version": "1.0.0", "ICD": { "library_path": "/usr/lib/libvulkan_VSI.so.1", "api_version": "1.3.204" } }
Qt WebEngine does not crash, but the screen remains white with no rendering output.
When running vulkaninfo, I received the following warning:
WARNING: [Loader Message] Code 0 : loader_scanned_icd_add: Driver /usr/lib/libvulkan_VSI.so.1 supports Vulkan 1.3, but only supports loader interface version 2. Interface version 5 or newer required to support this version of Vulkan (Policy #LDP_DRIVER_7)
Please confirm whether the current Vulkan driver supports WebGPU functionality, or if an updated driver with loader interface version 5 or newer is required.
3,910件の閲覧回数
Manuel_Salas
Hello @Aaronchou
I hope you are doing very well.
As you can see on table 7 of RN00210 (Release Notes for LF6.6.52_2.2.0), Vulkan GPU is supported on the i.MX8MP:
I am not sure what BSP you are using, please check the respective release notes for your BSP.
Also, you can try:
--enable-unsafe-webgpu --enable-features=Vulkan
Salas.
2,944件の閲覧回数
Aaronchou
I have updated the BSP to BSP 6.12.3-lts.
WebGPU still doesn’t work.
I’ve posted my observations in the comments.
Is there any update?
3,735件の閲覧回数
vix
Hi @Manuel_Salas
even with the flags you suggested, chromium is not able to see Vulkan and it reports
Vulkan: Disabled
Can you double check, please?
%3CLINGO-SUB%20id%3D%22lingo-sub-2027230%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX8MP%20%E3%81%A7%E3%81%AE%20WebGPU%20Vulkan%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%20(QtWebEngine%206.7.0)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2027230%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eimx8mp-lpddr4-evk%20%E3%81%AB%20QtWebEngine%206.7.0%20%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%3CBR%20%2F%3EQtWebEngine%20%E3%81%AE%20Chromium%20%E3%81%8C%20WebGPU%20%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E6%AC%A1%E3%81%AE%E3%83%95%E3%83%A9%E3%82%B0%E3%82%92%E8%A9%A6%E3%81%BF%E3%82%8B%E3%81%A8%3A%3CBR%20%2F%3E%20--enable-unsafe-webgpu%20--enable-vulkan%20--use-angle%3Dvulkan%2C%3CBR%20%2F%3E%20QtWebEngine%20%E3%81%8C%E3%82%AF%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EBSP%20Vulkan%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E3%81%BE%E3%81%A0%E5%AE%8C%E5%85%A8%E3%81%AB%E5%AE%9F%E8%A3%85%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2149756%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20WebGPU%20Vulkan%20Support%20on%20i.MX8MP%20(QtWebEngine%206.7.0)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2149756%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EBSP%20%E3%82%92%20BSP%206.12.3-lts%20%E3%81%AB%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3EWebGPU%E3%81%AF%E3%81%BE%E3%81%A0%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%E7%A7%81%E3%81%AE%E8%A6%B3%E5%AF%9F%E7%B5%90%E6%9E%9C%E3%82%92%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E6%8A%95%E7%A8%BF%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2102605%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20WebGPU%20Vulkan%20Support%20on%20i.MX8MP%20(QtWebEngine%206.7.0)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2102605%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203368%22%20target%3D%22_blank%22%3E%40Manuel_Salas%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%3CSTRONG%3EBSP%206.12.3-lts%3C%2FSTRONG%3E%E3%81%AB%E3%82%A2%E3%83%83%E3%83%97%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%81%97%E3%80%81WebGPU%20%E3%81%A8%20Vulkan%20%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E8%B5%B7%E5%8B%95%E3%83%95%E3%83%A9%E3%82%B0%3A%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3E%3CSPAN%3E%3CSPAN%20class%3D%22%22%3E--enable-features%3DVulkan%2CUseSkiaRenderer%2CWebGPUDeveloperFeatures%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E--enable-unsafe-webgpu%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E--ignore-gpu-blocklist%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E--in-process-gpu%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E--use-gl%3Degl%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FPRE%3E%3CP%3E%E7%A7%81%E3%81%AEVulkan%20ICD%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%EF%BC%88%2Fetc%2Fvulkan%2Ficd.d%2Fimx_icd.json%EF%BC%89%EF%BC%9A%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3E%3CSPAN%3E%3CSPAN%20class%3D%22%22%3E%7B%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E%22file_format_version%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3A%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E%221.0.0%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E%22ICD%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3A%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E%7B%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E%22library_path%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3A%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E%22%2Fusr%2Flib%2Flibvulkan_VSI.so.1%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E%22api_version%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3A%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E%221.3.204%22%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E%7D%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E%7D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FPRE%3E%3CP%3EQt%20WebEngine%20%E3%81%AF%E3%82%AF%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%83%AC%E3%83%B3%E3%83%80%E3%83%AA%E3%83%B3%E3%82%B0%E5%87%BA%E5%8A%9B%E3%81%8C%E3%81%AA%E3%81%8F%E7%94%BB%E9%9D%A2%E3%81%AF%E7%99%BD%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Evulkaninfo%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E8%AD%A6%E5%91%8A%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3E%3CSPAN%3E%3CSPAN%20class%3D%22%22%3EWARNING%3C%2FSPAN%3E%3A%20%5BLoader%20Message%5D%20Code%20%3CSPAN%20class%3D%22%22%3E0%3C%2FSPAN%3E%20%3A%20loader_scanned_icd_add%3A%20Driver%20%2Fusr%2Flib%2Flibvulkan_VSI.so%3CSPAN%20class%3D%22%22%3E.1%3C%2FSPAN%3E%20supports%20Vulkan%20%3CSPAN%20class%3D%22%22%3E1.3%3C%2FSPAN%3E%2C%20but%20%3CSPAN%20class%3D%22%22%3Eonly%3C%2FSPAN%3E%20supports%20loader%20interface%20%3CSPAN%20class%3D%22%22%3Eversion%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E2.%3C%2FSPAN%3E%20Interface%20%3CSPAN%20class%3D%22%22%3Eversion%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E5%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Eor%3C%2FSPAN%3E%20newer%20required%20%3CSPAN%20class%3D%22%22%3Eto%3C%2FSPAN%3E%20support%20this%20%3CSPAN%20class%3D%22%22%3Eversion%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Eof%3C%2FSPAN%3E%20Vulkan%20(%3CSPAN%20class%3D%22%22%3EPolicy%3C%2FSPAN%3E%20%23LDP_DRIVER_7)%3C%2FSPAN%3E%3C%2FPRE%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%81%AE%20Vulkan%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%20WebGPU%20%E6%A9%9F%E8%83%BD%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%205%20%E4%BB%A5%E9%99%8D%E3%81%AE%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%81%9F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2051653%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20WebGPU%20Vulkan%20Support%20on%20i.MX8MP%20(QtWebEngine%206.7.0)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2051653%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203368%22%20target%3D%22_blank%22%3E%40Manuel_Salas%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E6%8F%90%E6%A1%88%E3%81%97%E3%81%9F%E3%83%95%E3%83%A9%E3%82%B0%E3%81%8C%E3%81%82%E3%81%A3%E3%81%A6%E3%82%82%E3%80%81Chromium%E3%81%AFVulkan%E3%82%92%E8%AA%8D%E8%AD%98%E3%81%A7%E3%81%8D%E3%81%9A%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%A0%B1%E5%91%8A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EVulkan%3A%20%E7%84%A1%E5%8A%B9%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%82%E3%81%86%E4%B8%80%E5%BA%A6%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2027706%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20WebGPU%20Vulkan%20Support%20on%20i.MX8MP%20(QtWebEngine%206.7.0)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2027706%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F221375%22%20target%3D%22_blank%22%3E%40Aaronchou%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%8A%E5%85%83%E6%B0%97%E3%81%A7%E3%81%8A%E9%81%8E%E3%81%94%E3%81%97%E3%81%AE%E3%81%93%E3%81%A8%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3ERN00210%20(LF6.6.52_2.2.0%20%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%8E%E3%83%BC%E3%83%88)%20%E3%81%AE%E8%A1%A8%207%20%E3%81%AB%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81Vulkan%20GPU%20%E3%81%AF%20i.MX8MP%20%E3%81%A7%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alejandro_Salas_0-1736875971039.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alejandro_Salas_0-1736875971039.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F319541i8B6D3952935E9B56%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alejandro_Salas_0-1736875971039.png%22%20alt%3D%22Alejandro_Salas_0-1736875971039.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EAlejandro_Salas_0-1736875971039.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%20BSP%20%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82BSP%20%E3%81%AE%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20%E3%83%8E%E3%83%BC%E3%83%88%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E6%AC%A1%E3%81%AECAN%E3%82%82%E8%A9%A6%E3%81%99%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3A%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-css%22%3E%3CCODE%20translate%3D%22no%22%3E--enable-unsafe-webgpu%20--enable-features%3DVulkan%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B5%E3%83%A9%E3%82%B9%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
