Using PXP along with VGLite
2,093件の閲覧回数
temmka
Is it possible to use PXP and VGLite at the same time?
The scenario is:
1. Build the image using VGLite
2. Rotate this final image using PXP
Is there some example of how to configure and use them together?
Or maybe some other solution
The board is MIMXRT1160-EVK
Thank you
タグ(2)
2,075件の閲覧回数
RaRo
Hello @temmka,
In GUI-Guider v1.6.1 GA you could enable both of them and run the simulator without any issues.
Could you please take a look at AN13075: i.MX RT1170 Heterogeneous Graphics Pipeline – Application Note? There is mentioned a case when you could use PXP + VGLite implementation.
Kind regards, Raul.
