Example of 2D osd overlay using g2d and openVG1.1 (i.MX 8X)
mbj0010911
Hi iMX champ
I'm trying to make an OSD using the i.MX8X.
I found that G2D and OpenVG are available in the Graphics User's Guide,
Where can I find examples of OSD?
Thank for any help.
Jack-Cha
Hi Bio_TICFSL
Thanks for yuor kind reply.
If the customer need to implement the following use case with OSD on top of Camera Preview.
What kind of SDK API can be recommended? e.g. OpenGLES?
Thanks.
Jack
Bio_TICFSL
Yes, I will suggest openGL ES.
Jack-Cha
Hi NXP Team
Please let me know the difference between the G2D API example code that requires NDA and the Demo Framework code below.
https://github.com/NXPmicro/gtec-demo-framework
James
Jack-Cha
Hi NXP TechSupport Team
Can you please explain how to get G2D API documentation/User Guide as well as the relevant imx-gpu-sdk if available?
They would use i.MX8QuadXPlus device to implementa demo for Camera preview along with Text Rendering.
Should we also proceed NDA process with NXP to get a SW license?
James
Bio_TICFSL
The G2D does not require NDA, and this is not implemented as far as I know on MX8QXP.
Bio_TICFSL
You can find here the whole graphics demos that we have:
