eiQ tool proxy setting
khajanpandey
I have installed eIQ toolkit .however when i train the model it doesnt download pre trained model and fails with an error . Since i am working behind a proxy ,can you help me to know where can we set configuration .
anthony_huereca
  Have you configured the system settings on Windows to use the proxy? eIQ Portal doesn't have proxy specific settings, it would use the system-wide default.
-Anthony
anthony_huereca
  Can you share the error message you're getting?
khajanpandey
Sure,I am getting above error message .
anthony_huereca
-Anthony
