Guidelines on porting a Tensorflow model into i.MX8M Nano
shai_b
Senior Contributor II
Hi Team,
I am interested in guidelines on porting/converting a Tensorflow V2 project which running on Linux.
The goal is to run the trained model on the i.MX8M Nano MPU (that will run on CPU Core, NPU is not needed here).
Could you please guide the correct way to port a trained Tensorflow V2 model into i.MX8M?
Please be noted that the input is audio so the eIQ portal seems to be useless here.
Waiting for your kind response, Thanks a lot.
Shai
