clock control in zephyr
TomC818
I have read about the Clock Control subsystem, however I want to ask about the how will zephyr behave if the requested clock frequency is typically not resolvable when using bare metal code with the mcuxpressoIDE? Let's use prime number as an easy explanation example. How will the code behave?
%3CLINGO-SUB%20id%3D%22lingo-sub-2318364%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eclock%20control%20in%20zephyr%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2318364%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20have%20read%20about%20the%20Clock%20Control%20subsystem%2C%20however%20I%20want%20to%20ask%20about%20the%20how%20will%20zephyr%20behave%20if%20the%20requested%20clock%20frequency%20is%20typically%20not%20resolvable%20when%20using%20bare%20metal%20code%20with%20the%20mcuxpressoIDE%3F%20Let's%20use%20prime%20number%20as%20an%20easy%20explanation%20example.%20How%20will%20the%20code%20behave%3F%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
