Openamp_rsc_table example for imx95_evk board.
6,976 次查看
deepshika_borundiya
I am trying to run openamp_rsc_table example for imx95_evk board. On running west build command, zephyr.elf is generated. However, when I am running this elf file using remoteproc with Linux running on my A55 core, I don't see the messages sent between A Core and M Core. My M7 console only shows Zephyr Booting message and then halts. I have used yocto to generate Linux image for A55.
标记 (5)
6,456 次查看
danielchen
HI @deepshika_borundiya
please use the latest BSP,  it fixed this issue.
8 回复数
6,962 次查看
danielchen
could you please let us know the BSP version you are using?
6,954 次查看
deepshika_borundiya
i.MX Linux Yocto Project BSP 6.12.3_1.0.0 Release
6,896 次查看
danielchen
The openamp_rsc_table example now supports imx95_evk/m7.  The A55 core must run linux-imx (tested with version 6.6.52 )
To run this sample,  I would suggest you check the "Linux setup" and "Zephyr setup" in the readme file.
Please refer to below link for more details.
https://github.com/zephyrproject-rtos/zephyr/tree/main/samples/subsys/ipc/openamp_rsc_table
6,862 次查看
deepshika_borundiya
Hi Daniel,
I tried building this example. However, SAMPLE_RPMSG_CLIENT configuration is not defined. Therefore, the module: rpmsg_client_sample.ko is not generated.
While the application is building and successfully generating zephyr.elf, on running this elf on A Core (linux), it is not executing beyond Zephyr Booting message.
6,819 次查看
danielchen
Hi @deepshika_borundiya
I can find the rpmsg_client_sample.ko under below folder. Can you try it again?
/usr/lib/modules/6.12.3-lts-next-g37d02f4dcbbe/kernel/samples/rpmsg/rpmsg_client_sample.ko
6,663 次查看
deepshika_borundiya
Hi Daniel,
I had to add rpmsg_client_sample.c separately to linux build to generate an imx-image-full image. After copying zephyr_openamp_rsc_table.bin file and generating flash.bin, I booted the board. Post this my module is loaded but not in use. Moreover, my remoteproc's state is attached and I am unable to change the state.
root@imx95-19x19-lpddr5-evk:~# lsmod | grep rpmsg_client_sample
rpmsg_client_sample 12288 0
root@imx95-19x19-lpddr5-evk:~# ls /dev/ | grep rpmsg
rpmsg_ctrl0
root@imx95-19x19-lpddr5-evk:~# cat /sys/devices/platform/imx95-cm7/remoteproc/remoteproc1/state
attached
root@imx95-19x19-lpddr5-evk:~# echo stop > /sys/devices/platform/imx95-cm7/remoteproc/remoteproc1/state
-sh: echo: write error: No such process
6,594 次查看
danielchen
As far as I know, this is a known issue in  BSP6.6.x,   I will update you when this fix is merged.
I would suggest you refer to AN14748 for how to run application on M7 core of i.MX95.
https://docs.nxp.com/bundle/AN14748/page/topics/introduction.html
6,457 次查看
danielchen
%3CLINGO-SUB%20id%3D%22lingo-sub-2133303%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eimx95_evk%20%E6%9D%BF%E7%9A%84%20OpenAMP_RSC_Table%20%E7%A4%BA%E4%BE%8B%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2133303%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E4%B8%BA%20imx95_evk%20%E6%9D%BF%E8%BF%90%E8%A1%8C%20openamp_rsc_table%20%E7%A4%BA%E4%BE%8B%E3%80%82%E8%BF%90%E8%A1%8C%20west%20%E7%89%88%E6%9C%AC%20%E5%91%BD%E4%BB%A4%E6%97%B6%EF%BC%8C%E4%BC%9A%E7%94%9F%E6%88%90%20zephyr.elf%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E5%BD%93%E6%88%91%E5%9C%A8%20A55%20%E5%86%85%E6%A0%B8%E4%B8%8A%E8%BF%90%E8%A1%8C%20Linux%20%E5%B9%B6%E4%BD%BF%E7%94%A8%20remoteproc%20%E8%BF%90%E8%A1%8C%E8%BF%99%E4%B8%AA%20elf%20%E6%96%87%E4%BB%B6%E6%97%B6%EF%BC%8C%E6%88%91%E7%9C%8B%E4%B8%8D%E5%88%B0%20A%20%E5%86%85%E6%A0%B8%E5%92%8C%20M%20%E5%86%85%E6%A0%B8%E4%B9%8B%E9%97%B4%E5%8F%91%E9%80%81%E7%9A%84%E4%BF%A1%E6%81%AF%E3%80%82%E6%88%91%E7%9A%84%20M7%20%E4%B8%BB%E6%9C%BA%E5%8F%AA%E6%98%BE%E7%A4%BA%20Zephyr%20%E5%90%AF%E5%8A%A8%E6%B6%88%E6%81%AF%EF%BC%8C%E7%84%B6%E5%90%8E%E6%9A%82%E5%81%9C%E3%80%82%E6%88%91%E4%BD%BF%E7%94%A8%20yocto%20%E4%B8%BA%20A55%20%E7%94%9F%E6%88%90%20Linux%20%E6%98%A0%E5%83%8F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2151484%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Openamp_rsc_table%20example%20for%20imx95_evk%20board.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2151484%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F252659%22%20target%3D%22_blank%22%3E%40deepshika_borundiya%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%AF%B7%E4%BD%BF%E7%94%A8%E6%9C%80%E6%96%B0%E7%9A%84%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%EF%BC%8C%E5%AE%83%E8%A7%A3%E5%86%B3%E4%BA%86%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22danielchen_0-1755073311443.png%22%20style%3D%22width%3A%20714px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22danielchen_0-1755073311443.png%22%20style%3D%22width%3A%20714px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F352173iD37EA67B25513AF3%2Fimage-dimensions%2F714x125%3Fv%3Dv2%22%20width%3D%22714%22%20height%3D%22125%22%20role%3D%22button%22%20title%3D%22danielchen_0-1755073311443.png%22%20alt%3D%22danielchen_0-1755073311443.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%0A%3CP%3E%E4%B8%B9%E5%B0%BC%E5%B0%94%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2147725%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Openamp_rsc_table%20example%20for%20imx95_evk%20board.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2147725%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%8D%AE%E6%88%91%E6%89%80%E7%9F%A5%EF%BC%8C%E8%BF%99%E6%98%AF%20BSP6.6.x%20%E4%B8%AD%E7%9A%84%E4%B8%80%E4%B8%AA%E5%B7%B2%E7%9F%A5%E9%97%AE%E9%A2%98%E3%80%81%20%20%20%E5%90%88%E5%B9%B6%E6%AD%A4%E4%BF%AE%E5%A4%8D%E5%90%8E%EF%BC%8C%E6%88%91%E4%BC%9A%E5%8F%8A%E6%97%B6%E6%9B%B4%E6%96%B0%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%BB%BA%E8%AE%AE%E6%82%A8%E5%8F%82%E8%80%83%20AN14748%EF%BC%8C%E4%BA%86%E8%A7%A3%E5%A6%82%E4%BD%95%E5%9C%A8%20i.MX95%20%E7%9A%84%20M7%20%E5%86%85%E6%A0%B8%E4%B8%8A%E8%BF%90%E8%A1%8C%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fdocs.nxp.com%2Fbundle%2FAN14748%2Fpage%2Ftopics%2Fintroduction.html%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fdocs.nxp.com%2Fbundle%2FAN14748%2Fpage%2Ftopics%2Fintroduction.html%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%0A%3CP%3E%E4%B8%B9%E5%B0%BC%E5%B0%94%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2144229%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Openamp_rsc_table%20example%20for%20imx95_evk%20board.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2144229%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%A0%E5%A5%BD%20Daniel%EF%BC%8C%3CBR%20%2F%3E%E6%88%91%E5%BF%85%E9%A1%BB%E5%9C%A8%20linux%20%E7%89%88%E6%9C%AC%E4%B8%AD%E5%8D%95%E7%8B%AC%E6%B7%BB%E5%8A%A0%20rpmsg_client_sample.c%20%E6%89%8D%E8%83%BD%E7%94%9F%E6%88%90%20imx-image-full%20%E9%95%9C%E5%83%8F%E3%80%82%E5%A4%8D%E5%88%B6%20zephyr_openamp_rsc_table.bin%20%E6%96%87%E4%BB%B6%E5%B9%B6%E7%94%9F%E6%88%90%20flash.bin%20%E4%B9%8B%E5%90%8E%E3%80%81%E6%88%91%E5%90%AF%E5%8A%A8%E4%BA%86%E6%9D%BF%E3%80%82%E5%8F%91%E5%B8%83%E5%90%8E%EF%BC%8C%E6%88%91%E7%9A%84%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%EF%BC%8C%E4%BD%86%E6%9C%AA%E4%BD%BF%E7%94%A8%E3%80%82%E6%AD%A4%E5%A4%96%EF%BC%8C%E6%88%91%E7%9A%84%E8%BF%9C%E7%A8%8B%E7%A8%8B%E5%BA%8F%E7%9A%84%E7%8A%B6%E6%80%81%E6%98%AF%E9%99%84%E5%8A%A0%E7%9A%84%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E6%9B%B4%E6%94%B9%E7%8A%B6%E6%80%81%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3Eroot%20%40imx95%20-19x19-lpddr5-evk%EF%BC%9A~%23%20lsmod%20%7C%20grep%20rpmsg_client_sample%20rpmsg_client_samp%20%3CBR%20%2F%3E%20le%2012288%200%20root%20%40imx95%20-19x19-lpdr5-evk%EF%BC%9A~%23%20ls%20%2Fdev%2F%20%7C%20grep%20rpmsg%20rpmsg%20rpmsg_ctrl0%20root%20%40imx95%20-19x19-lpdr5-evk%EF%BC%9A~%23%20ls%20%2Fdev%2F%20%7C%20grep%20rpmsg%20rpmsg_ctrl0%20root%20-19xpdl19-ctrl0%20%3CBR%20%2F%3E%20root%20-19x19-lpdr5-evk%EF%BC%9A~dr5-evk%EF%BC%9A~%23%20cat%20%2Fsys%2Fdevices%2Fplatform%2Fimx95-cm7%2Fremoteproc%2Fremoteproc1%2F%E7%8A%B6%E6%80%81%E8%BF%9E%E6%8E%A5%E6%A0%B9%20%40imx95%20-19x19-lpddr5-evk%EF%BC%9A~%23%20%3CBR%20%2F%3E%20echo%20stop%20%26gt%3B%20%2Fsys%2Fdevices%2Fplatform%2Fimx95-cm7%2Fremoteproc%2Fremoteproc1%2Fstate-sh%EF%BC%9Aecho%EF%BC%9A%E5%86%99%E5%85%A5%E9%94%99%E8%AF%AF%EF%BC%9A%E6%B2%A1%E6%9C%89%E8%BF%99%E6%A0%B7%E7%9A%84%E8%BF%9B%E7%A8%8B%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%40imx95%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2139925%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Openamp_rsc_table%20example%20for%20imx95_evk%20board.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2139925%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F252659%22%20target%3D%22_blank%22%3E%40deepshika_borundiya%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%88%91%E5%8F%AF%E4%BB%A5%E5%9C%A8%E4%B8%8B%E9%9D%A2%E7%9A%84%E6%96%87%E4%BB%B6%E5%A4%B9%E4%B8%AD%E6%89%BE%E5%88%B0%20rpmsg_client_sample.ko%E3%80%82%E4%BD%A0%E8%83%BD%E5%86%8D%E8%AF%95%E4%B8%80%E6%AC%A1%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%2Fusr%2Flib%2Fmodules%2F6.12.3-lts-next-g37d02f4dcbbe%2Fkernel%2Fsamples%2Frpmsg%2Frpmsg_client_sample.ko%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%0A%3CP%3E%E4%B8%B9%E5%B0%BC%E5%B0%94%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137233%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Openamp_rsc_table%20example%20for%20imx95_evk%20board.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137233%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%97%A8%EF%BC%8C%E4%B8%B9%E5%B0%BC%E5%B0%94%EF%BC%8C%3CBR%20%2F%3E%EF%BC%8C%E6%88%91%E8%AF%95%E7%9D%80%E5%88%B6%E4%BD%9C%E4%BA%86%E8%BF%99%E4%B8%AA%E7%A4%BA%E4%BE%8B%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8CSAMPLE_RPMSG_CLIENT%20%E9%85%8D%E7%BD%AE%E6%9C%AA%E5%AE%9A%E4%B9%89%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%9C%AA%E7%94%9F%E6%88%90%E6%A8%A1%E5%9D%97%EF%BC%9Arpmsg_client_sample.ko%E3%80%82%3CBR%20%2F%3E%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E6%AD%A3%E5%9C%A8%E6%9E%84%E5%BB%BA%E5%B9%B6%E6%88%90%E5%8A%9F%E7%94%9F%E6%88%90%20zephyr.elf%E3%80%81%E5%9C%A8%20A%20Core%20(linux)%20%E4%B8%8A%E8%BF%90%E8%A1%8C%E8%BF%99%E4%B8%AA%20elf%20%E6%97%B6%EF%BC%8C%E9%99%A4%E4%BA%86%20Zephyr%20%E5%90%AF%E5%8A%A8%E6%B6%88%E6%81%AF%E5%A4%96%EF%BC%8C%E5%AE%83%E4%B8%8D%E4%BC%9A%E6%89%A7%E8%A1%8C%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2136834%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Openamp_rsc_table%20example%20for%20imx95_evk%20board.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136834%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eopenamp_rsc_table%20%E7%A4%BA%E4%BE%8B%E7%8E%B0%E5%9C%A8%E6%94%AF%E6%8C%81%20imx95_evk%2Fm7%E3%80%82%20A55%20%E6%A0%B8%E5%BF%83%E5%BF%85%E9%A1%BB%E8%BF%90%E8%A1%8C%20linux-imx%EF%BC%88%E6%B5%8B%E8%AF%95%E7%89%88%E6%9C%AC%E4%B8%BA%206.6.52%EF%BC%89%3C%2FP%3E%0A%3CP%3E%E8%A6%81%E8%BF%90%E8%A1%8C%E6%AD%A4%E7%A4%BA%E4%BE%8B%EF%BC%8C%E6%88%91%E5%BB%BA%E8%AE%AE%E6%82%A8%E6%9F%A5%E7%9C%8B%22Linux%20%E8%AE%BE%E7%BD%AE%22%20%E5%92%8C%22Zephyr%20%E8%AE%BE%E7%BD%AE%22%20%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%AF%A6%E6%83%85%E8%AF%B7%E5%8F%82%E9%98%85%E4%BB%A5%E4%B8%8B%E9%93%BE%E6%8E%A5%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fzephyrproject-rtos%2Fzephyr%2Ftree%2Fmain%2Fsamples%2Fsubsys%2Fipc%2Fopenamp_rsc_table%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fzephyrproject-rtos%2Fzephyr%2Ftree%2Fmain%2Fsamples%2Fsubsys%2Fipc%2Fopenamp_rsc_table%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%0A%3CP%3E%E4%B8%B9%E5%B0%BC%E5%B0%94%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2133421%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Openamp_rsc_table%20example%20for%20imx95_evk%20board.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2133421%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX%20Linux%20%E4%BF%9D%E7%95%99%E5%8E%9F%E6%96%87%20%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%206.12.3_1.0.0%20%E7%89%88%E6%9C%AC%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2133417%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Openamp_rsc_table%20example%20for%20imx95_evk%20board.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2133417%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E8%83%BD%E4%B8%8E%E6%88%91%E4%BB%AC%E8%81%94%E7%B3%BB%EF%BC%8C%E5%91%8A%E7%9F%A5%E6%82%A8%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%E7%89%88%E6%9C%AC%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
