MIMXRT1180-EVK LittleFS sample fails on external flash unless DCache is disabled
1,275件の閲覧回数
JasonPD
I am trying to run the Zephyr LittleFS sample (https://github.com/zephyrproject-rtos/zephyr/tree/main/samples/subsys/fs/littlefs) on the external flash (W25Q128JWSIQ) using the CM33 core but I am running into issues.
When I try to run the sample in its default configuration, it fails about 90% of the time. When I turn on the option to wipe the flash and rebuild the filesystem, it appears to fail almost every time.
The point at which it fails varies, but the log usually looks something like this:
スポイラ
*** Booting Zephyr OS build v4.3.0-6239-g28cd602a81ea ***
Sample program to r/w files on littlefs
Area 3 at 0xe20000 on w25q128jw@0 for 1966080 bytes
[00:00:00.022,000] <err> main: Erasing flash area ... 0
[00:00:00.028,000] <inf> littlefs: LittleFS version 2.11, disk version 2.1
[00:00:00.037,000] <inf> littlefs: FS at w25q128jw@0:0xe20000 is 480 0x1000-byte blocks with 512 cycle
[00:00:00.047,000] <inf> littlefs: partition sizes: rd 16 ; pr 16 ; ca 64 ; la 32
[00:00:00.055,000] <err> littlefs: WEST_TOPDIR/modules/fs/littlefs/lfs.c:1386: Corrupted dir pair at {0x0, 0x1}
[00:00:00.066,000] <wrn> littlefs: can't mount (LFS -84); formatting
[00:00:00.118,000] <inf> littlefs: /lfs mounted
/lfs mount: 0
/lfs: bsize = 16 ; frsize = 4096 ; blocks = 480 ; bfree = 478
Listing dir /lfs ...
[00:00:00.150,000] <wrn> littlefs: WEST_TOPDIR/modules/fs/littlefs/lfs.c:2109: Superblock 0x0 has become unwritable
[00:00:00.161,000] <err> fs: file open error (-5)
[00:00:00.167,000] <err> main: FAIL: open /lfs/boot_count: -5
[00:00:00.174,000] <inf> littlefs: /lfs unmounted
/lfs unmount: 0
At some point I get the "Superblock 0x0 has become unwritable" error and then the sample fails.
I found that disabling the DCache with the Kconfig option "CONFIG_DCACHE=n" makes the sample work reliably, leading me to believe that this is a caching issue.
スポイラ
[00:00:00.060,000] <err> main: Erasing flash area ... 0
[00:00:00.069,000] <inf> littlefs: LittleFS version 2.11, disk version 2.1
[00:00:00.127,000] <inf> littlefs: FS at w25q128jw@0:0xe20000 is 480 0x1000-byte blocks with 512 cycle
[00:00:00.139,000] <inf> littlefs: partition sizes: rd 16 ; pr 16 ; ca 64 ; la 32
[00:00:00.151,000] <err> littlefs: WEST_TOPDIR/modules/fs/littlefs/lfs.c:1386: Corrupted dir pair at {0x0, 0x1}
[00:00:00.164,000] <wrn> littlefs: can't mount (LFS -84); formatting
[00:00:00.235,000] <inf> littlefs: /lfs mounted
/lfs mount: 0
/lfs/boot_count read count:0 (bytes: 0)
/lfs/boot_count write new boot count 1: [wr:1]
[00:00:00.297,000] <inf> main: Test file: /lfs/pattern.bin not found, create one!
------ FILE: /lfs/pattern.bin ------
01 55 55 55 55 55 55 55 02 55 55 55 55 55 55 55
03 55 55 55 55 55 55 55 04 55 55 55 55 55 55 55
05 55 55 55 55 55 55 55 06 55 55 55 55 55 55 55
07 55 55 55 55 55 55 55 08 55 55 55 55 55 55 55
09 55 55 55 55 55 55 55 0a 55 55 55 55 55 55 55
0b 55 55 55 55 55 55 55 0c 55 55 55 55 55 55 55
0d 55 55 55 55 55 55 55 0e 55 55 55 55 55 55 55
0f 55 55 55 55 55 55 55 10 55 55 55 55 55 55 55
11 55 55 55 55 55 55 55 12 55 55 55 55 55 55 55
13 55 55 55 55 55 55 55 14 55 55 55 55 55 55 55
15 55 55 55 55 55 55 55 16 55 55 55 55 55 55 55
17 55 55 55 55 55 55 55 18 55 55 55 55 55 55 55
19 55 55 55 55 55 55 55 1a 55 55 55 55 55 55 55
1b 55 55 55 55 55 55 55 1c 55 55 55 55 55 55 55
1d 55 55 55 55 55 55 55 1e 55 55 55 55 55 55 55
1f 55 55 55 55 55 55 55 20 55 55 55 55 55 55 55
21 55 55 55 55 55 55 55 22 55 55 55 55 55 55 55
23 55 55 55 55 55 55 55 24 55 55 55 55 55 55 55
25 55 55 55 55 55 55 55 26 55 55 55 55 55 55 55
27 55 55 55 55 55 55 55 28 55 55 55 55 55 55 55
29 55 55 55 55 55 55 55 2a 55 55 55 55 55 55 55
2b 55 55 55 55 55 55 55 2c 55 55 55 55 55 55 55
2d 55 55 55 55 55 55 55 2e 55 55 55 55 55 55 55
2f 55 55 55 55 55 55 55 30 55 55 55 55 55 55 55
31 55 55 55 55 55 55 55 32 55 55 55 55 55 55 55
33 55 55 55 55 55 55 55 34 55 55 55 55 55 55 55
35 55 55 55 55 55 55 55 36 55 55 55 55 55 55 55
37 55 55 55 55 55 55 55 38 55 55 55 55 55 55 55
39 55 55 55 55 55 55 55 3a 55 55 55 55 55 55 55
3b 55 55 55 55 55 55 55 3c 55 55 55 55 55 55 55
3d 55 55 55 55 55 55 55 3e 55 55 55 55 55 55 55
3f 55 55 55 55 55 55 55 40 55 55 55 55 55 55 55
41 55 55 55 55 55 55 55 42 55 55 55 55 55 55 55
43 55 55 55 55 55 55 55 44 55 55 55 55 55 55 55
45 55 aa
[00:00:00.659,000] <inf> littlefs: /lfs unmounted
/lfs unmount: 0
However, if I leave the DCache enabled and flush and invalidate the DCache with "sys_cache_data_flush_and_invd_all()" after each modification of the flash (write and erase, on sample level, not on driver level) while interrupts are locked with "irq_lock()", it still does not work.
Disabling the DCache works as a temporary workaround but is not ideal for a production system. Is there something I am missing to get it to work?
The samples accessing the flash that are provided with the MCUXpresso SDK work fine, suggesting it is probably an issue with Zephyr or its configuration.
Other Zephyr samples accessing the flash show similar behavior, where only disabling the DCache allows reliable access but I have not done thorough testing on those.
Technical information:
Board: NXP MIMXRT1180-EVK (CM33 Core), connected via Micro USB to an Ubuntu VM via passthrough from a Windows PC
OS: Zephyr v4.3.0-6239-g28cd602a81ea
IDE: MCUXpresso for VS Code 26.3.72 (with Zephyr Developer Software Kit 4.3) on Ubuntu
Project Kconfig:
スポイラ
# Copyright (c) 2019 Peter Bigot Consulting, LLC
# SPDX-License-Identifier: Apache-2.0
# Optionally force the file system to be recreated
CONFIG_APP_WIPE_STORAGE=y
CONFIG_DEBUG=y
CONFIG_NO_OPTIMIZATIONS=y
CONFIG_LOG=y
CONFIG_PRINTK=y
CONFIG_SHELL=y
CONFIG_LOG_DEFAULT_LEVEL=3
CONFIG_LOG_BACKEND_UART=y
CONFIG_LOG_MODE_IMMEDIATE=y
CONFIG_UART_CONSOLE=y
CONFIG_FILE_SYSTEM=y
CONFIG_FILE_SYSTEM_LITTLEFS=y
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_FLASH=y
CONFIG_FLASH_MAP=y
# workaround, required for flash to work reliably
CONFIG_DCACHE=n
Any help would be appreciated.
Jason
3 返答(返信)
1,150件の閲覧回数
EdwinHz
Hi @JasonPD,
You issue is most definitely cache related, specifically what is described by the following article: Using NonCached Memory on i.MXRT
As mentioned there, the issue is most easily observed when using middleware like LwIP, and can be solved by placing critical data into non-cacheable memory regions (instead of outright disabling D-cache).
I recommend you check out that post, as well as the referenced Application Note (Using the i.MXRT L1 Cache) to better understand the issue, and follow the recommendations of the article to ensure a proper functionality of the LwIP middleware.
BR,
Edwin.
1,050件の閲覧回数
ThomasR2D2
I did some more digging and looked in the flash driver 'flash_mcux_flexspi_nor.c'. In there I found cash invalidation after write and erase protected by a define guard:
#ifdef CONFIG_HAS_MCUX_CACHE
For the CM33, which we are currently using exclusively, the KConf file says this:
config SOC_MIMXRT1189_CM33
    select HAS_MCUX_XCACHE
For the CM7 it looks like this:
config SOC_MIMXRT1189_CM7
    select HAS_MCUX_CACHE
I adjusted the define guards in the flash driver like so:
#if defined(CONFIG_HAS_MCUX_CACHE) || defined(CONFIG_HAS_MCUX_XCACHE)
With this change, I can now write and erase the flash without errors. I Re-enabled XIP and DCache and removed all IRQ disabling - seems to work for now.
Could you comment if this solution makes sense from NXPs point of view? Do we still need to disable IRQs when accessing flash?
Thomas
1,112件の閲覧回数
ThomasR2D2
Hello Edwin,
thank you for taking the time to help with this issue, but I don't quite understand the solution you suggested. The same example works with FreeRTOS and there is no LWIP Stack or middleware invovled - it is the plain LittleFS flash read/write example that is not working with Zephyr and working with FreeRTOS.
I understand, that critical buffers data should be put into non-cachable memory - but there is no subsystem or software, other than what Zephyr provides. Are you suggesting, that we try to identify the buffers in the Zephyr driver or subsystems that maybe cause the problem and move them to non-cachable memory?
I’d appreciate it if you could clarify and share any experience you have regarding which buffers are the usual suspects.
Thomas
%3CLINGO-SUB%20id%3D%22lingo-sub-2360070%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMIMXRT1180-EVK%20LittleFS%20%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%AF%E3%80%81DCache%20%E3%81%8C%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E9%99%90%E3%82%8A%E3%80%81%E5%A4%96%E9%83%A8%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2360070%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3EZephyr%20LittleFS%20%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%20(%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fzephyrproject-rtos%2Fzephyr%2Ftree%2Fmain%2Fsamples%2Fsubsys%2Ffs%2Flittlefs%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fzephyrproject-rtos%2Fzephyr%2Ftree%2Fmain%2Fsamples%2Fsubsys%2Ffs%2Flittlefs%3C%2FA%3E%20)%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82CM33%E3%82%B3%E3%82%A2%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%A4%96%E9%83%A8%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%EF%BC%88W25Q128JWSIQ%EF%BC%89%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%92%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E8%A8%AD%E5%AE%9A%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E7%B4%8490%25%E3%81%AE%E7%A2%BA%E7%8E%87%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E6%B6%88%E5%8E%BB%E3%81%97%E3%81%A6%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E5%86%8D%E6%A7%8B%E7%AF%89%E3%81%99%E3%82%8B%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E3%82%AA%E3%83%B3%E3%81%AB%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%81%BB%E3%81%BC%E6%AF%8E%E5%9B%9E%E5%A4%B1%E6%95%97%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%A4%B1%E6%95%97%E3%81%99%E3%82%8B%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%AF%E6%A7%98%E3%80%85%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%83%AD%E3%82%B0%E3%81%AF%E9%80%9A%E5%B8%B8%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E5%86%85%E5%AE%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CDIV%20class%3D%22lia-spoiler-container%22%3E%3CA%20class%3D%22lia-spoiler-link%22%20href%3D%22%23%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E3%83%8D%E3%82%BF%E3%83%90%E3%83%AC%3C%2FA%3E%3CNOSCRIPT%3E%20%EF%BC%88%E3%83%8F%E3%82%A4%E3%83%A9%E3%82%A4%E3%83%88%E3%81%97%E3%81%A6%E8%AA%AD%E3%82%80%EF%BC%89%3C%2FNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-border%22%3E%3CDIV%20class%3D%22lia-spoiler-content%22%3E***%20Zephyr%20OS%E3%83%93%E3%83%AB%E3%83%89v4.3.0-6239-g28cd602a81ea%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99***%3CBR%20%2F%3E%20littlefs%E4%B8%8A%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%AA%AD%E3%81%BF%E6%9B%B8%E3%81%8D%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%3CBR%20%2F%3Ew25q128jw%400%20%E3%81%AE%200xe20000%20%E3%81%AB%E3%81%82%E3%82%8B%E9%A0%98%E5%9F%9F%203%E3%80%811966080%20%E3%83%90%E3%82%A4%E3%83%88%3CBR%20%2F%3E%5B00%3A00%3A00.022%2C000%5D%3CERR%3E%20main%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E9%A0%98%E5%9F%9F%E3%82%92%E6%B6%88%E5%8E%BB%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%200%3CBR%20%2F%3E%20%5B00%3A00%3A00.028%2C000%5D%3CINF%3E%20littlefs%3A%20LittleFS%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%202.11%E3%80%81%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%202.1%3CBR%20%2F%3E%20%5B00%3A00%3A00.037%2C000%5D%3CINF%3E%20littlefs%3A%20w25q128jw%400%3A0xe20000%20%E3%81%AE%20FS%20%E3%81%AF%20480%20%E5%80%8B%E3%81%AE%200x1000%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A7%E3%80%81512%20%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%81%A7%E3%81%99%3CBR%20%2F%3E%5B00%3A00%3A00.047%2C000%5D%3CINF%3E%20littlefs%3A%20%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%B5%E3%82%A4%E3%82%BA%3A%20rd%2016%20%3B%20pr%2016%20%3B%20ca%2064%20%3B%20la%2032%3CBR%20%2F%3E%20%5B00%3A00%3A00.055%2C000%5D%3CERR%3E%20littlefs%3A%20WEST_TOPDIR%2Fmodules%2Ffs%2Flittlefs%2Flfs.c%3A1386%3A%7B0x0%2C%200x1%7D%20%E3%81%AE%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%83%9A%E3%82%A2%E3%81%8C%E7%A0%B4%E6%90%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B00%3A00%3A00.066%2C000%5D%3CWRN%3Elittlefs%3A%20%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%20(LFS%20-84)%3B%3CBR%20%2F%3E%20%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%5B00%3A00%3A00.118%2C000%5D%3CINF%3E%20littlefs%3A%20%2Flfs%20%E3%81%8C%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%2Flfs%20%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%3A%200%3CBR%20%2F%3E%20%2Flfs%3A%20bsize%20%3D%2016%20%3B%20frsize%20%3D%204096%20%3B%20blocks%20%3D%20480%20%3B%20bfree%20%3D%20478%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%20%2Flfs%20%E3%82%92%E4%B8%80%E8%A6%A7%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%3CBR%20%2F%3E%20%5B00%3A00%3A00.150%2C000%5D%3CWRN%3E%20littlefs%3A%20WEST_TOPDIR%2Fmodules%2Ffs%2Flittlefs%2Flfs.c%3A2109%3A%E3%82%B9%E3%83%BC%E3%83%91%E3%83%BC%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF0x0%E3%81%AF%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E4%B8%8D%E8%83%BD%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B00%3A00%3A00.161%2C000%5D%3CERR%3E%20fs%3A%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%82%A8%E3%83%A9%E3%83%BC%20(-5)%3CBR%20%2F%3E%20%5B00%3A00%3A00.167%2C000%5D%3CERR%3E%20main%3A%20%E5%A4%B1%E6%95%97%3A%20%2Flfs%2Fboot_count%20%E3%82%92%E9%96%8B%E3%81%91%E3%81%BE%E3%81%9B%E3%82%93%3A%20-5%3CBR%20%2F%3E%20%5B00%3A00%3A00.174%2C000%5D%3CINF%3E%20littlefs%3A%20%2Flfs%20%E3%81%8C%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%3CBR%20%2F%3E%2Flfs%20%E3%82%A2%E3%83%B3%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%3A%200%3C%2FINF%3E%3C%2FERR%3E%3C%2FERR%3E%3C%2FWRN%3E%3C%2FINF%3E%3C%2FWRN%3E%3C%2FERR%3E%3C%2FINF%3E%3C%2FINF%3E%3C%2FINF%3E%3C%2FERR%3E%3C%2FDIV%3E%3CNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-noscript-container%22%3E%3CDIV%20class%3D%22lia-spoiler-noscript-content%22%3E***%20Zephyr%20OS%E3%83%93%E3%83%AB%E3%83%89v4.3.0-6239-g28cd602a81ea%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99***w25q128jw%400%20%E3%81%AE%20littlefsArea%203%20%E3%81%AE%200xe20000%20%E3%81%AB%E3%81%82%E3%82%8B%201966080%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%AA%AD%E3%81%BF%E6%9B%B8%E3%81%8D%E3%81%99%E3%82%8B%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%5B00%3A00%3A00.022%2C000%5D%3CERR%3E%20main%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E9%A0%98%E5%9F%9F%E3%82%92%E6%B6%88%E5%8E%BB%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%200%5B00%3A00%3A00.028%2C000%5D%3CINF%3E%20littlefs%3A%20LittleFS%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%202.11%E3%80%81%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%202.1%5B00%3A00%3A00.037%2C000%5D%3CINF%3E%20littlefs%3A%20w25q128jw%400%3A0xe20000%20%E3%81%AE%20FS%20%E3%81%AF%20480%20%E5%80%8B%E3%81%AE%200x1000%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A7%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%80%81512%20%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%5B00%3A00%3A00.047%2C000%5D%20%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CINF%3E%20littlefs%3A%20%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%B5%E3%82%A4%E3%82%BA%3A%20rd%2016%20%3B%20pr%2016%20%3B%20ca%2064%20%3B%20la%2032%5B00%3A00%3A00.055%2C000%5D%3CERR%3E%20littlefs%3A%20WEST_TOPDIR%2Fmodules%2Ffs%2Flittlefs%2Flfs.c%3A1386%3A%7B0x0%2C%200x1%7D%5B00%3A00%3A00.066%2C000%5D%20%E3%81%A7%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%83%9A%E3%82%A2%E3%81%8C%E7%A0%B4%E6%90%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CWRN%3E%20littlefs%3A%20%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%20(LFS%20-84)%3B%20%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%E4%B8%AD%5B00%3A00%3A00.118%2C000%5D%20%3CINF%3E%20littlefs%3A%20%2Flfs%20%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E6%B8%88%E3%81%BF%2Flfs%20%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%3A%200%2Flfs%3A%20bsize%20%3D%2016%20%3B%20frsize%20%3D%204096%20%3B%20blocks%20%3D%20480%20%3B%20bfree%20%3D%20478%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%20%2Flfs%20%E3%82%92%E4%B8%80%E8%A6%A7%E8%A1%A8%E7%A4%BA%E4%B8%AD...%5B00%3A00%3A00.150%2C000%5D%3CWRN%3E%20littlefs%3A%20WEST_TOPDIR%2Fmodules%2Ffs%2Flittlefs%2Flfs.c%3A2109%3A%E3%82%B9%E3%83%BC%E3%83%91%E3%83%BC%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%200x0%20%E3%81%8C%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E4%B8%8D%E8%83%BD%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%5B00%3A00%3A00.161%2C000%5D%20%3CERR%3E%20fs%3A%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%82%A8%E3%83%A9%E3%83%BC%20(-5)%5B00%3A00%3A00.167%2C000%5D%3CERR%3E%20main%3A%20%E5%A4%B1%E6%95%97%3A%20%2Flfs%2Fboot_count%20%E3%82%92%E9%96%8B%E3%81%91%E3%81%BE%E3%81%9B%E3%82%93%3A%20-5%5B00%3A00%3A00.174%2C000%5D%3CINF%3E%20littlefs%3A%20%2Flfs%20%E3%82%A2%E3%83%B3%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%20%2Flfs%20%E3%82%A2%E3%83%B3%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%3A%200%3C%2FINF%3E%3C%2FERR%3E%3C%2FERR%3E%3C%2FWRN%3E%3C%2FINF%3E%3C%2FWRN%3E%3C%2FERR%3E%3C%2FINF%3E%3C%2FINF%3E%3C%2FINF%3E%3C%2FERR%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FNOSCRIPT%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%E3%81%82%E3%82%8B%E6%99%82%E7%82%B9%E3%81%A7%E3%80%8C%E3%82%B9%E3%83%BC%E3%83%91%E3%83%BC%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF0x0%E3%81%8C%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E4%B8%8D%E8%83%BD%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%80%81%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EKconfig%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%80%8CCONFIG_DCACHE%3Dn%E3%80%8D%E3%81%A7DCache%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%A8%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%8C%E7%A2%BA%E5%AE%9F%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%A0%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CDIV%20class%3D%22lia-spoiler-container%22%3E%3CA%20class%3D%22lia-spoiler-link%22%20href%3D%22%23%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E3%83%8D%E3%82%BF%E3%83%90%E3%83%AC%3C%2FA%3E%3CNOSCRIPT%3E%20%EF%BC%88%E3%83%8F%E3%82%A4%E3%83%A9%E3%82%A4%E3%83%88%E3%81%97%E3%81%A6%E8%AA%AD%E3%82%80%EF%BC%89%3C%2FNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-border%22%3E%3CDIV%20class%3D%22lia-spoiler-content%22%3E%3CP%3E***%20Zephyr%20OS%E3%83%93%E3%83%AB%E3%83%89v4.3.0-6239-g28cd602a81ea%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99***%3CBR%20%2F%3E%20littlefs%E4%B8%8A%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%AA%AD%E3%81%BF%E6%9B%B8%E3%81%8D%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%3CBR%20%2F%3Ew25q128jw%400%20%E3%81%AE%200xe20000%20%E3%81%AB%E3%81%82%E3%82%8B%E9%A0%98%E5%9F%9F%203%E3%80%811966080%20%E3%83%90%E3%82%A4%E3%83%88%3CBR%20%2F%3E%5B00%3A00%3A00.060%2C000%5D%3CERR%3E%20main%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E9%A0%98%E5%9F%9F%E3%82%92%E6%B6%88%E5%8E%BB%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%200%3CBR%20%2F%3E%20%5B00%3A00%3A00.069%2C000%5D%3CINF%3E%20littlefs%3A%20LittleFS%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%202.11%E3%80%81%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%202.1%3CBR%20%2F%3E%20%5B00%3A00%3A00.127%2C000%5D%3CINF%3E%20littlefs%3A%20w25q128jw%400%3A0xe20000%20%E3%81%AE%20FS%20%E3%81%AF%20480%20%E5%80%8B%E3%81%AE%200x1000%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A7%E3%80%81512%20%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%81%A7%E3%81%99%3CBR%20%2F%3E%5B00%3A00%3A00.139%2C000%5D%3CINF%3E%20littlefs%3A%20%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%B5%E3%82%A4%E3%82%BA%3A%20rd%2016%20%3B%20pr%2016%20%3B%20ca%2064%20%3B%20la%2032%3CBR%20%2F%3E%20%5B00%3A00%3A00.151%2C000%5D%3CERR%3E%20littlefs%3A%20WEST_TOPDIR%2Fmodules%2Ffs%2Flittlefs%2Flfs.c%3A1386%3A%7B0x0%2C%200x1%7D%20%E3%81%AE%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%83%9A%E3%82%A2%E3%81%8C%E7%A0%B4%E6%90%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B00%3A00%3A00.164%2C000%5D%3CWRN%3Elittlefs%3A%20%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%20(LFS%20-84)%3B%3CBR%20%2F%3E%20%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%5B00%3A00%3A00.235%2C000%5D%3CINF%3E%20littlefs%3A%20%2Flfs%20%E3%81%8C%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%2Flfs%20%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%3A%200%3CBR%20%2F%3E%20%2Flfs%3A%20bsize%20%3D%2016%20%3B%20frsize%20%3D%204096%20%3B%20blocks%20%3D%20480%20%3B%20bfree%20%3D%20478%3C%2FINF%3E%3C%2FWRN%3E%3C%2FERR%3E%3C%2FINF%3E%3C%2FINF%3E%3C%2FINF%3E%3C%2FERR%3E%3C%2FP%3E%3CP%3E%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%20%2Flfs%20%E3%82%92%E4%B8%80%E8%A6%A7%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FP%3E%3CP%3E%2Flfs%2Fboot_count%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E5%9B%9E%E6%95%B0%3A0%20(%E3%83%90%E3%82%A4%E3%83%88%E6%95%B0%3A%200)%3C%2FP%3E%3CP%3E%2Flfs%2Fboot_count%20%E3%81%AB%E6%96%B0%E3%81%97%E3%81%84%E3%83%96%E3%83%BC%E3%83%88%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%201%20%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%99%3A%20%5Bwr%3A1%5D%3CBR%20%2F%3E%20%5B00%3A00%3A00.297%2C000%5D%3CINF%3E%20main%3A%20%E3%83%86%E3%82%B9%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20%2Flfs%2Fpattern.bin%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%20------%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20%2Flfs%2Fpattern.bin%20------%3CBR%20%2F%3E%2001%2055%2055%2055%2055%2055%2055%2055%2002%2055%2055%2055%2055%2055%2055%2055%3CBR%20%2F%3E%2003%2055%2055%2055%2055%2055%2055%2055%2004%2055%2055%2055%2055%2055%2055%2055%3CBR%20%2F%3E%2005%2055%2055%2055%2055%2055%2055%2055%2006%2055%2055%2055%2055%2055%2055%2055%3CBR%20%2F%3E%2007%2055%2055%2055%2055%2055%2055%2055%2008%2055%2055%2055%2055%2055%2055%2055%3CBR%20%2F%3E%2009%2055%2055%2055%2055%2055%2055%2055%200a%2055%2055%2055%2055%2055%2055%2055%3CBR%20%2F%3E%200b%2055%2055%2055%2055%2055%2055%2055%200c%2055%2055%2055%2055%2055%2055%2055%3CBR%20%2F%3E%200d%2055%2055%2055%2055%2055%2055%2055%200e%2055%2055%2055%2055%2055%2055%2055%3CBR%20%2F%3E%200%2F55%2055%2055%2055%2055%2055%2055%2010%2055%2055%2055%2055%2055%2055%2055%3CBR%20%2F%3E%2011%2055%2055%2055%2055%2055%2055%2055%2012%2055%2055%2055%2055%2055%2055%2055%3CBR%20%2F%3E%2013%2055%2055%2055%2055%2055%2055%2055%2014%2055%2055%2055%2055%2055%2055%2055%3CBR%20%2F%3E%2015%2055%2055%2055%2055%2055%2055%2055%2016%2055%2055%2055%2055%2055%2055%2055%3CBR%20%2F%3E%2017%2055%2055%2055%2055%2055%2055%2055%2018%2055%2055%2055%2055%2055%2055%2055%3CBR%20%2F%3E%2019%2055%2055%2055%2055%2055%2055%2055%201a%2055%2055%2055%2055%2055%2055%2055%3CBR%20%2F%3E%201b%2055%2055%2055%2055%2055%2055%2055%201c%2055%2055%2055%2055%2055%2055%2055%3CBR%20%2F%3E%201d%2055%2055%2055%2055%2055%2055%2055%201e%2055%2055%2055%2055%2055%2055%2055%3CBR%20%2F%3E%201f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a%2055%2055%2055%2055%2055%2055%2055%3CBR%20%2F%3E%202b%2055%2055%2055%2055%2055%2055%2055%202c%2055%2055%2055%2055%2055%2055%2055%3CBR%20%2F%3E%202d%2055%2055%2055%2055%2055%2055%2055%202e%2055%2055%2055%2055%2055%2055%2055%3CBR%20%2F%3E%202f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a%2055%2055%2055%2055%2055%2055%2055%3CBR%20%2F%3E%203b%2055%2055%2055%2055%2055%2055%2055%203c%2055%2055%2055%2055%2055%2055%2055%3CBR%20%2F%3E%203d%2055%2055%2055%2055%2055%2055%2055%203e%2055%2055%2055%2055%2055%2055%2055%3CBR%20%2F%3E%203f%2055%2055%2055%2055%2055%2055%2055%2040%2055%2055%2055%2055%2055%2055%2055%3CBR%20%2F%3E%2041%2055%2055%2055%2055%2055%2055%2055%2042%2055%2055%2055%2055%2055%2055%2055%3CBR%20%2F%3E%2043%2055%2055%2055%2055%2055%2055%2055%2044%2055%2055%2055%2055%2055%2055%2055%3CBR%20%2F%3E%2045%2055%20aa%3CBR%20%2F%3E%20%5B00%3A00%3A00.659%2C000%5D%3CINF%3E%20littlefs%3A%20%2Flfs%20%E3%81%8C%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FINF%3E%3C%2FINF%3E%3C%2FP%3E%3CP%3E%2Flfs%20%E3%82%A2%E3%83%B3%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%3A%200%3C%2FP%3E%3C%2FDIV%3E%3CNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-noscript-container%22%3E%3CDIV%20class%3D%22lia-spoiler-noscript-content%22%3E***%20Zephyr%20OS%E3%83%93%E3%83%AB%E3%83%89v4.3.0-6239-g28cd602a81ea%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99***w25q128jw%400%20%E3%81%AE%20littlefsArea%203%20%E3%81%AE%200xe20000%20%E3%81%AB%E3%81%82%E3%82%8B%201966080%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%AA%AD%E3%81%BF%E6%9B%B8%E3%81%8D%E3%81%99%E3%82%8B%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%5B00%3A00%3A00.060%2C000%5D%3CERR%3E%20main%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E9%A0%98%E5%9F%9F%E3%82%92%E6%B6%88%E5%8E%BB%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%200%5B00%3A00%3A00.069%2C000%5D%3CINF%3E%20littlefs%3A%20LittleFS%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%202.11%E3%80%81%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%202.1%5B00%3A00%3A00.127%2C000%5D%3CINF%3E%20littlefs%3A%20w25q128jw%400%3A0xe20000%20%E3%81%AE%20FS%20%E3%81%AF%20480%20%E5%80%8B%E3%81%AE%200x1000%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A7%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%80%81512%20%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%5B00%3A00%3A00.139%2C000%5D%20%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CINF%3E%20littlefs%3A%20%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%B5%E3%82%A4%E3%82%BA%3A%20rd%2016%20%3B%20pr%2016%20%3B%20ca%2064%20%3B%20la%2032%5B00%3A00%3A00.151%2C000%5D%3CERR%3E%20littlefs%3A%20WEST_TOPDIR%2Fmodules%2Ffs%2Flittlefs%2Flfs.c%3A1386%3A%7B0x0%2C%200x1%7D%5B00%3A00%3A00.164%2C000%5D%20%E3%81%A7%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%83%9A%E3%82%A2%E3%81%8C%E7%A0%B4%E6%90%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CWRN%3E%20littlefs%3A%20%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%20(LFS%20-84)%3B%20%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%E4%B8%AD%5B00%3A00%3A00.235%2C000%5D%20%3CINF%3E%20littlefs%3A%20%2Flfs%20%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E6%B8%88%E3%81%BF%2Flfs%20%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%3A%200%2Flfs%3A%20bsize%20%3D%2016%20%3B%20frsize%20%3D%204096%20%3B%20blocks%20%3D%20480%20%3B%20bfree%20%3D%20478%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%20%2Flfs%20%E3%82%92%E4%B8%80%E8%A6%A7%E8%A1%A8%E7%A4%BA%E4%B8%AD%20...%2Flfs%2Fboot_count%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E5%9B%9E%E6%95%B0%3A0%20(%E3%83%90%E3%82%A4%E3%83%88%E6%95%B0%3A%200)%2Flfs%2Fboot_count%20%E6%96%B0%E3%81%97%E3%81%84%E3%83%96%E3%83%BC%E3%83%88%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%201%3A%20%5Bwr%3A1%5D%5B00%3A00%3A00.297%2C000%5D%3CINF%3E%20main%3A%20%E3%83%86%E3%82%B9%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20%2Flfs%2Fpattern.bin%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%EF%BC%81------%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20%2Flfs%2Fpattern.bin%20------01%2055%2055%2055%2055%2055%2055%2055%2002%2055%2055%2055%2055%2055%2055%205503%2055%2055%2055%2055%2055%2055%2055%2004%2055%2055%2055%2055%2055%2055%2055%205505%2055%2055%2055%2055%2055%2055%2055%2006%2055%2055%2055%2055%2055%2055%205507%2055%2055%2055%2055%2055%2055%2055%2008%2055%2055%2055%2055%2055%2055%2055%205509%2055%2055%2055%2055%2055%2055%2055%200a%2055%2055%2055%2055%2055%2055%20550b%2055%2055%2055%2055%2055%2055%2055%2055%200c%2055%2055%2055%2055%2055%2055%2055%20550d%2055%2055%2055%2055%2055%2055%2055%2055%200e%2055%2055%2055%2055%2055%2055%2055%20550f%2055%2055%2055%2055%2055%2055%2055%2010%2055%2055%2055%2055%2055%2055%205511%2055%2055%2055%2055%2055%2055%2055%2012%2055%2055%2055%2055%2055%2055%2055%205513%2055%2055%2055%2055%2055%2055%2055%2014%2055%2055%2055%2055%2055%2055%205515%2055%2055%2055%2055%2055%2055%2055%2016%2055%2055%2055%2055%2055%2055%2055%2017%2055%2055%2055%2055%2055%2055%2055%2018%2055%2055%2055%2055%2055%2055%2055%2055%2019%2055%2055%2055%2055%2055%2055%2055%201a%2055%2055%2055%2055%2055%2055%2055%201b%2055%2055%2055%2055%2055%2055%2055%201c%2055%2055%2055%2055%2055%2055%2055%201d%2055%2055%2055%2055%2055%2055%2055%201e%2055%2055%2055%2055%2055%2055%2055%2055%201f%2055%2055%2055%2055%2055%2055%2055%2020%2055%2055%2055%2055%2055%2055%2055%2021%2055%2055%2055%2055%2055%2055%2055%2022%2055%2055%2055%2055%2055%2055%2055%2023%2055%2055%2055%2055%2055%2055%2055%2024%2055%2055%2055%2055%2055%2055%2055%2025%2055%2055%2055%2055%2055%2055%2055%2026%2055%2055%2055%2055%2055%2055%2055%2027%2055%2055%2055%2055%2055%2055%2055%2028%2055%2055%2055%2055%2055%2055%2055%2029%2055%2055%2055%2055%2055%2055%2055%202a%2055%2055%2055%2055%2055%2055%20552b%2055%2055%2055%2055%2055%2055%2055%202c%2055%2055%2055%2055%2055%2055%20552d%2055%2055%2055%2055%2055%2055%2055%202e%2055%2055%2055%2055%2055%2055%20552f%2055%2055%2055%2055%2055%2055%2055%2030%2055%2055%2055%2055%2055%2055%205531%2055%2055%2055%2055%2055%2055%2055%2032%2055%2055%2055%2055%2055%2055%205533%2055%2055%2055%2055%2055%2055%2055%2034%2055%2055%2055%2055%2055%2055%205535%2055%2055%2055%2055%2055%2055%2055%2036%2055%2055%2055%2055%2055%2055%205537%2055%2055%2055%2055%2055%2055%2055%2038%2055%2055%2055%2055%2055%2055%205539%2055%2055%2055%2055%2055%2055%2055%203a%2055%2055%2055%2055%2055%2055%20553b%2055%2055%2055%2055%2055%2055%2055%203c%2055%2055%2055%2055%2055%2055%20553d%2055%2055%2055%2055%2055%2055%2055%203e%2055%2055%2055%2055%2055%2055%20553f%2055%2055%2055%2055%2055%2055%2055%2040%2055%2055%2055%2055%2055%2055%205541%2055%2055%2055%2055%2055%2055%2055%2042%2055%2055%2055%2055%2055%2055%205543%2055%2055%2055%2055%2055%2055%2055%2044%2055%2055%2055%2055%2055%2055%205545%2055%20aa%5B00%3A00%3A00.659%2C000%5D%3CINF%3E%20littlefs%3A%20%2Flfs%20%E3%82%A2%E3%83%B3%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%20%2Flfs%20%E3%82%A2%E3%83%B3%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%3A%200%3C%2FINF%3E%3C%2FINF%3E%3C%2FINF%3E%3C%2FWRN%3E%3C%2FERR%3E%3C%2FINF%3E%3C%2FINF%3E%3C%2FINF%3E%3C%2FERR%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FNOSCRIPT%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81DCache%20%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%9F%E3%81%BE%E3%81%BE%E3%80%81%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E5%A4%89%E6%9B%B4%20(%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%A8%E6%B6%88%E5%8E%BB%E3%80%81%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%AC%E3%83%99%E3%83%AB%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%AC%E3%83%99%E3%83%AB)%20%E3%81%AE%E3%81%9F%E3%81%B3%E3%81%AB%20%22sys_cache_data_flush_and_invd_all()%22%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20DCache%20%E3%82%92%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8A%E3%82%88%E3%81%B3%E7%84%A1%E5%8A%B9%E5%8C%96%E3%81%97%E3%80%81%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%20%22irq_lock()%22%20%E3%81%A7%E3%83%AD%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%82%82%E3%80%81%E3%82%84%E3%81%AF%E3%82%8A%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3EDCache%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E4%B8%80%E6%99%82%E7%9A%84%E3%81%AA%E5%9B%9E%E9%81%BF%E7%AD%96%E3%81%A8%E3%81%97%E3%81%A6%E3%81%AF%E6%9C%89%E5%8A%B9%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E6%9C%AC%E7%95%AA%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E3%81%AF%E7%90%86%E6%83%B3%E7%9A%84%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%95%E3%81%8B%E8%A6%8B%E8%90%BD%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E7%82%B9%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3EMCUXpresso%20SDK%E3%81%AB%E4%BB%98%E5%B1%9E%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%99%E3%82%8B%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8FZephyr%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%9D%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E8%80%83%E3%81%88%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%99%E3%82%8B%E4%BB%96%E3%81%AEZephyr%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%A7%E3%82%82%E5%90%8C%E6%A7%98%E3%81%AE%E6%8C%99%E5%8B%95%E3%81%8C%E8%A6%8B%E3%82%89%E3%82%8C%E3%80%81DCache%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AE%E3%81%BF%E5%AE%89%E5%AE%9A%E3%81%97%E3%81%9F%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%8C%E5%8F%AF%E8%83%BD%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%82%89%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E5%BE%B9%E5%BA%95%E7%9A%84%E3%81%AA%E3%83%86%E3%82%B9%E3%83%88%E3%81%AF%E8%A1%8C%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E6%8A%80%E8%A1%93%E6%83%85%E5%A0%B1%EF%BC%9A%3CBR%20%2F%3E%E3%83%9C%E3%83%BC%E3%83%89%EF%BC%9ANXP%20MIMXRT1180-EVK%EF%BC%88CM33%E3%82%B3%E3%82%A2%EF%BC%89%E3%82%92%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%ADUSB%E7%B5%8C%E7%94%B1%E3%81%A7Windows%20PC%E3%81%8B%E3%82%89%E3%83%91%E3%82%B9%E3%82%B9%E3%83%AB%E3%83%BC%E3%81%97%E3%81%A6Ubuntu%20VM%E3%81%AB%E6%8E%A5%E7%B6%9A%3CBR%20%2F%3EOS%3A%20Zephyr%20v4.3.0-6239-g28cd602a81ea%3CBR%20%2F%3EIDE%3A%20Ubuntu%E4%B8%8A%E3%81%AEVS%20Code%E7%94%A8MCUXpresso%2026.3.72%EF%BC%88Zephyr%E9%96%8B%E7%99%BA%E8%80%85%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%AD%E3%83%83%E3%83%884.3%E4%BB%98%E3%81%8D%EF%BC%89%3CBR%20%2F%3E%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88Kconfig%EF%BC%9A%3C%2FP%3E%3CDIV%20class%3D%22lia-spoiler-container%22%3E%3CA%20class%3D%22lia-spoiler-link%22%20href%3D%22%23%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E3%83%8D%E3%82%BF%E3%83%90%E3%83%AC%3C%2FA%3E%3CNOSCRIPT%3E%20%EF%BC%88%E3%83%8F%E3%82%A4%E3%83%A9%E3%82%A4%E3%83%88%E3%81%97%E3%81%A6%E8%AA%AD%E3%82%80%EF%BC%89%3C%2FNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-border%22%3E%3CDIV%20class%3D%22lia-spoiler-content%22%3E%23%3CBR%20%2F%3E%20%23%20%E8%91%97%E4%BD%9C%E6%A8%A9%20(c)%202019%20Peter%20Bigot%20Consulting%2C%20LLC%3CBR%20%2F%3E%20%23%3CBR%20%2F%3E%20%23%20SPDX-License-Identifier%3A%20Apache-2.0%3CBR%20%2F%3E%23%3CBR%20%2F%3E%3CBR%20%2F%3E%20%23%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E5%86%8D%E4%BD%9C%E6%88%90%E3%82%92%E5%BC%B7%E5%88%B6%E3%81%99%E3%82%8B%3CBR%20%2F%3ECONFIG_APP_WIPE_STORAGE%3Dy%3CBR%20%2F%3E%3CBR%20%2F%3E%20CONFIG_DEBUG%3Dy%3CBR%20%2F%3E%20CONFIG_NO_OPTIMIZATIONS%3Dy%3CBR%20%2F%3E%20CONFIG_LOG%3Dy%3CBR%20%2F%3E%20CONFIG_PRINTK%3Dy%3CBR%20%2F%3E%20CONFIG_SHELL%3Dy%3CBR%20%2F%3E%20CONFIG_LOG_DEFAULT_LEVEL%3D3%3CBR%20%2F%3E%20CONFIG_LOG_BACKEND_UART%3Dy%3CBR%20%2F%3E%20CONFIG_LOG_MODE_IMMEDIATE%3Dy%3CBR%20%2F%3E%20CONFIG_UART_CONSOLE%3Dy%3CBR%20%2F%3E%3CBR%20%2F%3E%20CONFIG_FILE_SYSTEM%3Dy%3CBR%20%2F%3E%20CONFIG_FILE_SYSTEM_LITTLEFS%3Dy%3CBR%20%2F%3E%3CBR%20%2F%3E%20CONFIG_MAIN_STACK_SIZE%3D4096%3CBR%20%2F%3E%3CBR%20%2F%3E%20CONFIG_FLASH%3Dy%3CBR%20%2F%3E%20CONFIG_FLASH_MAP%3Dy%3CBR%20%2F%3E%3CBR%20%2F%3E%20%23%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E7%A2%BA%E5%AE%9F%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E5%9B%9E%E9%81%BF%E7%AD%96%3CBR%20%2F%3ECONFIG_DCACHE%3Dn%3C%2FDIV%3E%3CNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-noscript-container%22%3E%3CDIV%20class%3D%22lia-spoiler-noscript-content%22%3E%23%23%20Copyright%20(c)%202019%20Peter%20Bigot%20Consulting%2C%20LLC%23%23%20SPDX-License-Identifier%3A%20Apache-2.0%23%23%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E5%86%8D%E4%BD%9C%E6%88%90%E3%82%92%E5%BC%B7%E5%88%B6%E3%81%97%E3%81%BE%E3%81%99%20CONFIG_APP_WIPE_STORAGE%3DyCONFIG_DEBUG%3DyCONFIG_NO_OPTIMIZATIONS%3DyCONFIG_LOG%3DyCONFIG_PRINTK%3DyCONFIG_SHELL%3DyCONFIG_LOG_DEFAULT_LEVEL%3D3CONFIG_LOG_BACKEND_UART%3DyCONFIG_LOG_MODE_IMMEDIATE%3DyCONFIG_UART_CONSOLE%3DyCONFIG_FILE_SYSTEM%3DyCONFIG_FILE_SYSTEM_LITTLEFS%3DyCONFIG_MAIN_STACK_SIZE%3D4096CONFIG_FLASH%3DyCONFIG_FLASH_MAP%3Dy%23%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E7%A2%BA%E5%AE%9F%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E5%9B%9E%E9%81%BF%E7%AD%96CONFIG_DCACHE%3Dn%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FNOSCRIPT%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%E3%81%A9%E3%82%93%E3%81%AA%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%A7%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E3%82%B8%E3%82%A7%E3%82%A4%E3%82%BD%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2362760%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MIMXRT1180-EVK%20LittleFS%20sample%20fails%20on%20external%20flash%20unless%20DCache%20is%20disabled%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2362760%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%A8%E3%83%89%E3%82%A6%E3%82%A3%E3%83%B3%E3%81%95%E3%82%93%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E8%A7%A3%E6%B1%BA%E3%81%AB%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%94%E6%8F%90%E6%A1%88%E3%81%84%E3%81%9F%E3%81%A0%E3%81%84%E3%81%9F%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%8C%E3%82%88%E3%81%8F%E7%90%86%E8%A7%A3%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%90%8C%E3%81%98%E4%BE%8B%E3%81%AFFreeRTOS%E3%81%A7%E3%82%82%E5%8B%95%E4%BD%9C%E3%81%97%E3%80%81LWIP%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%82%84%E3%83%9F%E3%83%89%E3%83%AB%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E4%B8%80%E5%88%87%E9%96%A2%E4%B8%8E%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82Zephyr%E3%81%A7%E3%81%AF%E5%8B%95%E4%BD%9C%E3%81%9B%E3%81%9A%E3%80%81FreeRTOS%E3%81%A7%E3%81%AF%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%80%81%E5%8D%98%E7%B4%94%E3%81%AALittleFS%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E8%AA%AD%E3%81%BF%E6%9B%B8%E3%81%8D%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E9%87%8D%E8%A6%81%E3%81%AA%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E4%B8%8D%E5%8F%AF%E8%83%BD%E3%81%AA%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AB%E6%A0%BC%E7%B4%8D%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E7%90%86%E8%A7%A3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81Zephyr%E3%81%8C%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E4%BB%A5%E5%A4%96%E3%81%AB%E3%80%81%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%B5%E3%83%96%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%84%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81Zephyr%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%B5%E3%83%96%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E5%86%85%E3%81%A7%E5%95%8F%E9%A1%8C%E3%81%AE%E5%8E%9F%E5%9B%A0%E3%81%A8%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%AE%E3%81%82%E3%82%8B%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%92%E7%89%B9%E5%AE%9A%E3%81%97%E3%80%81%E3%81%9D%E3%82%8C%E3%82%89%E3%82%92%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E4%B8%8D%E5%8F%AF%E8%83%BD%E3%81%AA%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%8F%90%E6%A1%88%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3CBR%20%2F%3E%E3%81%A9%E3%81%AE%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%BC%E3%81%8C%E3%82%88%E3%81%8F%E3%81%82%E3%82%8B%E5%8E%9F%E5%9B%A0%E3%81%AA%E3%81%AE%E3%81%8B%E3%80%81%E3%81%94%E8%AA%AC%E6%98%8E%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E3%81%94%E7%B5%8C%E9%A8%93%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8B%E3%81%A8%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%83%88%E3%83%BC%E3%83%9E%E3%82%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2362132%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MIMXRT1180-EVK%20LittleFS%20sample%20fails%20on%20external%20flash%20unless%20DCache%20is%20disabled%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2362132%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F261678%22%20target%3D%22_blank%22%3E%40JasonPD%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AE%E5%8E%9F%E5%9B%A0%E3%81%AF%E9%96%93%E9%81%95%E3%81%84%E3%81%AA%E3%81%8F%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E9%96%A2%E9%80%A3%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E5%85%B7%E4%BD%93%E7%9A%84%E3%81%AB%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E8%A8%98%E4%BA%8B%E3%81%A7%E8%AA%AC%E6%98%8E%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%86%85%E5%AE%B9%E3%81%A7%E3%81%99%E3%80%82%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-RT-Crossover-MCUs-Knowledge%2FUsing-NonCached-Memory-on-i-MXRT%2Fta-p%2F1183369%22%20target%3D%22_blank%22%3E%E3%80%8Ci.MXRT%20%E3%81%A7%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%80%8D%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E5%89%8D%E8%BF%B0%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%80%81%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AFLwIP%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%9F%E3%83%89%E3%83%AB%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AB%E6%9C%80%E3%82%82%E9%A1%95%E8%91%97%E3%81%AB%E7%8F%BE%E3%82%8C%E3%80%81D%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E5%AE%8C%E5%85%A8%E3%81%AB%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E9%87%8D%E8%A6%81%E3%81%AA%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E4%B8%8D%E5%8F%AF%E8%83%BD%E3%81%AA%E3%83%A1%E3%83%A2%E3%83%AA%E9%A0%98%E5%9F%9F%E3%81%AB%E9%85%8D%E7%BD%AE%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%95%8F%E9%A1%8C%E3%81%AE%E6%9C%AC%E8%B3%AA%E3%82%92%E3%82%88%E3%82%8A%E6%B7%B1%E3%81%8F%E7%90%86%E8%A7%A3%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%81%9D%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%A8%E5%8F%82%E7%85%A7%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%8E%E3%83%BC%E3%83%88%EF%BC%88%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN12042.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ei.MXRT%20L1%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FA%3E%EF%BC%89%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%80%81%E8%A8%98%E4%BA%8B%E3%81%AE%E6%8E%A8%E5%A5%A8%E4%BA%8B%E9%A0%85%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6LwIP%E3%83%9F%E3%83%89%E3%83%AB%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E6%A9%9F%E8%83%BD%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%E3%80%81%3CBR%20%2F%3E%E3%82%A8%E3%83%89%E3%82%A6%E3%82%A3%E3%83%B3%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2363614%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MIMXRT1180-EVK%20LittleFS%20sample%20fails%20on%20external%20flash%20unless%20DCache%20is%20disabled%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2363614%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%95%E3%82%89%E3%81%AB%E8%AA%BF%E3%81%B9%E3%81%A6%E3%80%81%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%80%8Cflash_mcux_flexspi_nor.c%E3%80%8D%E3%82%92%E8%A6%8B%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%81%AE%E4%B8%AD%E3%81%AB%E3%80%81%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%A8%E6%B6%88%E5%8E%BB%E5%BE%8C%E3%81%AB%E7%8F%BE%E9%87%91%E3%81%8C%E7%84%A1%E5%8A%B9%E5%8C%96%E3%81%95%E3%82%8C%E3%82%8B%E4%BB%95%E7%B5%84%E3%81%BF%E3%81%8C%E5%AE%9A%E7%BE%A9%E3%82%AC%E3%83%BC%E3%83%89%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E4%BF%9D%E8%AD%B7%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%20%3CEM%3E%23ifdef%20CONFIG_HAS_MCUX_CACHE%3C%2FEM%3E%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E5%BD%93%E7%A4%BE%E3%81%8C%E7%8B%AC%E5%8D%A0%E7%9A%84%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8BCM33%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81KConf%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%3CEM%3Econfig%20SOC_MIMXRT1189_CM33%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3EHAS_MCUX_XCACHE%20%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FEM%3E%3CBR%20%2F%3E%3CBR%20%2F%3ECM7%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%3CEM%3Econfig%20SOC_MIMXRT1189_CM7%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3EHAS_MCUX_CACHE%20%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E5%AE%9A%E7%BE%A9%E3%82%AC%E3%83%BC%E3%83%89%E3%82%92%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%AA%BF%E6%95%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%20%3CEM%3E%23if%20defined(CONFIG_HAS_MCUX_CACHE)%20%7C%7C%20defined(CONFIG_HAS_MCUX_XCACHE)%3C%2FEM%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%B8%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%A8%E6%B6%88%E5%8E%BB%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AA%E3%81%8F%E8%A1%8C%E3%81%88%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82XIP%E3%81%A8DCache%E3%82%92%E5%86%8D%E5%BA%A6%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AEIRQ%E7%84%A1%E5%8A%B9%E5%8C%96%E3%82%92%E8%A7%A3%E9%99%A4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E4%BB%8A%E3%81%AE%E3%81%A8%E3%81%93%E3%82%8D%E3%81%AF%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3ENXP%E3%81%AE%E8%A6%96%E7%82%B9%E3%81%8B%E3%82%89%E8%A6%8B%E3%81%A6%E3%80%81%E3%81%93%E3%81%AE%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%AF%E7%90%86%E3%81%AB%E3%81%8B%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%80%81%E3%81%94%E6%84%8F%E8%A6%8B%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%99%E3%82%8B%E9%9A%9B%E3%80%81%E4%BE%9D%E7%84%B6%E3%81%A8%E3%81%97%E3%81%A6IRQ%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%83%88%E3%83%BC%E3%83%9E%E3%82%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E
