FRDM-RW612 USB_DEVICE_STACK_NEXT support
已解决
跳至解决方案
6,796 次查看
wima88
Hi ,
I'm using zephyr 4.0.0 an tried to run some samples with USB device stack next an encounter following error
 <err> usbd_core: Failed to init device driver
however I ran some samples with old usb device stack.
I would like to know if this is the expected behavior as of this zephyr version or am I missing something
标记 (2)
1 解答
6,653 次查看
DanielRuvalcaba
I found the following issue in the Github repo NXP USB drivers don't work with usb_next · Issue #86409 · zephyrproject-rtos/zephyr. Looks like this has already been reported.
Could you please confirm is the same issue?
在原帖中查看解决方案
6 回复数
6,643 次查看
wima88
Thanks Daniel, I follow the issue. I was about to create a issue on git
Wimansha
6,762 次查看
wima88
Hi Daniel ,
Thank you for getting back to me .
I tried the following
1.  use the hid-mouse example as it is with usbd_next_proj.conf
2. use with loopback class
      1.  proj.conf
CONFIG_LOG=y
CONFIG_USB_DEVICE_STACK_NEXT=y
CONFIG_USBD_LOOPBACK_CLASS=y
2.  main.c
#include "sample_usbd.h"
/*located on zephyrproject/zephyr/samples/subsys/usb/common*/
#include <zephyr/kernel.h>
#include <zephyr/usb/usbd.h>
#include <zephyr/logging/log.h>
LOG_MODULE_REGISTER(app, LOG_LEVEL_DBG);
static void msg_cb(struct usbd_context *const usbd_ctx,
                   const struct usbd_msg *const msg) {
  LOG_INF("USBD message: %s", usbd_msg_type_string(msg->type));
  if (usbd_can_detect_vbus(usbd_ctx)) {
    if (msg->type == USBD_MSG_VBUS_READY) {
      if (usbd_enable(usbd_ctx)) {
        LOG_ERR("Failed to enable device support");
    if (msg->type == USBD_MSG_VBUS_REMOVED) {
      if (usbd_disable(usbd_ctx)) {
        LOG_ERR("Failed to disable device support");
int main(void) {
  struct usbd_context *sample_usbd;
  int ret;
  sample_usbd = sample_usbd_init_device(msg_cb);
  if (sample_usbd == NULL) {
    k_msleep(100);
    return 0;
  if (!usbd_can_detect_vbus(sample_usbd)) {
    ret = usbd_enable(sample_usbd);
      if (ret) {
        LOG_ERR("Failed to enable usb support !");
        return ret;
  return 0;
 in both cases I got   <err> usbd_core: Failed to init device driver . to be little more specific -12(-ENOMEM)
after tracing the issue back I pin point the error to udc_mcux_init(...) function located in drivers/usb/udc/udc_mcux_ehci.c
to narrow it further
        /* Init MCUX USB device driver. */
        status = mcux_if->deviceInit(priv->controller_id,
                &priv->mcux_device, &(priv->mcux_device.controllerHandle));
        if (status != kStatus_USB_Success) {
                return -ENOMEM;
6,694 次查看
DanielRuvalcaba
If you use the HID mouse example as is, does it work?
Could you please try using Zephyr 4.1.0?
Is this custom code? If not, could you please point me where did you get it?
Daniel.
6,666 次查看
wima88
Hi Daniel,
I tried it with zephyr 4.1.0,
still seen the same error code, according to 4.1.0 migration guide   not much been change in zephyr USB side
If I use HID-mouse as it is USB stack is initializing properly and I can see device enumeration on host.
Wimansha
6,654 次查看
DanielRuvalcaba
6,773 次查看
DanielRuvalcaba
What example are you testing?
Could you please share some reproduction steps?
Daniel.
%3CLINGO-SUB%20id%3D%22lingo-sub-2064972%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFRDM-RW612%20USB_DEVICE_STACK_NEXT%E6%94%AF%E6%8C%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2064972%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%2C%26nbsp%3B%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20zephyr%204.0.0%EF%BC%8C%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20USB%20%E8%AE%BE%E5%A4%87%E5%A0%86%E6%A0%88%E8%BF%90%E8%A1%8C%E4%B8%80%E4%BA%9B%E7%A4%BA%E4%BE%8B%EF%BC%8C%E7%84%B6%E5%90%8E%E9%81%87%E5%88%B0%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CERR%3E%20usbd_core%3A%20%E6%97%A0%E6%B3%95%E5%88%9D%E5%A7%8B%E5%8C%96%E8%AE%BE%E5%A4%87%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FERR%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E4%B8%8D%E8%BF%87%E6%88%91%E4%BD%BF%E7%94%A8%E6%97%A7%E7%9A%84%20USB%20%E8%AE%BE%E5%A4%87%E5%A0%86%E6%A0%88%E8%BF%90%E8%A1%8C%E4%BA%86%E4%B8%80%E4%BA%9B%E6%A0%B7%E6%9C%AC%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%E8%BF%99%E6%98%AF%E5%90%A6%E6%98%AF%20Zephyr%20%E7%89%88%E6%9C%AC%E7%9A%84%E9%A2%84%E6%9C%9F%E8%A1%8C%E4%B8%BA%EF%BC%8C%E8%BF%98%E6%98%AF%E6%88%91%E9%81%97%E6%BC%8F%E4%BA%86%E4%BB%80%E4%B9%88%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2069034%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFRDM-RW612%20USB_DEVICE_STACK_NEXT%E6%94%AF%E6%8C%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2069034%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E4%B8%B9%E5%B0%BC%E5%B0%94%EF%BC%8C%E6%88%91%E5%85%B3%E6%B3%A8%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E6%AD%A3%E5%87%86%E5%A4%87%E5%9C%A8%20git%20%E4%B8%8A%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%3C%2FP%3E%3CP%3E%E7%BB%B4%E6%9B%BC%E8%8E%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2068896%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFRDM-RW612%20USB_DEVICE_STACK_NEXT%E6%94%AF%E6%8C%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2068896%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%88%91%E5%9C%A8%20Github%20%E4%BB%93%E5%BA%93%E4%B8%AD%E5%8F%91%E7%8E%B0%E4%BA%86%E4%BB%A5%E4%B8%8B%E9%97%AE%E9%A2%98%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fzephyrproject-rtos%2Fzephyr%2Fissues%2F86409%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%EF%BC%9ANXP%20USB%20drivers%20don't%20work%20with%20usb_next%20%C2%B7%20Issue%20%2386409%20%C2%B7%20zephyrproject-rtos%2Fzephyr%3C%2FA%3E%20%E3%80%82%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E4%BC%BC%E4%B9%8E%E5%B7%B2%E7%BB%8F%E8%A2%AB%E6%8A%A5%E5%91%8A%E8%BF%87%E4%BA%86%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E8%83%BD%E5%90%A6%E7%A1%AE%E8%AE%A4%E8%BF%99%E6%98%AF%E5%90%8C%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%0A%3CP%3EDaniel%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2068791%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFRDM-RW612%20USB_DEVICE_STACK_NEXT%E6%94%AF%E6%8C%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2068791%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Daniel%2C%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E7%94%A8%20zephyr%204.1.0%EF%BC%8C%3C%2FP%3E%3CP%3E%E4%BB%8D%E7%84%B6%E7%9C%8B%E5%88%B0%E7%9B%B8%E5%90%8C%E7%9A%84%E9%94%99%E8%AF%AF%E4%BB%A3%E7%A0%81%EF%BC%8C%E6%A0%B9%E6%8D%AE%3CA%20href%3D%22https%3A%2F%2Fdocs.zephyrproject.org%2Flatest%2Freleases%2Fmigration-guide-4.1.html%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E4.1.0%20%E8%BF%81%E7%A7%BB%E6%8C%87%E5%8D%97%EF%BC%8C%3C%2FA%3E%20Zephyr%20USB%20%E7%AB%AF%E6%B2%A1%E6%9C%89%E5%A4%AA%E5%A4%A7%E5%8F%98%E5%8C%96%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%88%91%E4%BD%BF%E7%94%A8%20HID%20%E9%BC%A0%E6%A0%87%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%AE%83%E7%9A%84%20USB%20%E5%A0%86%E6%A0%88%E6%AD%A3%E5%9C%A8%E6%AD%A3%E7%A1%AE%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%8C%E5%B9%B6%E4%B8%94%E6%88%91%E5%8F%AF%E4%BB%A5%E5%9C%A8%E4%B8%BB%E6%9C%BA%E4%B8%8A%E7%9C%8B%E5%88%B0%E8%AE%BE%E5%A4%87%E6%9E%9A%E4%B8%BE%E3%80%82%3C%2FP%3E%3CP%3E%E7%BB%B4%E6%9B%BC%E8%8E%8E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2067551%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFRDM-RW612%20USB_DEVICE_STACK_NEXT%E6%94%AF%E6%8C%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2067551%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%8C%89%E5%8E%9F%E6%A0%B7%E4%BD%BF%E7%94%A8%20HID%20%E9%BC%A0%E6%A0%87%E7%A4%BA%E4%BE%8B%EF%BC%8C%E5%AE%83%E5%8F%AF%E4%BB%A5%E5%B7%A5%E4%BD%9C%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E8%83%BD%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20Zephyr%204.1.0%20%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E6%98%AF%E8%87%AA%E5%AE%9A%E4%B9%89%E4%BB%A3%E7%A0%81%E5%90%97%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%B2%A1%E6%9C%89%EF%BC%8C%E6%82%A8%E8%83%BD%E5%91%8A%E8%AF%89%E6%88%91%E6%82%A8%E4%BB%8E%E5%93%AA%E9%87%8C%E5%BE%97%E5%88%B0%E5%AE%83%E7%9A%84%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%0A%3CP%3EDaniel.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2065796%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFRDM-RW612%20USB_DEVICE_STACK_NEXT%E6%94%AF%E6%8C%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2065796%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Daniel%20%2C%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%E5%9B%9E%E5%A4%8D%E6%88%91%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E4%BA%86%E4%BB%A5%E4%B8%8B%3C%2FP%3E%3CP%3E1.%20%E4%BD%BF%E7%94%A8%20hid-mouse%20%E7%A4%BA%E4%BE%8B%EF%BC%8C%E4%B8%8E%20usbd_next_proj.conf%20%E7%9B%B8%E5%90%8C%3C%2FP%3E%3CP%3E2.%20%E4%B8%8E%E7%8E%AF%E5%9B%9E%E7%B1%BB%E4%B8%80%E8%B5%B7%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%201.%26nbsp%3B%20proj.conf%26nbsp%3B%3C%2FP%3E%3CDIV%20class%3D%22lia-indent-padding-left-60px%22%20style%3D%22padding-left%20%3A%2060px%3B%22%20style%3D%22padding-left%20%3A%2060px%3B%22%3ECONFIG_LOG%3Dy%3C%2FDIV%3E%3CDIV%20class%3D%22lia-indent-padding-left-60px%22%20style%3D%22padding-left%20%3A%2060px%3B%22%20style%3D%22padding-left%20%3A%2060px%3B%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22lia-indent-padding-left-60px%22%20style%3D%22padding-left%20%3A%2060px%3B%22%20style%3D%22padding-left%20%3A%2060px%3B%22%3ECONFIG_USB_DEVICE_STACK_NEXT%3Dy%3C%2FDIV%3E%3CDIV%20class%3D%22lia-indent-padding-left-60px%22%20style%3D%22padding-left%20%3A%2060px%3B%22%20style%3D%22padding-left%20%3A%2060px%3B%22%3ECONFIG_USBD_LOOPBACK_CLASS%3Dy%3C%2FDIV%3E%3CDIV%20class%3D%22lia-indent-padding-left-60px%22%20style%3D%22padding-left%20%3A%2060px%3B%22%20style%3D%22padding-left%20%3A%2060px%3B%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22lia-indent-padding-left-30px%22%20style%3D%22padding-left%20%3A%2030px%3B%22%20style%3D%22padding-left%20%3A%2030px%3B%22%3E2.%20main.c%3C%2FDIV%3E%3CDIV%20class%3D%22lia-indent-padding-left-30px%22%20style%3D%22padding-left%20%3A%2030px%3B%22%20style%3D%22padding-left%20%3A%2030px%3B%22%3E%26nbsp%3B%3C%2FDIV%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%23include%20%22sample_usbd.h%22%20%0A%2F*located%20on%20zephyrproject%2Fzephyr%2Fsamples%2Fsubsys%2Fusb%2Fcommon*%2F%0A%0A%23include%20%3CZEPHYR%3E%0A%23include%20%3CZEPHYR%3E%0A%0A%23include%20%3CZEPHYR%3E%0A%0ALOG_MODULE_REGISTER(app%2C%20LOG_LEVEL_DBG)%3B%0A%0Astatic%20void%20msg_cb(struct%20usbd_context%20*const%20usbd_ctx%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20const%20struct%20usbd_msg%20*const%20msg)%20%7B%0A%20%20LOG_INF(%22USBD%20message%3A%20%25s%22%2C%20usbd_msg_type_string(msg-%26gt%3Btype))%3B%0A%0A%20%20if%20(usbd_can_detect_vbus(usbd_ctx))%20%7B%0A%20%20%20%20if%20(msg-%26gt%3Btype%20%3D%3D%20USBD_MSG_VBUS_READY)%20%7B%0A%20%20%20%20%20%20if%20(usbd_enable(usbd_ctx))%20%7B%0A%20%20%20%20%20%20%20%20LOG_ERR(%22Failed%20to%20enable%20device%20support%22)%3B%0A%20%20%20%20%20%20%7D%0A%20%20%20%20%7D%0A%0A%20%20%20%20if%20(msg-%26gt%3Btype%20%3D%3D%20USBD_MSG_VBUS_REMOVED)%20%7B%0A%20%20%20%20%20%20if%20(usbd_disable(usbd_ctx))%20%7B%0A%20%20%20%20%20%20%20%20LOG_ERR(%22Failed%20to%20disable%20device%20support%22)%3B%0A%20%20%20%20%20%20%7D%0A%20%20%20%20%7D%0A%20%20%7D%0A%7D%0Aint%20main(void)%20%7B%0A%20%20struct%20usbd_context%20*sample_usbd%3B%0A%20%20int%20ret%3B%0A%0A%20%20sample_usbd%20%3D%20sample_usbd_init_device(msg_cb)%3B%0A%20%20if%20(sample_usbd%20%3D%3D%20NULL)%20%7B%0A%20%20%20%20k_msleep(100)%3B%0A%20%20%20%20return%200%3B%0A%20%20%7D%0A%0A%20%20if%20(!usbd_can_detect_vbus(sample_usbd))%20%7B%0A%20%20%20%20ret%20%3D%20usbd_enable(sample_usbd)%3B%0A%20%20%20%20%7B%0A%20%20%20%20%20%20if%20(ret)%20%7B%0A%20%20%20%20%20%20%20%20LOG_ERR(%22Failed%20to%20enable%20usb%20support%20!%22)%3B%0A%20%20%20%20%20%20%20%20return%20ret%3B%0A%20%20%20%20%20%20%7D%0A%20%20%20%20%7D%0A%20%20%7D%0A%20%20return%200%3B%0A%7D%3C%2FZEPHYR%3E%3C%2FZEPHYR%3E%3C%2FZEPHYR%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E5%9C%A8%E4%B8%A4%E7%A7%8D%E6%83%85%E5%86%B5%E4%B8%8B%E6%88%91%E9%83%BD%E5%BE%97%E5%88%B0%E4%BA%86%3CSTRONG%3E%3CERR%3E%20usbd_core%3A%20Failed%20to%20init%20device%20driver%20%E3%80%82%3C%2FERR%3E%3C%2FSTRONG%3E%E6%9B%B4%E5%85%B7%E4%BD%93%E4%B8%80%E7%82%B9%20-12(-ENOMEM)%3C%2FP%3E%3CP%3E%E8%BF%BD%E6%BA%AF%E9%97%AE%E9%A2%98%E5%90%8E%EF%BC%8C%E6%88%91%E5%B0%86%E9%94%99%E8%AF%AF%E5%AE%9A%E4%BD%8D%E5%88%B0%E4%BD%8D%E4%BA%8E%20drivers%2Fusb%2Fudc%2Fudc_mcux_ehci.c%20%E4%B8%AD%E7%9A%84%20udc_mcux_init(...)%20%E5%87%BD%E6%95%B0%3C%2FP%3E%3CP%3E%E8%BF%9B%E4%B8%80%E6%AD%A5%E7%BC%A9%E5%B0%8F%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%20%20%20%20%20%20%20%20%2F*%20Init%20MCUX%20USB%20device%20driver.%20*%2F%0A%20%20%20%20%20%20%20%20status%20%3D%20mcux_if-%26gt%3BdeviceInit(priv-%26gt%3Bcontroller_id%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%26amp%3Bpriv-%26gt%3Bmcux_device%2C%20%26amp%3B(priv-%26gt%3Bmcux_device.controllerHandle))%3B%0A%20%20%20%20%20%20%20%20if%20(status%20!%3D%20kStatus_USB_Success)%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20return%20-ENOMEM%3B%0A%20%20%20%20%20%20%20%20%7D%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2065718%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFRDM-RW612%20USB_DEVICE_STACK_NEXT%E6%94%AF%E6%8C%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2065718%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E6%AD%A3%E5%9C%A8%E6%B5%8B%E8%AF%95%E4%BB%80%E4%B9%88%E4%BE%8B%E5%AD%90%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E8%83%BD%E5%88%86%E4%BA%AB%E4%B8%80%E4%BA%9B%E5%A4%8D%E5%88%B6%E6%AD%A5%E9%AA%A4%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%0A%3CP%3EDaniel.%3C%2FP%3E%3C%2FLINGO-BODY%3E
