FLEXCAN Driver IRQ too slow?
1,681件の閲覧回数
agj
I have a CAN based protocol where pings consists of two CAN frames, but for some reason the second frame is seemingly lost.
As can be seen on the photo, the two frames are very close to eachother, but from my debugging the flexcan driver callback is only called once on the first frame.
/2026-04-07/can-frames.jpeg 
Any subsequent pings seem to behave differently, as the photo below shows.
/2026-04-07/can-frames-2.jpeg
If I lower the CAN bitrate the issue seems to dissapear - this is not practical for me because all other devices on my bus are speaking 1Mbit/s, so I have to look elsewhere. I am using a fairly simple setup using LTC2875:
My device tree:
&flexcan1 {
	/* J7/10 (main bus) */
	status = "okay";
	pinctrl-0 = <&pinmux_flexcan1>;
	pinctrl-names = "default";
	phys = <&can_phy1>;
	can-transceiver {
		max-bitrate = <5000000>;
&flexcan2 {
	status = "okay";
	pinctrl-0 = <&pinmux_flexcan2>;
	phys = <&can_phy2>;
	can-transceiver {
&flexcan3 {
	/* J9? */
	status = "okay";
	pinctrl-0 = <&pinmux_flexcan3>;
	phys = <&can_phy3>;
	can-transceiver {
To me, it looks a bit like the flexcan driver's IRQ is doing a lot of stuff before lowering the "I have handled the event"-flag, which might be what is leading to this issue, but my attempts at patching it has not resulted in any improvement.
I am using zephyr version 4.3.0 and the upstream `hal_nxp` module (so version 2.14.4 of the flexcan driver)
タグ(3)
4 返答(返信)
1,639件の閲覧回数
mayliu1
Hi @agj ,
Thank you so much for your interest in our products and for using our community.
 I suggest you check below :
1: Check whether your Zephyr setup is using a single RX mailbox or the RX FIFO.
2: I  suggest using the RX FIFO or multiple RX mailboxes.
3: Please check for RX FIFO overflow or warning states.
The NXP SDK defines specific receive statuses such as  kStatus_FLEXCAN_RxFifoBusy,   kStatus_FLEXCAN_RxFifoOverflow,  and    kStatus_FLEXCAN_RxFifoWarning .
If you can add some logging and see overflow or warning conditions, that would  point to a buffering issue rather than a PHY or bitrate problem.
Please try it.
Best Regards
May Liu
1,441件の閲覧回数
agj
I tried enabling `CONFIG_CAN_STATS=y` (and `CONFIG_STATS=y`)... `can show can@400c4000` shows that an rx overrun occurred (see below). This is very odd to me considering the default amount of mailboxes is 64. I also noticed that I can only process 6 can frames at a time on the MCU...
uart:~$ can show can@400c4000
core clock: 24000000 Hz
max bitrate: 1000000 bps
max std filters: 10
max ext filters: 10
capabilities: normal loopback listen-only triple-sampling
mode: normal
state: error-active
rx errors: 0
tx errors: 0
timing: sjw 1..4, prop_seg 1..8, phase_seg1 1..8, phase_seg2 2..8, prescaler 1..256
transceiver: can-phy1
statistics:
bit errors: 0
bit0 errors: 0
bit1 errors: 0
stuff errors: 0
crc errors: 0
form errors: 0
ack errors: 0
rx overruns: 1
1,481件の閲覧回数
agj
Hi May,
You make it sound like RX FIFO and Mailboxes are mutually exclusive, is this correct?
By my research, it looks like mailboxes are enabled as the default (confirmed through a gdb session - I have 64 mailboxes) however, I don't see how to enable RX FIFO. Can you assist in how to enable RX FIFO in my zephyr project?
Asger Gitz-Johansen
1,431件の閲覧回数
mayliu1
1:  64 mailboxes does not mean 64 active RX buffers .
FlexCAN supports 64 total mailboxes , but each mailbox can be configured as either Rx or Tx , so the effective receive capacity depends on how the driver configures them, not just on the raw hardware count.
2:   Rx FIFO and Mailboxes are not simply mutually exclusive . The FlexCAN block includes both Mailboxes and an Rx FIFO, and the hardware supports selectable priority between Mailboxes and Rx FIFO during matching .
3: your observation that you can only process 6 frames at a time matches the documented Legacy Rx FIFO depth of 6 frames .
%3CLINGO-SUB%20id%3D%22lingo-sub-2346384%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFLEXCAN%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AEIRQ%E3%81%8C%E9%81%85%E3%81%99%E3%81%8E%E3%82%8B%EF%BC%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2346384%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CBR%20%2F%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ECAN%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81ping%E3%81%AF2%E3%81%A4%E3%81%AECAN%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%81%A7%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E4%BD%95%E3%82%89%E3%81%8B%E3%81%AE%E7%90%86%E7%94%B1%E3%81%A72%E7%95%AA%E7%9B%AE%E3%81%AE%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%81%8C%E5%A4%B1%E3%82%8F%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%86%99%E7%9C%9F%E3%81%8B%E3%82%89%E3%82%82%E3%82%8F%E3%81%8B%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%812%E3%81%A4%E3%81%AE%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%81%AF%E9%9D%9E%E5%B8%B8%E3%81%AB%E8%BF%91%E3%81%84%E4%BD%8D%E7%BD%AE%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%AE%E7%B5%90%E6%9E%9C%E3%80%81FlexCan%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E3%81%AF%E6%9C%80%E5%88%9D%E3%81%AE%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%81%A7%E4%B8%80%E5%BA%A6%E3%81%A0%E3%81%91%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CBR%20%2F%3E%2F2026-04-07%2Fcan-frames.jpeg%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22can-frames.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22can-frames.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22can-frames.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22can-frames.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22can-frames.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22can-frames.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F381426i2093B8A16D75E9F5%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22can-frames.jpeg%22%20alt%3D%22can-frames.jpeg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%BE%8C%E7%B6%9A%E3%81%AEping%E3%81%AF%E3%80%81%E4%B8%8B%E3%81%AE%E5%86%99%E7%9C%9F%E3%81%AB%E7%A4%BA%E3%81%99%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E7%95%B0%E3%81%AA%E3%82%8B%E6%8C%99%E5%8B%95%E3%82%92%E7%A4%BA%E3%81%99%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CBR%20%2F%3E%2F2026-04-07%2Fcan-frames-2.jpeg%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22can-frames-2.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22can-frames-2.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22can-frames-2.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22can-frames-2.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22can-frames-2.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22can-frames-2.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F381427iB16F499D2F4E77B5%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22can-frames-2.jpeg%22%20alt%3D%22can-frames-2.jpeg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3ECAN%E3%83%93%E3%83%83%E3%83%88%E3%83%AC%E3%83%BC%E3%83%88%E3%82%92%E4%B8%8B%E3%81%92%E3%82%8B%E3%81%A8%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A7%A3%E6%B6%88%E3%81%95%E3%82%8C%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E7%A7%81%E3%81%AE%E3%83%90%E3%82%B9%E4%B8%8A%E3%81%AE%E4%BB%96%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AF1Mbit%2Fs%E3%81%A7%E9%80%9A%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E7%8F%BE%E5%AE%9F%E7%9A%84%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%9D%E3%81%AE%E3%81%9F%E3%82%81%E3%80%81%E5%88%A5%E3%81%AE%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%82%92%E6%8E%A2%E3%81%99%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AFLTC2875%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E6%AF%94%E8%BC%83%E7%9A%84%E3%82%B7%E3%83%B3%E3%83%97%E3%83%AB%E3%81%AA%E6%A7%8B%E6%88%90%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%222026-04-07T15_20_44%2C955548658%2B02_00.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222026-04-07T15_20_44%2C955548658%2B02_00.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222026-04-07T15_20_44%2C955548658%2B02_00.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222026-04-07T15_20_44%2C955548658%2B02_00.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222026-04-07T15_20_44%2C955548658%2B02_00.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222026-04-07T15_20_44%2C955548658%2B02_00.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F381428iBE9EE65FA744875A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%222026-04-07T15_20_44%2C955548658%2B02_00.png%22%20alt%3D%222026-04-07T15_20_44%2C955548658%2B02_00.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E2%80%83%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%222026-04-07T15_22_00%2C968533394%2B02_00.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222026-04-07T15_22_00%2C968533394%2B02_00.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222026-04-07T15_22_00%2C968533394%2B02_00.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222026-04-07T15_22_00%2C968533394%2B02_00.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222026-04-07T15_22_00%2C968533394%2B02_00.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222026-04-07T15_22_00%2C968533394%2B02_00.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F381434iA13BCE6A36668920%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%222026-04-07T15_22_00%2C968533394%2B02_00.png%22%20alt%3D%222026-04-07T15_22_00%2C968533394%2B02_00.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E7%A7%81%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%26amp%3Bflexcan1%20%7B%0A%09%2F*%20J7%2F10%20(main%20bus)%20*%2F%0A%09status%20%3D%20%22okay%22%3B%0A%09pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinmux_flexcan1%26gt%3B%3B%0A%09pinctrl-names%20%3D%20%22default%22%3B%0A%09phys%20%3D%20%26lt%3B%26amp%3Bcan_phy1%26gt%3B%3B%0A%0A%09can-transceiver%20%7B%0A%09%09max-bitrate%20%3D%20%26lt%3B5000000%26gt%3B%3B%0A%09%7D%3B%0A%7D%3B%0A%0A%26amp%3Bflexcan2%20%7B%0A%09%2F*%20J7%2F10%20(main%20bus)%20*%2F%0A%09status%20%3D%20%22okay%22%3B%0A%09pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinmux_flexcan2%26gt%3B%3B%0A%09pinctrl-names%20%3D%20%22default%22%3B%0A%09phys%20%3D%20%26lt%3B%26amp%3Bcan_phy2%26gt%3B%3B%0A%0A%09can-transceiver%20%7B%0A%09%09max-bitrate%20%3D%20%26lt%3B5000000%26gt%3B%3B%0A%09%7D%3B%0A%7D%3B%0A%0A%26amp%3Bflexcan3%20%7B%0A%09%2F*%20J9%3F%20*%2F%0A%09status%20%3D%20%22okay%22%3B%0A%09pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinmux_flexcan3%26gt%3B%3B%0A%09pinctrl-names%20%3D%20%22default%22%3B%0A%09phys%20%3D%20%26lt%3B%26amp%3Bcan_phy3%26gt%3B%3B%0A%0A%09can-transceiver%20%7B%0A%09%09max-bitrate%20%3D%20%26lt%3B5000000%26gt%3B%3B%0A%09%7D%3B%0A%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E7%A7%81%E3%81%AB%E3%81%AF%E3%80%81Flexcan%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AEIRQ%E3%81%8C%E3%80%8C%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%82%92%E5%87%A6%E7%90%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%8D%E3%83%95%E3%83%A9%E3%82%B0%E3%82%92%E4%B8%8B%E3%81%92%E3%82%8B%E5%89%8D%E3%81%AB%E5%A4%9A%E3%81%8F%E3%81%AE%E5%87%A6%E7%90%86%E3%82%92%E8%A1%8C%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A6%8B%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%8C%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AE%E5%8E%9F%E5%9B%A0%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E8%A9%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E6%94%B9%E5%96%84%E3%81%AF%E8%A6%8B%E3%82%89%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E7%A7%81%E3%81%AFZephyr%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B34.3.0%E3%81%A8%E3%82%A2%E3%83%83%E3%83%97%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%81%AE%60hal_nxp%60%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%EF%BC%88%E3%81%A4%E3%81%BE%E3%82%8AFlexcan%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B32.14.4%EF%BC%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2347091%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FLEXCAN%20Driver%20IRQ%20too%20slow%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2347091%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F260750%22%20target%3D%22_blank%22%3E%40agj%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%BC%8A%E7%A4%BE%E8%A3%BD%E5%93%81%E3%81%AB%E3%81%94%E9%96%A2%E5%BF%83%E3%82%92%E3%81%8A%E5%AF%84%E3%81%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E3%81%BE%E3%81%9F%E5%BC%8A%E7%A4%BE%E3%81%AE%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%82%92%E3%81%94%E5%88%A9%E7%94%A8%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E8%AA%A0%E3%81%AB%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CDIV%3E%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E3%82%92%E3%81%94%E7%A2%BA%E8%AA%8D%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CDIV%3E%0A%3CP%3E1%3A%20Zephyr%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%80%81%E5%8D%98%E4%B8%80%E3%81%AERX%E3%83%A1%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%80%81RX%20FIFO%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E2%EF%BC%9ARX%20FIFO%E3%81%BE%E3%81%9F%E3%81%AF%E8%A4%87%E6%95%B0%E3%81%AERX%E3%83%A1%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E3%EF%BC%9ARX%20FIFO%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%95%E3%83%AD%E3%83%BC%E3%81%BE%E3%81%9F%E3%81%AF%E8%AD%A6%E5%91%8A%E7%8A%B6%E6%85%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CDIV%3E%0A%3CP%3ENXP%20SDK%20%E3%81%AF%E3%80%81kStatus_FLEXCAN_RxFifoBusy%E3%80%81kStatus_FLEXCAN_RxFifoOverflow%E3%80%81kStatus_FLEXCAN_RxFifoWarning%20%E3%81%AA%E3%81%A9%E3%81%AE%E7%89%B9%E5%AE%9A%E3%81%AE%E5%8F%97%E4%BF%A1%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%AD%E3%82%B0%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%95%E3%83%AD%E3%83%BC%E3%82%84%E8%AD%A6%E5%91%8A%E7%8A%B6%E6%85%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%82%8C%E3%81%B0%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AFPHY%E3%82%84%E3%83%93%E3%83%83%E3%83%88%E3%83%AC%E3%83%BC%E3%83%88%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%9C%E3%81%B2%E3%81%8A%E8%A9%A6%E3%81%97%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%A1%E3%82%A4%E3%83%BB%E3%83%AA%E3%82%A6%3C%2FP%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2350572%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FLEXCAN%20Driver%20IRQ%20too%20slow%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2350572%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%A1%E3%82%A4%E3%81%95%E3%82%93%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%20RX%20FIFO%E3%81%A8%E3%83%A1%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%81%AF%E7%9B%B8%E4%BA%92%E3%81%AB%E6%8E%92%E4%BB%96%E7%9A%84%E3%81%A7%E3%81%82%E3%82%8B%E3%81%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%81%9E%E3%81%93%E3%81%88%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3CBR%20%2F%3E%E7%A7%81%E3%81%AE%E8%AA%BF%E6%9F%BB%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81%E3%83%A1%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%81%AF%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%EF%BC%88gdb%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E7%A2%BA%E8%AA%8D%E6%B8%88%E3%81%BF%20-%20%E3%83%A1%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%81%AF64%E5%80%8B%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%EF%BC%89%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81RX%20FIFO%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82Zephyr%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7RX%20FIFO%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E3%82%A2%E3%82%B9%E3%82%AC%E3%83%BC%E3%83%BB%E3%82%AE%E3%83%83%E3%83%84%EF%BC%9D%E3%83%A8%E3%83%8F%E3%83%B3%E3%82%BB%E3%83%B3%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2351497%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FLEXCAN%20Driver%20IRQ%20too%20slow%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2351497%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%60CONFIG_CAN_STATS%3Dy%60%EF%BC%88%E3%81%8A%E3%82%88%E3%81%B3%60CONFIG_STATS%3Dy%60%EF%BC%89%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%60can%20show%20can%40400c4000%60%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E5%8F%97%E4%BF%A1%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%A9%E3%83%B3%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%81%8C%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%88%E4%B8%8B%E8%A8%98%E5%8F%82%E7%85%A7%EF%BC%89%E3%80%82%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%83%A1%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E6%95%B0%E3%81%8C64%E5%80%8B%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E8%80%83%E3%81%88%E3%82%8B%E3%81%A8%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E9%9D%9E%E5%B8%B8%E3%81%AB%E5%A5%87%E5%A6%99%E3%81%AB%E6%80%9D%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81MCU%E3%81%A7%E3%81%AF%E4%B8%80%E5%BA%A6%E3%81%AB6%E3%81%A4%E3%81%AECAN%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%81%97%E3%81%8B%E5%87%A6%E7%90%86%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%AB%E3%82%82%E6%B0%97%E3%81%A5%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%60%60%60%3CBR%20%2F%3Euart%3A~%24%20can%20show%20can%40400c4000%3CBR%20%2F%3E%E3%82%B3%E3%82%A2%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A%2024000000%20Hz%3CBR%20%2F%3E%E6%9C%80%E5%A4%A7%E3%83%93%E3%83%83%E3%83%88%E3%83%AC%E3%83%BC%E3%83%88%3A%201000000%20bps%3CBR%20%2F%3E%E6%9C%80%E5%A4%A7%E6%A8%99%E6%BA%96%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E6%95%B0%3A%2010%3CBR%20%2F%3E%E6%9C%80%E5%A4%A7%E6%8B%A1%E5%BC%B5%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%E6%95%B0%3A%2010%3CBR%20%2F%3E%E6%A9%9F%E8%83%BD%3A%20%E9%80%9A%E5%B8%B8%E3%81%AE%E3%83%AB%E3%83%BC%E3%83%97%E3%83%90%E3%83%83%E3%82%AF%E3%80%81%E3%83%AA%E3%82%B9%E3%83%8B%E3%83%B3%E3%82%B0%E5%B0%82%E7%94%A8%E3%80%81%E3%83%88%E3%83%AA%E3%83%97%E3%83%AB%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AA%E3%83%B3%E3%82%B0%3CBR%20%2F%3E%E3%83%A2%E3%83%BC%E3%83%89%3A%20%E9%80%9A%E5%B8%B8%3CBR%20%2F%3E%E7%8A%B6%E6%85%8B%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%3CBR%20%2F%3E%E5%8F%97%E4%BF%A1%E3%82%A8%E3%83%A9%E3%83%BC%3A%200%3CBR%20%2F%3E%E9%80%81%E4%BF%A1%E3%82%A8%E3%83%A9%E3%83%BC%3A%200%3CBR%20%2F%3E%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%3A%20sjw%201..4%E3%80%81prop_seg%201..8%E3%80%81phase_seg1%201..8%E3%80%81phase_seg2%202..8%E3%80%81%E3%83%97%E3%83%AA%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%A9%201..256%3CBR%20%2F%3E%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B7%E3%83%BC%E3%83%90%E3%83%BC%3A%20can-phy1%3CBR%20%2F%3E%E7%B5%B1%E8%A8%88%EF%BC%9A%3CBR%20%2F%3E%E3%83%93%E3%83%83%E3%83%88%E3%82%A8%E3%83%A9%E3%83%BC%3A%200%3CBR%20%2F%3E%20bit0%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%200%3CBR%20%2F%3E%E3%83%93%E3%83%83%E3%83%881%E3%82%A8%E3%83%A9%E3%83%BC%3A%200%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%200%3CBR%20%2F%3E%20CRC%E3%82%A8%E3%83%A9%E3%83%BC%3A%200%3CBR%20%2F%3E%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%82%A8%E3%83%A9%E3%83%BC%3A%200%3CBR%20%2F%3E%E7%A2%BA%E8%AA%8D%E3%82%A8%E3%83%A9%E3%83%BC%3A%200%3CBR%20%2F%3ERX%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%A9%E3%83%B3%3A%201%3CBR%20%2F%3E%60%60%60%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2351527%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FLEXCAN%20Driver%20IRQ%20too%20slow%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2351527%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E1%EF%BC%9A%2064%E5%80%8B%E3%81%AE%E3%83%A1%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%81%AF%E3%80%8164%E5%80%8B%E3%81%AE%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%81%AARX%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%92%E6%84%8F%E5%91%B3%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3EFlexCAN%E3%81%AF%E5%90%88%E8%A8%8864%E5%80%8B%E3%81%AE%E3%83%A1%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E5%90%84%E3%83%A1%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%81%AFRx%E3%81%BE%E3%81%9F%E3%81%AFTx%E3%81%A8%E3%81%97%E3%81%A6%E6%A7%8B%E6%88%90%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E5%AE%9F%E9%9A%9B%E3%81%AE%E5%8F%97%E4%BF%A1%E5%AE%B9%E9%87%8F%E3%81%AF%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E5%AE%9F%E9%9A%9B%E3%81%AE%E6%95%B0%E3%81%A0%E3%81%91%E3%81%A7%E3%81%AA%E3%81%8F%E3%80%81%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%E3%81%8B%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E6%B1%BA%E3%81%BE%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayliu1_1-1776251461207.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayliu1_1-1776251461207.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F382451i2AAC19E49BBE4985%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayliu1_1-1776251461207.png%22%20alt%3D%22mayliu1_1-1776251461207.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E2%3A%20Rx%20FIFO%20%E3%81%A8%E3%83%A1%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%81%AF%E5%8D%98%E7%B4%94%E3%81%AB%E7%9B%B8%E4%BA%92%E6%8E%92%E4%BB%96%E7%9A%84%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82FlexCAN%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AB%E3%81%AF%E3%83%A1%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%81%A8Rx%20FIFO%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E3%83%9E%E3%83%83%E3%83%81%E3%83%B3%E3%82%B0%E4%B8%AD%E3%81%AB%E3%83%A1%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%81%A8Rx%20FIFO%E3%81%AE%E9%96%93%E3%81%A7%E5%84%AA%E5%85%88%E9%A0%86%E4%BD%8D%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%A7%E3%81%8D%E3%82%8B%E6%A9%9F%E8%83%BD%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E3%3A%20%E4%B8%80%E5%BA%A6%E3%81%AB%206%20%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%81%97%E3%81%8B%E5%87%A6%E7%90%86%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%A8%E3%81%84%E3%81%86%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%A6%B3%E5%AF%9F%E3%81%AF%E3%80%81%E6%96%87%E6%9B%B8%E5%8C%96%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%20Legacy%20Rx%20FIFO%20%E3%81%AE%E6%B7%B1%E3%81%95%206%20%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayliu1_0-1776251367914.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayliu1_0-1776251367914.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F382450iFD673320846DEFB1%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayliu1_0-1776251367914.png%22%20alt%3D%22mayliu1_0-1776251367914.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
