make 2 connections on KW41Z
kevin_lang
Hello I am evaluate KW41Z, and I am trying to use wireless_uart as example. When I am doing testing with NXP Toolbox on Android, I can see Advertising stopped when there is an connection.
May I know how can make 2 connections, that also means Advertising won't stop when there is a connection
Thanks you in advance.
Kevin
Labels (2)
kevin_lang
I mean even there is a connection to a central (NXP mobile app), I need to the device to continue advertising so other centrals can scan and found the device/get the advertising message
Kevin
stephanie_m
Which error are you getting? Did you try pressing the button at least for this example to test the connections, and once you do it I can guide you to which modifications you need to perform what you are looking for?
Regards ,
Estephania
stephanie_m
What do you mean by  "...that also means Advertising won't stop when there is a connection"? By any chance, have you tried pressing the button again the freedom board as you did with the first time?
Estephania
