jn5169 and Comparator
4,853 次查看
dmitryshelkovsk
Hi!. Is there any example on the work of comparator and interrupts?
I'm trying to write a firmware for Xiaomi Door Sensor (see foto).
The bottom contact goes to Gnd.
The top connect to DIO16, DIO17 from resistor.
If I understand correctly:
#define CONNECT_DEVICE_DIO     ((1 << (16))|(1 << (17)))
#Enable Input
vAHI_DioSetDirection(CONNECT_DEVICE_DIO, 0 );
#Disable PullUp
vAHI_DioSetPullup(0,CONNECT_DEVICE_DIO);
vAHI_ApConfigure(E_AHI_AP_REGULATOR_ENABLE,
                             E_AHI_AP_INT_DISABLE,
                             E_AHI_AP_SAMPLE_2,
                             E_AHI_AP_CLOCKDIV_500KHZ,
                             E_AHI_AP_INTREF);
            while (!bAHI_APRegulatorEnabled());   /* spin on reg not enabled */
vAHI_ComparatorEnable(E_AHI_AP_COMPARATOR_1, E_AHI_COMP_HYSTERESIS_40MV, E_AHI_COMP_SEL_EXT_INVERSE);
vAHI_ComparatorLowPowerMode(TRUE);
vAHI_ComparatorIntEnable(E_AHI_AP_COMPARATOR_1,TRUE,FALSE);
But everything works somehow wrong, it works on my hand side by side, etc.
Please help or at least push the right thought.
标记 (2)
4 回复数
4,584 次查看
stephanie_m
Hello ,
For further documentation regarding the comparator, could you please check this application note ? On chapter 4.3 Comparator.
Also, I believe that the application note JN-AN-1166 can help you.
Estephania
4,584 次查看
dmitryshelkovsk
Yes, l was check, but don't know, how use vref or bandgap.
4,584 次查看
stephanie_m
The only example we have available it's the one I mentioned or the ones in the AN-1189 or AN-1218
PRIVATE void vInitComparator(void)
       vAHI_ComparatorEnable(E_AHI_AP_COMPARATOR_1, E_AHI_COMP_HYSTERESIS_40MV, E_AHI_COMP_SEL_BANDGAP);
       *(uint32 *)ADDR_AP_CTRL |= (1 <<28); /* ensure low-power really set Fix from SMB/IL [lpsw3902] */
       *(uint32 *)ADDR_AP_COMPCTRL  &= 0xfffffffb;   /* clear bit 2 Ref Ticket [lpsw3219] */
Estephania
4,584 次查看
dmitryshelkovsk
Add
            vAHI_ProtocolPower(TRUE);
            vAHI_ApSetBandGap(E_AHI_AP_BANDGAP_ENABLE);
Before vAHI_ComparatorEnable()
And
vAHI_DioSetPullup(0,CONNECT_DEVICE_DIO); (Only for DIO17 pin this by design pcb)
Interrupt work, but work all time then then DIO17 connect to GND.
APP: Power Up
Set Sec state
APP: Comparator....
APP: Re-starting Stack....
APP: ISR_isSysCon
APP: +
APP: No event to process
APP: No event to process!
APP: vCheckStackEvent: ZPS_EVENT_NEW_POLL_COMPLETE, status = 235
APP: Going to sleep (CB)
--- vSetUpWakeUpConditions ---
APP: Woken up (CB)
APP: ISR_isSysCon
APP: +
APP: Woken up (CB)
APP: ISR_isSysCon
APP: +
APP: Woken up (CB)
APP: ISR_isSysCon
APP: +
If I want use Reedschalter or other element?
Change in vAHI_ComparatorIntEnable works identically.
vAHI_ComparatorIntEnable(E_AHI_AP_COMPARATOR_1,TRUE,TRUE);
