[email protected]
gregorirakhlin
Thanks in advance! I use USB-KW41Z to work with advertising channels BLE. Can I use this device to read information at operating frequencies after Connect_REQ.
Labels (2)
stephanie_m
Hello Gregori,
The sniffer will start to follow the connection when a Connection Request packet is received, and yes, you can use the USB-KW41Z.
For further information please check the USB-KW41Z Wireless Protocol Sniffer Quick Start Guide document located in the following path of the connectivity software.
<installation path>\MKW41Z_ConnSw_1.0.2\docs\wireless\Common
Estephania
