direct join
direct join
1,581件の閲覧回数
jokerc8
JN-UG-3113.pdf chapter6 describes the function ZPS_eAplZdoDirectJoinNetwork(), This function can be used on a Router and on the Co-ordinator to pre-determine the child nodes that will directly join it, But when I call ZPS_eAplZdoOrphanRejoinNetwork() in pre-determined child node, it seems does't work
1,570件の閲覧回数
mario_castaneda
I hope you are doing great.
What is the return value that you are getting ZPS_eAplZdoOrphanRejoinNetwork?
Could you please provide more information about your final application?
Mario
