custom wireless charging issues regarding MWPR1516 IC.
1,367 次查看
Hassan6969
I am designing a custom wireless charging receiver module for up to 15W application. I am using MWPR1516 IC for this purpose.
1: Is it compatible for 15W application?
2: Is it works with Qi protocol?
3:Do I need to program it or not ? if yes how can i do it e.g software,IDE etc.
4: I am open to other suggestions regarding ICs.
5: I need a IC having Qi capability and 15W wireless charging and do not need to program separately.
1,350 次查看
diazmarin09
I hope all is great with you. Thank you for using the NXP communities.
Please review the information below:
The WPR1516 wireless charging receiver IC family and reference designs extend NXP´s wireless charging portfolio to support up to 15W charging power.
It supports 5V/3A output following the WPC “Qi” specification.
The device does not come programed out of the box.
In this case, I do recommend to download the IAR Embedded Workbench for Arm and export the examples.
Note that the WPR1516 device supports debugging using the IAR and FreeMASTER tools.
An easier way to evaluate the device is using the RDWPR1500-LDO board. Have you considered it?
You may find further information about the programming process at the document below:
WPR1500-LDO MP Receiver Reference Design User’s Guide
The WPR1516 wireless charging receiver is a great option for your design. Unfortunately you would need to program it.
You may review the wireless power web page for further information.
I hope this information helps.
David
