bug report JN-AN-1217-zigbee30-base-device
brcueliu
operation steps:
1,flash coordinator with erase EEPROM
2.flash router with erase EEPROM
3.press SW3 on Coordinator to form a network,successful
4.Press SW2 to steering ,successful
5.press reset button on Router ,the Router join the network succefull
everything working well.but .. when do as below steps
1. flash router again with erase EEPROM .
2.Press SW2 on Coordinator to steering ,successful
3..press reset button on Router ,the Router join failed.
the Router log:
*********************************************** * ROUTER RESET * ***********************************************
APP: Entering APP_vInitResources()
APP: Entering APP_vSetUpHardware()
APP: Entering APP_vInitialise()
PDM: Capacity 41
PDM: Occupancy 22
Start Up Styae 0 On Network 0
APP: Entering BDB_vStart()
APP: BDB_EVENT_INIT_SUCCESS BDB Try Steering status 0
APP: Entering APP_vMainLoop()
APP-ZDO: Discovery Complete 00 MAC: 0000000000000000 Key: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Incoming FC: 0 Outgoing FC: 0 MAC: 0000000000000000 Key: 5a 69 67 42 65 65 41 6c 6c 69 61 6e 63 65 30 39 Incoming FC: 0 Outgoing FC: 0
APP-ZDO: Failed To Join ad Rejoin 0
APP-ZDO: Discovery Complete ea
COORDINATOR:
APP-BDB: NwkSteering Success
APP-EVT: Request Nwk Steering 00
BDB: APP_vGenCallback [0 2]
APP-EVT: Event 1, NodeState=1
BDB: APP_vGenCallback [0 9]
APP-ZDO: New Node 311d Has Joined
it's very confuse the Coordinator  said the Router had join as new node .but on the router side ,it's get join fail log.
i enable the BDB debug and  ZCL debug with CFLAGS += -DDEBUG_BDB ,CFLAGS += -DDEBUG_ZCL,and the Router ,then the Router  show the logs:
BDB: Disc on Ch 11 from 0x02108800 BDB Try Steering status 0
APP: Entering APP_vMainLoop() BDB: APP_vGenCallback [0 10]
BDB: vNsTryNwkJoin - index 0 of 1 Nwks BDB: Try To join 00158d0001011240 on Ch 11
BDB: APP_vGenCallback [0 8] FailedToJoin sNwkJoinFailedEvent.u8Status=173 !!!
the Joni Failed Event u8Status 173 is 0xAD,
ZPS_APL_APS_E_SECURITY_FAIL  0xAD
An APSDE-DATA.request requesting security has resulted in an error during the corresponding security processing.
Please review
thanks
Bruce Liu
liuxiang
Hello, I have encountered the same problem, how do you solve it?
Thank you.
liuxiang
Hello there,
I have encountered the same problem as you said the way, but when i call ZPS_vAplSecSetInitialSecurityState (ZPS_ZDO_PRECONFIGURED_LINK_KEY, sBDB.pu8DefaultTCLinkKey, 0, ZPS_APS_GLOBAL_LINK_KEY); returns an error with the error code 0XA3, why?
Thank you.
kevinsung
Hi, I think you can change SET_SERCURITY by 0x0UL before Permit join that same as my code
liuxiang
Hello there,
Thank you.
kevinsung
Router: Context Data will erase to 0x0UL after FACTORY NEW that  not pass security checking by Coordinator which changed KEY to new one.
if you want pair with KEY(0x0UL), you should change little code as below, FYR
OPEN project name: JN-AN-1216-Zigbee-3-0-IoT-ControlBridge and app_Znc_cmds.c or search string as APP_vConfigureDevice, change code to allow pair with zero key: remember change SET_TYPE to Router before JOIN active.
limcb
Hi, for this step:
usually only happens during development I think.
For your case, since the coordinator already registered the Router in Address Map, then the same router's IEEE64 address request a new join, it looks like potential MITM or some hijack.
From the JN-AN-1217, it looks like for the Router during startup, it will check for "Am I already in a network ?", If yes then I will perform a "Device Announce (secured with NWK Key)" to rejoin my last network; else I will perform "Association Request (unsecured)" to beacons.
If I am not mistaken, usually the user should perform Factory Reset operation on Router or they may just physically remove Router.
Factory Reset procedure should announce a Device Leave before factory resetting.
Coordinator will pickup Leave Indication then clear from address map.
Router will then rejoin with new address after Factory Reset.
If the Coordinator is powered down or out of range, AND the Router sends the Leave then immediately factory default, then the Coordinator will have a problem.
brcueliu
Hi Lim
i capture the packets ,the CO have send the network key to the Router ,and the logs of CO also show the Node Join successful.
if CO refuse the Router to join ,i think it would not print out the Router Join successful and assign a new Network ID and will not send the network KEY to the Router Node.
but i’ very confuse is that the CO transport the network key to Router ,but the Router still print out the Join failed logs.
i attached the Join failed and Join successful for you reference.
Thanks for your support
Bruce Liu
在 2016年12月9日,09:14,limcb <[email protected]> 写道:
NXP Community <https://community.freescale.com/resources/statics/1000/35400-NXP-Community-Email-banner-600x75.jpg>
Re: bug report JN-AN-1217-zigbee30-base-device
reply from Lim CB <https://community.nxp.com/people/limcb?et=watches.email.thread> in Wireless Connectivity - View the full discussion <https://community.nxp.com/message/858759?commentID=858759&et=watches.email.thread#comment-858759>
Hi, for this step:
For your case, since the coordinator already registered the Router in Address Map, then the same router's IEEE64 address request a new join, it looks like potential MITM.
If I am not mistaken, usually user would perform Factory Reset operation on Router or just physically remove Router.
Reply to this message by replying to this email, or go to the message on NXP Community <https://community.nxp.com/message/858759?commentID=858759&et=watches.email.thread#comment-858759>
Start a new discussion in Wireless Connectivity by email <mailto:discussions-community-wireless--connectivity@mail.freescale.jiveon.com> or at NXP Community <https://community.nxp.com/choose-container.jspa?contentType=1&containerType=14&container=11235&et=watches.email.thread>
Following Re: bug report JN-AN-1217-zigbee30-base-device <https://community.nxp.com/message/858759?commentID=858759&et=watches.email.thread#comment-858759> in these streams: Inbox
This email was sent by NXP Community because you are a registered user.
You may unsubscribe <https://community.nxp.com/unsubscribe.jspa?email=yslau%40163.com&token=942fc6d5e175c7ee0bcc1a5c15ed158b2949a1d0ae156e2505976caeba795637> instantly from NXP Community, or adjust email frequency in your email preferences <https://community.nxp.com/user-preferences!input.jspa>
limcb
Hi, it looks like the Coordinator is using the new LNK(1) key after the first successful Router join.
After you erase Router EEPROM and rejoin, the Coordinator should be using the standard 5A:69:...:30:39 HA_KEY but it looks like the Coordinator is using (1) to encrypt the Transport Key.
Factory Reset Join > Coordinator uses 5A:69:...:30:39 HA_KEY to encrypt Transport Key > Verify Key > then assign new LNK Key(2) to Router on Confirm Key.
Flash EEPROM on Router.
Join #2 > Coordinator uses (2) to encrypt Transport Key. Router unable to decrypt Transport Key because it is expecting to use HA_KEY to decrypt and Router does not know (2) from Erase EEPROM.
limcb
In addition to this, if you take a look at JN-UG-3113 ZigBee 3.0 Stack User Guide v1.2, have a look at Appendix B.2, "Clearing Stack Context Data Before a Rejoin", it seems to also describes what was happening.
liuxiang
Thank you.
