Zigbee 3.0 Stack certification
palak_patel
I have certain questions on JN5169 Zigbee 3.0 Stack Certification.
1). Is JN5179  Zigbee3.0 stack certified?
2). We are planning to use HVAC and Automobile clusters in one of our application. Are these clusters certified for JN5179?
3). If we write our own application with Zigbee 3.0 stack what else we need to do for Certification?
4). What extra certifications are required to make product certified?
Labels (3)
stephanie_m
Sorry for the inconveniences this might cause you but you will need to verify that with the person that helped you getting the information of the JN5179, it can be either your sales representative or your distributor.
Most of the wireless connectivity stacks are pre-certified and you will need to certify your application, nonetheless, as it is the JN5179 you are working with, you will need to verify if this apply as well for that stack with the person that helped you getting the part.
Sorry for the inconveniences this might cause you.
Estephania
