We have several readers that can achieve the purpose, it will depend on the tag protocol you are using the reader to use,. You can check our available readers in this page.
In this case, we do not have a ready solution as requested, there is the need for every customer to implement their application , still, you can check as well in the RFID Ecosystem for a solution provider for your needs.
Estephania
