Video- How to program the KW0x boards using IAR
5,839 次查看
CesarM
This video shows how to open an IAR-based project, where to access the board support packages for MRB-KW0x
and how to program a binary file to the boards
标签 (1)
2 回复数
5,552 次查看
afonsomenegola
Good video, I'm certainly going to use it. But first, how do I connect the MRB-K019032 board so I can program it via IAR?
Thanks!
5,552 次查看
CesarM
Hi Alfonso,
You will need an external debug/programming interface connected from your PC to the MRB-KW019032 (to header J5).
This debug interface should provide support for Cortex-M0 CPUs.
Here are some debug/programming interfaces you can use (they are provided as a reference):
- Segger JLink
https://www.segger.com/jlink-lite-cortexm.html (This is probably the most cost effective option)
https://www.segger.com/jlink_base.html
- PEMicro USB Multlink
http://www.pemicro.com/products/product_viewDetails.cfm?product_id=15320137
- IAR I-jet
https://www.iar.com/iar-embedded-workbench/add-ons-and-integrations/in-circuit-debugging-probes/
