Two FRDM-KW41Z device with same EUI
2,936件の閲覧回数
kunalkotecha1
Senior Contributor II
I have purchased 10 FRDM-KW41Z devices. I flashed an application and read a EUI from the console using "thr get eui". I found 2 devices with the same EUI. Similarly, there are 3 such pairs with the same EUI. So, I can now use only 7 devices.
Can anyone tell me what could be the reason and how to use those devices?
Kunal
ラベル(3)
タグ(3)
2,822件の閲覧回数
stephanie_m
Hello ,
Which example are you using?
Have you tried changing the default EUI in the example?
Estephania
