Thread communication between KW41Z and KW40Z
2,982件の閲覧回数
rcamilo
I was checking the new 1.0.1 version of the Thread stack with FRDM-KW41Z, FRDM-KW40Z and FRDM-KW24D nodes and I couldn't get the KW24D and KW40Z nodes to join a network created by the KW41Z node. I am using the thread_router_eligible_device example for all nodes. I programmed the FRDM-KW40Z and FRDM-KW24D devices using the source from Kinetis_Thread_1.0.1.12.exe installer, and I programmed the FRDM-KW41Z using the source from Kinetis_Thread_1.0.1_Alpha-1.exe installer. Is there anything I am missing?
ラベル(4)
3 返答(返信)
2,469件の閲覧回数
mario_castaneda
Hi Camilo,
I am assuming that you are an alpha customer.
For more information about the KW41z please contact your FAE.
Best Regards
Mario
2,469件の閲覧回数
rcamilo
Hi Michael,
Actually the FRDM-KW41Z was provided by NXP in a qualified alpha evaluation program.
2,469件の閲覧回数
michaeldalby
Hi, have you managed to purchase a FRDM-KW41Z development kit?.... I wasn't aware that they were released yet.
Cheers
Michael
