The sleep device cannot receive multicast messages
1948396491
Hello, I have a question for you.I added a sleeping device to a group.After being asked to keep the sleeping device awake, the sleeping device was controlled by group control, and no response was found from the sleeping device.But through the short address control is normal control.My problem is that the sleep device doesn't receive multicast messages whether it polls or not.
Sebastian_Del_Rio
Hi, I hope you're doing well!
Group addresses work for passing messages to multiple endpoints or nodes grouped together in a single 16-bit address. For this, a node must have a Group Address table containing information about the groups to which each endpoint in the device belongs to.
Could you please check that the Group Address table is being generated successfully? To add an endpoint to a group, the zps_eAplZdoGroupEndpointAdd function is used on the local node.
For reference, could you please take a look at the ZigBee 3.0 Stack User's Guide, here?
Please let me know if you need any more information.
Sebastian
