Security motion detector
2,062件の閲覧回数
rostislav
I am developing a PIR based motion detector using Zigbee. In a project created with BeeKit I found  API set like
* @fn zbStatus_t ZCL_IASZoneClusterServer(zbApsdeDataIndication_t *pIndication, afDeviceDef_t *pDevice)
* @brief Processes the requests received on the IAS Zone Cluster Server.
    afDeviceDef_t *pDev
I didn't find that this request handler is called anywhere in the created with BeeKit code. Do exist a document explaining usage of API like this or any example?
Thank you in advance.
1,773件の閲覧回数
rostislav
I found the answer: If application is set as IAS then created a structure afClusterDef_t const gaHaIASZoneClusterList[] that uses the API call as a method.
