SW3683 example projects: .axf file not found
3,069件の閲覧回数
Pel
Hello Team,
I'm currently trying to upload the SW3683 example codes on the PNEV7462C board with MCUXpresso.  When I tried to Debug a already built simple project (in this example blinky) the debugger can't find the .axf file:
When I checked the location file of the .axf file it is indeed missing:
Am I missing a step ? If not why the .axf file is missing ?
Thank you for your time.
3 返答(返信)
3,036件の閲覧回数
fangfang
I can't reproduce the phenomenon. Did you use the v11.4 of MCUxpresso? If not. You may use the version for your application. And you may refer to the thread for the more information. URL:https://community.nxp.com/t5/Kinetis-Microcontrollers/How-to-flash-the-MKM34Z265xxx7/td-p/1337565.
Have a nice day.
3,013件の閲覧回数
Pel
Thank you for the help. I read the thread and did some research but I couldn't find a solution to my problem. I tried to flash the chip but it require the .axf file also:
Unfortunately I still can't find the .axf file for the example project.
Regards.
3,044件の閲覧回数
Pel
Sorry I just realize that I put the screenshot of the wrong folder here is the right one:
