SPI(NOT spifi) api/driver for external serial flash memory in JN5189 sdk
1,946 次查看
jacinto1m
Is there any SPI flash memory api/driver/demo provided by the JN5189 sdk?
标签 (1)
  • JN
标记 (2)
1 回复
1,891 次查看
stephanie_m
There is no exact driver for what you are looking for , you will need to develop you own example using as a base the SPI examples .
You can try checking the K32W for the  k32w061dk6_otap_client_att_freertos Bluetooth LE example , which is located in the SDK, there are some drivers in the Framework-> Flash->External folder.That would be the closest MCU that you can use to help you in your own development.
Hope this helps.
Estephania
