SCTimer examples for QN908x
sanghamitrabhat
I am looking for information and examples for SCTimer usage on QN908x. I found this SCTimer cookbook here:
SCTImer cookbook
Is there a new version of the cookbook available, that covers QN908x? I am specifically looking at an application where an input signal is to be tracked to determine the percentage uptime (percentage of time the input signal is held high), and number of times the signal transitions. While the percentage uptime can be decoded using capture registers, what is the easiest way to configure the SCTimer, so we can get the count of the number of transitions?
Tags (3)
stephanie_m
All the documentation available of the QN9080 it's available in the QN908x  page . By any chance have you take a look at the chapter SCTimer/PWM (SCT) on the User Manual?
Estephania
