Question about connectivity of sensor with development kit
1,494 次查看
Anonymous
不适用
I would like to use the (IOTZTB-DK006 Advanced Development Kit for K32W061 and JN5189/88) with the (RD-UAMP-Sensor~microAmp Current Sensor) but I'm not sure if I could use the control bridge with it to collect data. How could I connect the two in order to collect multiple stacks of data together if I had multiple sensors through wireless means?
1,455 次查看
Ricardo_Zamora
Hope you are doing well. Yes, you could use the Control Bridge (Coordinator) to communicate with your Sensor (Router/End Device).
You can use the JN-AN-1243 Zigbee 3.0 Base Device Template.
Ricardo
