QN908x BLE HID Device Example not working
已解决
跳至解决方案
3,316 次查看
ankur_rathi
I am new to QN908x BLE development environment.
I have imported SDK Example code listed in MCUExpresso IDE.(SDK_2.x_QN908XCDK version:2.2.0)
Example code: HID Device bare metal.
I have followed the steps in readme file, but I am not able to see HID device while scanning on Mobile device.
I am able to load other example code and
Is there any document explaining how exactly this example code works or any document explaining the structure for setting up of BLE profile.
标签 (2)
1 解答
3,170 次查看
stephanie_m
No, it is not available on the web page, once you install the SDK there will be a folder with documentation:
<installation path>\SDK_2.2.0_QN908XCDK\docs\wireless\Bluetooth
When building the package in the MCUXpresso dashboard, you can also see there a link to download the documentation separated.
Estephania
在原帖中查看解决方案
4 回复数
3,170 次查看
stephanie_m
Did you check the BLE Demo Applications User's Guide?  I believe chapter 5.6 HID Device (Mouse) will be helpful.
The document is available on the SDK documentation
Estephania
3,170 次查看
ankur_rathi
Hi Estephania,
https://www.nxp.com/docs/en/application-note/FRDMKW40ZDAUG.pdf
https://www.nxp.com/docs/en/user-guide/UM10995.pdf
Are you referring to any of these one.
If not, can you please point the link where the document is.
I am not able to get it from NXP Documentation link (Documentation | NXP ).
3,171 次查看
stephanie_m
Estephania
3,170 次查看
ankur_rathi
Thanks Estephania for pointing the location for the document.
Now, I am able to get the device.
Thanks a lot.
